Resolved Display settings
Discussion in 'Windows 7' started by nuttyproffesser, 2009/12/07.
  1. 2009/12/07
    nuttyproffesser
    nuttyproffesser Inactive Thread Starter
    guys i also have a problem i have the ATI Radeon HD 3600 series i have it set to 1280x 1024 but each time i reboot or log off it goes back to 1280 x 764 how can it be configure so it doesnt change each time i have to log off or reboot....thanx in advance
  2. 2009/12/07
    Do you have a widescreen? If so, you likely have a 16:9 screen ratio, in whcih case the 4:3 ratio of 1280x1024 should not be used.
    nuttyproffesser
    no i have a samsung 17 inch LCD...this is another issue
  5. 2009/12/07
    There is no 1280 x 764 resolution.
    The closest one would be 1280 x 768. which is 5:3 aspect.
    What is your Samsung model?
  6. 2009/12/07
    nuttyproffesser
    my is the 723N series
  7. 2009/12/07
    I don't understand something here.
    Your monitor does support 1280 x 764 (5:4 ratio)resolution, which belongs to 4:3 family.
    1280 x 768 (5:3 ratio)belong to wide-screen family, so after restart, you must have some black margins at the top and at the bottom?
  8. 2009/12/08
    nuttyproffesser
    sorry i miss type it goes back to 1280x768 now is their a way to save it so it doesnt change setting each time i reboot or log off:rolleyes:
  9. 2009/12/08
    JCinvan
    JCinvan Inactive
    Most likely, if your card drivers are up to date, is that the resolution you chose isn't compatible with your monitor, have you tried 1280x960?
    Sorry I missed that.
  10. 2009/12/09
    Please enter your System Details. It helps us in answering your questions!
    1280 x 1024 is the native resolution for your 723N monitor. In your case I would double check the ATI driver & settings.
  11. 2009/12/09
    nuttyproffesser
    ATI driver setting are correct set to 1280 x1024 and the drivers are up to date...any other suggestions
  12. 2009/12/09
    No, sorry.
    We'd need more info.
    1. Did this start recently?
    2. Was it working OK before?
    3. New monitor?
    and again, enter your system details as asked for.
  13. 2009/12/09
    nuttyproffesser
    i was running win 7 x32 then upgraded to x64 becouse i play a lot of games so i wanted to run over 4gigs of ram if a wanted....and thats when this started to happend:rolleyes:
    optiplex745
    intel core 2
    FSB 1066
    ATI Radeon HD 3600
    1Terra HD
    4 GIG 5400
    LCD Samsung 723N 17inch
  14. 2009/12/09
    wildfire
    wildfire Getting Old
    nuttyproffesser, please read the above link, it will help us to answer your question.
  15. 2009/12/10
    Sounds like a driver problem to me.
  16. 2009/12/10
    JCinvan
    JCinvan Inactive
    Just got re-acquainted with an old friend: Driver Max, great app to back-up, update and restore your drivers, free!
  17. 2009/12/21
    nuttyproffesser
    never mind i just re-install the hole OS again and presto.....no problem fix....must have been corruption in the regestry and it didnt keep the save settings....hopes this helps the people having the same problem
  18. 2009/12/21
    I've marked this thread as 'Resolved', please see .....
