Windows Vista Display driver video issue
Discussion in 'Legacy Windows' started by burnsma64, 2015/03/23.
  1. 2015/04/11
    burnsma64
    burnsma64 Inactive Thread Starter
    Re my last post yesterday, I unchecked all the items you told me to. Doesn't that disable them? Or do you want them off there completely? Also I told you the 3 security programs...Avast, Windows Defender and Windows firewall. ??
  2. 2015/04/11
    You can uncheck the items which disables them but personally I would delete those items entirely from Autoruns instead of just disabling them.
    I know you told me what security programs you have installed but I need you to post the Security Check log that I asked for, thanks.
    burnsma64
    I'm sorry, but I am in the dark about what Security Check log you mean.
  5. 2015/04/11
    burnsma64
    Okay, I googled the dnld.
    Results of screen317's Security Check version 1.00
    Windows Vista Service Pack 2 x86 (UAC is disabled!)
    Internet Explorer 9
    Internet Explorer 8
    ``````````````Antivirus/Firewall Check:``````````````
    Windows Firewall Enabled!
    avast! Antivirus
    Antivirus up to date!
    `````````Anti-malware/Other Utilities Check:`````````
    Adobe Reader 10.1.6 Adobe Reader out of Date!
    ````````Process Check: objlist.exe by Laurent````````
    Windows Defender MSASCui.exe
    AVAST Software Avast AvastSvc.exe
    AVAST Software Avast AvastUI.exe
    `````````````````System Health check`````````````````
    Total Fragmentation on Drive C: 2 % Defragment your hard drive soon! (Do NOT defrag if SSD!)
    ````````````````````End of Log``````````````````````
  6. 2015/04/11
    Download and install the latest version of Adobe Reader from here, Adobe Reader 11.0.10.
    When you finish that process there is one final step that I need you to perform.
    We need to remove the tools we used to remove malware from your machine.
    Download DelFix by "Xplode " to your Desktop.
    Right Click the tool and click Run as admininistrator ( XP Users Double Click)
    Put a check mark next to the items below:
    Remove disinfection tools
    Create registry backup
    Purge System Restore
    Now click on the "Run " button.
    Allow the program to complete its work.
    All the tools we used will be removed.
    The tool will create and open a log report (DelFix.txt)
    Note: The report can be located at the following location C:\DelFix.txt
    Once that is done your computer should be all set.
  7. 2015/04/12
    burnsma64
    Okay, it is done. You have gone out of your way to help me and many thanks. Things are working okay, still have my surging problem, but I'll work on that another day. Maym
  8. 2015/04/12
    Do you have any other questions or would you consider this thread resolved?
  9. 2015/04/12
    burnsma64
    Resolved. :)
  10. 2015/04/12
    Ok, great. :)
    Since this issue is now resolved, please mark this thread as 'Resolved'.
