Resolved Display Colors Appear to be Negative
Discussion in 'Windows 10' started by virginia, 2018/07/06.
  1. 2018/07/06
    Helping a friend with Windows 10 Home, update 1803 installed. She is losing her eyesight and a relative tried to help her by making some changes to the display which resulted in pastel looking colors that appear to be in grayscale and/or inverted. The hoped for result was to provide more contrast for viewing email. Can't contact the relative to find out what was done.
    So far I have tried the following:
    Display Settings - Couldn't find anything that seemed to address the issue.
    Personalize - The only thing I found that might relate was "Colors" which asked me to pick a color background but all the options were washed out and I could see no colors.
    Ease of Access - One option is "Make the computer easier to see". I couldn't find anything there that seemed to make any difference.
    In searching the internet, one recommendation I saw was to uninstall the display adapter and then reinstall it. Since this problem was caused by a specific change to a setting or settings, I was reluctant to do the uninstall and restart.
    Any suggestions?
  2. 2018/07/06
    Hi Robert, When you were in Settings > Ease of Access > High Contrast > and switch on the High contrast radio button?
  5. 2018/07/07
    Got the color back to close to normal. Tinkered around in the Ease of Access contrast settings and that seemed to do the trick. Thanks for the suggestions.
  6. 2018/07/09
    Thanks for the update. :)
