Solved Desktop Freezes In XP
Discussion in 'Malware and Virus Removal Archive' started by snookie28, 2008/08/29.
  1. 2008/09/10
    snookie28
    snookie28 Inactive Thread Starter
    Desktop and urls in web sites freeze up
    Hello Geri, I did receive your post after I had the scan run during the night. Here are the results and I will proceed to your next step.Thank you,Snookie.
    KASPERSKY ONLINE SCANNER 7 REPORT
    Wednesday, September 10, 2008
    Operating System: Microsoft Windows XP Professional Service Pack 2 (build 2600)
    Kaspersky Online Scanner 7 version: 7.0.25.0
    Program database last update: Wednesday, September 10, 2008 03:53:17
    Records in database: 1205723
    Scan settings:
    Scan using the following database: extended
    Scan archives: yes
    Scan mail databases: yes
    Scan area - My Computer:
    A:\
    C:\
    D:\
    E:\
    Scan statistics:
    Files scanned: 92016
    Threat name: 4
    Infected objects: 5
    Suspicious objects: 0
    Duration of the scan: 05:55:20
    File name / Threat name / Threats count
    C:\_OTMoveIt\MovedFiles\09092008_235300\Documents and Settings\Bev\Application Data\Sun\Java\Deployment\cache\6.0\47\58535aaf-717c19a7 Infected: Trojan-Downloader.Java.OpenStream.ac 1
    C:\_OTMoveIt\MovedFiles\09092008_235300\Program Files\Windows Live\Messenger\msimg32.dll Infected: not-a-virus:AdTool.Win32.MyWebSearch.cv 1
    C:\_OTMoveIt\MovedFiles\09092008_235300\Program Files\Windows Live\Messenger\riched20.dll Infected: not-a-virus:AdTool.Win32.MyWebSearch.cj 1
    C:\_OTMoveIt\MovedFiles\09092008_235300\RECYCLER\NPROTECT\00000089.VIR Infected: not-a-virus:AdTool.Win32.MyWebSearch.cv 1
    C:\_OTMoveIt\MovedFiles\09092008_235300\RECYCLER\NPROTECT\00000104.VIR Infected: Trojan-Downloader.Win32.Agent.adrd 1
    The selected area was scanned.
  2. 2008/09/10
    snookie28
    Hello Geri, I started the computer in safe mode. At the command prompt I typed what you said.....when i got to the del *.* it asked me if i was sure to delete so I said Y. Then I typed in cd ..and it said system could not find the file specified and when I typed In rd nprotect It said directory Is not empty. I was not sure what to type In for each of the other drives.....so I exited...:rolleyes::confused:sorry I didn't understand what to put In for the other drives. Thanks,Snookie
    Geri Lifetime Subscription
    Geri Inactive Alumni
    Hi
    That is OK
    Your Kaspersky scan came back just as we wanted it. The nprotect was gone.
    Now one more thing to clean up and you should be good to go.
    • Please double-click OTMoveIt2.exe to run it.
    • Click on the CleanUp! button. When you do this a text file named cleanup.txt will be downloaded from the internet. If you get a warning from your firewall or other security programs regarding OTMoveIt attempting to contact the internet you should allow it to do so. After the list has been download you'll be asked if you want to Begin cleanup process? Select Yes.
    • This step removes the files, folders, and shortcuts created by the tools I had you download and run.
    Empty your recycle bin
    Let me know how things are running.
    Geri
  5. 2008/09/11
    snookie28
    Hello Geri, So far all is good. Thank you so much for your help. I signed up for 1 year for everyones help whenever I need It.Thanks again,Snookie28
  6. 2008/09/11
    You're welcome. :)
    Please look at this link for some preventive recommendations, It could keep you from ending up back here to the Malware and Virus Removal Forums.
    http://www.windowsbbs.com/showthread.php?t=67958
    I'll mark this one resolved.
    Surf Safely.
    Geri
