Solved Data Execution Prevention is crashing IE (referred by Wildfire)
Discussion in 'Malware and Virus Removal Archive' started by CUISTech, 2010/03/11.
  1. 2010/04/22
    I was due today, but they didn't want me :)
    1. Download Temp File Cleaner (TFC)
    2. Go to Kaspersky website and perform an online antivirus scan.
    1. Disable your active antivirus program.
    2. Read through the requirements and privacy statement and click on Accept button.
    3. It will start downloading and installing the scanner and virus definitions. You will be prompted to install an application from Kaspersky. Click Run.
    4. When the downloads have finished, click on Settings.
    5. Make sure these boxes are checked (ticked). If they are not, please tick them and click on the Save button:
      [*] Archives
      [*] Mail databases
    6. Click on My Computer under Scan.
    7. Once the scan is complete, it will display the results. Click on View Scan Report.
    8. You will see a list of infected items there. Click on Save Report As....
    9. Save this report to a convenient place. Change the Files of type to Text file (.txt) before clicking on the Save button. Then post it here.
    Post fresh HijackThis log as well.
  2. 2010/04/23
    CUISTech
    CUISTech Inactive Thread Starter
    KASPERSKY ONLINE SCANNER 7.0: scan report
    Friday, April 23, 2010
    Operating system: Microsoft Windows XP Professional Service Pack 3 (build 2600)
    Kaspersky Online Scanner version: 7.0.26.13
    Last database update: Thursday, April 22, 2010 19:58:30
    Records in database: 3968270
    Scan settings:
    scan using the following database: extended
    Scan archives: yes
    Scan e-mail databases: yes
    Scan area - Folder:
    C:\
    Scan statistics:
    Objects scanned: 49695
    Threats found: 1
    Infected objects found: 3
    Suspicious objects found: 0
    Scan duration: 00:53:50
    File name / Threat / Threats count
    C:\Program Files\RealVNC\VNC4\vncconfig.exe Infected: not-a-virus:RemoteAdmin.Win32.WinVNC.4 1
    C:\Program Files\RealVNC\VNC4\winvnc4.exe Infected: not-a-virus:RemoteAdmin.Win32.WinVNC.4 1
    C:\Program Files\RealVNC\VNC4\wm_hooks.dll Infected: not-a-virus:RemoteAdmin.Win32.WinVNC.4 1
    Selected area has been scanned.
    Scan saved at 10:09:54 AM, on 4/23/2010
    MSIE: Internet Explorer v8.00 (8.00.6001.18702)
    C:\Program Files\Symantec\Symantec Endpoint Protection\Smc.exe
    C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
    C:\Program Files\Common Files\LogiShrd\LVMVFM\LVPrcSrv.exe
    C:\Program Files\Common Files\InterVideo\RegMgr\iviRegMgr.exe
    C:\Program Files\Intel\AMT\LMS.exe
    C:\Program Files\Common Files\LogiShrd\LVCOMSER\LVComSer.exe
    C:\Program Files\PDF Complete\pdfsvc.exe
    C:\Program Files\Common Files\Protexis\License Service\PsiService_2.exe
    C:\Program Files\Symantec\Symantec Endpoint Protection\Rtvscan.exe
    C:\Program Files\Common Files\Intel\Privacy Icon\UNS\UNS.exe
    C:\Program Files\RealVNC\VNC4\WinVNC4.exe
    C:\Program Files\Symantec\Symantec Endpoint Protection\SmcGui.exe
    C:\WINDOWS\system32\igfxtray.exe
    C:\WINDOWS\system32\hkcmd.exe
    C:\WINDOWS\system32\igfxpers.exe
    C:\Program Files\Common Files\Intel\Privacy Icon\PrivacyIconClient.exe
    C:\WINDOWS\system32\igfxsrvc.exe
    C:\WINDOWS\RTHDCPL.EXE
    C:\Program Files\Common Files\Java\Java Update\jusched.exe
    C:\Program Files\Common Files\LogiShrd\LComMgr\Communications_Helper.exe
    C:\Program Files\Logitech\QuickCam\Quickcam.exe
    C:\Program Files\Symitar\SFW\RemoteAdminServer.exe
    C:\Program Files\Common Files\Logishrd\LQCVFX\COCIManager.exe
    C:\Program Files\Java\jre6\bin\java.exe
    C:\Program Files\Common Files\Java\Java Update\jucheck.exe
    C:\Documents and Settings\etaylor\Desktop\HijackThis.exe
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.hp.com
    R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyServer = 10.1.3.50:3128
    O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
    O2 - BHO: Spybot-S&D IE Protection - {53707962-6F74-2D53-2644-206D7942484F} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
    O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
    O3 - Toolbar: (no name) - {0BF43445-2F28-4351-9252-17FE6E806AA0} - (no file)
    O4 - HKLM\..\Run: [IgfxTray] C:\WINDOWS\system32\igfxtray.exe
    O4 - HKLM\..\Run: [HotKeysCmds] C:\WINDOWS\system32\hkcmd.exe
    O4 - HKLM\..\Run: [Persistence] C:\WINDOWS\system32\igfxpers.exe
    O4 - HKLM\..\Run: [picon] "C:\Program Files\Common Files\Intel\Privacy Icon\PrivacyIconClient.exe" -startup
    O4 - HKLM\..\Run: [RTHDCPL] RTHDCPL.EXE
    O4 - HKLM\..\Run: [PDF Complete] C:\Program Files\PDF Complete\pdfsty.exe
    O4 - HKLM\..\Run: [SetRefresh] C:\Program Files\Compaq\SetRefresh\SetRefresh.exe
    O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Common Files\Java\Java Update\jusched.exe "
    O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 9.0\Reader\Reader_sl.exe "
    O4 - HKLM\..\Run: [Adobe ARM] "C:\Program Files\Common Files\Adobe\ARM\1.0\AdobeARM.exe "
    O4 - HKLM\..\Run: [LogitechCommunicationsManager] "C:\Program Files\Common Files\LogiShrd\LComMgr\Communications_Helper.exe "
    O4 - HKLM\..\Run: [LogitechQuickCamRibbon] "C:\Program Files\Logitech\QuickCam\Quickcam.exe" /hide
    O4 - HKCU\..\Run: [SpybotSD TeaTimer] C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
    O4 - Global Startup: Remote Admin Server.lnk = C:\Program Files\Symitar\SFW\RemoteAdminServer.exe
    O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
    O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL
    O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
    O9 - Extra 'Tools' menuitem: Spybot - Search & Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
    O15 - ESC Trusted Zone: http://*.mcafee.com (HKLM)
    O15 - ESC Trusted Zone: http://betavscan.mcafeeasap.com (HKLM)
    O15 - ESC Trusted Zone: http://vs.mcafeeasap.com (HKLM)
    O15 - ESC Trusted Zone: http://www.mcafeeasap.com (HKLM)
    O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://update.microsoft.com/windowsupdate/v6/V5Controls/en/x86/client/wuweb_site.cab?1264545951608
    O16 - DPF: {E06E2E99-0AA1-11D4-ABA6-0060082AA75C} (GpcContainer Class) - https://jha.webex.com/client/T26L10NSP49EP32/webex/ieatgpc.cab
    O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} - http://platformdl.adobe.com/NOS/getPlusPlus/1.6/gp.cab
    O17 - HKLM\System\CCS\Services\Tcpip\Parameters: Domain = ncu.local
    O17 - HKLM\Software\..\Telephony: DomainName = ncu.local
    O17 - HKLM\System\CCS\Services\Tcpip\..\{602452C9-46DA-4D25-B056-7D265AB7CF3E}: NameServer = 10.1.3.6,10.1.3.2
    O17 - HKLM\System\CS1\Services\Tcpip\Parameters: Domain = ncu.local
    O17 - HKLM\System\CS3\Services\Tcpip\Parameters: Domain = ncu.local
    O23 - Service: Symantec Event Manager (ccEvtMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
    O23 - Service: Symantec Settings Manager (ccSetMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
    O23 - Service: IviRegMgr - InterVideo - C:\Program Files\Common Files\InterVideo\RegMgr\iviRegMgr.exe
    O23 - Service: Java Quick Starter (JavaQuickStarterService) - Sun Microsystems, Inc. - C:\Program Files\Java\jre6\bin\jqs.exe
    O23 - Service: Lavasoft Ad-Aware Service - Lavasoft - C:\Program Files\Lavasoft\Ad-Aware\AAWService.exe
    O23 - Service: LiveUpdate - Symantec Corporation - C:\PROGRA~1\Symantec\LIVEUP~1\LUCOMS~1.EXE
    O23 - Service: Intel(R) Management and Security Application Local Management Service (LMS) - Intel Corporation - C:\Program Files\Intel\AMT\LMS.exe
    O23 - Service: LVCOMSer - Logitech Inc. - C:\Program Files\Common Files\LogiShrd\LVCOMSER\LVComSer.exe
    O23 - Service: Process Monitor (LVPrcSrv) - Logitech Inc. - C:\Program Files\Common Files\LogiShrd\LVMVFM\LVPrcSrv.exe
    O23 - Service: LVSrvLauncher - Logitech Inc. - C:\Program Files\Common Files\LogiShrd\SrvLnch\SrvLnch.exe
    O23 - Service: PDF Document Manager (pdfcDispatcher) - PDF Complete Inc - C:\Program Files\PDF Complete\pdfsvc.exe
    O23 - Service: Protexis Licensing V2 (PSI_SVC_2) - Protexis Inc. - C:\Program Files\Common Files\Protexis\License Service\PsiService_2.exe
    O23 - Service: Symantec Management Client (SmcService) - Symantec Corporation - C:\Program Files\Symantec\Symantec Endpoint Protection\Smc.exe
    O23 - Service: Symantec Endpoint Protection (Symantec AntiVirus) - Symantec Corporation - C:\Program Files\Symantec\Symantec Endpoint Protection\Rtvscan.exe
    O23 - Service: Intel(R) Management and Security Application User Notification Service (UNS) - Intel Corporation - C:\Program Files\Common Files\Intel\Privacy Icon\UNS\UNS.exe
    O23 - Service: VNC Server Version 4 (WinVNC4) - RealVNC Ltd. - C:\Program Files\RealVNC\VNC4\WinVNC4.exe
    End of file - 8952 bytes
    Your computer is clean :)
    1. Turn off System Restore:
    - Windows XP:
    1. Click Start.
    5. Click Apply.
    7. Click OK.
    - Windows Vista and 7:
    1. Click Start.
    8. Click OK
    2. Restart computer.
    3. Turn System Restore on.
  5. 2010/04/26
    CUISTech
    Quick quiz, since I can't read the logs as well as you can... Was there an actual trojan among the reports I've published for you? And were you able to identify the origin?
    (Just so I can go speak to the people who use this computer about what happened and where.)
    Other than that, thanks so much for your time and patience.
  6. 2010/04/26
    You're very welcome :)
    Yes, trojans were present. As for their origins, it's simply impossible to say. There are many ways, your computer can get infected. If you read #8 from my previous post, you have some ideas.
