[CPU at 100%, lockups and very slow response]
Discussion in 'Windows XP' started by 401402, 2011/07/24.
  1. 2011/07/24
    401402
    401402 Inactive Thread Starter
    when i run you tube,or open any video...or run AVIRA ANTI CPU runs about 100% and locks up for a bit.
    i play Mafia wars and it takes about 40 sec for things to run after i click on an item to respond.
    i look at the task manager and the bottem item
    system idle process cpu stays steady at
    about 90 mem usage at 28k
    iexplore.exe user-runs cpu about 5-405.648K mem usage
  2. 2011/07/24
    Hi 401402, I would suspect Malware/Virus is your problem. Have a look at the Malware Section and look at the Procedure to Start your Post there. Neil.
    401402
    have done malware check /avira checks and ccleaner
  5. 2011/07/24
    I've just been looking at Specs and Reviews and wonder whether you have a large enough CPU for the use or whether you need to see whats running in the background.
    CPU's in Dell builds seem to vary between 1.4 to 2.2ghz.
    It would probably help others with experience on this Model if you filled in your System Details fully. Cheers Neil.
  6. 2011/07/24
    How ?
    Some nasties are very difficult to detect & even more difficult to get rid of. Rootkit infections are a very good example.
    You should read this & post in Malware and Virus Removal section.
    401402 likes this.
  7. 2011/07/26
    Your CPU might stay at 100% for a long time, but another reason could be that you have "run out" of memory.
    The basic memory is RAM. You could need more RAM to run your programs, for both the programs that you run yourself and the programs that are running in the background (startup programs).
  8. 2011/07/26
    Standard Vostro 1700 came with 2 Gb RAM - probably the sweet point for XP.
    Suspect the cause lies elsewhere - no harm in checking it out in the Malware & Virus Removal forum.
  9. 2011/07/26
    401402
    thanks all for your input when i have time to re read malware section...ive used cc leaner-anti malware all look good no infection and ccleaner was ok
  10. 2011/07/26
    CCleaner is NOT anti malware. Its a cleaning utility.
  11. 2011/07/26
    401402
    i know, i ran it as part of the cleaning process they were talking about
  12. 2011/07/27
    they ? :confused:
  13. 2011/08/04
    zz1958
    zz1958 Inactive
    401402, While I am no expert, you may try and clear your browsers cache, Mafia wars and U-tube are flash based and over time can gunk up the cache. I do not use IE so I may be wrong...just my experience from playing MW.
  14. 2011/08/04
    401402
    ok done that still nadda? oh well thanks all for your answers in trying to help me
    i'll put this to bed- its summer and i dont use computer that much
  15. 2011/08/04
    When you don't follow & don't respond, there is nothing much we can do to help.
    Admin. likes this.
