Cookies, History and TIFs moved ......
Discussion in 'Internet Explorer & Microsoft Edge' started by Christer, 2003/09/24.
  1. 2003/09/26
    Christer -thanks for the info re. Ghost - that's a couple of megs or so 'saved'.
  2. 2003/09/26
    Christer
    You´re welcome ...... :) ...... !
    charlesvar
    charlesvar Inactive Alumni
    Lonny, is this me you're referring to?
    "Charles di you originaly have win me ,, and upgrade to XP or is this another PC (i forget "
    if it is, this must be telepathy :)
    I dual boot, still running ME.
    Use both RegProt and ScirptSentry on the ME. As Brett indicated, works fine.
    On XP, use SSM - System Safety Monitor which does both jobs of the above as well as monitor all executes on the system.
    Warning: Does go thru a phase such as a newly installed Firewall does with outbound program permissions. SSM asks permission to allow every execute the system does including MS's with varying responses possible, ie, once, always - never - block once and some more variations that I can't think of at the moment.
    http://maxcomputing.narod.ru/ssme.html?lang Download
    http://www.mickeytheman.com/forums/index.php?showtopic=11 Some explanations.
    Regards - Charles
    EDIT: When I mentioned MS's executes, I'm refering to things like updates - MS update - or Media Player. NOT the OS itself.
  5. 2003/09/27
    Christer
    Lonny,
    thanks for the link to Security Suite!
    I´ll check it out later.
    Christer
