Connect HD from PC to laptop
Discussion in 'Mobile Devices' started by rgaleh, 2014/10/07.
  1. 2014/10/07
    rgaleh
    rgaleh Inactive Thread Starter
    my PC bit the dust. Is there any way I can take the Hard Drive from my PC and some how connect it to my laptop as a external drive? I would have to some how convert it to a USB invironment. I have some files on the Hard Drive I would like to recover.
    R. Gale Harter
  2. 2014/10/07
    Russ
    Russ Well-Known Member
    Russ,
    Hi rgaleh, I would add that you would need to establish whether your "PC" that "bit the dust" has SATA or PATA (IDEE) connection as you could end up with a problem :eek: trying to use the adapter suggested by Russ.
    Unless the adapter has the ability to connect both types of connectors, check it out first. ;) Neil.
  5. 2014/10/08
    lj50 Lifetime Subscription
    rgleh: What do you mean by bit the dust? Did the power supply, motherboard, or hard drive fail. Is it a desktop pc, or a laptop pc?
    lj50,
    rgaleh
    Thanks for the input. My 6year old desktop computers mother board sizzled and I didn't think it was worth fixing if there was a way to connect my sata drive to my laptop. I will do some more checking to make sure everything is compatible with windows 8. Thanks again for the input.
  7. 2014/10/09
    SpywareDr
  8. 2014/10/09
    Great piece of equipment Doc. Thanks.
    lj50,
    #7
  9. 2014/10/09
    SpywareDr
  10. 2014/10/09
    My desktop is from 2000 I figure how much longer can it last. I might purchase and try this out. Thanks again Doc.
    lj50,
    #9
  11. 2014/10/09
    rgaleh
    Connect hd from pc to lap top
    Doc I have ordered the adapter you suggested and will get back to you as to how it worked some time next month.. Seems to me to be pretty straight forward. I shall see. Thanks for your suggestion.
  12. 2014/10/09
    SpywareDr
