Computer will not stay on
Discussion in 'Windows XP' started by mojo13, 2005/04/19.
  1. 2005/04/20
    BillyBob Inactive
    I don't know if formatting and reinstalling windows would fix this problem.
    Maybe. But I do no think it is the OS itself.
    Like I said, everything works fine if I boot up with the cable unplugged.
    It seems everything else has been tried so I now have a Question.
    Is there anything hooked to the other end of the cable ? If there is then the problem may be on the end that we are not looking at.
    I ask because I see no reason for a problem with just the cable alone UNLESS IT IS BAD !!. . Because I do not believe there should be any real connections until something is plugged in at both ends. Or somewhere it the middle. ( jammed/shorted cable )
    Have you tried a different cable ?
    BillyBob
  2. 2005/04/20
    mojo13 Lifetime Subscription
    mojo13 Well-Known Member Thread Starter
    software or hardware???
    I have tried other cables. The cable goes to my wireless router which in turn is connected to the cable modem. This particular pc is hardwired (cat 5 cable)to a switch on the router. I'm typing this from the computer in question. As long as I connect the cable after I boot up, everything is fine. :cool:
    Another thing of interest: At one point I was going to reinstall windows. I booted up from the CD and it loaded the set-up files. When it finished that I got a screen saying the compurer does not have a hard drive and set-up cannot continue. I think I have a definate motherboard problem.
    surferdude2
    surferdude2 Inactive
    I don't think your MOBO is bad. Aborting an OS install can cause some very strange problems. If it were me, I would do a backup image and run a clean install from the CD. Have it format the existing partition when the offer is made.
    That's not to say a Repair Install won't work so I might even try that first just in case. It would obviously save lots of time. I have some doubts about the success though.
  5. 2005/04/20
    purplemtn
    purplemtn Inactive
    Mr
    It maybe a motherboard problem , but I have my doubts as it work after you plug in the cable and the MB works in safe mode.. has to be some that is conflicting at startup/setup .. Have you tried , by pressing F8 at startup , a step by step startup ?
    Have you rebuilt all your Network conection ?
    What does your BIOS say about you hard drine ?
  6. 2005/04/20
    Have you tried , by pressing F8 at startup , a step by step startup ? No
    Have you rebuilt all your Network conection ? No
    What does your BIOS say about you hard drine ? I'll check
    Could it be that my wireless router has gone bad? I will check it straight from the modem.
  7. 2005/04/20
    BillyBob Inactive
    I may be 100% it the wrong here put I think a system restore from a point previous to the attempt at what the original post says would have been of great help.
    If you boot without the cable, the reg is just saying " OH well such and such is not here so we ignore it. "
    When you plug the cable in AFTER booting the reg is STILL ignoring it.
    BillyBob
    PS
    Take a look at my new post in Hardware ( Bad Fan ?? ) and see what SR ( HOPEFULLY ) bailed my sorry butt out of this AM.
    BB
  8. 2005/04/20
    I took the router out of the picture and all went well. It booted up fine and stayed on... :rolleyes:
  9. 2005/04/20
    Went to the Linksys website, ran their Netset Assistance tool and all is resolved. Boots up normal now. Thanks for everyones help. :D
    Billy Bob, it was your comment about looking at the other end of the cable that set me straight! :D
  10. 2005/04/20
    BillyBob Inactive
    YES !!!! WAY TO GO
    Thanks for the report and we are very glad to read the good news.
    The idea about the other end just happened to POP UP out of the blue. Glad it worked.
    Lets hope it all stays well now.
    Also I seem ( hopefully ) to have my problem solved.
    Have a GREAT Day and enjoy.
    BillyBob
  11. 2005/04/20
    BillyBob Inactive
    As it turns out in this case maybe not.
    BillyBob
  12. 2005/04/20
    A new twist to the story
    Here is what happened, there seems to be a conflict with the phone modem. Earlier I disabled the onboard nic card and installed another one. That did not help so I removed it and went back to the original configuration because I got the router to work correctly. When putting things back together I took the phone modem out instead of the other nic card. My phones quit working so I discovered I had removed the wrong card. I reinstalled the modem card and the shut downs started all over again until I removed the modem card again. Now that it is removed everything is working correctly. :confused:
  13. 2005/04/20
    BillyBob Inactive
    If I understand correctly. Everything is OK as long as you leave the Modem card out ?
    If so. That reads like a POSSIBLE PORT conflict.
    BillyBob
  14. 2005/04/20
    That is correct. Dell says they will replace the MB
    My question is why would a port conflict shut a computer down? It won't stay on long enough to see the conflict and it doesn't show up in safe mode...
  15. 2005/04/20
    BillyBob Inactive
    It is going to take someone a LOT more knowledgeable than me to answer that.
    BillyBob
  16. 2005/04/20
    surferdude2
    Did you disable Automatic Restart on System Failure? That may allow you to view an error screen to get further corrective information.
  17. 2005/04/20
    Yes, I disabled it but it really wasn't doing that in the first place. It would automatically shut down after boot up.
    Would the Event Viewer have any clues?
  18. 2005/04/20
    surferdude2
    OK, now I see. I was hung on the restart and it was shutting down.
    I would hope the event viewer would chronicle any event that traumatic but you'll just have to look and hope.
    Run eventvwr.msc and check all three categories.
    As a very last resort, I'd still try a repair install and a clean install if that failed before I'd go to the MOBO swap trouble.
    Good luck.
  19. 2005/04/20
    Event Viewer
    Main things I found in Event Viewer.
    Application
    Details
    Product: Windows Operating System
    Source: PerfNet
    Version: 5.2
    Symbolic Name: PERFNET_UNABLE_OPEN_SERVER
    Message: Unable to open the Server service. Server performance data will not be returned. The error code returned is in the first DWORD in the Data section.
    Explanation
    A performance monitoring program tried to open the performance counters for the Server service. The Server service could not respond to the request. The Server service is not running or is transitioning between starting and stopping or vice versa.
    User Action
    To determine whether the Server service is running, at the command prompt, type Net Statistics
    A list of running services is displayed. If the Server service is not listed, at the command prompt, type Net Start Server
    Version: 5.0
    Explanation
    User Action
    Currently there are no Microsoft Knowledge Base articles available for this specific error or event message. For information about other support options you can use to find answers online, see http://support.microsoft.com/default.aspx.
    System
    Details
    Source: Service Control Manager
    Version: 5.0
    Symbolic Name: EVENT_SERVICE_START_FAILED
    Message: The %1 service failed to start due to the following error:
    %2.
    Explanation
    Service Control Manager (SCM) could not start the specified service, probably because the service is not configured correctly.
    User Action
    Do one or all of the following:
    Review the error information displayed in the message.
    Verify that the service password has not expired.
    Verify that the service is in the correct location.
    Verify that the service is not infected with a virus.
    To display the WIN32_EXIT_CODE error that SCM encountered when trying to start the program, at the command prompt, type
    sc query service name
    The information displayed can help you troubleshoot possible causes for the error.
    If the WIN32_EXIT_CODE is zero, then SCM did not attempt to start the service because the error was detected first.
    Version: 5.2
    %2
    Explanation
    User Action
    Related Knowledge Base articles
    You can find additional information on this topic in the following Microsoft Knowledge Base articles:
    "¢ Availability and description of the Port Reporter tool
    Describes the Port Reporter tool that you can use to log TCP and UDP port activity on computers that are running Windows Server 2003, Windows XP, and Windows 2000. Contains information about how to obtain, install, and configure the tool.
    "¢ "Event ID: 7000" or "Event ID: 7013" Error Message When You Attempt to Start a Service
    Describes a problem with logon failures when you try to start a service. Provides several resolutions.
    "¢ You cannot log on or you experience a long delay on a domain controller or on a member computer that is running Windows 2000, Windows XP, or Windows Server 2003
    Describes a problem that may occur if one or more services that run in the Lsass.exe process or in the Services.exe process are no longer configured to run as shared service processes. Lists the symptoms of this problem.
    "¢ Your Windows XP computer stops responding after you log on
    Provides a resolution for an issue that occurs when you log on to a computer that is running Windows XP, an "Applying local settings" message appears, and the computer stops responding.
    "¢ "CD Recording Software Will Cause Windows to Become Unstable" error message when you start Windows XP
    Explains why you may receive a "CD Recording software will cause Windows to become unstable" error message when you start Windows XP. The article contains a workaround.
    "¢ "Event ID: 7000" Error Message When ASCTRM Service Does Not Start
    On a computer that is running Windows NT 4.0, Windows 2000, or Windows XP, when you install or remove RealNetworks RealPlayer 8, or when you install or remove a program that installs RealPlayer 8 (for example, Netscape Navigator), the following...
  20. 2005/04/23
    modem card
    I installed the phone modem in a different PCI slot and reinstalled the drivers. Everything seems to be working correctly. Must have a bad PCI slot. :eek:
  21. 2005/04/26
    Dell came out and put a new MB in in less that 15 minutes. ;)
    I spent about a week troubleshooting it :eek:
