Resolved Computer is making a loud beep sound during startup
Discussion in 'Windows 7' started by desmog21, 2015/07/19.
  1. 2015/07/23
    Well if you formatted the partition then reboot the computer and see if it boots into Windows normally. If it boots normally then post a fresh screenshot of the Disk Management window in your next reply.
  2. 2015/07/27
    desmog21
    desmog21 Inactive Thread Starter
    I did format and installed new os..
    here is the link of the disk management =>http://imgur.com/a/KdFOh
    Also when i powered it will bring a list of windows to boot into..
    Remove the D partition in Disk Management, then run the bcdedit /set {bootmgr} displaybootmenu no command from Command Prompt again and reboot the computer. Windows should now boot without the boot selection menu and hopefully the beep sound won't be present this time.
  5. 2015/07/27
    desmog21
    So are you recommending that i should have just one partition?
  6. 2015/07/27
    desmog21
    Hello Evan!
    I did format and deleted the D partition and allocated the volume to C. also i run the bcdedit /set {bootmgr} displaybootmenu no command
    but the display option is still showing..link =>http://imgur.com/a/nOHIp
  7. 2015/07/27
    desmog21
    The boot manager has disappeared but when i booted my pc only to see a screen promt to choose from several different options
    here is the list of options that are presented during the boot up process.
    Windows 7 Vista/Server (Pointer)
    Windows 7 Vista/Server (debug-default mode)
    Windows 7 Vista/Server (debug-legacy mode)
    Windows 7 Vista/Server (no slic-pointer)
    Windows 7 Vista/Server (no-slic)
    Windows NT /2000/XP
    Loader Help
    Use the up down keys to highlight an entry.Press enter or 'b' to boot...Press 'c' for a command line.
  8. 2015/07/27
    That partition layout is how Windows should be set up so your partition layout in Disk Management looks fine now.
    Since you only have windows 7 installed you shouldn't be seeing any other menus to load other operating systems.
    Can you post a screenshot of the entire window showing the boot options? Thanks.
  9. 2015/07/28
    desmog21
    Thanks for replying..
    When my computer is booted only screen promt will popup to choose from several different options above..
    Here is the screen shot of the list =>http://imgur.com/viZzeez
  10. 2015/07/29
  11. 2015/07/29
    desmog21
    I did followed those steps but i couldn't arrived at somewhere because i have only one operating system installed not 2
    have a look at this pic =>http://imgur.com/O8eSb2t
  12. 2015/07/29
    Did you make sure to perform a clean install of Windows 7 and remove all of the current partitions during the installation of Windows 7?
    This menu that you are seeing could have been placed there by Acer since it could be a feature of your model of laptop. Have you gone into your laptops BIOS and looked for any settings regarding a Windows boot menu?
  13. 2015/08/07
    desmog21
    Everything is OK now..
    I installed windows 10
  14. 2015/08/07
    Ok fair enough. Would you consider this thread resolved?
  15. 2015/08/07
    desmog21
    Yes boss
  16. 2015/08/07
    desmog21
    Thanks for your help I really appreciate
  17. 2015/08/07
    lj50 Lifetime Subscription
    To mark this thread as resolved click on Thread Tools scroll down to and click on the last item on the list.
