Inactive Computer freezes after removing spyware
Discussion in 'Malware and Virus Removal Archive' started by juddson, 2010/10/06.
  1. 2010/10/11
    Any reason why your AVG is listed as outdated?
    We have to remember to install SP2, when Eset comes out clean.
    Update Adobe Reader
    You can download it from http://www.adobe.com/products/acrobat/readstep2.html
    After installing the latest Adobe Reader, uninstall all previous versions.
    Note. If you already have Adobe Photoshop® Album Starter Edition installed or do not wish to have it installed UNcheck the box which says Also Download Adobe Photoshop® Album Starter Edition.
    Alternatively, you can uninstall Adobe Reader (33.5 MB), download and install Foxit PDF Reader(3.5MB) from HERE.
    It's a much smaller file to download and uses a lot less resources than Adobe Reader.
    Note: When installing FoxitReader, make sure to UN-check any pre-checked toolbar, or other garbage.
    On this page:
    make sure, you have both boxes UN-checked AND (important!) click on Decline button
  2. 2010/10/11
    juddson
    juddson Inactive Thread Starter
    AVG wont update and has a yellow ! over the symbol. When opened a few things say VDB check failed. When I click fix it or update it says failed and asks to reboot the computer but that doesnt help anything. Also I have 4 windows updates that all say failed everytime I try to download and install them. Thanks so much for all the help :)
    juddson
    Eset also just gave me an error while updating unexpected error 2002 it says
    Nevermind that error I ran it again it worked the second time
  5. 2010/10/11
    juddson
    the scan found 6 things
    C:\ProgramData\Spybot - Search & Destroy\Recovery\FraudXPInternetSecurity.zip Win32/Bagle.gen.zip worm
    C:\ProgramData\Spybot - Search & Destroy\Recovery\WinFraudLoadedt.zip Win32/Bagle.gen.zip worm
    C:\ProgramData\Spybot - Search & Destroy\Recovery\WinFraudLoadedt1.zip Win32/Bagle.gen.zip worm
    C:\Users\All Users\Spybot - Search & Destroy\Recovery\FraudXPInternetSecurity.zip Win32/Bagle.gen.zip worm
    C:\Users\All Users\Spybot - Search & Destroy\Recovery\WinFraudLoadedt.zip Win32/Bagle.gen.zip worm
    C:\Users\All Users\Spybot - Search & Destroy\Recovery\WinFraudLoadedt1.zip Win32/Bagle.gen.zip worm
  7. 2010/10/12
    juddson
    Everytime I try to install SP2 I get an error and it wont install and in my update list Microsoft.Net Framework 3.5 SP1 will not install either
  8. 2010/10/12
    I didn't say to install anything yet.
    What happened with your AV program?
    Did you switch to Avast, or Avira?
    Does it update?
    Run OTL
      :OTL
      :Services
      :Reg
      :Files
      :Commands
      [purity]
      [emptytemp]
      [emptyflash]
      [Reboot]
    Your computer is clean :)
    1. We need to reset system restore to prevent your computer from being accidentally reinfected by using some old restore point(s). We'll create fresh, clean restore point, using following OTL script:
    Run OTL
    • Under the Custom Scans/Fixes box at the bottom, paste in the following:
    :OTL
    :Commands
    [purity]
    [emptytemp]
    [EMPTYFLASH]
    [CLEARALLRESTOREPOINTS]
    [Reboot]
    • Post resulting log.
    2. Now, we'll remove all tools, we used during our cleaning process
    Clean up with OTL:
    • Double-click OTL.exe to start the program.
    • Close all other programs apart from OTL as this step will require a reboot
    • On the OTL main screen, press the CLEANUP button
    • Say Yes to the prompt and then allow the program to reboot your computer.
    3. Make sure, Windows Updates are current (now, attempt to install SP2)
    4. If any Trojan was listed among your infection(s), make sure, you change all of your on-line important passwords (bank account(s), secured web sites, etc.) immediately!
    7. Run Temporary File Cleaner (TFC) weekly.
    10. Run defrag at your convenience.
    11. Read How did I get infected?, With steps so it does not happen again!: http://www.bleepingcomputer.com/forums/topic2520.html
    12. Please, let me know, how is your computer doing.
  9. 2010/10/12
    juddson
    Ok sorry I must have jumped the gun there. Yes i removed AVG and installed Avira and it updates fine
  10. 2010/10/12
    juddson
    All processes killed
    ========== OTL ==========
    ========== FILES ==========
    C:\ProgramData\Spybot - Search & Destroy\Recovery\FraudXPInternetSecurity.zip moved successfully.
    C:\ProgramData\Spybot - Search & Destroy\Recovery\WinFraudLoadedt.zip moved successfully.
    C:\ProgramData\Spybot - Search & Destroy\Recovery\WinFraudLoadedt1.zip moved successfully.
    File\Folder C:\Users\All Users\Spybot - Search & Destroy\Recovery\FraudXPInternetSecurity.zip not found.
    File\Folder C:\Users\All Users\Spybot - Search & Destroy\Recovery\WinFraudLoadedt.zip not found.
    File\Folder C:\Users\All Users\Spybot - Search & Destroy\Recovery\WinFraudLoadedt1.zip not found.
    [EMPTYTEMP]
    User: All Users
    User: Cat
    ->Temp folder emptied: 6780482 bytes
    ->Temporary Internet Files folder emptied: 55766402 bytes
    ->Java cache emptied: 0 bytes
    ->Google Chrome cache emptied: 20449072 bytes
    ->Apple Safari cache emptied: 0 bytes
    ->Flash cache emptied: 44580 bytes
    User: Default
    ->Flash cache emptied: 56504 bytes
    User: Default User
    User: Public
    %systemroot%\System32 (64bit) .tmp files removed: 726528 bytes
    Windows Temp folder emptied: 7632666 bytes
    %systemroot%\sysnative\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files folder emptied: 33170 bytes
    RecycleBin emptied: 53382 bytes
    Total Files Cleaned = 87.00 mb
    [EMPTYFLASH]
    User: All Users
    User: Cat
    User: Default
    User: Default User
    User: Public
    OTL by OldTimer - Version 3.2.14.1 log created on 10122010_182405
    C:\Users\Cat\AppData\Local\Microsoft\Windows\Temporary Internet Files\Low\Content.IE5\VIG0WW4H\00b42e3a-b809-49b2-b433-cc45b2bc89d33rd_party_BBS[1].htm moved successfully.
    C:\Users\Cat\AppData\Local\Microsoft\Windows\Temporary Internet Files\Low\Content.IE5\VIG0WW4H\p-01-0VIaSjnOLg[1].gif moved successfully.
    C:\Users\Cat\AppData\Local\Microsoft\Windows\Temporary Internet Files\Low\Content.IE5\DB68VY1F\p-01-0VIaSjnOLg[2].gif moved successfully.
    C:\Users\Cat\AppData\Local\Microsoft\Windows\Temporary Internet Files\Low\Content.IE5\0V7R4Y3D\95578-active-computer-freezes-after-removing-spyware-2[1].html moved successfully.
    C:\Users\Cat\AppData\Local\Microsoft\Windows\Temporary Internet Files\Low\MSIMGSIZ.DAT moved successfully.
    File move failed. C:\Windows\SysNative\SETE600.tmp scheduled to be moved on reboot.
    File move failed. C:\Windows\SysNative\SETE661.tmp scheduled to be moved on reboot.
    File move failed. C:\Windows\SysNative\SETEF50.tmp scheduled to be moved on reboot.
    File move failed. C:\Windows\SysNative\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\UMTEMYCJ\desktop.ini scheduled to be moved on reboot.
    File move failed. C:\Windows\SysNative\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\RRW31JTX\desktop.ini scheduled to be moved on reboot.
    File move failed. C:\Windows\SysNative\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\GM7COSYE\desktop.ini scheduled to be moved on reboot.
    File move failed. C:\Windows\SysNative\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\BZTA37AD\desktop.ini scheduled to be moved on reboot.
    File move failed. C:\Windows\SysNative\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\desktop.ini scheduled to be moved on reboot.
    File move failed. C:\Windows\SysNative\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\desktop.ini scheduled to be moved on reboot.
  11. 2010/10/12
    juddson
    [EMPTYTEMP]
    User: All Users
    User: Cat
    ->Temp folder emptied: 33002 bytes
    ->Temporary Internet Files folder emptied: 1285220 bytes
    ->Google Chrome cache emptied: 0 bytes
    User: Default
    User: Default User
    User: Public
    Windows Temp folder emptied: 0 bytes
    RecycleBin emptied: 0 bytes
    Total Files Cleaned = 2.00 mb
    [EMPTYFLASH]
    User: All Users
    User: Cat
    User: Default
    User: Default User
    User: Public
    Restore point Set: OTL Restore Point
    OTL by OldTimer - Version 3.2.14.1 log created on 10122010_183247
  12. 2010/10/12
    juddson
    Mircosoft.Net Framework 3.5 SP1 will not install Internet Explorer 8 will not install and SP2 will not install any ideas why that is happening?
  13. 2010/10/12
    juddson
    also when I go into the windows updater and click refresh updates I get an error there too
  14. 2010/10/12
    What does the error say?
  15. 2010/10/12
    juddson
    SP2 says Error: ERROR_NOT_FOUND(0x80070490)
    Framework 3.5 SP1 says in the error log:
    [10/12/10,03:19:09] Microsoft .NET Framework 2.0SP1 (x64) (CBS): [2] Error: Installation failed for component Microsoft .NET Framework 2.0SP1 (x64) (CBS). MSI returned error code 1
    [10/12/10,03:19:11] WapUI: [2] DepCheck indicates Microsoft .NET Framework 2.0SP1 (x64) (CBS) is not installed.
    [10/12/10,03:27:36] Microsoft .NET Framework 2.0SP1 (x64) (CBS): [2] Error: Installation failed for component Microsoft .NET Framework 2.0SP1 (x64) (CBS). MSI returned error code 1
    [10/12/10,03:27:39] WapUI: [2] DepCheck indicates Microsoft .NET Framework 2.0SP1 (x64) (CBS) is not installed.
    [10/12/10,03:37:00] Microsoft .NET Framework 2.0SP1 (x64) (CBS): [2] Error: Installation failed for component Microsoft .NET Framework 2.0SP1 (x64) (CBS). MSI returned error code 1
    [10/12/10,03:37:05] WapUI: [2] DepCheck indicates Microsoft .NET Framework 2.0SP1 (x64) (CBS) is not installed.
    [10/12/10,03:40:58] Microsoft .NET Framework 2.0SP1 (x64) (CBS): [2] Error: Installation failed for component Microsoft .NET Framework 2.0SP1 (x64) (CBS). MSI returned error code 1
    [10/12/10,03:41:00] WapUI: [2] DepCheck indicates Microsoft .NET Framework 2.0SP1 (x64) (CBS) is not installed.
    [10/12/10,18:58:25] Microsoft .NET Framework 2.0SP1 (x64) (CBS): [2] Error: Installation failed for component Microsoft .NET Framework 2.0SP1 (x64) (CBS). MSI returned error code 1
    [10/12/10,18:58:28] WapUI: [2] DepCheck indicates Microsoft .NET Framework 2.0SP1 (x64) (CBS) is not installed.
    [10/12/10,19:31:08] Microsoft .NET Framework 2.0SP1 (x64) (CBS): [2] Error: Installation failed for component Microsoft .NET Framework 2.0SP1 (x64) (CBS). MSI returned error code 1
    [10/12/10,19:31:12] WapUI: [2] DepCheck indicates Microsoft .NET Framework 2.0SP1 (x64) (CBS) is not installed.
    [10/12/10,20:12:24] Microsoft .NET Framework 2.0SP1 (x64) (CBS): [2] Error: Installation failed for component Microsoft .NET Framework 2.0SP1 (x64) (CBS). MSI returned error code 1
    [10/12/10,20:12:32] WapUI: [2] DepCheck indicates Microsoft .NET Framework 2.0SP1 (x64) (CBS) is not installed.
    [10/12/10,20:21:15] Microsoft .NET Framework 2.0SP1 (x64) (CBS): [2] Error: Installation failed for component Microsoft .NET Framework 2.0SP1 (x64) (CBS). MSI returned error code 1
    [10/12/10,20:21:33] WapUI: [2] DepCheck indicates Microsoft .NET Framework 2.0SP1 (x64) (CBS) is not installed.
  16. 2010/10/12
    How about the above error?
  17. 2010/10/12
    juddson
    That error is no longer happening and I got the Framework 3.5 to install I'll try the SP2 after I restart the computer
  18. 2010/10/12
    juddson
    SP2 will not install still and says the same error as before ERROR_NOT_FOUND(0x80070490)
    When I try to refresh for new updates in the windows updater it says error "WindowsUpdate_80070490"
    IE8 will not install either and it is the only update that shows up in the windows updater
  20. 2010/10/12
    juddson
    Ok I read all that and Tried the first 2 things which both didnt work. Now for the Regedit thing as I understand it im suposed to delete all the reg entries with KB905866 in them? Sorry if I dont understand it properly
