cd-dvd burner not burning
Discussion in 'Windows XP' started by gabieke, 2009/12/19.
  1. 2009/12/19
    gabieke
    gabieke Inactive Thread Starter
    i have a cd/dvd recorder ( samsung -nec -pioneer ) internal
    whit all those burners i can read - format - play .. anything you like ..... but not burning ..... its not a hardware prombleme ( they have the same faulty indication ) i still have the notice : no recorder found ????
    other burning software have the same indication ( as well to win explorer )
    i looked in too the register and the drive is found ( 3 sections )
    the only faulty place i found is : no upperfilter or lowerfilter ??
    how can i restore this ?? a xp repair dont do it ??
    any help will be appreciatet thx
  2. 2009/12/19
    sp3851
    sp3851 Well-Known Member
    Lets check the Service:
    This is if you have a CD burning program installed:
    Click Start, Administrative Tools, then Services.
    Scroll down to the "IMAPI CD-Burning COM Service ", right click it and click Properties.
    Set the Startup type to Manual, !Click Apply!, Then click Start.
    Press OK and we've enabled the CD burning service, install a CD burning program, and you should be able to write CDs. When you reboot, the service won't be started at boot, but when you try to burn a CD it will start (and when you are finished with the CD the service will stop again).
    If you do not have a CD burning program installed then:
    Set the Startup type to Automatic, !Click Apply!, Then click Start.
    gabieke
    It would help if you would post the Burning Software installed on your computer - Nero, Roxio ..... or just the native XP burning engine (CD only)?
    Have you checked on the Recording tab for each optical drive (Right click > Properties) that Enable recording on this drive is checked?
    Your post includes ....
    Suggests you have InCd or similar loaded - if so try removing it and see if the problem is resolved.
  6. 2009/12/19
    gabieke
    well Pete glad to hear you ... I beleve that the question is not as simpel as i image
    my favorite buring software is roxio ( 6 or 8 ) nero is in war with ( you know ... )
    i tried burn4free ....... cdburnerXP ..... isobuster ...
    what i wondering is that the inclused file in xp-pro isnt working
    note that the the device manager dont make any indication , so ?
    when i go in a comand promt ( driverquery /fo svc /si ) all drivers are on ' true ' so i'm wondering how to repair , note the hardware dont give's any indication of faulty working , where ever i look
    if i don't find a solution i do have a format c:\ , the 2 time in 14 days , so i do hate format
    do you have a idee ?? thx :)
  7. 2009/12/19
    You should have only one item of third party burning software installed - Roxio or Nero or .... to avoid conflicts.
    In all the years I ran XP I never used the inbuilt XP burning software, but I have a feeling that it is disabled when third party burning software is installed.
    As I posted earlier ....
    As you have more than one burner have you selected the recorder to burn to in your burning software? You have to in Nero which is my choice for burning.
    If you have formatted the drive and re-installed XP without resolving the problem repeating the operation is unlikely to make any difference.
    After format did you install the chipset drivers for the motherboard?
    Have you tried disconnecting two of the optical drives and burning to the remaining one? Not quite sure why you need 3 optical drives installed. Maybe I misunderstand you and you have only one drive installed at a time and none of the drives will burn.
    Have these drives been able to burn in the past?
  8. 2009/12/19
    gabieke
    wel Pete thx for suply and you quick anser
    i check the hardware on a other pc ...... and ?? working whitout problemes
    so damed whats going mal on this machine ??
    all you say'd i tri'ed .......... the same ... internet ... no solution
    so i'm disperation.... the only faulty i made is noth making a reg-recovery id when re-install xp .........i maked now a back-up ... but whit a faulty reg file
    thx for your idee's , if you have others plaese tell me
    sorry my english :)
  9. 2009/12/22
    gabieke
    well sorry for late respons .....it so complexe , i can tell all of it on the site ... note be ware of the register it scould be correct and the drivers of the decive
    if you are lookind on the www you will find a ton of possebilites , so fid what you need , and it will be at your idee to find the sollution
    so thanks Pete for your support and see you next time thx :):)
