Can not find 64bit driver for Linksys WPSM54G Wireless print server
Discussion in 'Windows 7' started by Brett63, 2009/11/01.
  1. 2009/11/01
    Brett63
    Brett63 Inactive Thread Starter
    Tried searching for a fix - Linksys/Cisco website is a joke, no help at all. I did find one post by a user who was able to manually install the print server using a TCP/IP port and a generic local printer. I tried that method to no avail.
    WIn 7 was awesome at detecting my system devices (clean install took about 20 minutes) and I was able to manually install my Linksys USB wireless connection (again, no driver support from Cisco) but so far I am having zero luck with the print server. Any help would be greatly appreciated!
  2. 2009/11/01
    Dennis L Inactive Alumni
    The issue seems to be a design flaw ...
    For the complete thread ...
    Some have tried a different approach ...
    For complete instruction for a TCP/IP connection
    See 2nd post in this thread ...
    http://forums.linksysbycisco.com/li...oard.id=Wireless_Print_Servers&thread.id=2456
    Memo .. Most Vista drivers are a suitable replacement when w7 are not available.
    Brett63
    Pretty sad that Linksys/Cisco hasn't ponied up a working driver for this.
    I had already tried the above methods and still no go. I'm stumped. Thanks for the reply!
  5. 2009/11/01
    Any chance running under "XP compatible" mode would work?
  6. 2009/11/02
    Brett63
    Nope, tried that. The setup prog hangs when it tries to install a USB hub...Guess I won't be printing from my Win7 machine until they come out with a 64bit driver. Thanks again.
