Solved Botnet Aftermath
Discussion in 'Malware and Virus Removal Archive' started by virginia, 2012/04/07.
  1. 2012/04/13
    New Problem
    We downloaded WOT and when we open IE it opens to Google as home page. However, when we try to open another tab, WOT pops up and says the website we are trying to go to is bad - and it shows my.freeze.com. I ran Malwarebytes quick scan but it didn't find anything. Any other scan I should run?
    Added Later - I looked in Control Panel and did see the Freeze.com Net Assistant listed but I didn't try to remove it yet. Thought I should wait for instructions from you.
  2. 2012/04/13
    It looks like leftovers from some bad add-on.
    I can see it listed in Add\Remove but I don't see it running anymore.
    Open IE, go Tools>Internet options>Advanced tab and click on "Reset" button.
    Restart IE and let me know if the problem is gone.
    No trojans were present.
    Broni,
    We had another update pending - IE9. Didn't realize that one hadn't been installed. We installed it and all is well with the my.freeze issue. However, it is still listed ih the Installed Programs in Control Panel. Would it be OK to uninstall it via Install/Remove programs?
  5. 2012/04/13
    From your logs it looks like an orphaned registry entry.
    It's not active.
    I'd leave it alone.
    If you insist on removing it, create new restore point, open registry editor, navigate to:
    [HKEY_USERS\S-1-5-21-2642140096-936624496-2998941002-1000\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall]
    Delete "NetAssistant 3.8.3" entry.
    Good luck and stay safe :)
  6. 2012/04/13
    I'll leave it alone - and thanks again.
  7. 2012/04/13
    You're very welcome [​IMG]
