Bluetooth icon is not appearing in taskbar
Discussion in 'Windows 10' started by Signode, 2024/04/15.
  1. 2024/04/15
    Signode
    Signode Well-Known Member Thread Starter
    Hi,
    I own a Lenovo ThinkPad T430 with W10 installed, and I'm experiencing an issue where the Bluetooth icon doesn't appear in the taskbar. When I navigate to Settings >> Bluetooth, I cannot find the Bluetooth 'turn on' button.
    I've tested the Bluetooth chip (PCB) by replacing it with another laptop's working Bluetooth chip, and it worked fine. However, the issue persists on my laptop.
    Interestingly, if I connect an external Bluetooth adapter, the Bluetooth icon appears in the taskbar, and the 'turn on' button shows up in Settings.
    Could you please help me resolve this issue?
    System Info:
    OS Version: Microsoft Windows 10 Pro, 64 bit, Build 19045, Installed 20220705010707.000000+300
    Processor: Intel(R) Core(TM) i5-3230M CPU @ 2.60GHz, Intel64 Family 6 Model 58 Stepping 9, CPU Count: 4
    Total Physical RAM: 4 GB
    Graphics Card: Intel(R) HD Graphics 4000, 2021 MB
    Hard Drives: C: 119 GB (63 GB Free); D: 0 GB (0 GB Free); E: 98 GB (45 GB Free); F: 99 GB (18 GB Free); G: 99 GB (64 GB Free);
    Motherboard: LENOVO 2349N7G, ver Win8 Pro DPK TPG, s/n 1ZSLY38WBB8
    System: LENOVO, ver LENOVO - 2820, s/n PBD9L9Z
    Antivirus: Windows Defender, Enabled and Updated
  2. 2024/04/16
    What do you want to be able to do withOUT a bluetooth device hooked up?
    I see the On/Off switch within my setting but it doesn't appear to do anything when I switch it to on.
    Signode
    Hi Steve.
    Thanks for your Answer.
    For example, if I want to connect a Bluetooth device to my laptop via the built-in Bluetooth, I would need to turn on the Bluetooth first and then proceed with the pairing process. However, in my case, neither the Bluetooth icon appears in the taskbar nor is the button available in Bluetooth settings.
  5. 2024/04/16
  6. 2024/04/16
