Windows Vista Blue screen, hard disk drive not detected, kernel stack?
Discussion in 'Legacy Windows' started by TAYLORBOY, 2010/08/20.
  1. 2010/08/20
    TAYLORBOY
    TAYLORBOY Inactive Thread Starter
    I have a Dell Inspiron 1525 with windows vista home edition.
    When I was on my laptop earlier I got the blue screen, and it said something about kernel stack and that the hard disk drive was no longer detected.
    This has happened three times now but my laptop still boots up, in fact im on it now tying this.
    I know you will need more information but any help will be greatly appreciated :)
  2. 2010/08/20
    Right... start by posting the exact error(s) you receive and we could maybe help you...
    TAYLORBOY
    Thanks for replying, I do not know what the exact errors say/are as the blue screen disappears after seconds and then it says windows was shut down to prevent damage to your system and it then reboots. I have been trying to find a way to find the error log but I cannot find it as im really no good at computers :)
  5. 2010/08/20
    TAYLORBOY
    If its any help, I have been onto dell support centre and run DELL PC CHECK UP 2, this scanned 27 things including two things to do with the hard drive and it never came back with any problem. The only thing it flagged is that I do not automatically update windows, but I turned this of on purpose as sometimes I would download something and it would cause problems.
  6. 2010/08/21
    Right-click Computer from your Start menu, click Properties, then click the Advanced system settings in the left menu. Click the Settings button under Startup and Recovery, and uncheck Automatically restart.
    You can also check your Event log for information.
    To open Event Viewer, go to Start and type eventvwr.msc in the Start Search box & hit Enter.
    Check your System log under Windows Logs for errors.
    You can double click on any error for more details, and there is also a button to copy the error to your clipboard for easy copying & pasting.
  7. 2010/08/21
    TAYLORBOY
    Hi Aries,
    I do not know if this is the information that you mean, but when I check the event log this is what I can see--
    <ViewerConfig>
    <QueryConfig>
    <QueryParams/>
    <QueryNode>
    <Name>
    Summary page events (1) (1)
    </Name>
    <Description>
    Critical events with event ID 41 from source Kernel-Power
    </Description>
    <QueryList>
    <Query Id= "0" Path= "System ">
    <Select Path= "System ">
    *[System[Provider[@Name='Microsoft-Windows-Kernel-Power'] and (Level=1) and (EventID=41)]]
    </Select>
    </Query>
    </QueryList>
    </QueryNode>
    </QueryConfig>
    </ViewerConfig>
    I do not know if its any help. The blue screen happened again and it gave me an option to run a test, this is what the screen said--
    ERROR CODE 0141
    Msg: ERROR CODE 2000-0141
    Msg: HARD DRIVE NO HARD DRIVE DETECTED
    It kept giving me the option to retry the test and the result was the same, it would not let me boot either. So I turned the laptop off and on and it was okay, after reading another thread it said about checking the BIOS, I think I found this and it said under Primary Drive-80GB HDD.
    Hope some of this helps, thanks for your help :)
  8. 2010/08/21
    What hard drive is in your system?
    Please enter your System Details. It helps us in answering your questions!
  9. 2010/08/21
    TAYLORBOY
    HARDWARE-SYSTEM SUMMARY: Dell Inspiron 1525
    MOTHERBOARD: Dell inc. OWP007
    PROCESSOR: Intel(R) Celeron(R) CPU 540 @ 1.86GHz
    MEMORY: Slot 1, Hyundai electronics-512 MB, DDR2 (PC2-5300)
    Slot 2, Hyundai electronics-512 MB, DDR2 (PC2-5300)
    Data Width 64 Bit
    VIDEO CARD:
    GRAHAM-PC (Dell Inc. Inspiron 1525)
    Video Adapter Mobile Intel(R) 965 Express Chipset Family
    Video Processor Mobile Intel(R) 965 Express Chipset Family
    Adapter DAC Type Internal
    PCI ID 0x8086 / 0x2A02 (Intel Corporation / Mobile 965 Express Integrated Graphics Controller)
    PCI sub ID 0x1028 / 0x022F (Dell / Mobile GM965/GL960 Integrated Graphics Controller)
    Memory 320 MBytes
    Dedicated Video Memory 0 MB (0)
    Dedicated System Memory 128 MB (134217728)
    Shared System Memory 123 MB (128997376)
    BIOS String Hardware Version 0.0
    BIOS Date 01/30/20
    PnP Device Id PCI\VEN_8086&DEV_2A02&SUBSYS_022F1028&REV_0C\3&2B8E0B4B&0&10
    Video Mode Description 1280 x 800 x 4294967296 colors
    Driver Version 7.14.10.1253
    Driver Date 2007-12-15 03:53:56
    HARD DRIVE, 1: TOSHIBA MK8046GSX
    OPTICAL DRIVE: DVD Writer 0
    Manufacturer Toshiba
    Model TSSTcorp DVD+-RW TS-L632H ATA Device (TSSTcorp DVD+/-RW TS-L632H)
    Firmware Version D300
    Interface Parallel ATA
    Transfer Mode (Current / Max) Ultra DMA-33 / Ultra DMA-33
    Drive Letter(s) E:
    Controller Buffer Size on Drive 2048 KB
    Removable Yes
    Capabilities
    CD Reader CD-ROM, CD-R, CD-RW
    CD Writer CD-R, CD-RW
    DVD Reader DVD-ROM, DVD-R, DVD-RW
    DVD Writer DVD-R, DVD-RW
    SMART Support No
    SOUND CARD: Property Value
    Intel(R) High Definition Audio HDMI
    Name Intel(R) High Definition Audio HDMI
    Manufacturer Intel(R) Corporation
    Device ID HDAUDIO\FUNC_01&VEN_1095&DEV_1392&SUBSYS_1028022F&REV_1000\4&394240AF&0&0101
    PnP Device Id HDAUDIO\FUNC_01&VEN_1095&DEV_1392&SUBSYS_1028022F&REV_1000\4&394240AF&0&0101
    SigmaTel High Definition Audio CODEC
    Name SigmaTel High Definition Audio CODEC
    Manufacturer SigmaTel
    Device ID HDAUDIO\FUNC_01&VEN_8384&DEV_7616&SUBSYS_1028022F&REV_1002\4&394240AF&0&0201
    PnP Device Id HDAUDIO\FUNC_01&VEN_8384&DEV_7616&SUBSYS_1028022F&REV_1002\4&394240AF&0&0201
    FLOPPPY DRIVE: Drive Drive Type Bus Type File System Total Size Used Space Free Space % Free
    C:\ (OS) Local Disk ATA NTFS 3.1 63422 (MB) 22684 (MB) 40738 (MB) 64 %
    D:\ (RECOVERY) Local Disk ATA NTFS 3.1 10239 (MB) 4124 (MB) 6115 (MB) 60 %
    E:\ DVD ATAPI
    F:\ (Mobile Partner) CD-ROM USB CDFS 9 (MB) 9 (MB) 0 (MB) 0 %
    G:\ Removable Disk USB
    INTERNET CONNECTIVITY: i use either wifi or a broadband dongle.
    OPERATING SYSTEM: Windows Vista Home Basic
    BIT TYPE: 64 Bit.
    I hope this is what you need?? Where I was not totally sure what information to put in I just pasted everything that was there, thanks for helping me :)
  10. 2010/08/21
    TAYLORBOY
    Im not sure if this has anything to do with it but I ran a scan with Spyware Doctor and it picked up two trojans, I have never had these before and let spyware doctor fix them. If its any help they were located in
    C:\users\GRAHAM\AppData\Local\Temp\jar_cache7287329339282892518.tml
    C:\users\GRAHAM\AppData\Local\Temp\jar_cache2292279519246801460.tml
  11. 2010/08/21
    I'd start by checking the hard drive using the disk diagnostics from the manufacturer
    It also looks like Toshiba uses re-branded Fujitsu drives, so you could try their utilities too.
    TAYLORBOY likes this.
  12. 2010/08/23
    TAYLORBOY
    Hi Arie, I tried to run both diagnostics but it says I have to be an administrator which I am so not sure why it said that.
    NOW TO THE EMBARRASSING BIT:eek:--when I was trying the things you suggested I realised that some on the side of my laptop was coming out, so I pulled it out and low and behold it was the HDD(I always thought it was located somewhere else but I was wrong again). When I turned the laptop upside down I realised that the screws for the HDD had come out so therefore the HDD must have just been sliding out every now and again. Anyway I put two new screws in and since then all is well and I think it has to have been that. Anyway im going to sit in the corner with a dunces hat on for a while. Thanks for taking the time to try and help and im sorry I wasted your time. :):):) I will mark resolved when I know you have seen its sorted :)
  13. 2010/08/24
    Yea, that would do it too :)
    Glad you got it solved.
