Resolved Blue Screen Appeared!
Discussion in 'Windows 7' started by FuzMic, 2010/11/18.
  1. 2010/11/26
    I suggested a check of the hard drive earlier in this thread :)
    No need to use vmware as you are running 7 Ultimate in which you can use Windows XP mode - a free download from MS including a copy of XP Pro.
    If the BSOD occurs only when running that task it is a pointer to the problem. Heavy CPU usage - would be worth checking out the CPU temps. I suggest Core Temp which you can leave running and monitor the load, max and min temps - screenshot.
  2. 2010/11/26
    markmadras
    markmadras Banned
    From this quote it is still a little unclear as to what is happening when you get a BSOD, are you having to shut down manually irrespective of "Auto Restart" being checked. If it is freezing is there any message on the screen or maybe just a flashing cursor.
    The idea of unchecking "Auto Restart" was to give you the chance to read the BSOD error message and report it here, which you have not done. We need to know what the error message/s say on the screen. If you are getting a Black Screen which freezes the PC and not Blue then please tell us as this is different.
    You do not need much time to do this test, just load up the disc and leave it running, you will see the results when you return to the PC. The test can be left to run for as long as you wish.
    This is from post 10. Have you followed this advise???
    Have you run a test on the hard drive as PeteC suggested???
    Have you installed the CPU temperature software PeteC suggested???
    http://www.alcpu.com/CoreTemp/
    _________________________________________________________________
    Other posts on this issue have gone around in circles , as you have seen. The only way to progress is for you to follow the advise we give and trying everything that is suggested and reporting back with the results. Please follow what has been suggested and run the memory and hard drive tests or this post will also go around in circles;).
    FuzMic
    FuzMic Well-Known Member Thread Starter
    Mark, sorry for appearing to taking you in circles. The reason why i did not run the test is the PC is being used for work and until i set up another PC to do the work i differed the tests. Meanwhile I was trying to fast fix and come back to the advices latter.
    On the reboot issue, i always get a Blue BSOD and i had to manually press the power switch to reboot. There is no black screen or flushing cursor; to me it is a true BSOD; hence i was able to read / report the bsod error message reported in my earlier thread. Hope this clear up this issue.
  5. 2010/11/27
    markmadras
    markmadras Banned
    OK, that makes the situation a lot clearer. As you may have already realised there is not likely to be a fast fix for this as running the tests, as advised, is going to be the only way to figure out what is going wrong.
  6. 2010/11/27
    markmadras
    markmadras Banned
    For a quick fix, did you follow this advise from post 10
  7. 2010/11/28
    FuzMic
    Mark just for quick reply:
    When i use the same PC with a different hard-Dsk with the same firewall setting, spyware/malware/AV there was no BSOD so far.
    This config do not have 2 suspects: vmware & vb.express.08.
    Please be patient as i working out some of my other priorities in solving this specially i am dealing with a new OS. Thanks anyway, will certainly come back when i exhausted all the avenues and probably by then EXHAUSTED! :)
  8. 2010/11/29
    markmadras
    markmadras Banned
    This is fairly convincing evidence that the original hard drive is corrupt or faulty. You can run the diagnostics test on this drive using another PC, then if it fails the test you will have resolved the problem.
  9. 2010/11/29
    Capt. Jack Sparrow
    Capt. Jack Sparrow Inactive
    Hello,
    It's a good idea if you could post the Dump files. C:\Windows\MiniDump Zip the files there and upload to Skydrive and post the link here. If that is giving you an error you could use this tool i made http://captaindebugger.wordpress.com/sf-diagnostic-tool-v4/ the instructions on how to use it is in the post. Make you right click and Run as administrator.
    Hope this helps,
    Captain
  10. 2010/11/29
    FuzMic
    Thanks Captain Jack :), will do in due course.
    Mark noted yr last response.
    PS
    Capt Jack please get the minidump here
    http://www.easy-share.com/1913140727/Minidump.zip
    Mark, tested the WD5000, quick test no problem, now doing extended test, half done no problem yet. I have a feeling it is not the harddisk either since it is brand new.
  11. 2010/11/30
    markmadras
    markmadras Banned
    Well, if the test completes with no errors then one of these progs is obviously suspect vmware & vb.express.08. I would check to see if there are any updates available for these programs.
    Capt Jack Sparrow may well shine some light when he examines your crash dumps. Meanwhile, the only other test to run will be the memtest and it may be worth trying the CPU temp sensor that PeteC suggested in post 21.
  12. 2010/11/30
    Capt. Jack Sparrow
    Hello Mate,
    You have multiple issues. First thing immediate you need to do is uninstall AVG and Zone Alarm Pro completely. Use the removal Tool and clean the left over files
    AVG: http://www.avg.com/us-en/download-tools
    Zone Alarm: http://download.zonealarm.com/bin/free/support/cpes_clean.exe
    You could install Microsoft Security Essentials
    Bugcheck:
    DRIVER_VERIFIER_DETECTED_VIOLATION (c4)
    A device driver attempting to corrupt the system has been caught. This is
    because the driver was specified in the registry as being suspect (by the
    administrator) and the kernel has enabled substantial checking of this driver.
    If the driver attempts to corrupt the system, bugchecks 0xC4, 0xC1 and 0xA will
    be among the most commonly seen crashes.
    Arguments:
    Arg1: 0000000000000000, caller is trying to allocate zero bytes
    Arg2: 0000000000000000, current IRQL
    Arg3: 0000000000000000, pool type
    Arg4: 0000000000000000, number of bytes
    Debugging Details:
    BUGCHECK_STR: 0xc4_0
    CURRENT_IRQL: 0
    CUSTOMER_CRASH_COUNT: 1
    DEFAULT_BUCKET_ID: VERIFIER_ENABLED_VISTA_MINIDUMP
    PROCESS_NAME: avgnsa.exe
    LAST_CONTROL_TRANSFER: from fffff80002d083dc to fffff8000287ef00
    STACK_TEXT:
    fffff880`054b15b8 fffff800`02d083dc : 00000000`000000c4 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KeBugCheckEx
    fffff880`054b15c0 fffff800`02d08e1b : fffffa80`04ed1b20 fffff800`02d1a057 fffffa80`04ed1b20 fffff980`2c14af90 : nt!VerifierBugCheckIfAppropriate+0x3c
    fffff880`054b1600 fffff800`02d19df8 : 00000000`f24b5357 00000000`00000080 00000000`00000000 00000000`00000000 : nt!ExAllocatePoolSanityChecks+0xcb
    fffff880`054b1640 fffff800`02d1a09d : fffff980`18518ec0 fffff980`2bea0fb8 00000000`f24b5357 00000000`00000000 : nt!VeAllocatePoolWithTagPriority+0x88
    fffff880`054b16b0 fffff880`03c6f707 : fffffa80`015366c8 fffff880`00000008 fffff800`00000000 00000000`00000003 : nt!VerifierExAllocatePoolWithTag+0x1d
    fffff880`054b16f0 fffff880`03d6503b : fffff980`2bea0ea0 fffff980`2bea0ea0 fffff980`00000020 fffff980`2bea0fb8 : afd!WskTdiEHReceive+0xe7
    fffff880`054b1780 fffff980`2bea0ea0 : fffff980`2bea0ea0 fffff980`00000020 fffff980`2bea0fb8 00000000`000002dd : avgtdia+0x803b
    fffff880`054b1788 fffff980`2bea0ea0 : fffff980`00000020 fffff980`2bea0fb8 00000000`000002dd fffff880`054b1810 : 0xfffff980`2bea0ea0
    fffff880`054b1790 fffff980`00000020 : fffff980`2bea0fb8 00000000`000002dd fffff880`054b1810 00000000`00000000 : 0xfffff980`2bea0ea0
    fffff880`054b1798 fffff980`2bea0fb8 : 00000000`000002dd fffff880`054b1810 00000000`00000000 fffff880`054b1818 : 0xfffff980`00000020
    fffff880`054b17a0 00000000`000002dd : fffff880`054b1810 00000000`00000000 fffff880`054b1818 00000000`00000003 : 0xfffff980`2bea0fb8
    fffff880`054b17a8 fffff880`054b1810 : 00000000`00000000 fffff880`054b1818 00000000`00000003 fffff880`03c6f620 : 0x2dd
    fffff880`054b17b0 00000000`00000000 : fffff880`054b1818 00000000`00000003 fffff880`03c6f620 fffff980`17fa6ec0 : 0xfffff880`054b1810
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    avgtdia+803b
    fffff880`03d6503b ?? ???
    SYMBOL_STACK_INDEX: 6
    SYMBOL_NAME: avgtdia+803b
    FOLLOWUP_NAME: MachineOwner
    MODULE_NAME: avgtdia
    IMAGE_NAME: avgtdia.sys
    DEBUG_FLR_IMAGE_TIMESTAMP: 4c081a25
    FAILURE_BUCKET_ID: X64_0xc4_0_VRF_avgtdia+803b
    Followup: MachineOwner
    Hope this helps,
    Captain
  13. 2010/11/30
    FuzMic
    Thank you Cap for the effort; for my education please indulge me further with answers to 3 questions:
    1 what makes you think that it is zone alarm, i don't see it in the extract u quoted. By the way in zone alarm forum, it is quoted that v9.2.076.xx has problem with win7.64bit while avg v9 will not be supported soon probably because of 64 bit issues??
    2 do you think the new version of avg 2011 will fix this beside going for ms..
    3 have you seen this event before in other pc with win7.64bit.ultimate.
    Cap's Off .. Salute!
  14. 2010/11/30
    Capt. Jack Sparrow
    Hello FuzMic,
    AVG is clearly a problem here, Driver Verifer on your computer has caught the problem. Not sure if AVG 2011 will fix it. I have personally seen 100s of cases where AVG and Zone Alarm casuing BSOD. I would Zone Alarm is a junk it corrupts the NETIO.sys drivers caused the System to crash. You better off with it. There are lot of other Firewall like Comodo that gives you good protection. IMO Windows Firewall with http://www.sphinx-soft.com/Vista/order.html free edtion will give you good protection. As far as Antivirus concern Microsoft provide a good one MSE. For added protection you could install WinPatrol Free edition.
    Hope this helps,
    Captain
  15. 2010/11/30
    FuzMic
    Feel very good from your words of advice. Will tinker along your lines and see what's the outcome. Michael.
  16. 2010/12/01
    markmadras
    markmadras Banned
    That's interesting, I suggested you got rid of AVG and all the other AV, spyware and firewall and installed MSE back in post 10. Turns out my hunch was very close to the problem.
    Capt Jack Sparrow, is there a good guide on line which would help me to learn more about dump files, especially how to handle them so they can be read and posted.
  17. 2010/12/01
    Capt. Jack Sparrow
    MarkMadras: There are lot of online material. You could check my blog as well that has enough information to get you started. http://captaindebugger.wordpress.com
    Good Luck,
    Captain
  18. 2010/12/02
    markmadras
    markmadras Banned
    Thanks for that Jack I'll have a good read of your site.
    Re Adac's post (now removed) if you see any more jumping into the middle of a thread just click on the red triangle "Report Post" and just put in a message like "Interrupting thread" then admin will remove it.
  19. 2010/12/09
    FuzMic
    Hi Captain & Mark
    The BSOD appeared again at the time of switching user - seems always when there is some major screen dimming. This happened in the same problem PC with the same now tested ok memory module, same harddisk but with AVG and zone alarm removed replaced by ms Security Essentials and Sphinx FireWall.
    The minidump is at Easy Share for the gurus to have another dig at this problem.
    http://www.easy-share.com/1913234718/NewMiniDump.zip
    Thanks!
  20. 2010/12/09
    FuzMic
    Last Blue Screen Dump file
    Arie, having problem using winsdk_web.exe due to firewall thus use the Blue Screen to get dump file.
    Sorry for the delay.
    Quote: Header
    120910-18064-01.dmp 09-12-10 2:08:22 PM PAGE_FAULT_IN_NONPAGED_AREA 0x00000050 fffff900`c22f0010 00000000`00000000 fffff960`002f1967 00000000`00000000 ntoskrnl.exe ntoskrnl.exe+70740 NT Kernel & System Microsoft® Windows® Operating System Microsoft Corporation 6.1.7600.16617 (win7_gdr.100618-1621) x64 C:\Windows\Minidump\120910-18064-01.dmp 2 15 7600
    Quote: Dump file
    ntoskrnl.exe ntoskrnl.exe+f0f14 fffff800`02819000 fffff800`02df5000 0x005dc000 0x4c1c44a9 19-06-10 12:16:41 PM Microsoft® Windows® Operating System NT Kernel & System 6.1.7600.16617 (win7_gdr.100618-1621) Microsoft Corporation C:\Windows\system32\ntoskrnl.exe
    hal.dll fffff800`02df5000 fffff800`02e3e000 0x00049000 0x4a5bdf08 14-07-09 9:27:36 AM
    kdcom.dll fffff800`00ba0000 fffff800`00baa000 0x0000a000 0x4a5bdfdb 14-07-09 9:31:07 AM
    mcupdate_AuthenticAMD.dll fffff880`00cd2000 fffff880`00cdf000 0x0000d000 0x4a5bdf65 14-07-09 9:29:09 AM
    PSHED.dll fffff880`00cdf000 fffff880`00cf3000 0x00014000 0x4a5be027 14-07-09 9:32:23 AM Microsoft® Windows® Operating System Platform Specific Hardware Error Driver 6.1.7600.16385 (win7_rtm.090713-1255) Microsoft Corporation C:\Windows\system32\PSHED.dll
    CLFS.SYS fffff880`00cf3000 fffff880`00d51000 0x0005e000 0x4a5bc11d 14-07-09 7:19:57 AM
    CI.dll fffff880`00c00000 fffff880`00cc0000 0x000c0000 0x4a5be01d 14-07-09 9:32:13 AM
    Wdf01000.sys fffff880`00d51000 fffff880`00df5000 0x000a4000 0x4a5bc19f 14-07-09 7:22:07 AM
    WDFLDR.SYS fffff880`00cc0000 fffff880`00ccf000 0x0000f000 0x4a5bc11a 14-07-09 7:19:54 AM
    ACPI.sys fffff880`00e21000 fffff880`00e78000 0x00057000 0x4a5bc106 14-07-09 7:19:34 AM
    WMILIB.SYS fffff880`00e78000 fffff880`00e81000 0x00009000 0x4a5bc117 14-07-09 7:19:51 AM
    msisadrv.sys fffff880`00e81000 fffff880`00e8b000 0x0000a000 0x4a5bc0fe 14-07-09 7:19:26 AM
    pci.sys fffff880`00e8b000 fffff880`00ebe000 0x00033000 0x4a5bc117 14-07-09 7:19:51 AM
    vdrvroot.sys fffff880`00ebe000 fffff880`00ecb000 0x0000d000 0x4a5bcadb 14-07-09 8:01:31 AM
    partmgr.sys fffff880`00ecb000 fffff880`00ee0000 0x00015000 0x4a5bc11e 14-07-09 7:19:58 AM
    compbatt.sys fffff880`00ee0000 fffff880`00ee9000 0x00009000 0x4a5bc3b6 14-07-09 7:31:02 AM
    BATTC.SYS fffff880`00ee9000 fffff880`00ef5000 0x0000c000 0x4a5bc3b5 14-07-09 7:31:01 AM
    volmgr.sys fffff880`00ef5000 fffff880`00f0a000 0x00015000 0x4a5bc11d 14-07-09 7:19:57 AM
    volmgrx.sys fffff880`00f0a000 fffff880`00f66000 0x0005c000 0x4a5bc141 14-07-09 7:20:33 AM
    pciide.sys fffff880`00f66000 fffff880`00f6d000 0x00007000 0x4a5bc115 14-07-09 7:19:49 AM
    PCIIDEX.SYS fffff880`00f6d000 fffff880`00f7d000 0x00010000 0x4a5bc114 14-07-09 7:19:48 AM
    mountmgr.sys fffff880`00f7d000 fffff880`00f97000 0x0001a000 0x4a5bc11a 14-07-09 7:19:54 AM
    atapi.sys fffff880`00f97000 fffff880`00fa0000 0x00009000 0x4a5bc113 14-07-09 7:19:47 AM
    ataport.SYS fffff880`00fa0000 fffff880`00fca000 0x0002a000 0x4a5bc118 14-07-09 7:19:52 AM
    nvstor.sys fffff880`00fca000 fffff880`00ff5000 0x0002b000 0x4a13a711 20-05-09 2:45:37 PM
    storport.sys fffff880`01099000 fffff880`010fb000 0x00062000 0x4a5bcace 14-07-09 8:01:18 AM
    nvstor64.sys fffff880`010fb000 fffff880`0113a000 0x0003f000 0x4a78d2cb 05-08-09 8:31:07 AM
    amdxata.sys fffff880`0113a000 fffff880`01145000 0x0000b000 0x4a12f2eb 20-05-09 1:56:59 AM
    fltmgr.sys fffff880`01145000 fffff880`01191000 0x0004c000 0x4a5bc11f 14-07-09 7:19:59 AM
    fileinfo.sys fffff880`01191000 fffff880`011a5000 0x00014000 0x4a5bc481 14-07-09 7:34:25 AM
    Ntfs.sys fffff880`0122e000 fffff880`013d1000 0x001a3000 0x4a5bc14f 14-07-09 7:20:47 AM
    msrpc.sys fffff880`01000000 fffff880`0105e000 0x0005e000 0x00000000
    ksecdd.sys fffff880`013d1000 fffff880`013eb000 0x0001a000 0x4a5bc156 14-07-09 7:20:54 AM
    cng.sys fffff880`01444000 fffff880`014b7000 0x00073000 0x4a5bc814 14-07-09 7:49:40 AM
    pcw.sys fffff880`014b7000 fffff880`014c8000 0x00011000 0x4a5bc0ff 14-07-09 7:19:27 AM
    Fs_Rec.sys fffff880`014c8000 fffff880`014d2000 0x0000a000 0x00000000
    ndis.sys fffff880`014d2000 fffff880`015c4000 0x000f2000 0x4a5bc184 14-07-09 7:21:40 AM
    NETIO.SYS fffff880`0160d000 fffff880`0166d000 0x00060000 0x4bbe946f 09-04-10 10:43:59 AM
    ksecpkg.sys fffff880`0166d000 fffff880`01698000 0x0002b000 0x4b21e0b4 11-12-09 2:03:32 PM
    tcpip.sys fffff880`01800000 fffff880`019fd000 0x001fd000 0x4c15a458 14-06-10 11:39:04 AM
    fwpkclnt.sys fffff880`01698000 fffff880`016e2000 0x0004a000 0x4a5bc164 14-07-09 7:21:08 AM
    vmstorfl.sys fffff880`016e2000 fffff880`016f2000 0x00010000 0x00000000
    volsnap.sys fffff880`016f2000 fffff880`0173e000 0x0004c000 0x4a5bc128 14-07-09 7:20:08 AM
    spldr.sys fffff880`0173e000 fffff880`01746000 0x00008000 0x4a0858bb 12-05-09 12:56:27 AM
    rdyboost.sys fffff880`01746000 fffff880`01780000 0x0003a000 0x4a5bc48a 14-07-09 7:34:34 AM
    mup.sys fffff880`01780000 fffff880`01792000 0x00012000 0x4a5bc201 14-07-09 7:23:45 AM
    hwpolicy.sys fffff880`01792000 fffff880`0179b000 0x00009000 0x4a5bc0fa 14-07-09 7:19:22 AM
    fvevol.sys fffff880`0179b000 fffff880`017d5000 0x0003a000 0x4a5bc1a7 14-07-09 7:22:15 AM
    disk.sys fffff880`017d5000 fffff880`017eb000 0x00016000 0x4a5bc11d 14-07-09 7:19:57 AM
    CLASSPNP.SYS fffff880`015c4000 fffff880`015f4000 0x00030000 0x4a5bc11e 14-07-09 7:19:58 AM
    cdrom.sys fffff880`01200000 fffff880`0122a000 0x0002a000 0x4a5bc11a 14-07-09 7:19:54 AM
    MpFilter.sys fffff880`0105e000 fffff880`0108b000 0x0002d000 0x4ba463f0 20-03-10 1:58:08 PM
    Null.SYS fffff880`015f4000 fffff880`015fd000 0x00009000 0x00000000
    Beep.SYS fffff880`017f9000 fffff880`01800000 0x00007000 0x4a5bca8d 14-07-09 8:00:13 AM
    vga.sys fffff880`0108b000 fffff880`01099000 0x0000e000 0x4a5bc587 14-07-09 7:38:47 AM
    VIDEOPRT.SYS fffff880`011a5000 fffff880`011ca000 0x00025000 0x4a5bc58b 14-07-09 7:38:51 AM
    watchdog.sys fffff880`011ca000 fffff880`011da000 0x00010000 0x4a5bc53f 14-07-09 7:37:35 AM
    RDPCDD.sys fffff880`011da000 fffff880`011e3000 0x00009000 0x4a5bce62 14-07-09 8:16:34 AM
    rdpencdd.sys fffff880`011e3000 fffff880`011ec000 0x00009000 0x4a5bce62 14-07-09 8:16:34 AM
    rdprefmp.sys fffff880`011ec000 fffff880`011f5000 0x00009000 0x4a5bce63 14-07-09 8:16:35 AM
    Msfs.SYS fffff880`011f5000 fffff880`01200000 0x0000b000 0x4a5bc113 14-07-09 7:19:47 AM
    Npfs.SYS fffff880`00e00000 fffff880`00e11000 0x00011000 0x4a5bc114 14-07-09 7:19:48 AM
    tdx.sys fffff880`02ce4000 fffff880`02d02000 0x0001e000 0x4a5bc16b 14-07-09 7:21:15 AM
    TDI.SYS fffff880`02d02000 fffff880`02d0f000 0x0000d000 0x4a5bc16e 14-07-09 7:21:18 AM
    netbt.sys fffff880`02d0f000 fffff880`02d54000 0x00045000 0x4a5bc178 14-07-09 7:21:28 AM
    afd.sys fffff880`02d54000 fffff880`02dde000 0x0008a000 0x4a5bc184 14-07-09 7:21:40 AM
    ws2ifsl.sys fffff880`02dde000 fffff880`02de9000 0x0000b000 0x4a5bccf9 14-07-09 8:10:33 AM
    wfplwf.sys fffff880`02de9000 fffff880`02df2000 0x00009000 0x4a5bccb6 14-07-09 8:09:26 AM
    pacer.sys fffff880`02c00000 fffff880`02c26000 0x00026000 0x4a5bccc5 14-07-09 8:09:41 AM
    netbios.sys fffff880`02c26000 fffff880`02c35000 0x0000f000 0x4a5bccb6 14-07-09 8:09:26 AM
    serial.sys fffff880`02c35000 fffff880`02c52000 0x0001d000 0x4a5bcaa8 14-07-09 8:00:40 AM
    wanarp.sys fffff880`02c52000 fffff880`02c6d000 0x0001b000 0x4a5bcced 14-07-09 8:10:21 AM
    termdd.sys fffff880`02c6d000 fffff880`02c81000 0x00014000 0x4a5bce64 14-07-09 8:16:36 AM
    rdbss.sys fffff880`02c81000 fffff880`02cd2000 0x00051000 0x4a5bc219 14-07-09 7:24:09 AM
    nsiproxy.sys fffff880`02cd2000 fffff880`02cde000 0x0000c000 0x4a5bc15e 14-07-09 7:21:02 AM
    mssmbios.sys fffff880`02df2000 fffff880`02dfd000 0x0000b000 0x4a5bc3be 14-07-09 7:31:10 AM
    discache.sys fffff880`00e11000 fffff880`00e20000 0x0000f000 0x4a5bc52e 14-07-09 7:37:18 AM
    csc.sys fffff880`03ecc000 fffff880`03f4f000 0x00083000 0x4a5bc22a 14-07-09 7:24:26 AM
    dfsc.sys fffff880`03f4f000 fffff880`03f6d000 0x0001e000 0x4a5bc200 14-07-09 7:23:44 AM
    blbdrive.sys fffff880`03f6d000 fffff880`03f7e000 0x00011000 0x4a5bc4df 14-07-09 7:35:59 AM
    tunnel.sys fffff880`03f7e000 fffff880`03fa4000 0x00026000 0x4a5bccc1 14-07-09 8:09:37 AM
    amdppm.sys fffff880`03fa4000 fffff880`03fb9000 0x00015000 0x4a5bc0fd 14-07-09 7:19:25 AM
    parport.sys fffff880`03fb9000 fffff880`03fd6000 0x0001d000 0x4a5bcaa8 14-07-09 8:00:40 AM
    ASACPI.sys fffff880`03fd6000 fffff880`03fde000 0x00008000 0x4a0b72fd 14-05-09 9:25:17 AM
    i8042prt.sys fffff880`03fde000 fffff880`03ffc000 0x0001e000 0x4a5bc11d 14-07-09 7:19:57 AM
    kbdclass.sys fffff880`03e00000 fffff880`03e0f000 0x0000f000 0x4a5bc116 14-07-09 7:19:50 AM
    VMkbd.sys fffff880`03e0f000 fffff880`03e1a000 0x0000b000 0x4cdc5386 12-11-10 4:35:18 AM
    mouclass.sys fffff880`03e1a000 fffff880`03e29000 0x0000f000 0x4a5bc116 14-07-09 7:19:50 AM
    serenum.sys fffff880`03e29000 fffff880`03e35000 0x0000c000 0x4a5bcaa1 14-07-09 8:00:33 AM
    usbohci.sys fffff880`03e35000 fffff880`03e40000 0x0000b000 0x4a5bcc06 14-07-09 8:06:30 AM
    USBPORT.SYS fffff880`03e40000 fffff880`03e96000 0x00056000 0x4a5bcc07 14-07-09 8:06:31 AM
    usbehci.sys fffff880`03e96000 fffff880`03ea7000 0x00011000 0x4a5bcc06 14-07-09 8:06:30 AM
    HDAudBus.sys fffff880`03ea7000 fffff880`03ecb000 0x00024000 0x4a5bcbf5 14-07-09 8:06:13 AM
    nvmf6264.sys fffff880`03a53000 fffff880`03aa4500 0x00051500 0x4a723142 31-07-09 7:48:18 AM
    nvlddmkm.sys fffff880`048ae000 fffff880`053b5b00 0x00b07b00 0x4a0c8387 15-05-09 4:48:07 AM
    dxgkrnl.sys fffff880`03aa5000 fffff880`03b99000 0x000f4000 0x4ac5509e 02-10-09 9:00:14 AM
    dxgmms1.sys fffff880`053b6000 fffff880`053fc000 0x00046000 0x4a5bc578 14-07-09 7:38:32 AM
    CompositeBus.sys fffff880`04800000 fffff880`04810000 0x00010000 0x4a5bcaa1 14-07-09 8:00:33 AM
    AgileVpn.sys fffff880`04810000 fffff880`04826000 0x00016000 0x4a5bccf0 14-07-09 8:10:24 AM
    rasl2tp.sys fffff880`04826000 fffff880`0484a000 0x00024000 0x4a5bcce3 14-07-09 8:10:11 AM
    ndistapi.sys fffff880`0484a000 fffff880`04856000 0x0000c000 0x4a5bccd8 14-07-09 8:10:00 AM
    ndiswan.sys fffff880`04856000 fffff880`04885000 0x0002f000 0x4a5bcce3 14-07-09 8:10:11 AM
    raspppoe.sys fffff880`04885000 fffff880`048a0000 0x0001b000 0x4a5bcce9 14-07-09 8:10:17 AM
    raspptp.sys fffff880`03b99000 fffff880`03bba000 0x00021000 0x4a5bccea 14-07-09 8:10:18 AM
    rassstp.sys fffff880`03bba000 fffff880`03bd4000 0x0001a000 0x4a5bccf1 14-07-09 8:10:25 AM
    rdpbus.sys fffff880`048a0000 fffff880`048ab000 0x0000b000 0x4a5bceaa 14-07-09 8:17:46 AM
    swenum.sys fffff880`048ab000 fffff880`048ac480 0x00001480 0x4a5bca92 14-07-09 8:00:18 AM
    ks.sys fffff880`03a00000 fffff880`03a43000 0x00043000 0x4a5bca9f 14-07-09 8:00:31 AM
    umbus.sys fffff880`03bd4000 fffff880`03be6000 0x00012000 0x4a5bcc20 14-07-09 8:06:56 AM
    vmnetadapter.sys fffff880`03be6000 fffff880`03bee000 0x00008000 0x4a800ce5 10-08-09 8:04:53 PM
    VMNET.SYS fffff880`03bee000 fffff880`03bf8000 0x0000a000 0x4a800ce2 10-08-09 8:04:50 PM
    usbhub.sys fffff880`0420a000 fffff880`04264000 0x0005a000 0x4a5bcc2d 14-07-09 8:07:09 AM
    NDProxy.SYS fffff880`04264000 fffff880`04279000 0x00015000 0x4a5bccdd 14-07-09 8:10:05 AM
    HdAudio.sys fffff880`04279000 fffff880`042d5000 0x0005c000 0x4a5bcc23 14-07-09 8:06:59 AM
    portcls.sys fffff880`042d5000 fffff880`04312000 0x0003d000 0x4a5bcc03 14-07-09 8:06:27 AM
    drmk.sys fffff880`04312000 fffff880`04334000 0x00022000 0x4a5bd8e5 14-07-09 9:01:25 AM
    ksthunk.sys fffff880`04334000 fffff880`04339200 0x00005200 0x4a5bca93 14-07-09 8:00:19 AM
    crashdmp.sys fffff880`0433a000 fffff880`04348000 0x0000e000 0x4a5bcabd 14-07-09 8:01:01 AM
    dump_diskdump.sys fffff880`04348000 fffff880`04352000 0x0000a000 0x4a5bcabc 14-07-09 8:01:00 AM
    dump_nvstor64.sys fffff880`04352000 fffff880`04391000 0x0003f000 0x4a78d2cb 05-08-09 8:31:07 AM
    dump_dumpfve.sys fffff880`04391000 fffff880`043a4000 0x00013000 0x4a5bc18f 14-07-09 7:21:51 AM
    win32k.sys fffff960`000d0000 fffff960`003df000 0x0030f000 0x4c7dc13c 01-09-10 10:58:04 AM
    Dxapi.sys fffff880`043a4000 fffff880`043b0000 0x0000c000 0x4a5bc574 14-07-09 7:38:28 AM
    monitor.sys fffff880`043b0000 fffff880`043be000 0x0000e000 0x4a5bc58c 14-07-09 7:38:52 AM
    TSDDD.dll fffff960`00500000 fffff960`0050a000 0x0000a000 0x4a5bce62 14-07-09 8:16:34 AM
    luafv.sys fffff880`043be000 fffff880`043e1000 0x00023000 0x4a5bc295 14-07-09 7:26:13 AM
    WudfPf.sys fffff880`01400000 fffff880`01421000 0x00021000 0x4a5bcbd1 14-07-09 8:05:37 AM
    smb.sys fffff880`043e1000 fffff880`043fd000 0x0001c000 0x4a5bcca5 14-07-09 8:09:09 AM
    vmnetbridge.sys fffff880`03a43000 fffff880`03a53000 0x00010000 0x4a800d26 10-08-09 8:05:58 PM
    lltdio.sys fffff880`01421000 fffff880`01436000 0x00015000 0x4a5bcc92 14-07-09 8:08:50 AM
    nwifi.sys fffff880`02417000 fffff880`0246a000 0x00053000 0x4a5bcc3b 14-07-09 8:07:23 AM
    ndisuio.sys fffff880`0246a000 fffff880`0247d000 0x00013000 0x4a5bccb5 14-07-09 8:09:25 AM
    rspndr.sys fffff880`0247d000 fffff880`02495000 0x00018000 0x4a5bcc92 14-07-09 8:08:50 AM
    HTTP.sys fffff880`02495000 fffff880`0255d000 0x000c8000 0x4a5bc1a8 14-07-09 7:22:16 AM
    srvnet.sys fffff880`0255d000 fffff880`0258a000 0x0002d000 0x4c7732f4 27-08-10 11:37:24 AM
    bowser.sys fffff880`0258a000 fffff880`025a8000 0x0001e000 0x4a5bc206 14-07-09 7:23:50 AM
    mpsdrv.sys fffff880`025a8000 fffff880`025c0000 0x00018000 0x4a5bcc79 14-07-09 8:08:25 AM
    mrxdav.sys fffff880`025c0000 fffff880`025e8000 0x00028000 0x4a5bc20d 14-07-09 7:23:57 AM
    mrxsmb.sys fffff880`02a0e000 fffff880`02a3b000 0x0002d000 0x4b88cf33 27-02-10 3:52:19 PM
    mrxsmb10.sys fffff880`02a3b000 fffff880`02a89000 0x0004e000 0x4b88cf3c 27-02-10 3:52:28 PM
    mrxsmb20.sys fffff880`02a89000 fffff880`02aac000 0x00023000 0x4b88cf3a 27-02-10 3:52:26 PM
    srv2.sys fffff880`02aac000 fffff880`02b13000 0x00067000 0x4c77330a 27-08-10 11:37:46 AM
    srv.sys fffff880`02b13000 fffff880`02ba9000 0x00096000 0x4c773318 27-08-10 11:38:00 AM
    hcmon.sys fffff880`02ba9000 fffff880`02bb5000 0x0000c000 0x4cdc4799 12-11-10 3:44:25 AM
    vmci.sys fffff880`02bb5000 fffff880`02bcd000 0x00018000 0x4cdc3ffe 12-11-10 3:11:58 AM
    VMparport.sys fffff880`02bcd000 fffff880`02bd8000 0x0000b000 0x4cdc3f68 12-11-10 3:09:28 AM
    vmx86.sys fffff880`038ee000 fffff880`039c4000 0x000d6000 0x4cdc5ebc 12-11-10 5:23:08 AM
    peauth.sys fffff880`03800000 fffff880`038a6000 0x000a6000 0x4a5bd8df 14-07-09 9:01:19 AM
    secdrv.SYS fffff880`038a6000 fffff880`038b1000 0x0000b000 0x4508052e 13-09-06 9:18:38 PM
    tcpipreg.sys fffff880`0415e000 fffff880`04170000 0x00012000 0x4a5bcccd 14-07-09 8:09:49 AM
    vmnetuserif.sys fffff880`04170000 fffff880`0417a000 0x0000a000 0x4cdc4b14 12-11-10 3:59:16 AM
    vstor2-ws60.sys fffff880`0417a000 fffff880`04186000 0x0000c000 0x4c6d93f7 20-08-10 4:28:39 AM
    fastfat.SYS fffff880`04186000 fffff880`041bc000 0x00036000 0x4a5bc1f0 14-07-09 7:23:28 AM
    MpNWMon.sys fffff880`041ed000 fffff880`041fd000 0x00010000 0x4ba463e8 20-03-10 1:58:00 PM
