Solved Backdoor.SdBot.gen and WinAntispyware2008 Problems
Discussion in 'Malware and Virus Removal Archive' started by mc89, 2009/04/08.
  1. 2009/04/10
    Juliet
    Juliet Well-Known Member
    It appears to be an orphaned registry entry.
    Next: Please disable all onboard security programs (all running with back ground protection) as it may hinder the scanner from working.
    This includes Antivirus, Firewall, and any Spyware scanners that run in the background.
    Click on this link Here to see a list of programs that should be disabled.
    The list is not all inclusive. If yours is not listed and you don't know how to disable it, please ask.
    Please open Notepad *Do Not Use Wordpad!* or use any other text editor than Notepad or the script will fail. (Start -> Run -> type notepad in the Open field -> OK) and copy and paste the text present inside the quote box below:
    Save this as "CFScript.txt " including quotes and change the "Save as type" to "All Files" and place it on your desktop.
    Referring to the screenshot above, drag CFScript.txt into ComboFix.exe. ComboFix will now run a scan on your system. It may reboot your system when it finishes. This is normal.
    When finished, it shall produce a log for you, C:\ComboFix.txt. Post that log in your next reply.
    CAUTION: Do not mouse-click ComboFix's window while it is running. That may cause it to stall.
    Note: the above code was created specifically for this user. If you are not this user, do NOT follow these directions as they could damage the workings of your system.
    CF disconnects your machine from the internet. The connection is automatically restored before CF completes its run. If CF runs into difficulty and terminates prematurely, the connection can be manually restored by restarting your machine.
    In your next reply post:
    ComboFix.txt
    New HJT log
    Anti-Virus Still finding the entry?
    How's the computer?
  2. 2009/04/10
    mc89
    mc89 Inactive Thread Starter
    ComboFix Log
    ComboFix 09-04-04.01 - Compaq_Owner 2009-04-10 19:19:27.2 - NTFSx86
    Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.503.206 [GMT -6:00]
    Running from: c:\documents and settings\Compaq_Owner\Desktop\Combo-Fix.exe
    Command switches used :: c:\documents and settings\Compaq_Owner\Desktop\CFScript.txt
    AV: Authentium Antivirus *On-access scanning enabled* (Updated)
    AV: PeoplePC Antivirus *On-access scanning enabled* (Updated)
    FW: PeoplePC Firewall *disabled*
    * Created a new restore point
    - REDUCED FUNCTIONALITY MODE -
    c:\windows\system32\system\
    ((((((((((((((((((((((((( Files Created from 2009-03-11 to 2009-04-11 )))))))))))))))))))))))))))))))
    2009-04-10 19:18 . 2006-03-03 00:42 73,728 --a------ C:\pv.exe
    2009-04-08 23:03 . 2009-04-09 01:47 <DIR> d-------- C:\ComboFix
    2009-04-08 23:03 . 2009-04-08 23:03 389,120 --a------ c:\windows\system32\CF32201.exe
    2009-04-05 01:48 . 2009-04-05 01:48 <DIR> d-------- c:\program files\Malwarebytes' Anti-Malware
    2009-04-05 01:48 . 2009-03-26 16:49 38,496 --a------ c:\windows\system32\drivers\mbamswissarmy.sys
    2009-04-05 01:48 . 2009-03-26 16:49 15,504 --a------ c:\windows\system32\drivers\mbam.sys
    2009-03-31 03:43 . 2009-03-31 03:43 <DIR> d-------- c:\documents and settings\Compaq_Owner\Application Data\Windows Search
    2009-03-31 03:33 . 2009-03-31 03:33 <DIR> d-------- c:\documents and settings\Compaq_Owner\Application Data\Windows Desktop Search
    2009-03-31 03:32 . 2009-03-31 03:32 <DIR> d-------- c:\windows\system32\GroupPolicy
    2009-03-31 03:32 . 2009-03-31 03:32 <DIR> d-------- c:\program files\Windows Desktop Search
    2009-03-31 03:30 . 2008-03-07 11:02 192,000 -----c--- c:\windows\system32\dllcache\offfilt.dll
    2009-03-31 03:30 . 2008-03-07 11:02 98,304 -----c--- c:\windows\system32\dllcache\nlhtml.dll
    2009-03-31 03:30 . 2008-03-07 11:02 29,696 -----c--- c:\windows\system32\dllcache\mimefilt.dll
    2009-03-15 13:31 . 2009-03-16 04:53 <DIR> d-------- c:\program files\Spybot - Search & Destroy
    2009-04-10 10:14 --------- d-----w c:\program files\FXDD - MetaTrader 4
    2009-04-05 10:44 --------- d-----w c:\program files\Smart PC Solutions
    2009-04-05 10:44 --------- d-----w c:\documents and settings\Compaq_Owner\Application Data\Smart PC Solutions
    2009-03-16 23:50 --------- d-----w c:\program files\Max Registry Cleaner
    2009-03-16 10:51 --------- d-----w c:\documents and settings\All Users\Application Data\Spybot - Search & Destroy
    2009-02-23 11:54 --------- d-----w c:\program files\CandleWorks
    2009-02-22 08:48 --------- d-----w c:\program files\LSI SoftModem
    2009-02-21 08:55 --------- d-----w c:\program files\PeoplePC
    2009-02-13 12:59 --------- d-----w c:\program files\Alwil Software
    2008-03-17 22:01 2,045 -c--a-w c:\program files\Deploy.log
    2007-01-22 03:28 28,672 ----a-w c:\documents and settings\Compaq_Owner\atwbxdet.dll
    2004-11-03 22:25 2,238 -c--a-w c:\program files\Common Files\emini.ico
    "MSMSGS "= "c:\program files\Messenger\msmsgs.exe" [2008-04-13 1695232]
    "ctfmon.exe "= "c:\windows\system32\ctfmon.exe" [2008-04-13 15360]
    "hpsysdrv "= "c:\windows\system\hpsysdrv.exe" [1998-05-07 52736]
    "IgfxTray "= "c:\windows\system32\igfxtray.exe" [2004-11-02 155648]
    "HotKeysCmds "= "c:\windows\system32\hkcmd.exe" [2004-11-02 126976]
    "SunJavaUpdateSched "= "c:\program files\Java\jre6\bin\jusched.exe" [2008-12-11 136600]
    "HPDJ Taskbar Utility "= "c:\windows\system32\spool\drivers\w32x86\3\hpztsb10.exe" [2004-03-04 172032]
    "KBD "= "c:\hp\KBD\KBD.EXE" [2005-02-02 61440]
    "Bart Station "= "c:\program files\PeoplePC\ISP7230\BIN\PPCOLink.exe" [2008-05-27 25944]
    "Recguard "= "c:\windows\SMINST\RECGUARD.EXE" [2004-04-14 233472]
    "RCSystemTray "= "c:\program files\Max Registry Cleaner\MaxRCSystemTray.exe" [2009-02-23 925568]
    "RCAutoLiveUpdate "= "c:\program files\Max Registry Cleaner\MaxLURC.exe" [2009-02-23 946048]
    "iTunesHelper "= "c:\program files\iTunes\iTunesHelper.exe" [2004-10-13 278528]
    "PeoplePC Internet Security Pack "= "c:\program files\PeoplePC\PeoplePC Internet Security Pack\bin\ppc_isp2.exe" [2007-10-26 46568]
    "AGRSMMSG "= "AGRSMMSG.exe" [2005-03-04 c:\windows\AGRSMMSG.exe]
    [HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Run]
    "DWQueuedReporting "= "c:\progra~1\COMMON~1\MICROS~1\DW\dwtrig20.exe" [2007-03-13 39264]
    c:\documents and settings\Compaq_Owner\Start Menu\Programs\Startup\
    Microsoft Find Fast.lnk - c:\program files\Microsoft Office\Office\FINDFAST.EXE [1996-12-04 111376]
    Office Startup.lnk - c:\program files\Microsoft Office\Office\OSA.EXE [1996-12-04 51984]
    c:\documents and settings\All Users\Start Menu\Programs\Startup\
    Adobe Reader Speed Launch.lnk - c:\program files\Adobe\Acrobat 7.0\Reader\reader_sl.exe [2005-09-24 29696]
    Compaq Connections.lnk - c:\program files\Compaq Connections\6750491\Program\Compaq Connections.exe [2004-08-09 16423]
    Windows Search.lnk - c:\program files\Windows Desktop Search\WindowsSearch.exe [2008-05-26 123904]
    [hkey_local_machine\software\microsoft\windows\currentversion\explorer\ShellExecuteHooks]
    "{56F9679E-7826-4C84-81F3-532071A8BCC5} "= "c:\program files\Windows Desktop Search\MSNLNamespaceMgr.dll" [2008-05-26 304128]
    [HKEY_LOCAL_MACHINE\system\currentcontrolset\control\session manager]
    BootExecute REG_MULTI_SZ autocheck autochk *\0SsiEfr.e\0lsdelete
    [HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile]
    "EnableFirewall "= 0 (0x0)
    "c:\\Program Files\\Compaq Connections\\6750491\\Program\\Compaq Connections.exe "=
    "c:\\Program Files\\iTunes\\iTunes.exe "=
    "c:\\WINDOWS\\SMINST\\INSTALL_APP.EXE "=
    "c:\\hp\\support\\HPSysInfo.exe "=
    "c:\\Program Files\\CandleWorks\\FXTS2\\FXTSpp.exe "=
    "c:\\Program Files\\Microsoft Office\\Office\\EXCEL.EXE "=
    "c:\\Program Files\\Common Files\\Microsoft Shared\\Works Shared\\wkscal.exe "=
    "c:\\Program Files\\Microsoft Works\\msworks.exe "=
    "c:\\Program Files\\Microsoft Works\\wkssb.exe "=
    "c:\\Program Files\\Online Services\\MSN90\\LaunchMsn.exe "=
    "c:\\Program Files\\Outlook Express\\msimn.exe "=
    "c:\\Program Files\\PC-Doctor for Windows\\Pcdrw32.exe "=
    "c:\\Program Files\\QuickTime\\PictureViewer.exe "=
    "c:\\Program Files\\QuickTime\\QuickTimePlayer.exe "=
    "c:\\Program Files\\QuickTime\\QuickTimeUpdater.exe "=
    "c:\\Program Files\\Outlook Express\\wab.exe "=
    "%windir%\\Network Diagnostic\\xpnetdiag.exe "=
    "c:\\Program Files\\Forexgrail\\ForexGrail.exe "=
    [HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile\GloballyOpenPorts\List]
    "3389:TCP "= 3389:TCP:mad:xpsp2res.dll,-22009
    R0 GRFILTER;CS NDIS Driver;c:\windows\system32\drivers\GRFilter.sys [2006-11-10 22584]
    R2 GRTdiMon;GR TDI Mon;c:\windows\system32\drivers\GRTdiMon.sys [2006-11-10 42040]
    R2 WinDefend;Windows Defender;c:\program files\Windows Defender\MsMpEng.exe [2006-11-03 13592]
    R3 ADSFilter;ADSFilter - (Aluria Filter Driver);c:\windows\system32\drivers\ADSFilter.sys [2006-11-20 56728]
    R3 ADSMonitor;ADSMonitor - (EarthLink Monitor Driver);c:\windows\system32\drivers\ADSMonitor.sys [2006-11-20 35352]
    S3 EarthLinkSafeConnectDriver;EarthLinkSafeConnectDriver;c:\program files\PeoplePC\PeoplePC Internet Security Pack\Sana\Driver\platform_XP\SafeConnectDriver.sys [2007-04-26 151832]
    S3 EarthLinkSafeConnectFilter;EarthLinkSafeConnectFilter;c:\program files\PeoplePC\PeoplePC Internet Security Pack\Sana\Driver\platform_XP\SafeConnectFilter.sys [2007-04-26 31000]
    S3 EarthLinkSafeConnectShim;EarthLinkSafeConnectShim;c:\program files\PeoplePC\PeoplePC Internet Security Pack\Sana\Driver\platform_XP\SafeConnectShim.sys [2006-10-16 38632]
    2009-04-10 c:\windows\Tasks\MP Scheduled Scan.job
    - c:\program files\Windows Defender\MpCmdRun.exe [2006-11-03 20:20]
    uStart Page = hxxp://msn.com/
    uDefault_Search_URL = hxxp://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iesearch&locale=EN_US&c=Q404&bd=presario&pf=desktop
    mStart Page = hxxp://www.google.com
    uInternet Connection Wizard,ShellNext = hxxp://www.symantecstore.com/promo=44984
    uInternet Settings,ProxyServer = http=localhost:8080
    uInternet Settings,ProxyOverride = <local>
    IE: Refresh Pa&ge with Full Quality - c:\program files\PeoplePC Accelerated\pac-page.html
    IE: Refresh Pi&cture with Full Quality - c:\program files\PeoplePC Accelerated\pac-image.html
    TCP: {151DAF64-54CF-4C69-9B0D-B956AA7053C2} = 209.244.0.3 209.244.0.4
    catchme 0.3.1375 W2K/XP/Vista - rootkit/stealth malware detector by Gmer, http://www.gmer.net
    Rootkit scan 2009-04-10 19:20:02
    Windows 5.1.2600 Service Pack 3 NTFS
    scanning hidden processes ...
    scanning hidden files ...
    scan completed successfully
    hidden files: 0
    Completion time: 2009-04-10 19:22:27
    ComboFix-quarantined-files.txt 2009-04-11 01:22:11
    ComboFix2.txt 2009-04-09 07:59:22
    Pre-Run: 69,165,658,112 bytes free
    Post-Run: 69,155,737,600 bytes free
    148 --- E O F --- 2009-03-13 10:56:42
    mc89
    HiJackthis Log
    Scan saved at 7:28:43 PM, on 4/10/2009
    MSIE: Internet Explorer v6.00 SP3 (6.00.2900.5512)
    C:\Program Files\Windows Defender\MsMpEng.exe
    C:\Program Files\LSI SoftModem\agrsmsvc.exe
    C:\WINDOWS\system32\crypserv.exe
    C:\Program Files\PeoplePC\PeoplePC Internet Security Pack\bin\UpdateService.exe
    C:\Program Files\PeoplePC\PeoplePC Internet Security Pack\bin\ProtectionService.exe
    C:\WINDOWS\system32\SearchIndexer.exe
    C:\windows\system\hpsysdrv.exe
    C:\WINDOWS\system32\igfxtray.exe
    C:\WINDOWS\system32\hkcmd.exe
    C:\Program Files\Java\jre6\bin\jusched.exe
    C:\WINDOWS\system32\spool\drivers\w32x86\3\hpztsb10.exe
    C:\HP\KBD\KBD.EXE
    C:\WINDOWS\AGRSMMSG.exe
    C:\Program Files\PeoplePC\ISP7230\Browser\Bartshel.exe
    C:\Program Files\Compaq Connections\6750491\Program\Compaq Connections.exe
    C:\Program Files\Windows Desktop Search\WindowsSearch.exe
    C:\PROGRA~1\PeoplePC\ISP7230\Browser\PPShared.exe
    C:\Program Files\Microsoft Office\Office\OSA.EXE
    C:\Program Files\PeoplePC Accelerated\PeoplePC.exe
    C:\WINDOWS\system32\wscntfy.exe
    C:\WINDOWS\explorer.exe
    C:\WINDOWS\system32\SearchProtocolHost.exe
    C:\Documents and Settings\Compaq_Owner\Desktop\HiJackThis.exe
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iesearch&locale=EN_US&c=Q404&bd=presario&pf=desktop
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://msn.com/
    R1 - HKCU\Software\Microsoft\Internet Connection Wizard,ShellNext = http://www.symantecstore.com/promo=44984
    R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyServer = http=localhost:8080
    O2 - BHO: Accelerator Plugin - {656EC4B7-072B-4698-B504-2A414C1F0037} - C:\PROGRA~1\PEOPLE~1\PRPL_I~1.DLL
    O2 - BHO: Java(tm) Plug-In SSV Helper - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre6\bin\ssv.dll
    O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
    O4 - HKLM\..\Run: [hpsysdrv] c:\windows\system\hpsysdrv.exe
    O4 - HKLM\..\Run: [IgfxTray] C:\WINDOWS\system32\igfxtray.exe
    O4 - HKLM\..\Run: [HotKeysCmds] C:\WINDOWS\system32\hkcmd.exe
    O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre6\bin\jusched.exe "
    O4 - HKLM\..\Run: [HPDJ Taskbar Utility] C:\WINDOWS\system32\spool\drivers\w32x86\3\hpztsb10.exe
    O4 - HKLM\..\Run: [KBD] C:\HP\KBD\KBD.EXE
    O4 - HKLM\..\Run: [Bart Station] C:\Program Files\PeoplePC\ISP7230\BIN\PPCOLink.exe -STATION
    O4 - HKLM\..\Run: [AGRSMMSG] AGRSMMSG.exe
    O4 - HKLM\..\Run: [Recguard] C:\WINDOWS\SMINST\RECGUARD.EXE
    O4 - HKLM\..\Run: [RCSystemTray] C:\Program Files\Max Registry Cleaner\MaxRCSystemTray.exe
    O4 - HKLM\..\Run: [RCAutoLiveUpdate] C:\Program Files\Max Registry Cleaner\MaxLURC.exe -AUTO
    O4 - HKLM\..\Run: [iTunesHelper] "C:\Program Files\iTunes\iTunesHelper.exe "
    O4 - HKLM\..\Run: [PeoplePC Internet Security Pack] "C:\Program Files\PeoplePC\PeoplePC Internet Security Pack\bin\ppc_isp2.exe" /tray
    O4 - HKCU\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background
    O4 - HKUS\S-1-5-18\..\Run: [DWQueuedReporting] "C:\PROGRA~1\COMMON~1\MICROS~1\DW\dwtrig20.exe" -t (User 'SYSTEM')
    O4 - HKUS\.DEFAULT\..\Run: [DWQueuedReporting] "C:\PROGRA~1\COMMON~1\MICROS~1\DW\dwtrig20.exe" -t (User 'Default user')
    O4 - Startup: Microsoft Find Fast.lnk = C:\Program Files\Microsoft Office\Office\FINDFAST.EXE
    O4 - Startup: Office Startup.lnk = C:\Program Files\Microsoft Office\Office\OSA.EXE
    O4 - Global Startup: Adobe Reader Speed Launch.lnk = C:\Program Files\Adobe\Acrobat 7.0\Reader\reader_sl.exe
    O4 - Global Startup: Compaq Connections.lnk = C:\Program Files\Compaq Connections\6750491\Program\Compaq Connections.exe
    O4 - Global Startup: Windows Search.lnk = C:\Program Files\Windows Desktop Search\WindowsSearch.exe
    O8 - Extra context menu item: Refresh Pa&ge with Full Quality - C:\Program Files\PeoplePC Accelerated\pac-page.html
    O8 - Extra context menu item: Refresh Pi&cture with Full Quality - C:\Program Files\PeoplePC Accelerated\pac-image.html
    O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MI1933~1\OFFICE11\REFIEBAR.DLL
    O17 - HKLM\System\CCS\Services\Tcpip\..\{151DAF64-54CF-4C69-9B0D-B956AA7053C2}: NameServer = 209.244.0.3 209.244.0.4
    O17 - HKLM\System\CS1\Services\Tcpip\..\{151DAF64-54CF-4C69-9B0D-B956AA7053C2}: NameServer = 209.244.0.3 209.244.0.4
    O23 - Service: ADSService - Aluria Software, a division of EarthLink, Inc. - C:\Program Files\Common Files\ADS\ADSService.exe
    O23 - Service: Agere Modem Call Progress Audio (AgereModemAudio) - Agere Systems - C:\Program Files\LSI SoftModem\agrsmsvc.exe
    O23 - Service: Crypkey License - Kenonic Controls Ltd. - C:\WINDOWS\SYSTEM32\crypserv.exe
    O23 - Service: DvpApi (dvpapi) - Authentium, Inc. - C:\Program Files\Common Files\Authentium\AntiVirus\dvpapi.exe
    O23 - Service: EarthLinkSafeConnectAgent - Unknown owner - C:\Program Files\PeoplePC\PeoplePC Internet Security Pack\Sana\Bin\SanaAgent.exe
    O23 - Service: ELNK Update Service (ELNKUpdateService) - EarthLink, Inc. - C:\Program Files\PeoplePC\PeoplePC Internet Security Pack\bin\UpdateService.exe
    O23 - Service: iPod Service (iPodService) - Apple Computer, Inc. - C:\Program Files\iPod\bin\iPodService.exe
    O23 - Service: Java Quick Starter (JavaQuickStarterService) - Sun Microsystems, Inc. - C:\Program Files\Java\jre6\bin\jqs.exe
    O23 - Service: ProtectionService - EarthLink, Inc. - C:\Program Files\PeoplePC\PeoplePC Internet Security Pack\bin\ProtectionService.exe
    End of file - 7298 bytes
  5. 2009/04/10
    mc89
    Anti-Virus Software Scan Results
    Start Scan Session: 4/7/2009 4:41:22 PM
    ISP Version: 3.1.1.26819
    Spyware Engine: 2.3.09
    Spyware Definition: 4/3/2009
    Virus Engine: 4.321.35
    Virus Definition: 4/3/2009
    Begin Memory Scan:
    Begin Service Scan:
    Begin Master Boot-Record Scan
    Begin Floppy Boot-Sector Scan
    Begin Registry Scan:
    Begin Cookie Scan:
    Begin File Scan:
    Spyware Scan Detected: WinAntiSpyware
    HKEY_LOCAL_MACHINE\software\antivirus
    End Scan Session: 4/7/2009 4:42:49 PM
    Spyware Quarantined: WinAntiSpyware
    Active Spyware Scan Detected: Backdoor.SdBot.gen [4/7/2009 8:46:40 PM]
    HKEY_CURRENT_USER\software\microsoft\windows\currentversion\run\ctfmon.exe
    Action Taken: Quarantined
    Active Spyware Scan Detected: WinAntiSpyware [4/7/2009 8:50:10 PM]
    Start Scan Session: 4/7/2009 10:20:49 PM
    Begin Memory Scan:
    Begin Service Scan:
    Begin Cookie Scan:
    Begin File Scan:
    End Scan Session: 4/7/2009 10:22:07 PM
    Start Scan Session: 4/8/2009 5:52:27 AM
    Begin Memory Scan:
    Begin Service Scan:
    Begin Cookie Scan:
    Begin File Scan:
    End Scan Session: 4/8/2009 5:54:21 AM
    Start Scan Session: 4/9/2009 2:46:04 AM
    Begin Memory Scan:
    Begin Service Scan:
    Begin Cookie Scan:
    Begin File Scan:
    End Scan Session: 4/9/2009 2:48:26 AM
    Start Scan Session: 4/9/2009 6:10:26 AM
    Begin Memory Scan:
    Begin Service Scan:
    Begin Cookie Scan:
    Begin File Scan:
    End Scan Session: 4/9/2009 6:12:00 AM
    Active Spyware Scan Detected: WinAntiSpyware [4/9/2009 6:38:43 AM]
    Start Scan Session: 4/10/2009 12:55:46 AM
    Begin Memory Scan:
    Begin Service Scan:
    Begin Cookie Scan:
    Begin File Scan:
    End Scan Session: 4/10/2009 1:14:34 AM
    Spyware Quarantined: Backdoor.SdBot.gen
    Start Scan Session: 4/10/2009 1:27:17 AM
    Begin Memory Scan:
    End Scan Session: 4/10/2009 1:27:38 AM
    Start Scan Session: 4/10/2009 4:08:13 AM
    Begin File Scan:
    End Scan Session: 4/10/2009 4:08:21 AM
    Start Scan Session: 4/10/2009 4:17:24 AM
    Begin Memory Scan:
    Begin Service Scan:
    Begin Cookie Scan:
    Begin File Scan:
    End Scan Session: 4/10/2009 4:24:45 AM
    Start Scan Session: 4/10/2009 7:35:19 PM
    Begin Memory Scan:
    Begin Service Scan:
    Begin Cookie Scan:
    Begin File Scan:
    End Scan Session: 4/10/2009 7:37:23 PM
    Start Scan Session: 4/10/2009 7:49:39 PM
    Begin Memory Scan:
    Begin Service Scan:
    Begin Cookie Scan:
    Begin File Scan:
    End Scan Session: 4/10/2009 7:51:20 PM
    Start Scan Session: 4/10/2009 8:05:37 PM
    Begin Memory Scan:
    Begin Service Scan:
    Begin Cookie Scan:
    Begin File Scan:
    End Scan Session: 4/10/2009 8:06:31 PM
    The Anti-Virus caught these 2 again after the script was run. Do you think this malware is programmed into the WindowsXP System Restore feature and regenerates them after reboot?
  6. 2009/04/11
    Juliet
    Thats what I'm starting to think.
    Scans we've run that generally pick up the WinAntiSpyware files and folders aren't finding it.
    Let's run the below online scan.
    Don't freak if you see it found something, kinda expecting it to in quarantine folders.
    Perform an online scan with Panda ActiveScan
    * Click on Scan Your PC Now
    * A "pop up" window will appear, or a new tab will open.
    * Click on Register
    * Choose the option you like most, but we recommend the Free Registration.
    Click on Register [​IMG]
    # Enter your e-mail address, and create a password.
    # Select "I do not want to receive any type of information ". (unless you want to receive such information)
    # Click on Send
    # Confirm registration, and continue by entering your user name and password, then click on Enter
    # Select Full Scan, then Click on Scan Now
    # Wait for the components to be loaded and installed. Don't close this window or go to another page while it is downloading. You can continue using the Internet by opening another window in your browser.
    # If it finds any malware it can disinfect, the Disinfect button will be enabled. Click on Disinfect
    # Please ignore the offer to buy the program. Click on Export To
    * Export the log and save it to your desktop.
    * Please attach the contents of that log in your next reply.
    * Turn off the real time scanner of any existing antivirus program while performing the online scan
    Please post your Panda log.
    How's your computer?
  7. 2009/04/11
    mc89
    Panda Log Results
    ANALYSIS: 2009-04-11 20:01:10
    PROTECTIONS: 2
    MALWARE: 2
    SUSPECTS: 1
    PROTECTIONS
    Description Version Active Updated
    Authentium Antivirus 4.305 Yes Yes
    PeoplePC Antivirus 3.93 Yes Yes
    MALWARE
    Id Description Type Active Severity Disinfectable Disinfected Location
    00132734 adware/24-7-search Adware No 0 Yes No c:\windows\system32\unppc.exe
    02885963 Rootkit/Booto.C Virus/Worm No 0 Yes Yes C:\System Volume Information\_restore{A85EC1FF-58D4-4723-A09B-E5784A945816}\RP3\A0001154.sys
    SUSPECTS
    Sent Location ƒ
    No C:\Program Files\Interbank FX Trader 4\terminal.exe ƒ
    VULNERABILITIES
    Id Severity Description ƒ
  8. 2009/04/11
    mc89
    Active Scan Disinfection
    The report pasted with the text jumbled. I'm not sure if it is going to be clear. The report sent to my Desktop states that the Rootkit/Booto.c was disinfected. The adware/24-7-search was not disiinfected. The Panda program allowed one free disinfection. I sent the suspicious file to their lab.
  9. 2009/04/11
    mc89
    Anti-Virus Scan after Panda
    Begin Memory Scan:
    Begin Service Scan:
    Begin Cookie Scan:
    Begin File Scan:
    Begin Memory Scan:
    Begin Service Scan:
    Begin Cookie Scan:
    Begin File Scan:
    Begin Memory Scan:
    Begin Service Scan:
    Begin Cookie Scan:
    Begin File Scan:
    Begin Memory Scan:
    Begin Service Scan:
    Begin Cookie Scan:
    Begin File Scan:
    Begin Memory Scan:
    Begin Service Scan:
    Begin Cookie Scan:
    Begin File Scan:
    Begin Memory Scan:
    Begin Service Scan:
    Begin Cookie Scan:
    Begin File Scan:
    Begin Memory Scan:
    Begin File Scan:
    Begin Memory Scan:
    Begin Service Scan:
    Begin Cookie Scan:
    Begin File Scan:
    Begin Memory Scan:
    Begin Service Scan:
    Begin Cookie Scan:
    Begin File Scan:
    Begin Memory Scan:
    Begin Service Scan:
    Begin Cookie Scan:
    Begin File Scan:
    Begin Memory Scan:
    Begin Service Scan:
    Begin Cookie Scan:
    Begin File Scan:
    Start Scan Session: 4/10/2009 11:57:47 PM
    Begin File Scan:
    End Scan Session: 4/10/2009 11:58:06 PM
    Start Scan Session: 4/11/2009 12:28:10 AM
    Begin File Scan:
    End Scan Session: 4/11/2009 12:28:14 AM
    Start Scan Session: 4/11/2009 1:24:59 AM
    Begin File Scan:
    End Scan Session: 4/11/2009 1:25:04 AM
    Start Scan Session: 4/11/2009 1:25:23 AM
    Begin File Scan:
    End Scan Session: 4/11/2009 1:25:27 AM
    Start Scan Session: 4/11/2009 1:53:35 AM
    Begin Memory Scan:
    Begin Service Scan:
    Begin Cookie Scan:
    Begin File Scan:
    End Scan Session: 4/11/2009 1:54:55 AM
    Start Scan Session: 4/11/2009 2:46:28 AM
    Begin Memory Scan:
    Begin Service Scan:
    Begin Cookie Scan:
    Begin File Scan:
    End Scan Session: 4/11/2009 2:47:34 AM
    Start Scan Session: 4/11/2009 5:59:16 AM
    Begin Memory Scan:
    Begin Service Scan:
    Begin Cookie Scan:
    Begin File Scan:
    End Scan Session: 4/11/2009 6:01:16 AM
    Start Scan Session: 4/11/2009 8:34:43 PM
    Begin Memory Scan:
    Begin Service Scan:
    Begin Cookie Scan:
    Begin File Scan:
    End Scan Session: 4/11/2009 9:31:26 PM
    Start Scan Session: 4/11/2009 10:18:26 PM
    Begin Memory Scan:
    End Scan Session: 4/11/2009 10:19:05 PM
    My Anti-Virus program caught these 2 again after the Panda scan.
  10. 2009/04/12
    Juliet
    Welcome back
    c:\windows\system32\unPPC.exe - This belongs to PeoplePC, which I assume is your ISP?
    The other item was found in system restore points as expected.
    Don't miss or skip this next step, this will remove malicious files from quarantine and set a clean restore point.
    Go to Start > Run > copy and paste the full text path in the run box
    "%userprofile%\desktop\combofix.exe" /u
    Run your antivirus scan again and let's see if it still finds anything.
  11. 2009/04/14
    mc89
    Loaded new Anti-Virus Software
    On Saturday April 11th, I received an anti-virus software update disk from my ISP. It is supported by Kaspersky. I deleted the previous version and loaded the new one. I ran a scan and it did not find anything. I then ran the script that you sent to me in your last post and I received a message that the file could not be located. I believe everything is now cleared. My computer seems to be working fine now. Are their any other programs you would like for me to run?
  12. 2009/04/14
    Juliet
    Thats good news.
    Couple of folders and files I want you to look for and if found delete.
    C:\Qoobox<--delete
    C:\ComboFix <--delete
    C:\ComboFix.txt <--delete this file.
    You should be good to go now, good job!
    Please take the time to read over a few of my preventive tips.
    Please navigate to Microsoft Windows Updates and download all the "Critical Updates " for Windows.
    Firefox 3
    The award-winning Web browser is now faster, more secure, and fully customizable to your online life. With Firefox 2, added powerful new features that make your online experience even better. It has more features and is a lot more secure than IE. It is a very easy and painless download and install, it will no way interfere with IE, you can use them both.
    *NoScript - Addon for Firefox that stops all scripts from running on websites. Stops malicious software from invading via flash, java, javascript, and many other entry points.
    How to prevent Malware: Created by Miekiemoes
    Here are some additional utilities that will further enhance your safety.
    # http://www.trillian.cc → Trillian or http://www.miranda-im.com → Miranda-IM - These are Malware free Instant Messenger programs which allow you to connect to multiple IM services in one program! (AOL, Yahoo, ICQ, IRC, MSN)
    Read this article 'Safe Computing Practices'.
    So how did I get infected in the first place.
    Secure My Computer: A Layered Approach
    Strong passwords: How to create and use them
    Free Antivirus-AntiSpyware-Firewall Software
    Slow Computer May Not Be Malware Related, Help! My computer is slow!
    http://users.telenet.be/bluepatchy/miekiemoes/slowcomputer.html
    PC Safety and Security--What Do I Need?
    http://www.techsupportforum.com/sec...115548-pc-safety-security-what-do-i-need.html
    Stand Up and Be Counted ---> Malware Complaints <--- where you can make difference!
    This site offers people who have been (or are) victims of malware the opportunity to document their story.
    Extra note:
    Make sure your programs are up to date - because older versions may contain Security Leaks. To find out what programs need to be updated, please run the Secunia Software Inspector Scan. http://secunia.com/software_inspector/
  13. 2009/04/15
    mc89
    Thank You.
    I ran a search and found the Qoobox and ComboFix files and deleted them. The ComboFix.txt did not come up in the search. I checked for critical updates and downloaded them. The scan with Secunia.com was very helpful. It showed that my Java and Adobe need updating, so I will work on those next. The rest of the tips you included are very helpful and informative too.
    Thank you for all of your help with fixing my problems. It is greatly appreciated!
  14. 2009/04/15
    Juliet
    Glad we could help:)
    Safe Surfing
