Automobile Radio Harddrive
Discussion in 'Mobile Devices' started by kiaville, 2013/01/24.
  1. 2013/01/24
    kiaville
    kiaville Well-Known Member Thread Starter
    Don't know where is a good place to post this question but since it is portable I will try here.
    Can you connect a computer (pc) to a car radio through the usb port for the purpose of editing the music on the hard drive?
    **edit to clarify message.**
  2. 2013/01/24
    What does "cp" stand for?
    I can't say that I've seen a car radio with a hard drive. Doesn't music come via the air waves?
    Or maybe I'm so old I should stay out of this thread:eek:
    kiaville
    "cp" is backwards, sorry, should be pc. Many of todays radios have a hard drive so you can download your music from a cd to the hard drive then you do not need the cd to play the music. Mine has a 28 gigabyte hard drive.
  5. 2013/01/24
    I edited your original post...
    And WOW, I am getting old...
    But, have you looked in the manual? I'd think you should at lease be able to get the music off it's hard drive to a USB device and then edit the music and put it back on.
  6. 2013/01/24
    kiaville
    Manuals aren't that specific. The radio menu itself only allows for a complete deletion of the hard drive.
    A 28 gig. will hold approximately 6000 songs.
  7. 2013/01/25
    Assuming that the radio hard drive has a controller aka an external hard drive then the PC should recognise it as an additional drive. The USB port on the radio must be there for a purpose.
    Guess the only way to find out is to try it :)
  8. 2013/01/25
    kiaville
    That is what I was wondering about since it pretty much works that way with cameras, etc. Thanks.
  9. 2013/01/25
    kiaville
    Come on Steve you can't be that old. I'm approaching 70 myself.
  10. 2013/02/11
    If you load the files from a cd onto the hard drive then you should edit the files (tags) prior to putting them onto the cd.
  11. 2013/02/13
    kiaville
    Although that is a true statement it doesn't apply to the question.
