Solved Antivirus7 popups
Discussion in 'Malware and Virus Removal Archive' started by SuenGeoff, 2010/04/12.
  1. 2010/04/19
    Please download OTC to your desktop. It'll remove most tools and logs we used so far. If any tool, file or folder (belonging to the program we have used) hasn't been deleted, please delete it manually.
    • Double-click OTC.exe to run it. (Vista and 7 users, please right click on OTC and select "Run as an Administrator ")
    • Click on the CleanUp! button and follow the prompts.
    • You will be asked to reboot the machine to finish the Cleanup process, choose Yes. If it doesn't ask you to reboot, restart computer manually.
    • After the reboot all the tools we used should be gone.
    • The tool will delete itself once it finishes.
    Please download JavaRa to your desktop and unzip it to its own folder
    • Accept any prompts.
    • Open JavaRa.exe again and select Search For Updates.
    • Select Update Using Sun Java's Website then click Search and click on the Open Webpage button. Download and install the latest Java Runtime Environment (JRE) version for your computer.
    Print this post out, since you won't have an access to it, at some point.
    1. Open HijackThis.
    2. Close all windows, except for HijackThis.
    3. Put checkmarks next to the following HijackThis entries:
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = about:blank
    O2 - BHO: (no name) - {5C255C8A-E604-49b4-9D64-90988571CECB} - (no file)
    O4 - HKLM\..\Run: [SoundMan] SOUNDMAN.EXE
    O4 - HKUS\S-1-5-18\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SYSTEM')
    O4 - HKUS\.DEFAULT\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'Default user')
    4. You should also checkmark following entries (these are unnecessary startups; no actual programs will be removed):
    O4 - HKLM\..\Run: [AntivirusRegistration] C:\Program Files\CA\Etrust Antivirus\Register.exe
    O4 - HKLM\..\Run: [NeroFilterCheck] C:\WINDOWS\system32\NeroCheck.exe
    O4 - HKLM\..\Run: [RealTray] C:\Program Files\Real\RealPlayer\RealPlay.exe SYSTEMBOOTHIDEPLAYER
    O4 - HKLM\..\Run: [SSBkgdUpdate] "C:\Program Files\Common Files\Scansoft Shared\SSBkgdUpdate\SSBkgdupdate.exe" -Embedding -boot
    O4 - HKLM\..\Run: [PaperPort PTD] C:\Program Files\ScanSoft\PaperPort\pptd40nt.exe
    O4 - HKLM\..\Run: [BrMfcWnd] C:\Program Files\Brother\Brmfcmon\BrMfcWnd.exe /AUTORUN
    O4 - HKLM\..\Run: [SetDefPrt] C:\Program Files\Brother\Brmfl06a\BrStDvPt.exe
    O4 - HKLM\..\Run: [ControlCenter3] C:\Program Files\Brother\ControlCenter3\brctrcen.exe /autorun
    O4 - HKLM\..\Run: [IndexSearch] C:\Program Files\ScanSoft\PaperPort\IndexSearch.exe
    O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre6\bin\jusched.exe "
    O4 - HKCU\..\Run: [WMPNSCFG] C:\Program Files\Windows Media Player\WMPNSCFG.exe
    5. Click on Fix checked button.
    6. Restart computer.
    7. Post new HijackThis log.
  2. 2010/04/20
    SuenGeoff
    SuenGeoff Inactive Thread Starter
    Scan saved at 13:11:57, on 20/04/2010
    MSIE: Internet Explorer v8.00 (8.00.6001.18702)
    C:\WINDOWS\system32\Ati2evxx.exe
    C:\Program Files\Home Cinema\PowerCinema\Kernel\TV\CLCapSvc.exe
    C:\Program Files\CyberLink\Shared Files\CLML_NTService\CLMLServer.exe
    C:\Program Files\CyberLink\Shared Files\CLML_NTService\CLMLService.exe
    C:\Program Files\Microsoft LifeCam\MSCamS32.exe
    C:\Program Files\Vodafone\Vodafone Mobile Connect\Bin\VMCService.exe
    C:\Program Files\Home Cinema\PowerCinema\Kernel\TV\CLSched.exe
    C:\WINDOWS\system32\wscntfy.exe
    C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
    C:\WINDOWS\AGRSMMSG.exe
    C:\Program Files\Synaptics\SynTP\SynTPLpr.exe
    C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
    C:\Program Files\Home Cinema\PowerDVD\PDVDServ.exe
    C:\Program Files\Home Cinema\PowerCinema\PCMService.exe
    C:\PROGRA~1\COMMON~1\X10\Common\x10nets.exe
    C:\Program Files\Common Files\AOL\1162400641\ee\AOLHostManager.exe
    C:\WINDOWS\vVX1000.exe
    C:\Program Files\Common Files\AOL\1162400641\ee\AOLServiceHost.exe
    C:\Program Files\Skype\Phone\Skype.exe
    C:\Program Files\Skype\Plugin Manager\skypePM.exe
    C:\PROGRA~1\SYSTRAN\5.0\Personal\SYSTRA~1.EXE
    O1 - Hosts: ÿþ127.0.0.1 localhost
    O1 - Hosts: ::1 localhost
    O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
    O2 - BHO: Windows Live Sign-in Helper - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
    O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - C:\Program Files\Google\Google Toolbar\GoogleToolbar_32.dll
    O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.5.4723.1820\swg.dll
    O3 - Toolbar: SYSTRAN Web Translator 5.0 - {A5899B52-3AF9-4F56-85FE-AD7B3BE8490F} - C:\Program Files\SYSTRAN\5.0\Personal\IEPlugIn.dll
    O3 - Toolbar: Google Toolbar - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - C:\Program Files\Google\Google Toolbar\GoogleToolbar_32.dll
    O4 - HKLM\..\Run: [ATIPTA] C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
    O4 - HKLM\..\Run: [AGRSMMSG] AGRSMMSG.exe
    O4 - HKLM\..\Run: [SynTPLpr] C:\Program Files\Synaptics\SynTP\SynTPLpr.exe
    O4 - HKLM\..\Run: [SynTPEnh] C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
    O4 - HKLM\..\Run: [RemoteControl] "C:\Program Files\Home Cinema\PowerDVD\PDVDServ.exe "
    O4 - HKLM\..\Run: [PCMService] "C:\Program Files\Home Cinema\PowerCinema\PCMService.exe "
    O4 - HKLM\..\Run: [HostManager] C:\Program Files\Common Files\AOL\1162400641\ee\AOLHostManager.exe
    O4 - HKLM\..\Run: [LifeCam] "C:\Program Files\Microsoft LifeCam\LifeExp.exe "
    O4 - HKLM\..\Run: [VX1000] C:\WINDOWS\vVX1000.exe
    O4 - HKLM\..\Run: [MobileConnect] %programfiles%\Vodafone\Vodafone Mobile Connect\Bin\MobileConnect.exe /silent
    O4 - HKCU\..\Run: [swg] "C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe "
    O4 - HKCU\..\Run: [Skype] "C:\Program Files\Skype\Phone\Skype.exe" /nosplash /minimized
    O4 - Startup: Adobe Media Player.lnk = C:\Program Files\Adobe Media Player\Adobe Media Player.exe
    O4 - Global Startup: Adobe Reader Speed Launch.lnk = C:\Program Files\Adobe\Acrobat 7.0\Reader\reader_sl.exe
    O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~3\OFFICE11\EXCEL.EXE/3000
    O8 - Extra context menu item: Google Sidewiki... - res://C:\Program Files\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_96D6FF0C6D236BF8.dll/cmsidewiki.html
    O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~3\OFFICE11\REFIEBAR.DLL
    O9 - Extra button: Real.com - {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - C:\WINDOWS\system32\Shdocvw.dll
    O9 - Extra button: Medion-UK - {3FD66E0B-4A58-4220-9F1C-07C75A078193} - http://www.medion.co.uk (file missing) (HKCU)
    O16 - DPF: {0CCA191D-13A6-4E29-B746-314DEE697D83} (Facebook Photo Uploader 5 Control) - http://upload.facebook.com/controls/2008.10.10_v5.5.8/FacebookPhotoUploader5.cab
    O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} (Windows Genuine Advantage Validation Tool) - http://go.microsoft.com/fwlink/?linkid=39204
    O16 - DPF: {1C3DE665-D259-4C72-9D7D-C51FCB4CCFB9} (Panasonic Network Camera) - http://cannonhall.viewnetcam.com/SysCamInst.cab
    O16 - DPF: {62789780-B744-11D0-986B-00609731A21D} (Autodesk MapGuide ActiveX Control) - http://www.meuparque.parquedasnacoes.pt/inframoura/mgaxctrl.cab
    O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://update.microsoft.com/windowsupdate/v6/V5Controls/en/x86/client/wuweb_site.cab?1133518157244
    O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} (MUWebControl Class) - http://www.update.microsoft.com/mic...ls/en/x86/client/muweb_site.cab?1204469914750
    O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} - http://platformdl.adobe.com/NOS/getPlusPlus/1.6/gp.cab
    O16 - DPF: {FF1CD9A3-00CD-45C1-8182-4EEC229A182D} (Plaxo Auto-Import Utility) - https://www.plaxo.com/activex/plx_upldr-2k-xp.cab
    O18 - Protocol: skype4com - {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - C:\PROGRA~1\COMMON~1\Skype\SKYPE4~1.DLL
    O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - C:\WINDOWS\system32\Ati2evxx.exe
    O23 - Service: CyberLink Background Capture Service (CBCS) (CLCapSvc) - Unknown owner - C:\Program Files\Home Cinema\PowerCinema\Kernel\TV\CLCapSvc.exe
    O23 - Service: CyberLink Task Scheduler (CTS) (CLSched) - Unknown owner - C:\Program Files\Home Cinema\PowerCinema\Kernel\TV\CLSched.exe
    O23 - Service: CyberLink Media Library Service - Cyberlink - C:\Program Files\CyberLink\Shared Files\CLML_NTService\CLMLServer.exe
    O23 - Service: Google Update Service (gupdate) (gupdate) - Google Inc. - C:\Program Files\Google\Update\GoogleUpdate.exe
    O23 - Service: Google Software Updater (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
    O23 - Service: Vodafone Mobile Connect Service (VMCService) - Vodafone - C:\Program Files\Vodafone\Vodafone Mobile Connect\Bin\VMCService.exe
    O23 - Service: X10 Device Network Service (x10nets) - X10 - C:\PROGRA~1\COMMON~1\X10\Common\x10nets.exe
    End of file - 8089 bytes
    Your computer is clean :)
    1. Turn off System Restore:
    - Windows XP:
    1. Click Start.
    5. Click Apply.
    7. Click OK.
    - Windows Vista and 7:
    1. Click Start.
    8. Click OK
    2. Restart computer.
    3. Turn System Restore on.
  5. 2010/04/20
    SuenGeoff
    Thank you for your invaluable help. You asked earlier what happed to my AVG, I had to unistall this was because I had no way of temporarily uninstalling the antivirus application as there were no instructions for doing this despite me searching on the AVG website. The only application I could temp uninstall was Resident Shield, I have fed this back to AVG. I have now reinstalled AVG. This warns me of unsafe websites, do I still need to install WOT and will this download without having to disable AVG?
  6. 2010/04/20
    You're very welcome :)
    If AVG works fine for you, you can skip WOT.
    Stay safe :)
