Solved Another crudware machine
Discussion in 'Malware and Virus Removal Archive' started by elcajongunsfan, 2014/10/26.
  1. 2014/10/28
    elcajongunsfan Lifetime Subscriber
    elcajongunsfan Well-Known Member Thread Starter
    233
    El Cajon California
    Computer Experience:
    Experienced
    Fix result of Farbar Recovery Tool (FRST written by Farbar) (x86) Version: 27-10-2014 01
    Ran by pcuser at 2014-10-28 16:43:22 Run:1
    Running from C:\Documents and Settings\pcuser\Desktop
    Loaded Profile: pcuser (Available profiles: pcuser)
    Boot Mode: Normal
    Content of fixlist:
    HKU\S-1-5-18\...\RunOnce: [SpUninstallDeleteDir] => rmdir /s /q "C:\WINDOWS\system32\config\systemprofile\Application Data\SearchProtect "
    ProxyServer: http=127.0.0.1:13091;
    SearchScopes: HKLM - {246A41D6-8573-909C-93FF-2DADB0FCBF14} URL =
    Toolbar: HKCU - No Name - {472734EA-242A-422B-ADF8-83D1E48CC825} - No File
    Toolbar: HKCU - No Name - {2318C2B1-4965-11D4-9B18-009027A5CD4F} - No File
    S3 catchme; \??\C:\DOCUME~1\pcuser\LOCALS~1\Temp\catchme.sys [X]
    S4 IntelIde; No ImagePath
    C:\Documents and Settings\pcuser\Local Settings\temp\Quarantine.exe
    C:\Documents and Settings\pcuser\Local Settings\temp\sqlite3.dll
    C:\Documents and Settings\TEMP\Local Settings\temp\jre-6u31-windows-i586-iftw-rv.exe
    HKU\S-1-5-18\Software\Microsoft\Windows\CurrentVersion\RunOnce\\SpUninstallDeleteDir => value deleted successfully.
    "C:\WINDOWS\system32\config\systemprofile\Application Data\SearchProtect" => File/Directory not found.
    HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings\\ProxyServer => value deleted successfully.
    "HKLM\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{246A41D6-8573-909C-93FF-2DADB0FCBF14}" => Key deleted successfully.
    "HKCR\CLSID\{246A41D6-8573-909C-93FF-2DADB0FCBF14}" => Key not found.
    HKCU\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser\\{472734EA-242A-422B-ADF8-83D1E48CC825} => value deleted successfully.
    "HKCR\CLSID\{472734EA-242A-422B-ADF8-83D1E48CC825}" => Key not found.
    HKCU\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser\\{2318C2B1-4965-11D4-9B18-009027A5CD4F} => value deleted successfully.
    "HKCR\CLSID\{2318C2B1-4965-11D4-9B18-009027A5CD4F}" => Key not found.
    catchme => Service deleted successfully.
    IntelIde => Service deleted successfully.
    C:\Documents and Settings\pcuser\Local Settings\temp\Quarantine.exe => Moved successfully.
    C:\Documents and Settings\pcuser\Local Settings\temp\sqlite3.dll => Moved successfully.
    C:\Documents and Settings\TEMP\Local Settings\temp\jre-6u31-windows-i586-iftw-rv.exe => Moved successfully.
    ==== End of Fixlog ====
  2. 2014/10/28
    843
    Daly City, CA
    Experienced
    How is computer doing?
    Last scans...
    [​IMG] Download Security Check from here or here and save it to your Desktop.
    • Double-click SecurityCheck.exe
    • Follow the onscreen instructions inside of the black box.
    • A Notepad document should open automatically called checkup.txt; please post the contents of that document.
    NOTE 1. If one of your security applications (e.g., third-party firewall) requests permission to allow DIG.EXE access the Internet, allow it to do so.
    NOTE 2. SecurityCheck may produce some false warning(s), so leave the results reading to me.
    NOTE 3. If you receive UNSUPPORTED OPERATING SYSTEM! ABORTED! message restart computer and Security Check should run
    [​IMG] Please download Farbar Service Scanner (FSS) and run it on the computer with the issue.
    • Make sure the following options are checked:
      • Internet Services
      • Windows Firewall
      • System Restore
      • Security Center
      • Windows Update
      • Windows Defender
      • Other Services
    • Press "Scan ".
    • It will create a log (FSS.txt) in the same directory the tool is run.
    • Please copy and paste the log to your reply.
    [​IMG] Download Temp File Cleaner (TFC)
    Alternate download: http://www.itxassociates.com/OT-Tools/TFC.exe
    • Double click on TFC.exe to run the program.
    • Click on Start button to begin cleaning process.
    • TFC will close all running programs, and it may ask you to restart computer.
    [​IMG] Please run a free online scan with the ESET Online Scanner
    • Disable your antivirus program
    • Internet Explorer users - Click on this link to open ESET OnlineScan.
    • For alternate browsers only: (Microsoft Internet Explorer users can skip these steps)
      • Click on ESET Smart Installer to download the ESET Smart Installer. Save it to your desktop.
      • Double click on the [img=http://www.bleepstatic.com/fhost/uploads/0/esetsmartinstaller_enu.png] icon on your desktop.
    • Check "YES, I accept the Terms of Use. "
    • Click the Start button.
    • Accept any security warnings from your browser.
    • Check "Enable detection of potentially unwanted applications ".
    • Click Advanced settings and make sure all 4 boxes are checkmarked (two of them are already checkmarked by default).
      Do NOT checkmark "Use custom proxy settings "
    • ESET will then download updates for itself, install itself, and begin scanning your computer. Please be patient as this can take some time.
    • When the scan completes, click List Threats
    • Click Export, and save the file to your desktop using a unique name, such as ESETScan. Include the contents of this report in your next reply.
    • Click the Back button.
    • Click the Finish button.
    233
    El Cajon California
    Experienced
    Machine is running very well. The search function is still damaged. But doing some research, it appears to be a Microsoft download called Windows Search 4.0. I was gonna uninstall it and it tossed up a warning saying several other programs would be affected by uninstalling. But, other places say there's no prob dumping it
    Results of screen317's Security Check version 0.99.89
    Windows XP Service Pack 3 x86
    Internet Explorer 8
    ``````````````Antivirus/Firewall Check:``````````````
    Windows Firewall Enabled!
    Microsoft Security Essentials
    Antivirus up to date! (On Access scanning disabled!)
    `````````Anti-malware/Other Utilities Check:`````````
    Spybot - Search & Destroy
    Java 7 Update 71
    Java version out of Date!
    Adobe Flash Player 15.0.0.189
    Adobe Reader XI
    Mozilla Firefox (33.0.1)
    Google Chrome 35.0.1916.153
    Google Chrome 38.0.2125.104
    ````````Process Check: objlist.exe by Laurent````````
    Microsoft Security Essentials MSMpEng.exe
    Microsoft Security Essentials msseces.exe
    `````````````````System Health check`````````````````
    Total Fragmentation on Drive C:: 14% Defragment your hard drive soon! (Do NOT defrag if SSD!)
    ````````````````````End of Log``````````````````````
    Farbar Service Scanner Version: 21-07-2014
    Ran by pcuser (administrator) on 28-10-2014 at 18:14:06
    Running from "C:\Documents and Settings\pcuser\Desktop "
    Microsoft Windows XP Professional Service Pack 3 (X86)
    Boot Mode: Normal
    Internet Services:
    Connection Status:
    Localhost is accessible.
    LAN connected.
    Google IP is accessible.
    Google.com is accessible.
    Yahoo.com is accessible.
    IE proxy is enabled.
    Windows Firewall:
    Firewall Disabled Policy:
    System Restore:
    System Restore Disabled Policy:
    Security Center:
    Windows Update:
    Windows Autoupdate Disabled Policy:
    Other Services:
    File Check:
    C:\WINDOWS\system32\dhcpcsvc.dll => MD5 is legit
    C:\WINDOWS\system32\Drivers\afd.sys => MD5 is legit
    C:\WINDOWS\system32\Drivers\netbt.sys => MD5 is legit
    C:\WINDOWS\system32\Drivers\tcpip.sys => MD5 is legit
    C:\WINDOWS\system32\Drivers\ipsec.sys => MD5 is legit
    C:\WINDOWS\system32\dnsrslvr.dll => MD5 is legit
    C:\WINDOWS\system32\ipnathlp.dll => MD5 is legit
    C:\WINDOWS\system32\netman.dll => MD5 is legit
    C:\WINDOWS\system32\wbem\WMIsvc.dll => MD5 is legit
    C:\WINDOWS\system32\srsvc.dll => MD5 is legit
    C:\WINDOWS\system32\Drivers\sr.sys => MD5 is legit
    C:\WINDOWS\system32\wscsvc.dll => MD5 is legit
    C:\WINDOWS\system32\wuauserv.dll => MD5 is legit
    C:\WINDOWS\system32\qmgr.dll => MD5 is legit
    C:\WINDOWS\system32\es.dll => MD5 is legit
    C:\WINDOWS\system32\cryptsvc.dll => MD5 is legit
    C:\WINDOWS\system32\svchost.exe => MD5 is legit
    C:\WINDOWS\system32\rpcss.dll => MD5 is legit
    C:\WINDOWS\system32\services.exe => MD5 is legit
    Extra List:
    Gpc(3) IPSec(5) NetBT(6) NwlnkIpx(9) NwlnkNb(10) PSched(7) Tcpip(4)
    0x0B00000005000000010000000200000003000000040000000C0000000B0000000600000007000000090000000A000000
    IpSec Tag value is correct.
    **** End of log ****
    C:\AdwCleaner\Quarantine\C\Documents and Settings\All Users\Application Data\apn\APN-Stub\W3IV6-G\APNIC.7z.vir Win32/Bundled.Toolbar.Ask.B potentially unsafe application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Documents and Settings\All Users\Application Data\apn\APN-Stub\W3IV6-G\APNIC.dll.vir Win32/Bundled.Toolbar.Ask.B potentially unsafe application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Documents and Settings\pcuser\Application Data\eDownload\iSafe_setup.exe.vir a variant of Win32/ELEX.Q potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Documents and Settings\pcuser\Local Settings\Application Data\CRE\edfllcfghbogdahicgpcmnmkgpcmdjeo.crx.vir a variant of Win32/Toolbar.Conduit.AH potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Documents and Settings\pcuser\Local Settings\Application Data\CRE\nemfjadlboooiffmcelkafilagddogim.crx.vir a variant of Win32/Toolbar.Conduit.AH potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Documents and Settings\pcuser\Local Settings\Application Data\FilesFrog Update Checker\update_checker.exe.vir Win32/Somoto.D potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Documents and Settings\pcuser\Local Settings\Application Data\Google\Chrome\User Data\Default\Extensions\edfllcfghbogdahicgpcmnmkgpcmdjeo\10.31.4.510_0\APISupport\APISupport.dll.vir a variant of Win32/Conduit.SearchProtect.P potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Documents and Settings\pcuser\Local Settings\Application Data\Google\Chrome\User Data\Default\Extensions\edfllcfghbogdahicgpcmnmkgpcmdjeo\10.31.4.510_0\nativeMessaging\TBMessagingHost.exe.vir a variant of Win32/Toolbar.Conduit.AH potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Documents and Settings\pcuser\Local Settings\Application Data\Google\Chrome\User Data\Default\Extensions\edfllcfghbogdahicgpcmnmkgpcmdjeo\10.31.4.510_0\plugins\ChromeApiPlugin.dll.vir a variant of Win32/Conduit.SearchProtect.N potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Documents and Settings\pcuser\Local Settings\Application Data\Google\Chrome\User Data\Default\Extensions\lgonpmchaeokedifbjenbcnjcdefdceg\1.26.62_0\extensionData\plugins\91.js.vir JS/Toolbar.Crossrider.B potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Documents and Settings\pcuser\Local Settings\Application Data\Google\Chrome\User Data\Default\Extensions\nemfjadlboooiffmcelkafilagddogim\10.31.4.510_0\APISupport\APISupport.dll.vir a variant of Win32/Conduit.SearchProtect.P potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Documents and Settings\pcuser\Local Settings\Application Data\Google\Chrome\User Data\Default\Extensions\nemfjadlboooiffmcelkafilagddogim\10.31.4.510_0\nativeMessaging\TBMessagingHost.exe.vir a variant of Win32/Toolbar.Conduit.AH potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Documents and Settings\pcuser\Local Settings\Application Data\Google\Chrome\User Data\Default\Extensions\nemfjadlboooiffmcelkafilagddogim\10.31.4.510_0\plugins\ChromeApiPlugin.dll.vir a variant of Win32/Conduit.SearchProtect.N potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Conduit\Community Alerts\Alert.dll.vir Win32/Toolbar.Conduit.Y potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Conduit\CT3282812\plugins\TBVerifier.dll.vir Win32/Toolbar.Conduit.AC potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Conduit\CT3289663\plugins\TBVerifier.dll.vir Win32/Toolbar.Conduit.AC potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\PC Health Kit\PCHealthKit.exe.vir a variant of Win32/SpeedingUpMyPC.F application cleaned by deleting - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\PC Health Kit\PCHKSmartScan.exe.vir a variant of Win32/Adware.SpeedingUpMyPC.C application cleaned by deleting - quarantined
    C:\AdwCleaner\Quarantine\C\windows\system32\roboot.exe.vir a variant of Win32/Systweak.A potentially unwanted application deleted - quarantined
    C:\Documents and Settings\pcuser\Application Data\VisicomToolBar\GamesAGoGo_toolbar_3.0.0.2.exe a variant of Win32/Toolbar.Visicom.A potentially unwanted application deleted - quarantined
    C:\Documents and Settings\pcuser\My Documents\Downloads\cdbxp_setup_4.4.1.3341.exe Win32/OpenCandy potentially unsafe application deleted - quarantined
    C:\Documents and Settings\pcuser\My Documents\Downloads\Chrome (1).exe a variant of Win32/AirAdInstaller.A potentially unwanted application deleted - quarantined
    C:\Documents and Settings\pcuser\My Documents\Downloads\iSafe (1).exe a variant of Win32/ELEX.C potentially unwanted application deleted - quarantined
    C:\Documents and Settings\pcuser\My Documents\Downloads\iSafe (2).exe a variant of Win32/ELEX.C potentially unwanted application deleted - quarantined
    C:\Documents and Settings\pcuser\My Documents\Downloads\iSafe.exe a variant of Win32/ELEX.C potentially unwanted application deleted - quarantined
    C:\Documents and Settings\pcuser\My Documents\Downloads\speedupmypc (1).exe Win32/SpeedUpMyPC potentially unwanted application deleted - quarantined
    C:\Documents and Settings\pcuser\My Documents\Downloads\speedupmypc.exe Win32/SpeedUpMyPC potentially unwanted application deleted - quarantined
    C:\Program Files\FLV Player\Uninstall\__Uninstall_.exe a variant of Win32/InstallCore.BY potentially unwanted application deleted - quarantined
    C:\System Volume Information\_restore{298B278E-AC83-4387-8D34-EE0A30F3019B}\RP756\A0209219.exe a variant of Win32/InstallIQ.C potentially unwanted application deleted - quarantined
    C:\System Volume Information\_restore{298B278E-AC83-4387-8D34-EE0A30F3019B}\RP757\A0209253.dll Win32/Bundled.Toolbar.Ask.B potentially unsafe application deleted - quarantined
    C:\System Volume Information\_restore{298B278E-AC83-4387-8D34-EE0A30F3019B}\RP757\A0209255.dll Win32/Toolbar.Conduit.AC potentially unwanted application deleted - quarantined
    C:\System Volume Information\_restore{298B278E-AC83-4387-8D34-EE0A30F3019B}\RP757\A0209256.dll Win32/Toolbar.Conduit.AC potentially unwanted application deleted - quarantined
    C:\System Volume Information\_restore{298B278E-AC83-4387-8D34-EE0A30F3019B}\RP757\A0209257.dll Win32/Toolbar.Conduit.Y potentially unwanted application deleted - quarantined
    C:\System Volume Information\_restore{298B278E-AC83-4387-8D34-EE0A30F3019B}\RP757\A0209263.exe a variant of Win32/ELEX.Q potentially unwanted application deleted - quarantined
    C:\System Volume Information\_restore{298B278E-AC83-4387-8D34-EE0A30F3019B}\RP757\A0209281.exe Win32/Somoto.D potentially unwanted application deleted - quarantined
    C:\System Volume Information\_restore{298B278E-AC83-4387-8D34-EE0A30F3019B}\RP757\A0209323.exe a variant of Win32/SpeedingUpMyPC.F application cleaned by deleting - quarantined
    C:\System Volume Information\_restore{298B278E-AC83-4387-8D34-EE0A30F3019B}\RP757\A0209328.exe a variant of Win32/Adware.SpeedingUpMyPC.C application cleaned by deleting - quarantined
    C:\System Volume Information\_restore{298B278E-AC83-4387-8D34-EE0A30F3019B}\RP757\A0209337.dll a variant of Win32/Conduit.SearchProtect.N potentially unwanted application deleted - quarantined
    C:\System Volume Information\_restore{298B278E-AC83-4387-8D34-EE0A30F3019B}\RP757\A0209338.exe a variant of Win32/Toolbar.Conduit.AH potentially unwanted application deleted - quarantined
    C:\System Volume Information\_restore{298B278E-AC83-4387-8D34-EE0A30F3019B}\RP757\A0209339.dll a variant of Win32/Conduit.SearchProtect.P potentially unwanted application deleted - quarantined
    C:\System Volume Information\_restore{298B278E-AC83-4387-8D34-EE0A30F3019B}\RP757\A0209342.dll a variant of Win32/Conduit.SearchProtect.N potentially unwanted application deleted - quarantined
    C:\System Volume Information\_restore{298B278E-AC83-4387-8D34-EE0A30F3019B}\RP757\A0209343.exe a variant of Win32/Toolbar.Conduit.AH potentially unwanted application deleted - quarantined
    C:\System Volume Information\_restore{298B278E-AC83-4387-8D34-EE0A30F3019B}\RP757\A0209344.dll a variant of Win32/Conduit.SearchProtect.P potentially unwanted application deleted - quarantined
    C:\System Volume Information\_restore{298B278E-AC83-4387-8D34-EE0A30F3019B}\RP757\A0209346.exe a variant of Win32/Systweak.A potentially unwanted application deleted - quarantined
  5. 2014/10/28
    843
    Daly City, CA
    Experienced
    [​IMG] What is exact issue with search?
    [​IMG] Are you required to use proxies?
    [​IMG] Update your Java version here: http://www.java.com/en/download/manual.jsp
    Alternate download: http://www.filehippo.com/search?q=java
    Note 2: If you're running 64-bit system make sure you install BOTH, 32-bit and 64-bit Java.
    Note 3: The Java Quick Starter (JQS.exe) adds a service to improve the initial startup time of Java applets and applications. If you don't want to run another extra service, go to Start > Control Panel > Java > Advanced > Miscellaneous and uncheck the box for Java Quick Starter. Click OK and restart your computer.
  6. 2014/10/28
    233
    El Cajon California
    Experienced
    The search function is damaged. The search window comes up with missing areas. No on the proxy. Let me see if I can create an image
  7. 2014/10/28
    233
    El Cajon California
    Experienced
    843
    Daly City, CA
    Experienced
  9. 2014/10/28
    233
    El Cajon California
    Experienced
    Done.
  10. 2014/10/28
    843
    Daly City, CA
    Experienced
    Download Windows Repair (All in One) from this site
    Install the program then run it.
    NOTE 1. In Windows Vista, 7 and 8 right click on the program, click "Run As Administrator ".
    NOTE 2. Disable your antivirus program before running Windows Repair.
    Go to Step 3 and click on Check button next to 1. See If Check Disk Is Needed.
    If the tool that the Check Disk is needed click on Do It button next to 2. Check Disk.
    In that case make sure you restart computer.
    Once the above is done go to Step 4 and allow it to run System File Check by clicking on Do It button:
    Go to Step 5 and under "System Restore" click on Create button:
    Go to Repairs tab and click Open Repairs button.
    In next window....
    Leave all checkmarks as they're.
    Click on Start Repairs button.
    Post Windows Repair log which is located in the following folder:
    64-bit systems - C:\Program Files (x86)\Tweaking.com\Windows Repair (All in One)\Logs
    32-bit systems - C:\Program Files\Tweaking.com\Windows Repair (All in One)\Logs
  11. 2014/10/28
    233
    El Cajon California
    Experienced
    Microsoft Windows XP [Version 5.1.2600]
    (C) Copyright 1985-2001 Microsoft Corp.
    C:\Documents and Settings\pcuser\Desktop>CD /D C:\
    C:\>chkdsk C:
    The type of the file system is NTFS.
    WARNING! F parameter not specified.
    Running CHKDSK in read-only mode.
    CHKDSK is verifying files (stage 1 of 3)...
    0 percent completed.
    1 percent completed.
    2 percent completed.
    3 percent completed.
    4 percent completed.
    5 percent completed.
    6 percent completed.
    7 percent completed.
    8 percent completed.
    9 percent completed.
    10 percent completed.
    11 percent completed.
    12 percent completed.
    13 percent completed.
    14 percent completed.
    15 percent completed.
    16 percent completed.
    17 percent completed.
    18 percent completed.
    19 percent completed.
    20 percent completed.
    21 percent completed.
    22 percent completed.
    23 percent completed.
    24 percent completed.
    25 percent completed.
    26 percent completed.
    27 percent completed.
    28 percent completed.
    29 percent completed.
    30 percent completed.
    31 percent completed.
    32 percent completed.
    33 percent completed.
    34 percent completed.
    35 percent completed.
    36 percent completed.
    37 percent completed.
    38 percent completed.
    39 percent completed.
    40 percent completed.
    41 percent completed.
    42 percent completed.
    43 percent completed.
    44 percent completed.
    45 percent completed.
    46 percent completed.
    47 percent completed.
    48 percent completed.
    49 percent completed.
    50 percent completed.
    51 percent completed.
    52 percent completed.
    53 percent completed.
    54 percent completed.
    55 percent completed.
    56 percent completed.
    57 percent completed.
    58 percent completed.
    59 percent completed.
    60 percent completed.
    61 percent completed.
    62 percent completed.
    63 percent completed.
    64 percent completed.
    65 percent completed.
    66 percent completed.
    67 percent completed.
    68 percent completed.
    69 percent completed.
    70 percent completed.
    71 percent completed.
    72 percent completed.
    73 percent completed.
    74 percent completed.
    75 percent completed.
    76 percent completed.
    77 percent completed.
    78 percent completed.
    79 percent completed.
    80 percent completed.
    81 percent completed.
    82 percent completed.
    83 percent completed.
    84 percent completed.
    85 percent completed.
    86 percent completed.
    87 percent completed.
    88 percent completed.
    89 percent completed.
    90 percent completed.
    91 percent completed.
    92 percent completed.
    93 percent completed.
    94 percent completed.
    95 percent completed.
    96 percent completed.
    97 percent completed.
    98 percent completed.
    99 percent completed.
    100 percent completed.
    File verification completed.
    CHKDSK is verifying indexes (stage 2 of 3)...
    Index verification completed.
    CHKDSK is verifying security descriptors (stage 3 of 3)...
    Security descriptor verification completed.
    CHKDSK is verifying Usn Journal...
    Usn Journal verification completed.
    Correcting errors in the master file table's (MFT) BITMAP attribute.
    Correcting errors in the Volume Bitmap.
    Windows found problems with the file system.
    Run CHKDSK with the /F (fix) option to correct these.
    78116030 KB total disk space.
    31556424 KB in 225959 files.
    112380 KB in 15632 indexes.
    0 KB in bad sectors.
    402686 KB in use by the system.
    65536 KB occupied by the log file.
    46044540 KB available on disk.
    4096 bytes in each allocation unit.
    19529007 total allocation units on disk.
    11511135 allocation units available on disk.
    C:\>
    Tweaking.com - Windows Repair v2.10.0
    System Variables
    OS: Microsoft Windows XP
    OS Architecture: 32-bit
    OS Version: 5.1.2600
    OS Service Pack: Service Pack 3
    Computer Name: 745REGMSO-07
    Windows Drive: C:\
    Windows Path: C:\WINDOWS
    Program Files: C:\Program Files
    Current Profile: C:\Documents and Settings\pcuser
    Current Profile SID: S-1-5-21-1060284298-1409082233-839522115-1003
    Current Profile Classes: S-1-5-21-1060284298-1409082233-839522115-1003_Classes
    Profiles Location: C:\Documents and Settings
    Profiles Location 2: C:\WINDOWS\ServiceProfiles
    Local Settings AppData: C:\Documents and Settings\pcuser\Local Settings\Application Data
    System Information
    System Up Time: 0 Days 00:12:19
    Process Count: 32
    Commit Total: 268.16 MB
    Commit Limit: 3.84 GB
    Commit Peak: 275.04 MB
    Handle Count: 8155
    Kernel Total: 71.25 MB
    Kernel Paged: 58.20 MB
    Kernel Non Paged: 13.04 MB
    System Cache: 1.57 GB
    Thread Count: 483
    Memory Before Cleaning with CleanMem
    Memory Total: 1.99 GB
    Memory Used: 458.06 MB(22.481%)
    Memory Avail.: 1.54 GB
    Cleaning Memory Before Starting Repairs...
    Memory After Cleaning with CleanMem
    Memory Used: 337.79 MB(16.5785%)
    Memory Avail.: 1.66 GB
    Starting Repairs...
    Started at (10/28/2014 8:42:07 PM)
    Setting Any Missing 'InstallDate' From Uninstall Sections Before Running Repair...
    Total Missing 'InstallDate' Fixed: 142
    01 - Reset Registry Permissions 01/03
    HKEY_CURRENT_USER & Sub Keys
    Start (10/28/2014 8:42:11 PM)
    Running Repair Under Current User Account
    Done (10/28/2014 8:42:23 PM)
    01 - Reset Registry Permissions 02/03
    HKEY_LOCAL_MACHINE & Sub Keys
    Start (10/28/2014 8:42:23 PM)
    Running Repair Under System Account
    Done (10/28/2014 8:46:01 PM)
    01 - Reset Registry Permissions 03/03
    HKEY_CLASSES_ROOT & Sub Keys
    Start (10/28/2014 8:46:01 PM)
    Done (10/28/2014 8:48:01 PM)
    03 - Reset Service Permissions
    Start (10/28/2014 8:48:01 PM)
    Done (10/28/2014 8:48:34 PM)
    04 - Register System Files
    Start (10/28/2014 8:48:34 PM)
    Done (10/28/2014 8:50:23 PM)
    05 - Repair WMI
    Start (10/28/2014 8:50:24 PM)
    Starting Security Center So We Can Export The Security Info.
    Exporting Antivirus Info...
    Microsoft Security Essentials Exported.
    Exporting 3rd Party Firewall Info...
    No 3rd Party Firewall Products Reported.
    Done (10/28/2014 8:56:49 PM)
    06 - Repair Windows Firewall
    Start (10/28/2014 8:56:49 PM)
    Done (10/28/2014 8:57:05 PM)
    07 - Repair Internet Explorer
    Start (10/28/2014 8:57:05 PM)
    Done (10/28/2014 8:59:20 PM)
    08 - Repair MDAC/MS Jet
    Start (10/28/2014 8:59:20 PM)
    Done (10/28/2014 8:59:33 PM)
    09 - Repair Hosts File
    Start (10/28/2014 8:59:33 PM)
    Done (10/28/2014 8:59:35 PM)
    10 - Remove Policies Set By Infections
    Start (10/28/2014 8:59:35 PM)
    Done (10/28/2014 8:59:37 PM)
    11 - Repair Start Menu Icons Removed By Infections
    Start (10/28/2014 8:59:37 PM)
    Done (10/28/2014 8:59:39 PM)
    12 - Repair Icons
    Start (10/28/2014 8:59:39 PM)
    Done (10/28/2014 8:59:40 PM)
    13 - Repair Winsock & DNS Cache
    Start (10/28/2014 8:59:40 PM)
    Done (10/28/2014 8:59:53 PM)
    15 - Repair Proxy Settings
    Start (10/28/2014 8:59:53 PM)
    Done (10/28/2014 8:59:56 PM)
    17 - Repair Windows Updates
    Start (10/28/2014 8:59:56 PM)
    Setting Windows Updates Files That Are In Use To Be Removed At Next Boot.
    Done (10/28/2014 9:00:30 PM)
    18 - Repair CD/DVD Missing/Not Working
    Start (10/28/2014 9:00:30 PM)
    iTunes not found, not applying UpperFilters iTunes Reg Key
    19 - Repair Volume Shadow Copy Service
    Done (10/28/2014 9:01:08 PM)
    21 - Repair MSI (Windows Installer)
    Start (10/28/2014 9:01:08 PM)
    Done (10/28/2014 9:01:17 PM)
    23.01 - Repair bat Association
    Start (10/28/2014 9:01:17 PM)
    Done (10/28/2014 9:01:20 PM)
    23.02 - Repair cmd Association
    Start (10/28/2014 9:01:20 PM)
    Done (10/28/2014 9:01:22 PM)
    23.03 - Repair com Association
    Start (10/28/2014 9:01:22 PM)
    Done (10/28/2014 9:01:24 PM)
    23.04 - Repair Directory Association
    Start (10/28/2014 9:01:24 PM)
    Done (10/28/2014 9:01:26 PM)
    23.05 - Repair Drive Association
    Start (10/28/2014 9:01:26 PM)
    Done (10/28/2014 9:01:28 PM)
    23.06 - Repair exe Association
    Start (10/28/2014 9:01:28 PM)
    Done (10/28/2014 9:01:31 PM)
    23.07 - Repair Folder Association
    Start (10/28/2014 9:01:31 PM)
    Done (10/28/2014 9:01:33 PM)
    23.08 - Repair inf Association
    Start (10/28/2014 9:01:33 PM)
    Done (10/28/2014 9:01:36 PM)
    23.09 - Repair lnk (Shortcuts) Association
    Start (10/28/2014 9:01:36 PM)
    Done (10/28/2014 9:01:38 PM)
    23.10 - Repair msc Association
    Start (10/28/2014 9:01:38 PM)
    Done (10/28/2014 9:01:40 PM)
    23.11 - Repair reg Association
    Start (10/28/2014 9:01:40 PM)
    Done (10/28/2014 9:01:43 PM)
    23.12 - Repair scr Association
    Start (10/28/2014 9:01:43 PM)
    Done (10/28/2014 9:01:45 PM)
    24 - Repair Windows Safe Mode
    Start (10/28/2014 9:01:45 PM)
    Done (10/28/2014 9:01:47 PM)
    25 - Repair Print Spooler
    Start (10/28/2014 9:01:47 PM)
    Done (10/28/2014 9:02:04 PM)
    26 - Restore Important Windows Services
    Start (10/28/2014 9:02:04 PM)
    Done (10/28/2014 9:02:14 PM)
    27 - Set Windows Services To Default Startup
    Start (10/28/2014 9:02:14 PM)
    Done (10/28/2014 9:02:26 PM)
    Skipping Repair.
    Repair is for Windows v6.2 (Windows 8 & Newer) or higher.
    Current version: 5.1
    Skipping Repair.
    Skipping Repair.
    31 - Repair Windows 'New' Submenu
    Start (10/28/2014 9:02:26 PM)
    Done (10/28/2014 9:02:29 PM)
    Cleaning up empty logs...
    All Selected Repairs Done.
    Done at (10/28/2014 9:02:29 PM)
    Total Repair Time: 00:20:23
    ...YOU MUST RESTART YOUR SYSTEM...
  12. 2014/10/28
    843
    Daly City, CA
    Experienced
    How is search thingy?
  13. 2014/10/28
    233
    El Cajon California
    Experienced
    still is the same.. Maybe removing windows search 4.0 will revert back to the original
  14. 2014/10/28
    843
    Daly City, CA
    Experienced
    I suggest you create new topic about this issue in Windows forum.
    Here...
    Your computer is clean [​IMG]
    1. This step will remove all cleaning tools we used, it'll reset restore points (so you won't get reinfected by accidentally using some older restore point) and it'll make some other minor adjustments...
    This is a very crucial step so make sure you don't skip it.
    Download [​IMG]DelFix by Xplode to your desktop. Delfix will delete all the used tools and logfiles.
    Double-click Delfix.exe to start the tool.
    Make sure the following items are checked:
    • Activate UAC (optional; some users prefer to keep it off)
    • Remove disinfection tools
    • Create registry backup
    • Purge System Restore
    • Reset system settings
    Now click "Run" and wait patiently.
    Once finished a logfile will be created. You don't have to attach it to your next reply.
    2. Make sure Windows Updates are current.
    3. If any trojans, rootkits or bootkits were listed among your infection(s), make sure, you change all of your on-line important passwords (bank account(s), secured web sites, etc.) immediately!
    4. Check if your browser plugins are up to date.
    Firefox - https://www.mozilla.org/en-US/plugincheck/
    other browsers: https://browsercheck.qualys.com/ (click on "Launch a quick scan now" link)
    7. Run Temporary File Cleaner (TFC), AdwCleaner and Junkware Removal Tool (JRT) weekly (you need to redownload these tools since they were removed by DelFix).
    10. When installing\updating ANY program, make sure you always select "Custom " installation, so you can UN-check any possible "drive-by-install" (foistware), like toolbars etc., which may try to install along with the legitimate program. Do NOT click "Next" button without looking at any given page.
    11. Read:
    How did I get infected?, With steps so it does not happen again!: http://www.bleepingcomputer.com/forums/topic2520.html
    Simple and easy ways to keep your computer safe and secure on the Internet: http://www.bleepingcomputer.com/tutorials/keep-your-computer-safe-online/
    About those Toolbars and Add-ons - Potentially Unwanted Programs (PUPs) which change your browser settings: http://www.bleepingcomputer.com/for...curity-questions-best-practices/#entry3187642
    12. Please, let me know, how your computer is doing.
  15. 2014/10/28
    233
    El Cajon California
    Experienced
    Machine is running well. I do not think I wil pursue the search issue. The owner is happy to get her machine back.. Looking at various Microsoft web forums there could be some fixes such as registering .dlls again. If she wants that, then.... I just wanted to help get the malware cleaned off.
    Again thanks. And just a comment, the tools you run are fairly predictable, but knowing which objects to apply to the various fix files was fascinating and I'll assume it took years to acquire that knowledge..
    Thanks again
  16. 2014/10/28
    843
    Daly City, CA
    Experienced
    Way to go!! [​IMG]
    Good luck and stay safe :)
