Solved Alureon virus (?) major problems
Discussion in 'Malware and Virus Removal Archive' started by Milkman23, 2011/06/30.
  1. 2011/06/30
    Milkman23
    Milkman23 Inactive Thread Starter
    [Resolved] Alureon virus (?) major problems
    Hello,
    I am having major problems with a suspect virus that will not go away and is slowly taking over my computer. microsoft sec. essentials detects it immidiately after any startup but can only quarrantine it not remove it and it after only about 5 minutes creates its own facade or overlay on my screen is the only way i can explain it (it tries to copy the normal os but the start button goes from green and oval to grey and square) I have mwbam installed and ms sec ess but to no avail. i have downloaded all of the 4 programs and ran the diagnostics that you have requested and here they are:
    1.) Malwarebytes' Anti-Malware 1.51.0.1200
    www.malwarebytes.org
    Database version: 6950
    Windows 5.1.2600 Service Pack 2
    Internet Explorer 8.0.6001.18702
    6/27/2011 12:47:08 PM
    mbam-log-2011-06-27 (12-47-08).txt
    Scan type: Quick scan
    Objects scanned: 244376
    Time elapsed: 27 minute(s), 14 second(s)
    Memory Processes Infected: 0
    Memory Modules Infected: 0
    Registry Keys Infected: 0
    Registry Values Infected: 0
    Folders Infected: 0
    Files Infected: 0
    (No malicious items detected)
    Folders Infected:
    Files Infected:
    2.)
    GMER 1.0.15.15640 - http://www.gmer.net
    Rootkit scan 2011-06-25 20:53:30
    Windows 5.1.2600 Service Pack 2 Harddisk0\DR0 -> \Device\Ide\IdePort0 WDC_WD1600AVJB-63J5A0 rev.01.03E01
    Running: rxuy0xvn.exe; Driver: C:\DOCUME~1\James\LOCALS~1\Temp\awryapog.sys
    ---- User code sections - GMER 1.0.15 ----
    .text C:\WINDOWS\Explorer.EXE[132] ntdll.dll!NtProtectVirtualMemory 7C90D6EE 5 Bytes JMP 00CD000A
    .text C:\WINDOWS\Explorer.EXE[132] ntdll.dll!NtWriteVirtualMemory 7C90DFAE 5 Bytes JMP 00CE000A
    .text C:\WINDOWS\Explorer.EXE[132] ntdll.dll!KiUserExceptionDispatcher 7C90E47C 5 Bytes JMP 00C7000C
    .text C:\Program Files\Internet Explorer\iexplore.exe[584] ntdll.dll!NtProtectVirtualMemory 7C90D6EE 5 Bytes JMP 00E5000A
    .text C:\Program Files\Internet Explorer\iexplore.exe[584] ntdll.dll!NtWriteVirtualMemory 7C90DFAE 5 Bytes JMP 00E6000A
    .text C:\Program Files\Internet Explorer\iexplore.exe[584] ntdll.dll!KiUserExceptionDispatcher 7C90E47C 5 Bytes JMP 00B3000C
    .text C:\Program Files\Internet Explorer\iexplore.exe[584] USER32.dll!UnhookWindowsHookEx 7E41F21E 5 Bytes JMP 3E25467C C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[584] USER32.dll!CallNextHookEx 7E41F85B 5 Bytes JMP 3E2DD0ED C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[584] USER32.dll!CreateWindowExW 7E41FC25 5 Bytes JMP 3E2EDB1C C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[584] USER32.dll!DialogBoxParamW 7E42555F 5 Bytes JMP 3E2154C5 C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[584] USER32.dll!SetWindowsHookExW 7E42DDB5 5 Bytes JMP 3E2E9AC9 C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[584] USER32.dll!DialogBoxIndirectParamW 7E432032 5 Bytes JMP 3E3E480F C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[584] USER32.dll!MessageBoxIndirectA 7E43A04A 5 Bytes JMP 3E3E4741 C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[584] USER32.dll!DialogBoxParamA 7E43B10C 5 Bytes JMP 3E3E47AC C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[584] USER32.dll!MessageBoxExW 7E4505D8 5 Bytes JMP 3E3E4612 C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[584] USER32.dll!MessageBoxExA 7E4505FC 5 Bytes JMP 3E3E4674 C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[584] USER32.dll!DialogBoxIndirectParamA 7E456B50 5 Bytes JMP 3E3E4872 C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[584] USER32.dll!MessageBoxIndirectW 7E4662AB 5 Bytes JMP 3E3E46D6 C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[584] ole32.dll!CoCreateInstance 774FFAC3 5 Bytes JMP 3E2EDB78 C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[584] ole32.dll!OleLoadFromStream 7752A257 5 Bytes JMP 3E3E4B77 C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\WINDOWS\System32\svchost.exe[1084] ntdll.dll!NtProtectVirtualMemory 7C90D6EE 5 Bytes JMP 007D000A
    .text C:\WINDOWS\System32\svchost.exe[1084] ntdll.dll!NtWriteVirtualMemory 7C90DFAE 5 Bytes JMP 007E000A
    .text C:\WINDOWS\System32\svchost.exe[1084] ntdll.dll!KiUserExceptionDispatcher 7C90E47C 5 Bytes JMP 007C000C
    .text C:\WINDOWS\System32\svchost.exe[1084] ole32.dll!CoCreateInstance 774FFAC3 5 Bytes JMP 00C3000A
    .text C:\Program Files\Internet Explorer\iexplore.exe[2692] ntdll.dll!NtProtectVirtualMemory 7C90D6EE 5 Bytes JMP 00E5000A
    .text C:\Program Files\Internet Explorer\iexplore.exe[2692] ntdll.dll!NtWriteVirtualMemory 7C90DFAE 5 Bytes JMP 00E6000A
    .text C:\Program Files\Internet Explorer\iexplore.exe[2692] ntdll.dll!KiUserExceptionDispatcher 7C90E47C 5 Bytes JMP 00B3000C
    .text C:\Program Files\Internet Explorer\iexplore.exe[2692] USER32.dll!CreateWindowExW 7E41FC25 5 Bytes JMP 3E2EDB1C C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[2692] USER32.dll!DialogBoxParamW 7E42555F 5 Bytes JMP 3E2154C5 C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[2692] USER32.dll!DialogBoxIndirectParamW 7E432032 5 Bytes JMP 3E3E480F C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[2692] USER32.dll!MessageBoxIndirectA 7E43A04A 5 Bytes JMP 3E3E4741 C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[2692] USER32.dll!DialogBoxParamA 7E43B10C 5 Bytes JMP 3E3E47AC C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[2692] USER32.dll!MessageBoxExW 7E4505D8 5 Bytes JMP 3E3E4612 C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[2692] USER32.dll!MessageBoxExA 7E4505FC 5 Bytes JMP 3E3E4674 C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[2692] USER32.dll!DialogBoxIndirectParamA 7E456B50 5 Bytes JMP 3E3E4872 C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[2692] USER32.dll!MessageBoxIndirectW 7E4662AB 5 Bytes JMP 3E3E46D6 C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[3512] ntdll.dll!NtProtectVirtualMemory 7C90D6EE 5 Bytes JMP 00B3000A
    .text C:\Program Files\Internet Explorer\iexplore.exe[3512] ntdll.dll!NtWriteVirtualMemory 7C90DFAE 5 Bytes JMP 00E5000A
    .text C:\Program Files\Internet Explorer\iexplore.exe[3512] ntdll.dll!KiUserExceptionDispatcher 7C90E47C 5 Bytes JMP 00B2000C
    .text C:\Program Files\Internet Explorer\iexplore.exe[3512] USER32.dll!UnhookWindowsHookEx 7E41F21E 5 Bytes JMP 3E25467C C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[3512] USER32.dll!CallNextHookEx 7E41F85B 5 Bytes JMP 3E2DD0ED C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[3512] USER32.dll!CreateWindowExW 7E41FC25 5 Bytes JMP 3E2EDB1C C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[3512] USER32.dll!DialogBoxParamW 7E42555F 5 Bytes JMP 3E2154C5 C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[3512] USER32.dll!SetWindowsHookExW 7E42DDB5 5 Bytes JMP 3E2E9AC9 C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[3512] USER32.dll!DialogBoxIndirectParamW 7E432032 5 Bytes JMP 3E3E480F C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[3512] USER32.dll!MessageBoxIndirectA 7E43A04A 5 Bytes JMP 3E3E4741 C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[3512] USER32.dll!DialogBoxParamA 7E43B10C 5 Bytes JMP 3E3E47AC C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[3512] USER32.dll!MessageBoxExW 7E4505D8 5 Bytes JMP 3E3E4612 C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[3512] USER32.dll!MessageBoxExA 7E4505FC 5 Bytes JMP 3E3E4674 C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[3512] USER32.dll!DialogBoxIndirectParamA 7E456B50 5 Bytes JMP 3E3E4872 C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[3512] USER32.dll!MessageBoxIndirectW 7E4662AB 5 Bytes JMP 3E3E46D6 C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[3512] ole32.dll!CoCreateInstance 774FFAC3 5 Bytes JMP 3E2EDB78 C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    .text C:\Program Files\Internet Explorer\iexplore.exe[3512] ole32.dll!OleLoadFromStream 7752A257 5 Bytes JMP 3E3E4B77 C:\WINDOWS\system32\IEFRAME.dll (Internet Explorer/Microsoft Corporation)
    ---- User IAT/EAT - GMER 1.0.15 ----
    IAT C:\Program Files\Internet Explorer\iexplore.exe[3512] @ C:\WINDOWS\system32\ole32.dll [KERNEL32.dll!LoadLibraryExW] [451F1ACB] C:\Program Files\Internet Explorer\xpshims.dll (Internet Explorer Compatibility Shims for XP/Microsoft Corporation)
    ---- Devices - GMER 1.0.15 ----
    Device \Driver\prodrv06 \Device\ProDrv06 E1C98C30
    Device \Driver\atapi -> DriverStartIo \Device\Ide\IdePort0 8A5E833B
    ---- Disk sectors - GMER 1.0.15 ----
    Disk \Device\Harddisk0\DR0 TDL4@MBR code has been found <-- ROOTKIT !!!
    Disk \Device\Harddisk0\DR0 sector 00: rootkit-like behavior
    ---- EOF - GMER 1.0.15 ----
    3.)
    aswMBR version 0.9.7.675 Copyright(c) 2011 AVAST Software
    Run date: 2011-06-27 12:03:52
    12:03:52.343 OS Version: Windows 5.1.2600 Service Pack 2
    12:03:52.343 Number of processors: 1 586 0x209
    12:03:52.343 ComputerName: LIVINGROOM UserName: James
    12:03:52.906 Initialize success
    12:04:06.343 Disk 0 (boot) \Device\Harddisk0\DR0 -> \Device\Ide\IdeDeviceP0T0L0-3
    12:04:06.343 Disk 0 Vendor: WDC_WD1600AVJB-63J5A0 01.03E01 Size: 152627MB BusType: 3
    12:04:06.343 Device \Driver\atapi -> DriverStartIo 8a5e833b
    12:04:08.343 Disk 0 MBR read successfully
    12:04:08.343 Disk 0 MBR scan
    12:04:08.343 Disk 0 TDL4@MBR code has been found
    12:04:08.343 Disk 0 Windows XP default MBR code found via API
    12:04:08.343 Disk 0 MBR hidden
    12:04:08.343 Disk 0 MBR [TDL4] **ROOTKIT**
    12:04:08.343 Disk 0 trace - called modules:
    12:04:08.343 ntoskrnl.exe CLASSPNP.SYS disk.sys >>UNKNOWN [0x8a5e84f0]<<
    12:04:08.359 1 nt!IofCallDriver -> \Device\Harddisk0\DR0[0x8a5b8ab8]
    12:04:08.359 3 CLASSPNP.SYS[f763805b] -> nt!IofCallDriver -> [0x8a5c3cd0]
    12:04:08.359 \Driver\atapi[0x8a621c08] -> IRP_MJ_CREATE -> 0x8a5e84f0
    12:04:08.359 Scan finished successfully
    12:04:34.812 Disk 0 MBR has been saved successfully to "C:\Documents and Settings\James\Desktop\MBR.dat "
    12:04:34.812 The log file has been saved successfully to "C:\Documents and Settings\James\Desktop\aswMBR.txt "
    4.)
    DDS (Ver_2011-06-23.01) - NTFSx86
    Internet Explorer: 8.0.6001.18702
    Run by James at 12:16:50 on 2011-06-27
    Microsoft Windows XP Home Edition 5.1.2600.2.1252.1.1033.18.2046.1429 [GMT -7:00]
    AV: Microsoft Security Essentials *Enabled/Updated* {EDB4FA23-53B8-4AFA-8C5D-99752CCA7095}
    AV: Microsoft Security Essentials *Disabled/Updated* {BCF43643-A118-4432-AEDE-D861FCBCFCDF}
    C:\WINDOWS\system32\svchost -k DcomLaunch
    svchost.exe
    c:\Program Files\Microsoft Security Client\Antimalware\MsMpEng.exe
    C:\WINDOWS\system32\svchost.exe -k WudfServiceGroup
    svchost.exe
    svchost.exe
    C:\WINDOWS\system32\LEXBCES.EXE
    C:\WINDOWS\system32\LEXPPS.EXE
    svchost.exe
    C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
    C:\Program Files\Bonjour\mDNSResponder.exe
    C:\WINDOWS\system32\CSHelper.exe
    C:\Program Files\Common Files\Portrait Displays\Shared\DTSRVC.exe
    C:\Program Files\Microsoft Security Client\msseces.exe
    C:\Program Files\Portrait Displays\Pivot Software\wpctrl.exe
    C:\Program Files\Canon\IJPLM\IJPLMSVC.EXE
    C:\Program Files\Google\Update\GoogleUpdate.exe
    C:\Program Files\Common Files\Portrait Displays\Drivers\pdisrvc.exe
    C:\WINDOWS\System32\svchost.exe -k imgsvc
    C:\Program Files\Portrait Displays\Pivot Software\floater.exe
    C:\WINDOWS\system32\UAService7.exe
    C:\Program Files\Acer Display\eDisplay Management\DTHtml.exe
    C:\Program Files\Canon\CAL\CALMAIN.exe
    C:\Program Files\Common Files\Portrait Displays\Shared\HookManager.exe
    C:\Program Files\Common Files\Portrait Displays\Drivers\pdiSdkHelper.exe
    C:\WINDOWS\System32\svchost.exe -k netsvcs
    uDefault_Page_URL = hxxp://www.msn.com
    uInternet Connection Wizard,ShellNext = iexplore
    uInternet Settings,ProxyOverride = <local>;*.local
    BHO: {02478D38-C3F9-4efb-9B51-7695ECA05670} - No File
    BHO: Adobe PDF Reader Link Helper: {06849e9f-c8d7-4d59-b87d-784b7d6be0b3} - c:\program files\common files\adobe\acrobat\activex\AcroIEHelper.dll
    BHO: {2A32EFE1-1ACD-4CF7-9F72-3C2CC28880A1} - No File
    BHO: {3CEFE32A-6805-4F77-BBEE-DC3C32C0F9A6} - No File
    BHO: {41833C93-EE9E-472F-9DB9-8CB402659890} - No File
    BHO: {4664BAA6-DB16-4836-B878-EBA3338F3734} - No File
    BHO: {542adc8c-4f73-4c17-9394-c0fd51d0398e} - No File
    BHO: {5C255C8A-E604-49b4-9D64-90988571CECB} - No File
    BHO: {5C9E9E35-9524-4DCF-94F0-3F03AB5F88F8} - No File
    BHO: DriveLetterAccess: {5ca3d70e-1895-11cf-8e15-001234567890} - c:\windows\system32\dla\tfswshx.dll
    BHO: {65D886A2-7CA7-479B-BB95-14D1EFB7946A} - No File
    BHO: {6FED410D-73D1-4FB7-A466-B22FA391FA5D} - No File
    BHO: {73BDEA63-5750-4ABB-A7E8-F079B2E370A4} - No File
    BHO: {74BCF4CF-EB01-463A-8F3B-065286F9C275} - No File
    BHO: {75AEE836-9155-44E0-96E7-7BA042ED6E74} - No File
    BHO: {87a930ec-bc4b-4388-a3e5-2e574308fd84} - No File
    BHO: {8963fe7a-d87a-4ff6-822a-0f5b437cd5f9} - No File
    BHO: Windows Live Sign-in Helper: {9030d464-4c02-4abf-8ecc-5164760863c6} - c:\program files\common files\microsoft shared\windows live\WindowsLiveLogin.dll
    BHO: Google Toolbar Helper: {aa58ed58-01dd-4d91-8333-cf10577473f7} - c:\program files\google\google toolbar\GoogleToolbar_32.dll
    BHO: Google Toolbar Notifier BHO: {af69de43-7d58-4638-b6fa-ce66b5ad205d} - c:\program files\google\googletoolbarnotifier\5.6.6209.1142\swg.dll
    BHO: {AFB67358-50B6-46A8-8BBE-0B42980B91D3} - No File
    BHO: {B2814E74-88CB-4A28-949E-1A4F99F6BDF9} - No File
    BHO: {C28132D3-A042-D2B2-159B-AA8F032629EC} - No File
    BHO: {C74F5288-9E3A-40B3-9423-6D9019A2CCF0} - No File
    BHO: MSN Toolbar Helper: {d2ce3e00-f94a-4740-988e-03dc2f38c34f} - c:\program files\msn\toolbar\3.0.1203.0\msneshellx.dll
    BHO: {D3F2AFFE-FCA4-4334-800C-5608ABF05B02} - No File
    BHO: Java(tm) Plug-In 2 SSV Helper: {dbc80044-a445-435b-bc74-9c25c1c588a9} - c:\program files\java\jre6\bin\jp2ssv.dll
    BHO: JQSIEStartDetectorImpl Class: {e7e6f031-17ce-4c07-bc86-eabfe594f69c} - c:\program files\java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
    BHO: {ED60C118-39A8-408C-8603-DE1B9BECCFCB} - No File
    BHO: {FB55771D-45B3-44A4-BDBF-5E27D7D4DDCF} - No File
    BHO: {FDD3B846-8D59-4ffb-8758-209B6AD74ACC} - No File
    TB: {BA52B914-B692-46c4-B683-905236F6F655} - No File
    TB: MSN Toolbar: {1e61ed7c-7cb8-49d6-b9e9-ab4c880c8414} - c:\program files\msn\toolbar\3.0.1203.0\msneshellx.dll
    TB: Google Toolbar: {2318c2b1-4965-11d4-9b18-009027a5cd4f} - c:\program files\google\google toolbar\GoogleToolbar_32.dll
    TB: {EF99BD32-C1FB-11D2-892F-0090271D4F88} - No File
    TB: {4E7BD74F-2B8D-469E-9EB4-FE6FA694B13E} - No File
    TB: {604BC32A-9680-40D1-9AC6-E06B23A1BA4C} - No File
    TB: {98279C38-DE4B-4BCF-93C9-8EC26069D6F4} - No File
    EB: {4528BBE0-4E08-11D5-AD55-00010333D0AD} - No File
    EB: Real.com: {fe54fa40-d68c-11d2-98fa-00c0f0318afe} - c:\windows\system32\Shdocvw.dll
    EB: {32683183-48a0-441b-a342-7c2a440a9478} - No File
    uRun: [Yahoo! Pager] "c:\program files\yahoo!\messenger\YahooMessenger.exe" -quiet
    uRun: [PID] c:\docume~1\james\locals~1\temp\lt0vpamv.exe
    uRun: [AntiVirus_AntiSpyware_2011] "c:\documents and settings\james\application data\antivirus_antispyware_2011\AntiVirus AntiSpyware.exe" /STARTUP
    uRun: [ctfmon.exe] c:\windows\system32\ctfmon.exe
    mRun: [MSC] "c:\program files\microsoft security client\msseces.exe" -hide -runkey
    mRun: [QuickTime Task] "c:\program files\quicktime\qttask.exe" -atboottime
    mRun: [iTunesHelper] "c:\program files\itunes\iTunesHelper.exe "
    mRun: [PivotSoftware] "c:\program files\portrait displays\pivot software\wpctrl.exe "
    mRun: [DT ACR] c:\program files\common files\portrait displays\shared\DT_startup.exe -ACR
    mRun: [Adobe Reader Speed Launcher] "c:\program files\adobe\reader 8.0\reader\Reader_sl.exe "
    mRun: [Adobe ARM] "c:\program files\common files\adobe\arm\1.0\AdobeARM.exe "
    dRun: [DWQueuedReporting] "c:\progra~1\common~1\micros~1\dw\dwtrig20.exe" -t
    IE: {e2e2dd38-d088-4134-82b7-f2ba38496583} - %windir%\Network Diagnostic\xpnetdiag.exe
    IE: {FB5F1910-F110-11d2-BB9E-00C04F795683} - c:\program files\messenger\msmsgs.exe
    IE: {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - {FE54FA40-D68C-11d2-98FA-00C0F0318AFE} - c:\windows\system32\Shdocvw.dll
    DPF: {15B782AF-55D8-11D1-B477-006097098764} - hxxp://media.keytrain.com/player/IE/awswaxd.cab
    DPF: {166B1BCA-3F9C-11CF-8075-444553540000} - hxxp://fpdownload.macromedia.com/pub/shockwave/cabs/director/sw.cab
    DPF: {1A1F56AA-3401-46F9-B277-D57F3421F821} - hxxp://www.worldwinner.com/games/v47/shared/FunGamesLoader.cab
    DPF: {233C1507-6A77-46A4-9443-F871F945D258} - hxxp://fpdownload.macromedia.com/get/shockwave/cabs/director/sw.cab
    DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} - c:\program files\yahoo!\common\Yinsthelper.dll
    DPF: {4ED9DDF0-7479-4BBE-9335-5A1EDB1D8A21} - hxxp://download.mcafee.com/molbin/shared/mcinsctl/en-us/4,0,0,76/mcinsctl.cab
    DPF: {4F1E5B1A-2A80-42CA-8532-2D05CB959537} - hxxp://by23fd.bay23.hotmail.msn.com/resources/MsnPUpld.cab
    DPF: {5ED80217-570B-4DA9-BF44-BE107C0EC166} - hxxp://cdn.scan.onecare.live.com/resource/download/scanner/wlscbase6087.cab
    DPF: {6C6FE41A-0DA6-42A1-9AD8-792026B2B2A7} - hxxp://www.worldwinner.com/games/v41/freecell/freecell.cab
    DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} - hxxp://update.microsoft.com/microsoftupdate/v6/V5Controls/en/x86/client/muweb_site.cab?1165536969073
    DPF: {8A0019EB-51FA-4AE5-A40B-C0496BBFC739} - hxxp://picture.vzw.com/activex/VerizonWirelessUploadControl.cab
    DPF: {8A94C905-FF9D-43B6-8708-F0F22D22B1CB} - hxxp://www.worldwinner.com/games/shared/wwlaunch.cab
    DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_26-windows-i586.cab
    DPF: {8F6E7FB2-E56B-4F66-A4E1-9765D2565280} - hxxp://www.worldwinner.com/games/launcher/ie/v2.22.01.0/iewwload.cab
    DPF: {8FFBE65D-2C9C-4669-84BD-5829DC0B603C} - hxxp://fpdownload.macromedia.com/get/flashplayer/current/polarbear/ultrashim.cab
    DPF: {A17E30C4-A9BA-11D4-8673-60DB54C10000} - hxxp://us.dl1.yimg.com/download.yahoo.com/dl/installs/yse/ymmapi_416.dll
    DPF: {B06CE1BC-5D9D-4676-BD28-1752DBF394E0} - hxxp://www.worldwinner.com/games/v41/hangman/hangman.cab
    DPF: {BCC0FF27-31D9-4614-A68E-C18E1ADA4389} - hxxp://download.mcafee.com/molbin/shared/mcgdmgr/en-us/1,0,0,16/mcgdmgr.cab
    DPF: {C3F79A2B-B9B4-4A66-B012-3EE46475B072} - hxxp://messenger.zone.msn.com/binary/MessengerStatsPAClient.cab56907.cab
    DPF: {CAFEEFAC-0016-0000-0026-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_26-windows-i586.cab
    DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_26-windows-i586.cab
    DPF: {D0C0F75C-683A-4390-A791-1ACFD5599AB8} - hxxp://games.myspace.com/Gameshell/GameHost/1.0/OberonGameHost.cab
    DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} - hxxp://fpdownload2.macromedia.com/get/shockwave/cabs/flash/swflash.cab
    DPF: {DF780F87-FF2B-4DF8-92D0-73DB16A1543A} - hxxp://games.pogo.com/online2/pogo/bejeweled2/popcaploader_v6.cab
    DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} - hxxp://platformdl.adobe.com/NOS/getPlusPlus/1.6/gp.cab
    SSODL: WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - c:\windows\system32\WPDShServiceObj.dll
    SEH: {ED60C118-39A8-408C-8603-DE1B9BECCFCB} - No File
    LSA: Authentication Packages = msv1_0 c:\windows\system32\ljJYSklK
    R1 MpFilter;Microsoft Malware Protection Driver;c:\windows\system32\drivers\MpFilter.sys [2009-12-2 165264]
    R1 MpKsl06ffcffe;MpKsl06ffcffe;c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{c9460285-6bce-43e2-a058-2c55ac9abaa6}\MpKsl06ffcffe.sys [2011-6-27 28752]
    R2 CSHelper;CopySafe Helper Service;c:\windows\system32\CSHelper.exe [2010-1-16 266240]
    R2 PdiService;Portrait Displays SDK Service;c:\program files\common files\portrait displays\drivers\pdisrvc.exe [2011-2-16 109168]
    S1 lofpusik;lofpusik;c:\windows\system32\drivers\lofpusik.sys [2011-6-27 41680]
    S1 MpKsl28583a7a;MpKsl28583a7a;\??\c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{37b381fb-89fa-43ac-a2a8-8ccac7e1086a}\mpksl28583a7a.sys --> c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{37b381fb-89fa-43ac-a2a8-8ccac7e1086a}\MpKsl28583a7a.sys [?]
    S1 MpKsl3b684326;MpKsl3b684326;\??\c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{ed4e103c-01eb-415c-b4b4-4535e44aa3bf}\mpksl3b684326.sys --> c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{ed4e103c-01eb-415c-b4b4-4535e44aa3bf}\MpKsl3b684326.sys [?]
    S1 MpKsla5197085;MpKsla5197085;\??\c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{90d430c6-00ed-4cb4-af43-90824f222e38}\mpksla5197085.sys --> c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{90d430c6-00ed-4cb4-af43-90824f222e38}\MpKsla5197085.sys [?]
    S2 gupdate;Google Update Service (gupdate);c:\program files\google\update\GoogleUpdate.exe [2010-2-16 135664]
    S2 HitmanPro35CrusaderBoot;Hitman Pro 3.5 Crusader (Boot); "c:\documents and settings\james\local settings\temporary internet files\content.ie5\6jlcfosk\hitmanpro35[1].exe" /crusader:boot --> c:\documents and settings\james\local settings\temporary internet files\content.ie5\6jlcfosk\HitmanPro35[1].exe [?]
    S3 gupdatem;Google Update Service (gupdatem);c:\program files\google\update\GoogleUpdate.exe [2010-2-16 135664]
    2011-06-27 19:07:45 41680 ----a-w- c:\windows\system32\drivers\lofpusik.sys
    2011-06-27 18:55:53 28752 ----a-w- c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{c9460285-6bce-43e2-a058-2c55ac9abaa6}\MpKsl06ffcffe.sys
    2011-06-26 02:14:00 39984 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
    2011-06-26 02:13:53 22712 ----a-w- c:\windows\system32\drivers\mbam.sys
    2011-06-26 00:17:50 73728 ----a-w- c:\windows\system32\javacpl.cpl
    2011-06-23 07:41:20 7074640 ----a-w- c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{c9460285-6bce-43e2-a058-2c55ac9abaa6}\mpengine.dll
    2011-06-26 00:17:32 472808 ----a-w- c:\windows\system32\deployJava1.dll
    2011-05-25 02:14:10 222080 ------w- c:\windows\system32\MpSigStub.exe
    2011-04-28 08:10:57 0 ----a-w- c:\windows\Xpoxohewazuco.bin
    2011-04-26 16:57:29 16968 ----a-w- c:\windows\system32\drivers\hitmanpro35.sys
    =================== ROOTKIT ====================
    Stealth MBR rootkit/Mebroot/Sinowal/TDL4 detector 0.4.2 by Gmer, http://www.gmer.net
    Windows 5.1.2600 Disk: WDC_WD1600AVJB-63J5A0 rev.01.03E01 -> Harddisk0\DR0 -> \Device\Ide\IdeDeviceP0T0L0-3
    device: opened successfully
    user: MBR read successfully
    Disk trace:
    called modules: ntoskrnl.exe CLASSPNP.SYS disk.sys >>UNKNOWN [0x8A5E84F0]<<
    _asm { PUSH EBP; MOV EBP, ESP; PUSH ECX; MOV EAX, [EBP+0x8]; CMP EAX, [0x8a5ee7d0]; MOV EAX, [0x8a5ee84c]; PUSH EBX; PUSH ESI; MOV ESI, [EBP+0xc]; MOV EBX, [ESI+0x60]; PUSH EDI; JNZ 0x20; MOV [EBP+0x8], EAX; }
    1 nt!IofCallDriver[0x804E37D5] -> \Device\Harddisk0\DR0[0x8A5B8AB8]
    3 CLASSPNP[0xF763805B] -> nt!IofCallDriver[0x804E37D5] -> [0x8A5C3CD0]
    \Driver\atapi[0x8A621C08] -> IRP_MJ_CREATE -> 0x8A5E84F0
    error: Read A device attached to the system is not functioning.
    kernel: MBR read successfully
    _asm { XOR AX, AX; MOV SS, AX; MOV SP, 0x7c00; STI ; PUSH AX; POP ES; PUSH AX; POP DS; CLD ; MOV SI, 0x7c1b; MOV DI, 0x61b; PUSH AX; PUSH DI; MOV CX, 0x1e5; REP MOVSB ; RETF ; MOV BP, 0x7be; MOV CL, 0x4; CMP [BP+0x0], CH; JL 0x2e; JNZ 0x3a; }
    detected disk devices:
    detected hooks:
    \Driver\atapi DriverStartIo -> 0x8A5E833B
    user & kernel MBR OK
    Warning: possible TDL3 rootkit infection !
    ============= FINISH: 12:18:39.73 ===============
    5.)
    the 5th files says don't send unless requested and says to "zip" it up, but i don't know how to do that....
  2. 2011/06/30
    As posted in our instructions:
    The scan will instruct you to post Attach.txt as an attachment. No need for that though... just post it's contents as you would any other log.
    Welcome aboard [​IMG]
    Please, observe following rules:
    • Read all of my instructions very carefully. Your mistakes during cleaning process may have very serious consequences, like unbootable computer.
    • If you're stuck, or you're not sure about certain step, always ask before doing anything else.
    • Please refrain from running tools or applying updates other than those I suggest.
    • Never run more than one scan at a time.
    • Keep updating me regarding your computer behavior, good, or bad.
    • The cleaning process, once started, has to be completed. Even if your computer appears to act better, it may still be infected. Once the computer is totally clean, I'll certainly let you know.
    • If you leave the topic without explanation in the middle of a cleaning process, you may not be eligible to receive any more help in malware removal forum.
    • I close my topics if you have not replied in 5 days. If you need more time, simply let me know. If I closed your topic and you need it to be reopened, simply PM me.
    Please, provide missing Attach.txt log.
    Then...
    Download TDSSKiller and save it to your desktop.
    • Doubleclick on TDSSKiller.exe to run the application, then on Start Scan.
    • If an infected file is detected, the default action will be Cure, click on Continue.
    • If a suspicious file is detected, the default action will be Skip, click on Continue.
    • It may ask you to reboot the computer to complete the process. Click on Reboot Now.
    • If no reboot is require, click on Report. A log file should appear. Please copy and paste the contents of that file here.
    • If a reboot is required, the report can also be found in your root directory (usually C:\ folder) in the form of TDSSKiller_xxxx_log.txt. Please copy and paste the contents of that file here.
    Milkman23 likes this.
  5. 2011/07/01
    Milkman23
    I ran the TDSSKiller as asked and rebooted (it did in fact find the rootkit virus and cured it) then when the comp rebooted it si apparantly gone. I ran it again (TDSSKILLER) and found NOTHING!!!!! here is the log.
    2011/07/01 13:45:06.0796 1744 TDSS rootkit removing tool 2.5.8.0 Jun 28 2011 19:12:16
    2011/07/01 13:45:07.0562 1744 ================================================================================
    2011/07/01 13:45:07.0562 1744 SystemInfo:
    2011/07/01 13:45:07.0562 1744 OS Version: 5.1.2600 ServicePack: 2.0
    2011/07/01 13:45:07.0562 1744 Product type: Workstation
    2011/07/01 13:45:07.0562 1744 ComputerName: LIVINGROOM
    2011/07/01 13:45:07.0578 1744 UserName: James
    2011/07/01 13:45:07.0578 1744 Windows directory: C:\WINDOWS
    2011/07/01 13:45:07.0578 1744 System windows directory: C:\WINDOWS
    2011/07/01 13:45:07.0578 1744 Processor architecture: Intel x86
    2011/07/01 13:45:07.0578 1744 Number of processors: 1
    2011/07/01 13:45:07.0578 1744 Page size: 0x1000
    2011/07/01 13:45:07.0578 1744 Boot type: Normal boot
    2011/07/01 13:45:07.0578 1744 ================================================================================
    2011/07/01 13:45:08.0875 1744 Initialize success
    2011/07/01 13:45:11.0703 2164 ================================================================================
    2011/07/01 13:45:11.0703 2164 Scan started
    2011/07/01 13:45:11.0703 2164 Mode: Manual;
    2011/07/01 13:45:12.0328 2164 abp480n5 (6abb91494fe6c59089b9336452ab2ea3) C:\WINDOWS\System32\DRIVERS\ABP480N5.SYS
    2011/07/01 13:45:12.0390 2164 ACPI (a10c7534f7223f4a73a948967d00e69b) C:\WINDOWS\system32\DRIVERS\ACPI.sys
    2011/07/01 13:45:12.0437 2164 ACPIEC (9859c0f6936e723e4892d7141b1327d5) C:\WINDOWS\system32\drivers\ACPIEC.sys
    2011/07/01 13:45:12.0500 2164 adpu160m (9a11864873da202c996558b2106b0bbc) C:\WINDOWS\System32\DRIVERS\adpu160m.sys
    2011/07/01 13:45:12.0546 2164 aeaudio (11c04b17ed2abbb4833694bcd644ac90) C:\WINDOWS\system32\drivers\aeaudio.sys
    2011/07/01 13:45:12.0609 2164 aec (1ee7b434ba961ef845de136224c30fec) C:\WINDOWS\system32\drivers\aec.sys
    2011/07/01 13:45:12.0656 2164 Afc (fe3ea6e9afc1a78e6edca121e006afb7) C:\WINDOWS\system32\drivers\Afc.sys
    2011/07/01 13:45:12.0718 2164 AFD (55e6e1c51b6d30e54335750955453702) C:\WINDOWS\System32\drivers\afd.sys
    2011/07/01 13:45:12.0765 2164 agp440 (2c428fa0c3e3a01ed93c9b2a27d8d4bb) C:\WINDOWS\System32\DRIVERS\agp440.sys
    2011/07/01 13:45:12.0828 2164 agpCPQ (67288b07d6aba6c1267b626e67bc56fd) C:\WINDOWS\System32\DRIVERS\agpCPQ.sys
    2011/07/01 13:45:12.0890 2164 Aha154x (c23ea9b5f46c7f7910db3eab648ff013) C:\WINDOWS\System32\DRIVERS\aha154x.sys
    2011/07/01 13:45:12.0921 2164 aic78u2 (19dd0fb48b0c18892f70e2e7d61a1529) C:\WINDOWS\System32\DRIVERS\aic78u2.sys
    2011/07/01 13:45:12.0968 2164 aic78xx (b7fe594a7468aa0132deb03fb8e34326) C:\WINDOWS\System32\DRIVERS\aic78xx.sys
    2011/07/01 13:45:13.0031 2164 AliIde (1140ab9938809700b46bb88e46d72a96) C:\WINDOWS\System32\DRIVERS\aliide.sys
    2011/07/01 13:45:13.0062 2164 alim1541 (f312b7cef21eff52fa23056b9d815fad) C:\WINDOWS\System32\DRIVERS\alim1541.sys
    2011/07/01 13:45:13.0109 2164 amdagp (675c16a3c1f8482f85ee4a97fc0dde3d) C:\WINDOWS\System32\DRIVERS\amdagp.sys
    2011/07/01 13:45:13.0140 2164 amsint (79f5add8d24bd6893f2903a3e2f3fad6) C:\WINDOWS\System32\DRIVERS\amsint.sys
    2011/07/01 13:45:13.0203 2164 asc (62d318e9a0c8fc9b780008e724283707) C:\WINDOWS\System32\DRIVERS\asc.sys
    2011/07/01 13:45:13.0234 2164 asc3350p (69eb0cc7714b32896ccbfd5edcbea447) C:\WINDOWS\System32\DRIVERS\asc3350p.sys
    2011/07/01 13:45:13.0265 2164 asc3550 (5d8de112aa0254b907861e9e9c31d597) C:\WINDOWS\System32\DRIVERS\asc3550.sys
    2011/07/01 13:45:13.0359 2164 AsyncMac (02000abf34af4c218c35d257024807d6) C:\WINDOWS\system32\DRIVERS\asyncmac.sys
    2011/07/01 13:45:13.0421 2164 atapi (cdfe4411a69c224bd1d11b2da92dac51) C:\WINDOWS\system32\DRIVERS\atapi.sys
    2011/07/01 13:45:13.0484 2164 Atmarpc (ec88da854ab7d7752ec8be11a741bb7f) C:\WINDOWS\system32\DRIVERS\atmarpc.sys
    2011/07/01 13:45:13.0562 2164 audstub (d9f724aa26c010a217c97606b160ed68) C:\WINDOWS\system32\DRIVERS\audstub.sys
    2011/07/01 13:45:13.0640 2164 BCMModem (41347688046d49cde0f6d138a534f73d) C:\WINDOWS\system32\DRIVERS\BCMSM.sys
    2011/07/01 13:45:13.0703 2164 Beep (da1f27d85e0d1525f6621372e7b685e9) C:\WINDOWS\system32\drivers\Beep.sys
    2011/07/01 13:45:13.0953 2164 cbidf (90a673fc8e12a79afbed2576f6a7aaf9) C:\WINDOWS\System32\DRIVERS\cbidf2k.sys
    2011/07/01 13:45:14.0000 2164 cbidf2k (90a673fc8e12a79afbed2576f6a7aaf9) C:\WINDOWS\system32\drivers\cbidf2k.sys
    2011/07/01 13:45:14.0062 2164 CCDECODE (6163ed60b684bab19d3352ab22fc48b2) C:\WINDOWS\system32\DRIVERS\CCDECODE.sys
    2011/07/01 13:45:14.0109 2164 cd20xrnt (f3ec03299634490e97bbce94cd2954c7) C:\WINDOWS\System32\DRIVERS\cd20xrnt.sys
    2011/07/01 13:45:14.0156 2164 Cdaudio (c1b486a7658353d33a10cc15211a873b) C:\WINDOWS\system32\drivers\Cdaudio.sys
    2011/07/01 13:45:14.0203 2164 Cdfs (cd7d5152df32b47f4e36f710b35aae02) C:\WINDOWS\system32\drivers\Cdfs.sys
    2011/07/01 13:45:14.0265 2164 cdrbsdrv (351735695e9ead93de6af85d8beb1ca8) C:\WINDOWS\system32\drivers\cdrbsdrv.sys
    2011/07/01 13:45:14.0312 2164 Cdrom (af9c19b3100fe010496b1a27181fbf72) C:\WINDOWS\system32\DRIVERS\cdrom.sys
    2011/07/01 13:45:14.0421 2164 CmdIde (e5dcb56c533014ecbc556a8357c929d5) C:\WINDOWS\System32\DRIVERS\cmdide.sys
    2011/07/01 13:45:14.0468 2164 Cpqarray (3ee529119eed34cd212a215e8c40d4b6) C:\WINDOWS\System32\DRIVERS\cpqarray.sys
    2011/07/01 13:45:14.0562 2164 dac2w2k (e550e7418984b65a78299d248f0a7f36) C:\WINDOWS\System32\DRIVERS\dac2w2k.sys
    2011/07/01 13:45:14.0609 2164 dac960nt (683789caa3864eb46125ae86ff677d34) C:\WINDOWS\System32\DRIVERS\dac960nt.sys
    2011/07/01 13:45:14.0687 2164 Disk (00ca44e4534865f8a3b64f7c0984bff0) C:\WINDOWS\system32\DRIVERS\disk.sys
    2011/07/01 13:45:14.0796 2164 dmboot (c0fbb516e06e243f0cf31f597e7ebf7d) C:\WINDOWS\system32\drivers\dmboot.sys
    2011/07/01 13:45:14.0859 2164 dmio (f5e7b358a732d09f4bcf2824b88b9e28) C:\WINDOWS\system32\drivers\dmio.sys
    2011/07/01 13:45:14.0890 2164 dmload (e9317282a63ca4d188c0df5e09c6ac5f) C:\WINDOWS\system32\drivers\dmload.sys
    2011/07/01 13:45:14.0953 2164 DMusic (a6f881284ac1150e37d9ae47ff601267) C:\WINDOWS\system32\drivers\DMusic.sys
    2011/07/01 13:45:15.0031 2164 dpti2o (40f3b93b4e5b0126f2f5c0a7a5e22660) C:\WINDOWS\System32\DRIVERS\dpti2o.sys
    2011/07/01 13:45:15.0093 2164 drmkaud (1ed4dbbae9f5d558dbba4cc450e3eb2e) C:\WINDOWS\system32\drivers\drmkaud.sys
    2011/07/01 13:45:15.0156 2164 drvmcdb (7f056a52bcba3102d2d37a4a2646c807) C:\WINDOWS\system32\drivers\drvmcdb.sys
    2011/07/01 13:45:15.0218 2164 drvnddm (d3c1e501ed42e77574b3095309dd4075) C:\WINDOWS\system32\drivers\drvnddm.sys
    2011/07/01 13:45:15.0796 2164 E100B (98b46b331404a951cabad8b4877e1276) C:\WINDOWS\system32\DRIVERS\e100b325.sys
    2011/07/01 13:45:15.0859 2164 EL90XBC (6e883bf518296a40959131c2304af714) C:\WINDOWS\system32\DRIVERS\el90xbc5.sys
    2011/07/01 13:45:15.0921 2164 enodpl (b4556f3d468c8dcb0b259d9d866cd4c4) C:\WINDOWS\system32\drivers\enodpl.sys
    2011/07/01 13:45:16.0000 2164 Fastfat (3117f595e9615e04f05a54fc15a03b20) C:\WINDOWS\system32\drivers\Fastfat.sys
    2011/07/01 13:45:16.0046 2164 Fdc (ced2e8396a8838e59d8fd529c680e02c) C:\WINDOWS\system32\DRIVERS\fdc.sys
    2011/07/01 13:45:16.0093 2164 Fips (e153ab8a11de5452bcf5ac7652dbf3ed) C:\WINDOWS\system32\drivers\Fips.sys
    2011/07/01 13:45:16.0140 2164 Flpydisk (0dd1de43115b93f4d85e889d7a86f548) C:\WINDOWS\system32\DRIVERS\flpydisk.sys
    2011/07/01 13:45:16.0187 2164 FltMgr (3d234fb6d6ee875eb009864a299bea29) C:\WINDOWS\system32\drivers\fltmgr.sys
    2011/07/01 13:45:16.0234 2164 Fs_Rec (3e1e2bd4f39b0e2b7dc4f4d2bcc2779a) C:\WINDOWS\system32\drivers\Fs_Rec.sys
    2011/07/01 13:45:16.0281 2164 Ftdisk (6ac26732762483366c3969c9e4d2259d) C:\WINDOWS\system32\DRIVERS\ftdisk.sys
    2011/07/01 13:45:16.0328 2164 GEARAspiWDM (8182ff89c65e4d38b2de4bb0fb18564e) C:\WINDOWS\system32\Drivers\GEARAspiWDM.sys
    2011/07/01 13:45:16.0375 2164 Gpc (c0f1d4a21de5a415df8170616703debf) C:\WINDOWS\system32\DRIVERS\msgpc.sys
    2011/07/01 13:45:16.0468 2164 HidUsb (1de6783b918f540149aa69943bdfeba8) C:\WINDOWS\system32\DRIVERS\hidusb.sys
    2011/07/01 13:45:16.0562 2164 hpn (b028377dea0546a5fcfba928a8aefae0) C:\WINDOWS\System32\DRIVERS\hpn.sys
    2011/07/01 13:45:16.0640 2164 HTTP (9f8b0f4276f618964fd118be4289b7cd) C:\WINDOWS\system32\Drivers\HTTP.sys
    2011/07/01 13:45:16.0718 2164 i2omgmt (8f09f91b5c91363b77bcd15599570f2c) C:\WINDOWS\system32\drivers\i2omgmt.sys
    2011/07/01 13:45:16.0750 2164 i2omp (ed6bf9e441fdea13292a6d30a64a24c3) C:\WINDOWS\System32\DRIVERS\i2omp.sys
    2011/07/01 13:45:16.0796 2164 i8042prt (5502b58eef7486ee6f93f3f164dcb808) C:\WINDOWS\system32\DRIVERS\i8042prt.sys
    2011/07/01 13:45:16.0843 2164 i81x (06b7ef73ba5f302eecc294cdf7e19702) C:\WINDOWS\system32\DRIVERS\i81xnt5.sys
    2011/07/01 13:45:16.0890 2164 iAimFP0 (7b5b44efe5eb9dadfb8ee29700885d23) C:\WINDOWS\system32\DRIVERS\wADV01nt.sys
    2011/07/01 13:45:16.0921 2164 iAimFP1 (eb1f6bab6c22ede0ba551b527475f7e9) C:\WINDOWS\system32\DRIVERS\wADV02NT.sys
    2011/07/01 13:45:16.0968 2164 iAimFP2 (03ce989d846c1aa81145cb22fcb86d06) C:\WINDOWS\system32\DRIVERS\wADV05NT.sys
    2011/07/01 13:45:17.0015 2164 iAimFP3 (525849b4469de021d5d61b4db9be3a9d) C:\WINDOWS\system32\DRIVERS\wSiINTxx.sys
    2011/07/01 13:45:17.0078 2164 iAimFP4 (589c2bcdb5bd602bf7b63d210407ef8c) C:\WINDOWS\system32\DRIVERS\wVchNTxx.sys
    2011/07/01 13:45:17.0125 2164 iAimTV0 (d83bdd5c059667a2f647a6be5703a4d2) C:\WINDOWS\system32\DRIVERS\wATV01nt.sys
    2011/07/01 13:45:17.0171 2164 iAimTV1 (ed968d23354daa0d7c621580c012a1f6) C:\WINDOWS\system32\DRIVERS\wATV02NT.sys
    2011/07/01 13:45:17.0234 2164 iAimTV3 (d738273f218a224c1ddac04203f27a84) C:\WINDOWS\system32\DRIVERS\wATV04nt.sys
    2011/07/01 13:45:17.0281 2164 iAimTV4 (0052d118995cbab152daabe6106d1442) C:\WINDOWS\system32\DRIVERS\wCh7xxNT.sys
    2011/07/01 13:45:17.0359 2164 ialm (9a883c3c4d91292c0d09de7c728e781c) C:\WINDOWS\system32\DRIVERS\ialmnt5.sys
    2011/07/01 13:45:17.0453 2164 Imapi (f8aa320c6a0409c0380e5d8a99d76ec6) C:\WINDOWS\system32\DRIVERS\imapi.sys
    2011/07/01 13:45:17.0546 2164 ini910u (4a40e045faee58631fd8d91afc620719) C:\WINDOWS\System32\DRIVERS\ini910u.sys
    2011/07/01 13:45:17.0593 2164 IntelIde (2d722b2b54ab55b2fa475eb58d7b2aad) C:\WINDOWS\System32\DRIVERS\intelide.sys
    2011/07/01 13:45:17.0640 2164 intelppm (279fb78702454dff2bb445f238c048d2) C:\WINDOWS\system32\DRIVERS\intelppm.sys
    2011/07/01 13:45:17.0671 2164 ip6fw (4448006b6bc60e6c027932cfc38d6855) C:\WINDOWS\system32\drivers\ip6fw.sys
    2011/07/01 13:45:17.0734 2164 IpFilterDriver (731f22ba402ee4b62748adaf6363c182) C:\WINDOWS\system32\DRIVERS\ipfltdrv.sys
    2011/07/01 13:45:17.0765 2164 IpInIp (e1ec7f5da720b640cd8fb8424f1b14bb) C:\WINDOWS\system32\DRIVERS\ipinip.sys
    2011/07/01 13:45:17.0828 2164 IpNat (e2168cbc7098ffe963c6f23f472a3593) C:\WINDOWS\system32\DRIVERS\ipnat.sys
    2011/07/01 13:45:17.0875 2164 IPSec (64537aa5c003a6afeee1df819062d0d1) C:\WINDOWS\system32\DRIVERS\ipsec.sys
    2011/07/01 13:45:17.0921 2164 IRENUM (50708daa1b1cbb7d6ac1cf8f56a24410) C:\WINDOWS\system32\DRIVERS\irenum.sys
    2011/07/01 13:45:18.0000 2164 isapnp (e504f706ccb699c2596e9a3da1596e87) C:\WINDOWS\system32\DRIVERS\isapnp.sys
    2011/07/01 13:45:18.0062 2164 Kbdclass (ebdee8a2ee5393890a1acee971c4c246) C:\WINDOWS\system32\DRIVERS\kbdclass.sys
    2011/07/01 13:45:18.0109 2164 kmixer (ba5deda4d934e6288c2f66caf58d2562) C:\WINDOWS\system32\drivers\kmixer.sys
    2011/07/01 13:45:18.0171 2164 KSecDD (674d3e5a593475915dc6643317192403) C:\WINDOWS\system32\drivers\KSecDD.sys
    2011/07/01 13:45:18.0312 2164 mnmdd (4ae068242760a1fb6e1a44bf4e16afa6) C:\WINDOWS\system32\drivers\mnmdd.sys
    2011/07/01 13:45:18.0359 2164 Modem (6fc6f9d7acc36dca9b914565a3aeda05) C:\WINDOWS\system32\drivers\Modem.sys
    2011/07/01 13:45:18.0421 2164 MODEMCSA (1992e0d143b09653ab0f9c5e04b0fd65) C:\WINDOWS\system32\drivers\MODEMCSA.sys
    2011/07/01 13:45:18.0468 2164 Mouclass (34e1f0031153e491910e12551400192c) C:\WINDOWS\system32\DRIVERS\mouclass.sys
    2011/07/01 13:45:18.0531 2164 mouhid (b1c303e17fb9d46e87a98e4ba6769685) C:\WINDOWS\system32\DRIVERS\mouhid.sys
    2011/07/01 13:45:18.0562 2164 MountMgr (65653f3b4477f3c63e68a9659f85ee2e) C:\WINDOWS\system32\drivers\MountMgr.sys
    2011/07/01 13:45:18.0609 2164 MpFilter (7e34bfa1a7b60bba1da03d677f16cd63) C:\WINDOWS\system32\DRIVERS\MpFilter.sys
    2011/07/01 13:45:18.0765 2164 MpKsl53f7aeaf (5f53edfead46fa7adb78eee9ecce8fdf) c:\Documents and Settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{EB78CEF2-AD35-4266-8DF5-3D6B97B60C9B}\MpKsl53f7aeaf.sys
    2011/07/01 13:45:18.0875 2164 mraid35x (3f4bb95e5a44f3be34824e8e7caf0737) C:\WINDOWS\System32\DRIVERS\mraid35x.sys
    2011/07/01 13:45:18.0921 2164 MRxDAV (29414447eb5bde2f8397dc965dbb3156) C:\WINDOWS\system32\DRIVERS\mrxdav.sys
    2011/07/01 13:45:19.0015 2164 MRxSmb (fb6c89bb3ce282b08bdb1e3c179e1c39) C:\WINDOWS\system32\DRIVERS\mrxsmb.sys
    2011/07/01 13:45:19.0078 2164 Msfs (561b3a4333ca2dbdba28b5b956822519) C:\WINDOWS\system32\drivers\Msfs.sys
    2011/07/01 13:45:19.0140 2164 MSKSSRV (ae431a8dd3c1d0d0610cdbac16057ad0) C:\WINDOWS\system32\drivers\MSKSSRV.sys
    2011/07/01 13:45:19.0187 2164 MSPCLOCK (13e75fef9dfeb08eeded9d0246e1f448) C:\WINDOWS\system32\drivers\MSPCLOCK.sys
    2011/07/01 13:45:19.0234 2164 MSPQM (1988a33ff19242576c3d0ef9ce785da7) C:\WINDOWS\system32\drivers\MSPQM.sys
    2011/07/01 13:45:19.0296 2164 mssmbios (469541f8bfd2b32659d5d463a6714bce) C:\WINDOWS\system32\DRIVERS\mssmbios.sys
    2011/07/01 13:45:19.0343 2164 MSTEE (bf13612142995096ab084f2db7f40f77) C:\WINDOWS\system32\drivers\MSTEE.sys
    2011/07/01 13:45:19.0390 2164 Mup (82035e0f41c2dd05ae41d27fe6cf7de1) C:\WINDOWS\system32\drivers\Mup.sys
    2011/07/01 13:45:19.0437 2164 NABTSFEC (5c8dc6429c43dc6177c1fa5b76290d1a) C:\WINDOWS\system32\DRIVERS\NABTSFEC.sys
    2011/07/01 13:45:19.0484 2164 NDIS (558635d3af1c7546d26067d5d9b6959e) C:\WINDOWS\system32\drivers\NDIS.sys
    2011/07/01 13:45:19.0546 2164 NdisIP (520ce427a8b298f54112857bcf6bde15) C:\WINDOWS\system32\DRIVERS\NdisIP.sys
    2011/07/01 13:45:19.0593 2164 NdisTapi (08d43bbdacdf23f34d79e44ed35c1b4c) C:\WINDOWS\system32\DRIVERS\ndistapi.sys
    2011/07/01 13:45:19.0625 2164 Ndisuio (34d6cd56409da9a7ed573e1c90a308bf) C:\WINDOWS\system32\DRIVERS\ndisuio.sys
    2011/07/01 13:45:19.0656 2164 NdisWan (0b90e255a9490166ab368cd55a529893) C:\WINDOWS\system32\DRIVERS\ndiswan.sys
    2011/07/01 13:45:19.0703 2164 NDProxy (59fc3fb44d2669bc144fd87826bb571f) C:\WINDOWS\system32\drivers\NDProxy.sys
    2011/07/01 13:45:19.0750 2164 NetBIOS (3a2aca8fc1d7786902ca434998d7ceb4) C:\WINDOWS\system32\DRIVERS\netbios.sys
    2011/07/01 13:45:19.0796 2164 NetBT (0c80e410cd2f47134407ee7dd19cc86b) C:\WINDOWS\system32\DRIVERS\netbt.sys
    2011/07/01 13:45:19.0906 2164 Npfs (4f601bcb8f64ea3ac0994f98fed03f8e) C:\WINDOWS\system32\drivers\Npfs.sys
    2011/07/01 13:45:19.0984 2164 Ntfs (19a811ef5f1ed5c926a028ce107ff1af) C:\WINDOWS\system32\drivers\Ntfs.sys
    2011/07/01 13:45:20.0046 2164 Null (73c1e1f395918bc2c6dd67af7591a3ad) C:\WINDOWS\system32\drivers\Null.sys
    2011/07/01 13:45:20.0140 2164 nv (2b298519edbfcf451d43e0f1e8f1006d) C:\WINDOWS\system32\DRIVERS\nv4_mini.sys
    2011/07/01 13:45:20.0265 2164 NwlnkFlt (b305f3fad35083837ef46a0bbce2fc57) C:\WINDOWS\system32\DRIVERS\nwlnkflt.sys
    2011/07/01 13:45:20.0296 2164 NwlnkFwd (c99b3415198d1aab7227f2c88fd664b9) C:\WINDOWS\system32\DRIVERS\nwlnkfwd.sys
    2011/07/01 13:45:20.0343 2164 omci (53d5f1278d9edb21689bbbcecc09108d) C:\WINDOWS\system32\DRIVERS\omci.sys
    2011/07/01 13:45:20.0421 2164 P3 (3e16eff2a6fed2d8d7f5a66dfe65d183) C:\WINDOWS\system32\DRIVERS\p3.sys
    2011/07/01 13:45:20.0453 2164 Parport (29744eb4ce659dfe3b4122deb45bc478) C:\WINDOWS\system32\DRIVERS\parport.sys
    2011/07/01 13:45:20.0500 2164 PartMgr (3334430c29dc338092f79c38ef7b4cd0) C:\WINDOWS\system32\drivers\PartMgr.sys
    2011/07/01 13:45:20.0562 2164 ParVdm (70e98b3fd8e963a6a46a2e6247e0bea1) C:\WINDOWS\system32\drivers\ParVdm.sys
    2011/07/01 13:45:20.0609 2164 PCI (8086d9979234b603ad5bc2f5d890b234) C:\WINDOWS\system32\DRIVERS\pci.sys
    2011/07/01 13:45:20.0687 2164 PCIIde (ccf5f451bb1a5a2a522a76e670000ff0) C:\WINDOWS\system32\DRIVERS\pciide.sys
    2011/07/01 13:45:20.0734 2164 Pcmcia (82a087207decec8456fbe8537947d579) C:\WINDOWS\system32\drivers\Pcmcia.sys
    2011/07/01 13:45:20.0859 2164 PdiPorts (3b2f443b8e23d17d46f0e43e2fc42cfe) C:\WINDOWS\system32\Drivers\PdiPorts.sys
    2011/07/01 13:45:21.0015 2164 perc2 (6c14b9c19ba84f73d3a86dba11133101) C:\WINDOWS\System32\DRIVERS\perc2.sys
    2011/07/01 13:45:21.0062 2164 perc2hib (f50f7c27f131afe7beba13e14a3b9416) C:\WINDOWS\System32\DRIVERS\perc2hib.sys
    2011/07/01 13:45:21.0156 2164 Pivot (943f840611d33832308ec5310b616b57) C:\WINDOWS\system32\drivers\pivot.sys
    2011/07/01 13:45:21.0203 2164 pivotmou (998c58295288eedfbfe95e7f6cc94df4) C:\WINDOWS\system32\drivers\pivotmou.sys
    2011/07/01 13:45:21.0296 2164 PptpMiniport (1c5cc65aac0783c344f16353e60b72ac) C:\WINDOWS\system32\DRIVERS\raspptp.sys
    2011/07/01 13:45:21.0343 2164 Processor (0d97d88720a4087ec93af7dbb303b30a) C:\WINDOWS\system32\DRIVERS\processr.sys
    2011/07/01 13:45:21.0500 2164 prodrv06 (f2e3c8f1eb6ba0733e0a1f6373df7957) C:\WINDOWS\System32\drivers\prodrv06.sys
    2011/07/01 13:45:21.0750 2164 prohlp02 (150307b52807d0c493c605ab913038ad) C:\WINDOWS\system32\drivers\prohlp02.sys
    2011/07/01 13:45:22.0359 2164 PSched (48671f327553dcf1d27f6197f622a668) C:\WINDOWS\system32\DRIVERS\psched.sys
    2011/07/01 13:45:22.0390 2164 Ptilink (80d317bd1c3dbc5d4fe7b1678c60cadd) C:\WINDOWS\system32\DRIVERS\ptilink.sys
    2011/07/01 13:45:22.0437 2164 PxHelp20 (7e1eacdecba39e0b2a35306426f0decc) C:\WINDOWS\system32\DRIVERS\PxHelp20.sys
    2011/07/01 13:45:22.0531 2164 ql1080 (0a63fb54039eb5662433caba3b26dba7) C:\WINDOWS\System32\DRIVERS\ql1080.sys
    2011/07/01 13:45:22.0609 2164 Ql10wnt (6503449e1d43a0ff0201ad5cb1b8c706) C:\WINDOWS\System32\DRIVERS\ql10wnt.sys
    2011/07/01 13:45:22.0640 2164 ql12160 (156ed0ef20c15114ca097a34a30d8a01) C:\WINDOWS\System32\DRIVERS\ql12160.sys
    2011/07/01 13:45:22.0671 2164 ql1240 (70f016bebde6d29e864c1230a07cc5e6) C:\WINDOWS\System32\DRIVERS\ql1240.sys
    2011/07/01 13:45:22.0718 2164 ql1280 (907f0aeea6bc451011611e732bd31fcf) C:\WINDOWS\System32\DRIVERS\ql1280.sys
    2011/07/01 13:45:22.0765 2164 RasAcd (fe0d99d6f31e4fad8159f690d68ded9c) C:\WINDOWS\system32\DRIVERS\rasacd.sys
    2011/07/01 13:45:22.0828 2164 Rasl2tp (98faeb4a4dcf812ba1c6fca4aa3e115c) C:\WINDOWS\system32\DRIVERS\rasl2tp.sys
    2011/07/01 13:45:22.0875 2164 RasPppoe (7306eeed8895454cbed4669be9f79faa) C:\WINDOWS\system32\DRIVERS\raspppoe.sys
    2011/07/01 13:45:22.0906 2164 Raspti (fdbb1d60066fcfbb7452fd8f9829b242) C:\WINDOWS\system32\DRIVERS\raspti.sys
    2011/07/01 13:45:22.0968 2164 Rdbss (03b965b1ca47f6ef60eb5e51cb50e0af) C:\WINDOWS\system32\DRIVERS\rdbss.sys
    2011/07/01 13:45:23.0015 2164 RDPCDD (4912d5b403614ce99c28420f75353332) C:\WINDOWS\system32\DRIVERS\RDPCDD.sys
    2011/07/01 13:45:23.0078 2164 rdpdr (a2cae2c60bc37e0751ef9dda7ceaf4ad) C:\WINDOWS\system32\DRIVERS\rdpdr.sys
    2011/07/01 13:45:23.0156 2164 RDPWD (b54cd38a9ebfbf2b3561426e3fe26f62) C:\WINDOWS\system32\drivers\RDPWD.sys
    2011/07/01 13:45:23.0234 2164 redbook (b31b4588e4086d8d84adbf9845c2402b) C:\WINDOWS\system32\DRIVERS\redbook.sys
    2011/07/01 13:45:23.0375 2164 Secdrv (90a3935d05b494a5a39d37e71f09a677) C:\WINDOWS\system32\DRIVERS\secdrv.sys
    2011/07/01 13:45:23.0437 2164 serenum (a2d868aeeff612e70e213c451a70cafb) C:\WINDOWS\system32\DRIVERS\serenum.sys
    2011/07/01 13:45:23.0500 2164 Serial (cd9404d115a00d249f70a371b46d5a26) C:\WINDOWS\system32\DRIVERS\serial.sys
    2011/07/01 13:45:23.0562 2164 sfdrv01 (fca5dd901ed19b56b7ffca6fe1627edc) C:\WINDOWS\system32\drivers\sfdrv01.sys
    2011/07/01 13:45:23.0656 2164 sfhlp01 (462aee0ea0481ea8bd45cac876a4ccc4) C:\WINDOWS\system32\drivers\sfhlp01.sys
    2011/07/01 13:45:23.0703 2164 sfhlp02 (3ad2b15ccc03febfbaf5ff057822aa75) C:\WINDOWS\system32\drivers\sfhlp02.sys
    2011/07/01 13:45:23.0765 2164 Sfloppy (0d13b6df6e9e101013a7afb0ce629fe0) C:\WINDOWS\system32\drivers\Sfloppy.sys
    2011/07/01 13:45:23.0875 2164 sisagp (732d859b286da692119f286b21a2a114) C:\WINDOWS\System32\DRIVERS\sisagp.sys
    2011/07/01 13:45:23.0937 2164 SLIP (5caeed86821fa2c6139e32e9e05ccdc9) C:\WINDOWS\system32\DRIVERS\SLIP.sys
    2011/07/01 13:45:24.0015 2164 smwdm (5018a9db5eb62e3edb3110f82f556285) C:\WINDOWS\system32\drivers\smwdm.sys
    2011/07/01 13:45:24.0125 2164 Sparrow (83c0f71f86d3bdaf915685f3d568b20e) C:\WINDOWS\System32\DRIVERS\sparrow.sys
    2011/07/01 13:45:24.0187 2164 splitter (0ce218578fff5f4f7e4201539c45c78f) C:\WINDOWS\system32\drivers\splitter.sys
    2011/07/01 13:45:24.0250 2164 SQTECH905C (6f6a0307c30b33e65aaf52c46cea2ecd) C:\WINDOWS\system32\Drivers\Capt905c.sys
    2011/07/01 13:45:24.0328 2164 sr (e41b6d037d6cd08461470af04500dc24) C:\WINDOWS\system32\DRIVERS\sr.sys
    2011/07/01 13:45:24.0375 2164 Srv (7a4f147cc6b133f905f6e65e2f8669fb) C:\WINDOWS\system32\DRIVERS\srv.sys
    2011/07/01 13:45:24.0421 2164 sscdbhk5 (328e8bb94ec58480f60458fb4b8437a7) C:\WINDOWS\system32\drivers\sscdbhk5.sys
    2011/07/01 13:45:24.0484 2164 ssrtln (7ec8b427cee5c0cdac066320b93f1355) C:\WINDOWS\system32\drivers\ssrtln.sys
    2011/07/01 13:45:24.0593 2164 streamip (284c57df5dc7abca656bc2b96a667afb) C:\WINDOWS\system32\DRIVERS\StreamIP.sys
    2011/07/01 13:45:24.0640 2164 swenum (03c1bae4766e2450219d20b993d6e046) C:\WINDOWS\system32\DRIVERS\swenum.sys
    2011/07/01 13:45:24.0703 2164 swmidi (94abc808fc4b6d7d2bbf42b85e25bb4d) C:\WINDOWS\system32\drivers\swmidi.sys
    2011/07/01 13:45:24.0796 2164 symc810 (1ff3217614018630d0a6758630fc698c) C:\WINDOWS\System32\DRIVERS\symc810.sys
    2011/07/01 13:45:24.0828 2164 symc8xx (070e001d95cf725186ef8b20335f933c) C:\WINDOWS\System32\DRIVERS\symc8xx.sys
    2011/07/01 13:45:24.0875 2164 sym_hi (80ac1c4abbe2df3b738bf15517a51f2c) C:\WINDOWS\System32\DRIVERS\sym_hi.sys
    2011/07/01 13:45:24.0906 2164 sym_u3 (bf4fab949a382a8e105f46ebb4937058) C:\WINDOWS\System32\DRIVERS\sym_u3.sys
    2011/07/01 13:45:24.0968 2164 sysaudio (650ad082d46bac0e64c9c0e0928492fd) C:\WINDOWS\system32\drivers\sysaudio.sys
    2011/07/01 13:45:25.0031 2164 tandpl (126d7b3b4c7b724491c604060e1f4e14) C:\WINDOWS\system32\drivers\tandpl.sys
    2011/07/01 13:45:25.0109 2164 Tcpip (2a5554fc5b1e04e131230e3ce035c3f9) C:\WINDOWS\system32\DRIVERS\tcpip.sys
    2011/07/01 13:45:25.0171 2164 TDPIPE (38d437cf2d98965f239b0abcd66dcb0f) C:\WINDOWS\system32\drivers\TDPIPE.sys
    2011/07/01 13:45:25.0218 2164 TDTCP (ed0580af02502d00ad8c4c066b156be9) C:\WINDOWS\system32\drivers\TDTCP.sys
    2011/07/01 13:45:25.0250 2164 TermDD (a540a99c281d933f3d69d55e48727f47) C:\WINDOWS\system32\DRIVERS\termdd.sys
    2011/07/01 13:45:25.0312 2164 tfsnboio (c229bf90443be8d3bd2b65d7f3ac0f35) C:\WINDOWS\system32\dla\tfsnboio.sys
    2011/07/01 13:45:25.0375 2164 tfsncofs (79ee9fcd7728e54ab8fbc30962f0416f) C:\WINDOWS\system32\dla\tfsncofs.sys
    2011/07/01 13:45:25.0437 2164 tfsndrct (9efb37e7de17d783a059b653f7e8afad) C:\WINDOWS\system32\dla\tfsndrct.sys
    2011/07/01 13:45:25.0500 2164 tfsndres (130254995ebedcb34d62e8d78ec9dbd0) C:\WINDOWS\system32\dla\tfsndres.sys
    2011/07/01 13:45:25.0562 2164 tfsnifs (9b40e1e4aeed849812a2e43a388a7e77) C:\WINDOWS\system32\dla\tfsnifs.sys
    2011/07/01 13:45:25.0656 2164 tfsnopio (818047ad850b312705aa17ca96b9427d) C:\WINDOWS\system32\dla\tfsnopio.sys
    2011/07/01 13:45:25.0703 2164 tfsnpool (4603e813bcc6dd465cd8d2afd37fa90d) C:\WINDOWS\system32\dla\tfsnpool.sys
    2011/07/01 13:45:25.0765 2164 tfsnudf (6fc2cd904a9a55acfdfc780a611a75ed) C:\WINDOWS\system32\dla\tfsnudf.sys
    2011/07/01 13:45:25.0843 2164 tfsnudfa (d4afa4d00f8db3fd1c15b3fe49c3a96c) C:\WINDOWS\system32\dla\tfsnudfa.sys
    2011/07/01 13:45:26.0000 2164 TosIde (f2790f6af01321b172aa62f8e1e187d9) C:\WINDOWS\System32\DRIVERS\toside.sys
    2011/07/01 13:45:26.0062 2164 Udfs (12f70256f140cd7d52c58c7048fde657) C:\WINDOWS\system32\drivers\Udfs.sys
    2011/07/01 13:45:26.0109 2164 ultra (1b698a51cd528d8da4ffaed66dfc51b9) C:\WINDOWS\System32\DRIVERS\ultra.sys
    2011/07/01 13:45:26.0187 2164 Update (ced744117e91bdc0beb810f7d8608183) C:\WINDOWS\system32\DRIVERS\update.sys
    2011/07/01 13:45:26.0265 2164 USBAAPL (5c2bdc152bbab34f36473deaf7713f22) C:\WINDOWS\system32\Drivers\usbaapl.sys
    2011/07/01 13:45:26.0343 2164 usbccgp (bffd9f120cc63bcbaa3d840f3eef9f79) C:\WINDOWS\system32\DRIVERS\usbccgp.sys
    2011/07/01 13:45:26.0406 2164 usbehci (15e993ba2f6946b2bfbbfcd30398621e) C:\WINDOWS\system32\DRIVERS\usbehci.sys
    2011/07/01 13:45:26.0453 2164 usbhub (c72f40947f92cea56a8fb532edf025f1) C:\WINDOWS\system32\DRIVERS\usbhub.sys
    2011/07/01 13:45:26.0531 2164 usbprint (a42369b7cd8886cd7c70f33da6fcbcf5) C:\WINDOWS\system32\DRIVERS\usbprint.sys
    2011/07/01 13:45:26.0562 2164 usbscan (a6bc71402f4f7dd5b77fd7f4a8ddba85) C:\WINDOWS\system32\DRIVERS\usbscan.sys
    2011/07/01 13:45:26.0625 2164 USBSTOR (6cd7b22193718f1d17a47a1cd6d37e75) C:\WINDOWS\system32\DRIVERS\USBSTOR.SYS
    2011/07/01 13:45:26.0671 2164 usbuhci (f8fd1400092e23c8f2f31406ef06167b) C:\WINDOWS\system32\DRIVERS\usbuhci.sys
    2011/07/01 13:45:26.0718 2164 VgaSave (8a60edd72b4ea5aea8202daf0e427925) C:\WINDOWS\System32\drivers\vga.sys
    2011/07/01 13:45:26.0796 2164 viaagp (d92e7c8a30cfd14d8e15b5f7f032151b) C:\WINDOWS\System32\DRIVERS\viaagp.sys
    2011/07/01 13:45:26.0828 2164 ViaIde (59cb1338ad3654417bea49636457f65d) C:\WINDOWS\System32\DRIVERS\viaide.sys
    2011/07/01 13:45:26.0875 2164 VolSnap (ee4660083deba849ff6c485d944b379b) C:\WINDOWS\system32\drivers\VolSnap.sys
    2011/07/01 13:45:27.0015 2164 Wanarp (984ef0b9788abf89974cfed4bfbaacbc) C:\WINDOWS\system32\DRIVERS\wanarp.sys
    2011/07/01 13:45:27.0125 2164 wdmaud (efd235ca22b57c81118c1aeb4798f1c1) C:\WINDOWS\system32\drivers\wdmaud.sys
    2011/07/01 13:45:27.0281 2164 WpdUsb (cf4def1bf66f06964dc0d91844239104) C:\WINDOWS\system32\DRIVERS\wpdusb.sys
    2011/07/01 13:45:27.0312 2164 WS2IFSL (6abe6e225adb5a751622a9cc3bc19ce8) C:\WINDOWS\System32\drivers\ws2ifsl.sys
    2011/07/01 13:45:27.0390 2164 WSTCODEC (d5842484f05e12121c511aa93f6439ec) C:\WINDOWS\system32\DRIVERS\WSTCODEC.SYS
    2011/07/01 13:45:27.0437 2164 WudfPf (f15feafffbb3644ccc80c5da584e6311) C:\WINDOWS\system32\DRIVERS\WudfPf.sys
    2011/07/01 13:45:27.0500 2164 WudfRd (28b524262bce6de1f7ef9f510ba3985b) C:\WINDOWS\system32\DRIVERS\wudfrd.sys
    2011/07/01 13:45:27.0609 2164 {6080A529-897E-4629-A488-ABA0C29B635E} (fd1f4e9cf06c71c8d73a24acf18d8296) C:\WINDOWS\system32\drivers\ialmsbw.sys
    2011/07/01 13:45:27.0671 2164 {D31A0762-0CEB-444e-ACFF-B049A1F6FE91} (d4d7331d33d1fa73e588e5ce0d90a4c1) C:\WINDOWS\system32\drivers\ialmkchw.sys
    2011/07/01 13:45:27.0703 2164 MBR (0x1B8) (8f558eb6672622401da993e1e865c861) \Device\Harddisk0\DR0
    2011/07/01 13:45:27.0890 2164 Boot (0x1200) (6795f34f41247053f450a4a776dfcb67) \Device\Harddisk0\DR0\Partition0
    2011/07/01 13:45:27.0906 2164 ================================================================================
    2011/07/01 13:45:27.0906 2164 Scan finished
    2011/07/01 13:45:27.0921 2116 Detected object count: 0
    2011/07/01 13:45:27.0921 2116 Actual detected object count: 0
  6. 2011/07/01
    Milkman23
    Just wanted to let you know that by now the virus would have already taken over and MS SEC ESS would want to try to delete virus but would be unsuccessful and just reboot. So far nothing is happening (which is VERY GOOD) I believe you have solved this annoying dilema for me, but will wait for your final say. An early HUGE Thank you though for this, and when I get into a little bit better place financially I will definitely support this site too.
    James
  7. 2011/07/01
    You're very welcome [​IMG]
    We're not done yet though. We have to make sure no other evil is hiding there.
    Firstly....
    Then...
    [color= "Blue"]**Note: In the event you already have Combofix, this is a new version that I need you to download. It is important that it is saved directly to your desktop**[/color]
    2. Close any open browsers.
      • Click on [color= "Red"]this link[/color] to see a list of programs that should be disabled. The list is not all inclusive. If yours is not listed and you don't know how to disable it, please ask.
      NOTE1. If Combofix asks you to install Recovery Console, please allow it.
      • Close any open browsers.
      • [color= "Red"]WARNING:[/color] Combofix will disconnect your machine from the Internet as soon as it starts
    6. Please post the "C:\ComboFix.txt"
    **Note 1: Do not mouseclick combofix's window while it's running. That may cause it to stall
    **Note 2 for AVG users: ComboFix will not run until AVG is uninstalled as a protective measure against the anti-virus. This is because AVG "falsely" detects ComboFix (or its embedded files) as a threat and may remove them resulting in the tool not working correctly which in turn can cause "unpredictable results ". Since AVG cannot be effectively disabled before running ComboFix, the author recommends you to uninstall AVG first.
    Use AppRemover to uninstall it: http://www.appremover.com/
    We can reinstall it when we're done with CF.
    **Note 3: If you receive an error "Illegal operation attempted on a registery key that has been marked for deletion ", restart computer to fix the issue.
    NOTE.
    If, for some reason, Combofix refuses to run, try one of the following:
    1. Run Combofix from Safe Mode.
    2. Delete Combofix file, download fresh one, but rename combofix.exe to yourname.exe BEFORE saving it to your desktop.
    Do NOT run it yet.
    Please download and run the below tool named Rkill (courtesy of BleepingComputer.com) which may help allow other programs to run.
    There are 4 different versions. If one of them won't run then download and try to run the other one.
    Vista and Win7 users need to right click Rkill and choose Run as Administrator
    You only need to get one of these to run, not all of them. You may get warnings from your antivirus about this tool, ignore them or shutdown your antivirus.
    Rkill.com
    Rkill.scr
    Rkill.exe
    • Double-click on the Rkill desktop icon to run the tool.
    • If using Vista or Windows 7 right-click on it and choose Run As Administrator.
    • A black DOS box will briefly flash and then disappear. This is normal and indicates the tool ran successfully.
    • If not, delete the file, then download and use the one provided in Link 2.
    • If it does not work, repeat the process and attempt to use one of the remaining links until the tool runs.
    • Do not reboot until instructed.
    • If the tool does not run from any of the links provided, please let me know.
    Once you've gotten one of them to run, immediately run your_name.exe by double clicking on it.
    If normal mode still doesn't work, run BOTH tools from safe mode.
    In case #2, please post BOTH logs, rKill and Combofix.
  8. 2011/07/01
    Milkman23
    Ok, here is the last log you have asked for:
    ComboFix 11-07-01.01 - James 07/01/2011 19:07:49.1.1 - x86
    Microsoft Windows XP Home Edition 5.1.2600.2.1252.1.1033.18.2046.1535 [GMT -7:00]
    Running from: c:\documents and settings\James\Desktop\ComboFix.exe
    AV: Microsoft Security Essentials *Disabled/Updated* {EDB4FA23-53B8-4AFA-8C5D-99752CCA7095}
    c:\documents and settings\D'Anne\WINDOWS
    c:\documents and settings\James\Application Data\Adobe\plugs
    c:\documents and settings\James\Application Data\Adobe\shed
    c:\documents and settings\James\err.log
    c:\documents and settings\James\Local Settings\Application Data\{16C1894B-E821-460E-9B01-ACE95F30BFFE}
    c:\documents and settings\James\Local Settings\Application Data\{16C1894B-E821-460E-9B01-ACE95F30BFFE}\chrome.manifest
    c:\documents and settings\James\Local Settings\Application Data\{16C1894B-E821-460E-9B01-ACE95F30BFFE}\chrome\content\_cfg.js
    c:\documents and settings\James\Local Settings\Application Data\{16C1894B-E821-460E-9B01-ACE95F30BFFE}\chrome\content\overlay.xul
    c:\documents and settings\James\Local Settings\Application Data\{16C1894B-E821-460E-9B01-ACE95F30BFFE}\install.rdf
    c:\documents and settings\James\WINDOWS
    c:\documents and settings\Kari\Local Settings\Application Data\{418FAB35-B606-4BB6-8540-3243C15D0633}
    c:\documents and settings\Kari\Local Settings\Application Data\{418FAB35-B606-4BB6-8540-3243C15D0633}\chrome.manifest
    c:\documents and settings\Kari\Local Settings\Application Data\{418FAB35-B606-4BB6-8540-3243C15D0633}\chrome\content\_cfg.js
    c:\documents and settings\Kari\Local Settings\Application Data\{418FAB35-B606-4BB6-8540-3243C15D0633}\chrome\content\overlay.xul
    c:\documents and settings\Kari\Local Settings\Application Data\{418FAB35-B606-4BB6-8540-3243C15D0633}\install.rdf
    c:\documents and settings\Kelsey\Local Settings\Application Data\{613C5EB8-BAD8-456E-A489-1145D13F6720}
    c:\documents and settings\Kelsey\Local Settings\Application Data\{613C5EB8-BAD8-456E-A489-1145D13F6720}\chrome.manifest
    c:\documents and settings\Kelsey\Local Settings\Application Data\{613C5EB8-BAD8-456E-A489-1145D13F6720}\chrome\content\_cfg.js
    c:\documents and settings\Kelsey\Local Settings\Application Data\{613C5EB8-BAD8-456E-A489-1145D13F6720}\chrome\content\overlay.xul
    c:\documents and settings\Kelsey\Local Settings\Application Data\{613C5EB8-BAD8-456E-A489-1145D13F6720}\install.rdf
    c:\documents and settings\Kelsey\WINDOWS
    c:\program files\Common Files\dobe~1
    c:\program files\mantec~1
    c:\program files\smante~1
    c:\program files\wnsxs~1
    c:\temp\fse
    c:\temp\fse\tmpZTF.log
    c:\windows\admintxt.txt
    c:\windows\Downloaded Program Files\popcaploader.dll
    c:\windows\Downloaded Program Files\popcaploader.inf
    c:\windows\ppatch~1
    c:\windows\pppatc~1
    c:\windows\sks~1
    c:\windows\sks~2
    c:\windows\system32\ahgpqybn.ini
    c:\windows\system32\bkymbbgr.ini
    c:\windows\SYSTEM32\CbdLoUvw.ini
    c:\windows\system32\CbdLoUvw.ini2
    c:\windows\SYSTEM32\cbeeg.ini2
    c:\windows\system32\deaflrbd.ini
    c:\windows\system32\dgwmgbdt.ini
    c:\windows\system32\FikTAcdd.ini
    c:\windows\SYSTEM32\FikTAcdd.ini2
    c:\windows\system32\fjweqlfv.ini
    c:\windows\system32\ftkblqoe.ini
    c:\windows\system32\fwqwfulx.ini
    c:\windows\system32\gchivraa.ini
    c:\windows\system32\gxaiefus.ini
    c:\windows\system32\hoxsvaei.ini
    c:\windows\system32\hpbjrnjx.ini
    c:\windows\system32\hRqsuBeg.ini
    c:\windows\SYSTEM32\hRqsuBeg.ini2
    c:\windows\system32\irulstxl.ini
    c:\windows\system32\ivsmtwng.ini
    c:\windows\system32\kgqkbmbe.ini
    c:\windows\SYSTEM32\KlkSYJjl.ini
    c:\windows\system32\KlkSYJjl.ini2
    c:\windows\system32\lfhdrcnv.ini
    c:\windows\system32\lopXwyay.ini
    c:\windows\system32\lopXwyay.ini2
    c:\windows\SYSTEM32\MonnTvut.ini
    c:\windows\SYSTEM32\MonnTvut.ini2
    c:\windows\system32\mqfoxtog.ini
    c:\windows\system32\napetrih.ini
    c:\windows\SYSTEM32\NTtAcccf.ini
    c:\windows\SYSTEM32\NTtAcccf.ini2
    c:\windows\system32\ojhyegox.ini
    c:\windows\system32\phltsdut.ini
    c:\windows\system32\pkcgsmcg.ini
    c:\windows\system32\pmipwjgq.ini
    c:\windows\system32\QAIjlnnn.ini
    c:\windows\system32\QAIjlnnn.ini2
    c:\windows\system32\qsqlhyoc.ini
    c:\windows\system32\qtgmhohq.ini
    c:\windows\system32\racle~1
    c:\windows\system32\sheoatyd.ini
    c:\windows\system32\srcxhdxf.ini
    c:\windows\system32\syvqodsk.ini
    c:\windows\SYSTEM32\TAcIPXyb.ini
    c:\windows\SYSTEM32\TAcIPXyb.ini2
    c:\windows\SYSTEM32\tsDegfii.ini
    c:\windows\system32\tsDegfii.ini2
    c:\windows\system32\uddmqiod.ini
    c:\windows\system32\wdwaomlx.ini
    c:\windows\system32\wiqdtiwd.ini
    c:\windows\system32\wlxwudgg.ini
    c:\windows\system32\wskbtcpi.ini
    c:\windows\system32\xlcbiyys.ini
    c:\windows\system32\xvlckduv.ini
    c:\windows\system32\ydbtunoi.ini
    c:\windows\system32\ystem~1
    c:\windows\wnsxs~1
    ((((((((((((((((((((((((((((((((((((((( Drivers/Services )))))))))))))))))))))))))))))))))))))))))))))))))
  9. 2011/07/02
    Go on.....
  10. 2011/07/02
    Milkman23
    Milkman23 Inactive Thread Starter
    I believe that is all of the logs you have asked for, I have not ran programs or installed any more since my last post. The computer is running great with no problems as of yet. Does it have a clean bill of health or do you need more info?
  11. 2011/07/02
    First of all, I'll ask for the 3rd time:
    Secondly, Combofix log is incomplete.
    Look for C:\combofix.txt and post its content.
  12. 2011/07/02
    Milkman23
    when i try to post the attach.txt it says i have 60 images and I have no idea what that means or how to fix it, so i will post in sections i guess.
    UNLESS SPECIFICALLY INSTRUCTED, DO NOT POST THIS LOG.
    IF REQUESTED, ZIP IT UP & ATTACH IT
    Boot Device: \Device\HarddiskVolume2
    Install Date: 1/21/2004 5:56:52 PM
    System Uptime: 6/27/2011 11:55:25 AM (1 hours ago)
    Motherboard: Dell Computer Corp. | | 0N2828
    Processor: Intel(R) Pentium(R) 4 CPU 2.66GHz | Microprocessor | 2660/533mhz
    ==== Disk Partitions =========================
    A: is Removable
    C: is FIXED (NTFS) - 149 GiB total, 117.63 GiB free.
    D: is CDROM ()
    ==== Disabled Device Manager Items =============
    ==== System Restore Points ===================
    RP1481: 3/24/2011 10:13:21 PM - Software Distribution Service 3.0
    RP1482: 3/26/2011 8:51:13 PM - Software Distribution Service 3.0
    RP1483: 3/27/2011 9:53:22 PM - System Checkpoint
    RP1484: 3/27/2011 11:24:36 PM - Software Distribution Service 3.0
    RP1485: 3/28/2011 11:27:10 PM - System Checkpoint
    RP1486: 3/29/2011 8:38:39 AM - Software Distribution Service 3.0
    RP1487: 3/30/2011 8:52:41 AM - System Checkpoint
    RP1488: 3/30/2011 1:53:25 PM - Software Distribution Service 3.0
    RP1489: 3/31/2011 3:38:46 PM - Software Distribution Service 3.0
    RP1490: 4/1/2011 9:04:35 PM - System Checkpoint
    RP1491: 4/2/2011 10:39:25 AM - Software Distribution Service 3.0
    RP1492: 4/3/2011 1:31:37 PM - System Checkpoint
    RP1493: 4/4/2011 10:09:06 AM - Software Distribution Service 3.0
    RP1494: 4/5/2011 10:35:51 AM - System Checkpoint
    RP1495: 4/5/2011 11:38:37 AM - Software Distribution Service 3.0
    RP1496: 4/6/2011 12:02:18 PM - Software Distribution Service 3.0
    RP1497: 4/7/2011 12:43:54 PM - Software Distribution Service 3.0
    RP1498: 4/8/2011 1:29:18 PM - Software Distribution Service 3.0
    RP1499: 4/9/2011 3:11:59 PM - System Checkpoint
    RP1500: 4/9/2011 6:32:30 PM - Software Distribution Service 3.0
    RP1501: 4/10/2011 3:14:43 AM - Software Distribution Service 3.0
    RP1502: 4/11/2011 10:50:29 AM - Software Distribution Service 3.0
    RP1503: 4/12/2011 7:08:20 PM - Software Distribution Service 3.0
    RP1504: 4/13/2011 8:50:36 PM - System Checkpoint
    RP1505: 4/14/2011 12:56:41 AM - Software Distribution Service 3.0
    RP1506: 4/15/2011 11:28:04 AM - Software Distribution Service 3.0
    RP1507: 4/16/2011 12:58:31 PM - System Checkpoint
    RP1508: 4/16/2011 3:11:55 PM - Software Distribution Service 3.0
    RP1509: 4/17/2011 5:52:32 PM - Software Distribution Service 3.0
    RP1510: 4/18/2011 8:36:02 PM - System Checkpoint
    RP1511: 4/19/2011 4:08:50 PM - Removed NetAssistant
    RP1512: 4/21/2011 11:15:30 AM - System Checkpoint
    RP1513: 4/22/2011 2:46:47 PM - System Checkpoint
    RP1514: 4/23/2011 7:29:02 PM - System Checkpoint
    RP1515: 4/24/2011 9:16:32 PM - System Checkpoint
    RP1516: 4/25/2011 9:18:15 PM - System Checkpoint
    RP1517: 4/26/2011 10:54:16 PM - System Checkpoint
    RP1518: 4/28/2011 11:09:57 AM - System Checkpoint
    RP1519: 4/29/2011 4:32:50 PM - System Checkpoint
    RP1520: 5/1/2011 1:23:11 PM - System Checkpoint
    RP1521: 5/2/2011 2:02:50 PM - System Checkpoint
    RP1522: 5/3/2011 3:43:36 PM - System Checkpoint
    RP1523: 5/4/2011 8:51:36 PM - System Checkpoint
    RP1524: 5/6/2011 10:07:15 AM - System Checkpoint
    RP1525: 5/19/2011 10:04:43 AM - Removed RuneScape Launcher 1.0.4
    RP1526: 6/25/2011 5:17:22 PM - Installed Java(TM) 6 Update 26
  13. 2011/07/02
    Milkman23
    ==== Installed Programs ======================
    Acer eDisplay Management
    Adobe Flash Player 10 ActiveX
    Adobe Reader 8.3.0
    Adobe Shockwave Player 11.5
    Apple Application Support
    Apple Mobile Device Support
    Apple Software Update
    ArtistScope Plugin IE
    Banctec Service Agreement
    BCM V.92 56K Modem
    Bonjour
    Canon Camera Access Library
    Canon DIGITAL CAMERA Solution Disk Software Guide
    CANON iMAGE GATEWAY Task for ZoomBrowser EX
    Canon Internet Library for ZoomBrowser EX
    Canon iP2600 series
    Canon iP2600 series User Registration
    Canon MovieEdit Task for ZoomBrowser EX
    Canon My Printer
    Canon Personal Printing Guide
    Canon PowerShot A495 and PowerShot A490 Camera User Guide
    Canon PowerShot SX120 IS Camera User Guide
    Canon Utilities CameraWindow
    Canon Utilities CameraWindow DC
    Canon Utilities CameraWindow DC 8
    Canon Utilities CameraWindow DC_DV 6 for ZoomBrowser EX
    Canon Utilities Easy-PhotoPrint EX
    Canon Utilities Movie Uploader for YouTube
    Canon Utilities MyCamera
    Canon Utilities MyCamera DC
    Canon Utilities PhotoStitch
    Canon Utilities RemoteCapture Task for ZoomBrowser EX
    Canon Utilities Solution Menu
    Canon Utilities ZoomBrowser EX
    Canon ZoomBrowser EX Memory Card Utility
    Coupon Printer for Windows
    Dell Networking Guide
    Dell Support
    DIGReqEx
    DS21Patch
    Google Earth Plug-in
    Google Toolbar for Internet Explorer
    Google Update Helper
    Help and Support Customization
    Hotfix for Microsoft .NET Framework 3.5 SP1 (KB953595)
    Hotfix for Microsoft .NET Framework 3.5 SP1 (KB958484)
    Hotfix for Windows Media Format 11 SDK (KB929399)
    Hotfix for Windows Media Player 11 (KB939683)
    Hotfix for Windows XP (KB906569)
    Hotfix for Windows XP (KB914440)
    Hotfix for Windows XP (KB915865)
    Hotfix for Windows XP (KB926239)
    Hotfix for Windows XP (KB952287)
    Hotfix for Windows XP (KB954550-v5)
    Hotfix for Windows XP (KB961118)
    Hotfix for Windows XP (KB979306)
    Hotfix for Windows XP (KB981793)
    Intel(R) Extreme Graphics 2 Driver
    Intel(R) PRO Network Adapters and Drivers
    Intel(R) PROSet
    Internet Explorer Default Page
    iTunes
    Jasc Paint Shop Photo Album
    Jasc Paint Shop Pro 8 Dell Edition
    Java Auto Updater
    Malwarebytes' Anti-Malware version 1.51.0.1200
    Microsoft .NET Framework 1.1
    Microsoft .NET Framework 1.1 Security Update (KB979906)
    Microsoft .NET Framework 2.0 Service Pack 2
    Microsoft .NET Framework 3.0 Service Pack 2
    Microsoft Application Error Reporting
    Microsoft Choice Guard
    Microsoft Compression Client Pack 1.0 for Windows XP
    Microsoft Data Access Components KB870669
    Microsoft Encarta Encyclopedia Standard 2004
    Microsoft Game Studios Common Redistributables Pack 1
    Microsoft Internationalized Domain Names Mitigation APIs
    Microsoft National Language Support Downlevel APIs
    Microsoft Silverlight
    Microsoft Text-to-Speech Engine 4.0 (English)
    Microsoft User-Mode Driver Framework Feature Pack 1.0
    Microsoft Visual C++ 2005 ATL Update kb973923 - x86 8.0.50727.4053
    Microsoft Visual C++ 2005 Redistributable
    Microsoft Visual C++ 2008 ATL Update kb973924 - x86 9.0.30729.4148
    Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.17
    Microsoft XML Parser
    Modem Helper
    MSN
    MSN Encarta Plus Support Files
    MSN Music Assistant
    MSN Toolbar
    MSVCRT
    MSXML 4.0 SP2 (KB927978)
    MSXML 4.0 SP2 (KB936181)
    MSXML 4.0 SP2 (KB954430)
    MSXML 4.0 SP2 (KB973688)
    MSXML 4.0 SP2 Parser and SDK
    MSXML 6 Service Pack 2 (KB973686)
    MyDSC2
    OLYMPUS Master
    Pivot Software
    PIXMA Extended Survey Program
    QuickTime
    Qwest QuickCare
    RealOne Player
    SDK
    Security Update for Step By Step Interactive Training (KB898458)
    Security Update for Step By Step Interactive Training (KB923723)
    Security Update for Windows Internet Explorer 8 (KB971961)
    Security Update for Windows Internet Explorer 8 (KB981332)
    Security Update for Windows Internet Explorer 8 (KB982381)
    Security Update for Windows Media Player (KB911564)
    Security Update for Windows Media Player (KB952069)
    Security Update for Windows Media Player (KB954155)
    Security Update for Windows Media Player (KB968816)
    Security Update for Windows Media Player (KB973540)
    Security Update for Windows Media Player (KB978695)
    Security Update for Windows Media Player 10 (KB911565)
    Security Update for Windows Media Player 10 (KB917734)
    Security Update for Windows Media Player 11 (KB936782)
    Security Update for Windows Media Player 11 (KB954154)
    Security Update for Windows Media Player 6.4 (KB925398)
    Security Update for Windows XP (KB2229593)
    Security Update for Windows XP (KB883939)
    Security Update for Windows XP (KB890046)
    Security Update for Windows XP (KB893756)
    Security Update for Windows XP (KB896358)
    Security Update for Windows XP (KB896422)
    Security Update for Windows XP (KB896423)
    Security Update for Windows XP (KB896424)
    Security Update for Windows XP (KB896428)
    Security Update for Windows XP (KB896688)
    Security Update for Windows XP (KB899587)
    Security Update for Windows XP (KB899588)
    Security Update for Windows XP (KB899591)
    Security Update for Windows XP (KB900725)
    Security Update for Windows XP (KB901017)
    Security Update for Windows XP (KB901190)
    Security Update for Windows XP (KB901214)
    Security Update for Windows XP (KB902400)
    Security Update for Windows XP (KB903235)
    Security Update for Windows XP (KB904706)
    Security Update for Windows XP (KB905414)
    Security Update for Windows XP (KB905749)
    Security Update for Windows XP (KB905915)
    Security Update for Windows XP (KB908519)
    Security Update for Windows XP (KB908531)
    Security Update for Windows XP (KB911562)
    Security Update for Windows XP (KB911567)
    Security Update for Windows XP (KB911927)
    Security Update for Windows XP (KB912812)
    Security Update for Windows XP (KB912919)
    Security Update for Windows XP (KB913446)
    Security Update for Windows XP (KB913580)
    Security Update for Windows XP (KB914388)
    Security Update for Windows XP (KB914389)
    Security Update for Windows XP (KB916281)
    Security Update for Windows XP (KB917159)
    Security Update for Windows XP (KB917344)
    Security Update for Windows XP (KB917422)
    Security Update for Windows XP (KB917953)
    Security Update for Windows XP (KB918118)
    Security Update for Windows XP (KB918439)
    Security Update for Windows XP (KB918899)
    Security Update for Windows XP (KB919007)
    Security Update for Windows XP (KB920213)
    Security Update for Windows XP (KB920214)
    Security Update for Windows XP (KB920670)
    Security Update for Windows XP (KB920683)
    Security Update for Windows XP (KB920685)
    Security Update for Windows XP (KB921398)
    Security Update for Windows XP (KB921503)
    Security Update for Windows XP (KB921883)
    Security Update for Windows XP (KB922616)
    Security Update for Windows XP (KB922760)
    Security Update for Windows XP (KB922819)
    Security Update for Windows XP (KB923191)
    Security Update for Windows XP (KB923414)
    Security Update for Windows XP (KB923561)
    Security Update for Windows XP (KB923689)
    Security Update for Windows XP (KB923694)
    Security Update for Windows XP (KB923980)
    Security Update for Windows XP (KB924191)
    Security Update for Windows XP (KB924270)
    Security Update for Windows XP (KB924496)
    Security Update for Windows XP (KB924667)
    Security Update for Windows XP (KB925486)
    Security Update for Windows XP (KB925902)
    Security Update for Windows XP (KB926255)
    Security Update for Windows XP (KB926436)
    Security Update for Windows XP (KB927779)
    Security Update for Windows XP (KB927802)
    Security Update for Windows XP (KB928255)
    Security Update for Windows XP (KB928843)
    Security Update for Windows XP (KB929123)
    Security Update for Windows XP (KB930178)
    Security Update for Windows XP (KB931261)
    Security Update for Windows XP (KB931784)
    Security Update for Windows XP (KB932168)
    Security Update for Windows XP (KB933729)
    Security Update for Windows XP (KB935839)
    Security Update for Windows XP (KB935840)
    Security Update for Windows XP (KB936021)
    Security Update for Windows XP (KB938829)
    Security Update for Windows XP (KB941202)
    Security Update for Windows XP (KB941568)
    Security Update for Windows XP (KB941569)
    Security Update for Windows XP (KB941644)
    Security Update for Windows XP (KB941693)
    Security Update for Windows XP (KB943055)
    Security Update for Windows XP (KB943460)
    Security Update for Windows XP (KB943485)
    Security Update for Windows XP (KB944653)
    Security Update for Windows XP (KB945553)
    Security Update for Windows XP (KB946026)
    Security Update for Windows XP (KB946648)
    Security Update for Windows XP (KB948590)
    Security Update for Windows XP (KB948881)
    Security Update for Windows XP (KB950749)
    Security Update for Windows XP (KB950760)
    Security Update for Windows XP (KB950762)
    Security Update for Windows XP (KB950974)
    Security Update for Windows XP (KB951066)
    Security Update for Windows XP (KB951376-v2)
    Security Update for Windows XP (KB951376)
    Security Update for Windows XP (KB951698)
    Security Update for Windows XP (KB951748)
    Security Update for Windows XP (KB952004)
    Security Update for Windows XP (KB952954)
    Security Update for Windows XP (KB955069)
    Security Update for Windows XP (KB956572)
    Security Update for Windows XP (KB956802)
    Security Update for Windows XP (KB956803)
    Security Update for Windows XP (KB956844)
    Security Update for Windows XP (KB958470)
    Security Update for Windows XP (KB958644)
    Security Update for Windows XP (KB958869)
    Security Update for Windows XP (KB959426)
    Security Update for Windows XP (KB960225)
    Security Update for Windows XP (KB960803)
    Security Update for Windows XP (KB960859)
    Security Update for Windows XP (KB961501)
    Security Update for Windows XP (KB969059)
    Security Update for Windows XP (KB969947)
    Security Update for Windows XP (KB970238)
    Security Update for Windows XP (KB970430)
    Security Update for Windows XP (KB971468)
    Security Update for Windows XP (KB971657)
    Security Update for Windows XP (KB972270)
    Security Update for Windows XP (KB973354)
    Security Update for Windows XP (KB973507)
    Security Update for Windows XP (KB973869)
    Security Update for Windows XP (KB973904)
    Security Update for Windows XP (KB974112)
    Security Update for Windows XP (KB974318)
    Security Update for Windows XP (KB974392)
    Security Update for Windows XP (KB974571)
    Security Update for Windows XP (KB975025)
    Security Update for Windows XP (KB975467)
    Security Update for Windows XP (KB975560)
    Security Update for Windows XP (KB975561)
    Security Update for Windows XP (KB975562)
    Security Update for Windows XP (KB975713)
    Security Update for Windows XP (KB977816)
    Security Update for Windows XP (KB977914)
    Security Update for Windows XP (KB978037)
    Security Update for Windows XP (KB978262)
    Security Update for Windows XP (KB978338)
    Security Update for Windows XP (KB978542)
    Security Update for Windows XP (KB978601)
    Security Update for Windows XP (KB978706)
    Security Update for Windows XP (KB979309)
    Security Update for Windows XP (KB979482)
    Security Update for Windows XP (KB979559)
    Security Update for Windows XP (KB979683)
    Security Update for Windows XP (KB980195)
    Security Update for Windows XP (KB980218)
    Security Update for Windows XP (KB980232)
    Segoe UI
    Shockwave
    Sonic DLA
    Sonic RecordNow!
    Sonic Update Manager
    Update for Microsoft .NET Framework 3.5 SP1 (KB963707)
    Update for Windows Internet Explorer 8 (KB976662)
    Update for Windows Internet Explorer 8 (KB980182)
    Update for Windows XP (KB894391)
    Update for Windows XP (KB896727)
    Update for Windows XP (KB898461)
    Update for Windows XP (KB900485)
    Update for Windows XP (KB904942)
    Update for Windows XP (KB910437)
    Update for Windows XP (KB911280)
    Update for Windows XP (KB914882)
    Update for Windows XP (KB916595)
    Update for Windows XP (KB920872)
    Update for Windows XP (KB922582)
    Update for Windows XP (KB925720)
    Update for Windows XP (KB927891)
    Update for Windows XP (KB929338)
    Update for Windows XP (KB930916)
    Update for Windows XP (KB931836)
    Update for Windows XP (KB933360)
    Update for Windows XP (KB936357)
    Update for Windows XP (KB938828)
    Update for Windows XP (KB942763)
    Update for Windows XP (KB955759)
    Update for Windows XP (KB961503)
    Update for Windows XP (KB967715)
    Update for Windows XP (KB968389)
    Update for Windows XP (KB971737)
    Update for Windows XP (KB973687)
    Update for Windows XP (KB973815)
    Viewpoint Media Player
    VoiceOver Kit
    WebFldrs XP
    Windows Genuine Advantage Notifications (KB905474)
    Windows Imaging Component
    Windows Installer 3.1 (KB893803)
    Windows Live Call
    Windows Live Communications Platform
    Windows Live Essentials
    Windows Live Messenger
    Windows Live OneCare safety scanner
    Windows Live Sign-in Assistant
    Windows Live Upload Tool
    Windows Media Format 11 runtime
    Windows Presentation Foundation
    Windows XP Hotfix - KB834707
    Windows XP Hotfix - KB867282
    Windows XP Hotfix - KB873333
    Windows XP Hotfix - KB873339
    Windows XP Hotfix - KB885250
    Windows XP Hotfix - KB885835
    Windows XP Hotfix - KB885836
    Windows XP Hotfix - KB886185
    Windows XP Hotfix - KB887472
    Windows XP Hotfix - KB887742
    Windows XP Hotfix - KB888113
    Windows XP Hotfix - KB888240
    Windows XP Hotfix - KB888302
    Windows XP Hotfix - KB890047
    Windows XP Hotfix - KB890175
    Windows XP Hotfix - KB890859
    Windows XP Hotfix - KB890923
    Windows XP Hotfix - KB891781
    Windows XP Hotfix - KB893066
    Windows XP Hotfix - KB893086
    Windows XP Service Pack 2
    WordPerfect Office 11
    XML Paper Specification Shared Components Pack 1.0
  14. 2011/07/02
    Milkman23
    ==== Event Viewer Messages From Past Week ========
    6/27/2011 9:37:14 AM, error: Microsoft Antimalware [1119] - Microsoft Antimalware has encountered a critical error when taking action on malware or other potentially unwanted software. For more information please see the following: http://go.microsoft.com/fwlink/?linkid=37020&name=Trojan:DOS/Alureon.A&threatid=2147636949 Name: Trojan:DOS/Alureon.A ID: 2147636949 Severity: Severe Category: Trojan Path: rootkit:_AlureonMbr Detection Origin: Unknown Detection Type: Concrete Detection Source: System User: NT AUTHORITY\SYSTEM Process Name: Unknown Action: Remove Action Status: To finish removing malware and other potentially unwanted software, restart the computer. To see how to finish removing malware and other potentially unwanted software, see the support article on the Microsoft Security website. Error Code: 0x80070032 Error description: The request is not supported. Signature Version: AV: 1.107.249.0, AS: 1.107.249.0, NIS: 0.0.0.0 Engine Version: AM: 1.1.7000.0, NIS: 0.0.0.0
    6/27/2011 8:34:59 AM, error: Microsoft Antimalware [1119] - Microsoft Antimalware has encountered a critical error when taking action on malware or other potentially unwanted software. For more information please see the following: http://go.microsoft.com/fwlink/?linkid=37020&name=Trojan:DOS/Alureon.A&threatid=2147636949 Name: Trojan:DOS/Alureon.A ID: 2147636949 Severity: Severe Category: Trojan Path: rootkit:_AlureonMbr Detection Origin: Unknown Detection Type: Concrete Detection Source: System User: NT AUTHORITY\SYSTEM Process Name: Unknown Action: Remove Action Status: To finish removing malware and other potentially unwanted software, restart the computer. To see how to finish removing malware and other potentially unwanted software, see the support article on the Microsoft Security website. Error Code: 0x80070032 Error description: The request is not supported. Signature Version: AV: 1.107.249.0, AS: 1.107.249.0, NIS: 0.0.0.0 Engine Version: AM: 1.1.7000.0, NIS: 0.0.0.0
    6/27/2011 12:15:51 AM, error: Microsoft Antimalware [1119] - Microsoft Antimalware has encountered a critical error when taking action on malware or other potentially unwanted software. For more information please see the following: http://go.microsoft.com/fwlink/?linkid=37020&name=Trojan:DOS/Alureon.A&threatid=2147636949 Name: Trojan:DOS/Alureon.A ID: 2147636949 Severity: Severe Category: Trojan Path: rootkit:_AlureonMbr Detection Origin: Unknown Detection Type: Concrete Detection Source: System User: NT AUTHORITY\SYSTEM Process Name: Unknown Action: Remove Action Status: To finish removing malware and other potentially unwanted software, restart the computer. To see how to finish removing malware and other potentially unwanted software, see the support article on the Microsoft Security website. Error Code: 0x80070032 Error description: The request is not supported. Signature Version: AV: 1.107.249.0, AS: 1.107.249.0, NIS: 0.0.0.0 Engine Version: AM: 1.1.7000.0, NIS: 0.0.0.0
    6/27/2011 12:07:44 PM, error: Microsoft Antimalware [1119] - Microsoft Antimalware has encountered a critical error when taking action on malware or other potentially unwanted software. For more information please see the following: http://go.microsoft.com/fwlink/?linkid=37020&name=Trojan:DOS/Alureon.A&threatid=2147636949 Name: Trojan:DOS/Alureon.A ID: 2147636949 Severity: Severe Category: Trojan Path: file:_C:\Documents and Settings\James\Desktop\MBR.dat;rootkit:_AlureonMbr Detection Origin: Local machine Detection Type: Concrete Detection Source: System User: NT AUTHORITY\SYSTEM Process Name: C:\Documents and Settings\James\Desktop\aswMBR.exe Action: Remove Action Status: To finish removing malware and other potentially unwanted software, restart the computer. To see how to finish removing malware and other potentially unwanted software, see the support article on the Microsoft Security website. Error Code: 0x80070032 Error description: The request is not supported. Signature Version: AV: 1.107.249.0, AS: 1.107.249.0, NIS: 0.0.0.0 Engine Version: AM: 1.1.7000.0, NIS: 0.0.0.0
    6/27/2011 11:56:25 AM, error: Microsoft Antimalware [2001] - Microsoft Antimalware has encountered an error trying to update signatures. New Signature Version: Previous Signature Version: 1.107.249.0 Update Source: Microsoft Update Server Update Stage: Search Source Path: Default URL Signature Type: AntiVirus Update Type: Full User: NT AUTHORITY\SYSTEM Current Engine Version: Previous Engine Version: 1.1.7000.0 Error code: 0x80070424 Error description: The specified service does not exist as an installed service.
  15. 2011/07/02
    Milkman23
    6/25/2011 2:51:34 PM, error: Service Control Manager [7032] - The Service Control Manager tried to take a corrective action (Restart the service) after the unexpected termination of the Windows Management Instrumentation service, but this action failed with the following error: An instance of the service is already running.
    6/25/2011 11:58:31 PM, error: Microsoft Antimalware [1119] - Microsoft Antimalware has encountered a critical error when taking action on malware or other potentially unwanted software. For more information please see the following: http://go.microsoft.com/fwlink/?linkid=37020&name=Trojan:DOS/Alureon.A&threatid=2147636949 Name: Trojan:DOS/Alureon.A ID: 2147636949 Severity: Severe Category: Trojan Path: rootkit:_AlureonMbr Detection Origin: Unknown Detection Type: Concrete Detection Source: System User: NT AUTHORITY\SYSTEM Process Name: Unknown Action: Remove Action Status: To finish removing malware and other potentially unwanted software, restart the computer. To see how to finish removing malware and other potentially unwanted software, see the support article on the Microsoft Security website. Error Code: 0x80070032 Error description: The request is not supported. Signature Version: AV: 1.107.249.0, AS: 1.107.249.0, NIS: 0.0.0.0 Engine Version: AM: 1.1.7000.0, NIS: 0.0.0.0
    6/24/2011 4:25:03 PM, error: Microsoft Antimalware [2001] - Microsoft Antimalware has encountered an error trying to update signatures. New Signature Version: Previous Signature Version: 1.107.249.0 Update Source: Microsoft Update Server Update Stage: Search Source Path: Default URL Signature Type: AntiVirus Update Type: Full User: NT AUTHORITY\SYSTEM Current Engine Version: Previous Engine Version: 1.1.7000.0 Error code: 0x80070424 Error description: The specified service does not exist as an installed service.
    ==== End Of File ===========================
  16. 2011/07/02
    Milkman23
    And Finally:
    ComboFix 11-07-01.02 - James 07/02/2011 11:40:27.2.1 - x86
    Microsoft Windows XP Home Edition 5.1.2600.2.1252.1.1033.18.2046.1559 [GMT -7:00]
    AV: Microsoft Security Essentials *Disabled/Updated* {BCF43643-A118-4432-AEDE-D861FCBCFCDF}
    ((((((((((((((((((((((((( Files Created from 2011-06-02 to 2011-07-02 )))))))))))))))))))))))))))))))
    2011-07-02 16:49 . 2011-07-02 16:49 28752 ----a-w- c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{51A758B9-7A12-45DD-944E-CBEDC1E17EBC}\MpKsl79b14fef.sys
    2011-07-02 02:56 . 2011-06-07 15:55 7074640 ----a-w- c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{51A758B9-7A12-45DD-944E-CBEDC1E17EBC}\mpengine.dll
    2011-06-26 02:14 . 2011-05-29 16:11 39984 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
    2011-06-26 02:13 . 2011-05-29 16:11 22712 ----a-w- c:\windows\system32\drivers\mbam.sys
    2011-06-26 00:17 . 2011-06-26 00:17 73728 ----a-w- c:\windows\system32\javacpl.cpl
    2011-06-26 00:17 . 2011-01-14 23:18 472808 ----a-w- c:\windows\system32\deployJava1.dll
    2011-06-07 15:55 . 2010-04-28 15:25 7074640 ----a-w- c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\Backup\mpengine.dll
    2011-05-25 02:14 . 2010-04-27 14:52 222080 ------w- c:\windows\system32\MpSigStub.exe
    2011-04-27 10:09 . 2011-04-26 11:13 0 ----a-w- c:\documents and settings\Kari\Local Settings\Application Data\Xpoxohewazuco.bin
    2011-04-26 16:57 . 2010-04-27 14:19 16968 ----a-w- c:\windows\system32\drivers\hitmanpro35.sys
    ((((((((((((((((((((((((((((( SnapShot@2011-07-02_02.19.06 )))))))))))))))))))))))))))))))))))))))))
    + 2011-07-02 16:49 . 2011-07-02 16:49 16384 c:\windows\Temp\Perflib_Perfdata_148.dat
    + 2010-06-05 09:32 . 2011-07-02 08:35 49152 c:\windows\Installer\{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}\ConfigIcon.dll
    - 2010-06-05 09:32 . 2011-02-15 05:20 49152 c:\windows\Installer\{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}\ConfigIcon.dll
    + 2009-05-25 05:25 . 2011-07-02 04:08 49152 c:\windows\.jagex_cache_32\runescape\jagmisc.dll
    - 2009-05-25 05:25 . 2011-07-01 03:24 49152 c:\windows\.jagex_cache_32\runescape\jagmisc.dll
    + 2010-05-28 23:22 . 2011-07-02 04:08 81920 c:\windows\.jagex_cache_32\runescape\hw3d.dll
    - 2010-05-28 23:22 . 2011-07-01 03:24 81920 c:\windows\.jagex_cache_32\runescape\hw3d.dll
    + 2010-02-21 23:55 . 2011-07-02 04:08 937984 c:\windows\.jagex_cache_32\runescape\sw3d.dll
    - 2010-02-21 23:55 . 2011-07-01 03:24 937984 c:\windows\.jagex_cache_32\runescape\sw3d.dll
    + 2009-05-25 05:25 . 2011-07-02 04:08 137216 c:\windows\.jagex_cache_32\runescape\jaggl.dll
    - 2009-05-25 05:25 . 2011-07-01 03:24 137216 c:\windows\.jagex_cache_32\runescape\jaggl.dll
    - 2010-05-28 23:22 . 2011-07-01 03:24 102400 c:\windows\.jagex_cache_32\runescape\jagdx.dll
    + 2010-05-28 23:22 . 2011-07-02 04:08 102400 c:\windows\.jagex_cache_32\runescape\jagdx.dll
    - 2010-05-28 23:22 . 2011-07-01 03:24 148992 c:\windows\.jagex_cache_32\runescape\jaclib.dll
    + 2010-05-28 23:22 . 2011-07-02 04:08 148992 c:\windows\.jagex_cache_32\runescape\jaclib.dll
    + 2011-07-02 08:34 . 2011-07-02 08:34 20333056 c:\windows\Installer\6e71c7.msp
    "MSC "= "c:\program files\Microsoft Security Client\msseces.exe" [2010-11-30 997408]
    "QuickTime Task "= "c:\program files\QuickTime\qttask.exe" [2010-11-30 421888]
    "iTunesHelper "= "c:\program files\iTunes\iTunesHelper.exe" [2011-01-25 421160]
    "PivotSoftware "= "c:\program files\Portrait Displays\Pivot Software\wpctrl.exe" [2007-02-09 694008]
    "DT ACR "= "c:\program files\Common Files\Portrait Displays\Shared\DT_startup.exe" [2009-08-25 81920]
    "Adobe Reader Speed Launcher "= "c:\program files\Adobe\Reader 8.0\Reader\Reader_sl.exe" [2011-05-27 40368]
    "Adobe ARM "= "c:\program files\Common Files\Adobe\ARM\1.0\AdobeARM.exe" [2011-03-30 937920]
    [HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Run]
    "DWQueuedReporting "= "c:\progra~1\COMMON~1\MICROS~1\DW\dwtrig20.exe" [2007-02-26 437160]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MsMpSvc]
    @= "Service "
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Adobe Reader Speed Launcher]
    2011-05-27 21:52 40368 ----a-w- c:\program files\Adobe\Reader 8.0\Reader\reader_sl.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\CanonMyPrinter]
    2007-09-14 01:50 1603152 ----a-w- c:\program files\Canon\MyPrinter\BJMYPRT.EXE
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\CanonSolutionMenu]
    2007-10-26 01:10 652624 ----a-w- c:\program files\Canon\SolutionMenu\CNSLMAIN.EXE
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\iTunesHelper]
    2011-01-25 23:08 421160 ----a-w- c:\program files\iTunes\iTunesHelper.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\MSMSGS]
    2004-10-13 16:24 1694208 ------w- c:\program files\Messenger\msmsgs.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\QuickTime Task]
    2010-11-30 01:38 421888 ----a-w- c:\program files\QuickTime\QTTask.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\TkBellExe]
    2004-01-15 00:40 151597 ----a-w- c:\program files\Common Files\Real\Update_OB\realsched.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\security center]
    "AntiVirusOverride "=dword:00000001
    "FirewallOverride "=dword:00000001
    R1 MpKsl79b14fef;MpKsl79b14fef;c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{51A758B9-7A12-45DD-944E-CBEDC1E17EBC}\MpKsl79b14fef.sys [7/2/2011 9:49 AM 28752]
    R2 PdiService;Portrait Displays SDK Service;c:\program files\Common Files\Portrait Displays\Drivers\pdisrvc.exe [2/16/2011 2:22 AM 109168]
    S1 MpKsl28583a7a;MpKsl28583a7a;\??\c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{37B381FB-89FA-43AC-A2A8-8CCAC7E1086A}\MpKsl28583a7a.sys --> c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{37B381FB-89FA-43AC-A2A8-8CCAC7E1086A}\MpKsl28583a7a.sys [?]
    S1 MpKsl3b684326;MpKsl3b684326;\??\c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{ED4E103C-01EB-415C-B4B4-4535E44AA3BF}\MpKsl3b684326.sys --> c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{ED4E103C-01EB-415C-B4B4-4535E44AA3BF}\MpKsl3b684326.sys [?]
    S1 MpKsl53f7aeaf;MpKsl53f7aeaf;\??\c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{EB78CEF2-AD35-4266-8DF5-3D6B97B60C9B}\MpKsl53f7aeaf.sys --> c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{EB78CEF2-AD35-4266-8DF5-3D6B97B60C9B}\MpKsl53f7aeaf.sys [?]
    S1 MpKsla5197085;MpKsla5197085;\??\c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{90D430C6-00ED-4CB4-AF43-90824F222E38}\MpKsla5197085.sys --> c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{90D430C6-00ED-4CB4-AF43-90824F222E38}\MpKsla5197085.sys [?]
    S1 MpKsle86772d0;MpKsle86772d0;\??\c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{C9460285-6BCE-43E2-A058-2C55AC9ABAA6}\MpKsle86772d0.sys --> c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{C9460285-6BCE-43E2-A058-2C55AC9ABAA6}\MpKsle86772d0.sys [?]
    S2 CSHelper;CopySafe Helper Service;c:\windows\SYSTEM32\CSHelper.exe [1/16/2010 3:59 PM 266240]
    S2 gupdate;Google Update Service (gupdate);c:\program files\Google\Update\GoogleUpdate.exe [2/16/2010 5:37 PM 135664]
    S2 HitmanPro35CrusaderBoot;Hitman Pro 3.5 Crusader (Boot); "c:\documents and settings\James\Local Settings\Temporary Internet Files\Content.IE5\6JLCFOSK\HitmanPro35[1].exe" /crusader:boot --> c:\documents and settings\James\Local Settings\Temporary Internet Files\Content.IE5\6JLCFOSK\HitmanPro35[1].exe [?]
    S3 gupdatem;Google Update Service (gupdatem);c:\program files\Google\Update\GoogleUpdate.exe [2/16/2010 5:37 PM 135664]
    *NewlyCreated* - MPKSL79B14FEF
    2011-05-06 c:\windows\Tasks\AppleSoftwareUpdate.job
    - c:\program files\Apple Software Update\SoftwareUpdate.exe [2009-10-22 19:50]
    2011-07-02 c:\windows\Tasks\GoogleUpdateTaskMachineCore1cc202b92d88e10.job
    - c:\program files\Google\Update\GoogleUpdate.exe [2010-02-17 00:37]
    2011-07-02 c:\windows\Tasks\GoogleUpdateTaskMachineUA.job
    2011-07-02 c:\windows\Tasks\MP Scheduled Scan.job
    - c:\program files\Microsoft Security Client\Antimalware\MpCmdRun.exe [2010-11-11 20:26]
    2011-07-02 c:\windows\Tasks\User_Feed_Synchronization-{99C7E015-A9F4-4734-9BD9-487DD37545E8}.job
    - c:\windows\system32\msfeedssync.exe [2006-10-17 11:31]
    uInternet Connection Wizard,ShellNext = iexplore
    uInternet Settings,ProxyOverride = <local>;*.local
    TCP: DhcpNameServer = 192.168.0.1 205.171.3.25
    Rootkit scan 2011-07-02 11:48
    Windows 5.1.2600 Service Pack 2 NTFS
    scanning hidden processes ...
    scanning hidden files ...
    scan completed successfully
    hidden files: 0
    [HKEY_LOCAL_MACHINE\System\ControlSet001\Services\HitmanPro35CrusaderBoot]
    "ImagePath "= "\ "c:\documents and settings\James\Local Settings\Temporary Internet Files\Content.IE5\6JLCFOSK\HitmanPro35
    [1].exe\" /crusader:boot "
    [HKEY_USERS\S-1-5-21-3467059179-3465910588-4126901205-1007\RemoteAccess\Profile\x *]
    "EnableAutodisconnect "=dword:00000001
    "EnableExitDisconnect "=dword:00000001
    "DisconnectIdleTime "=dword:00000014
    [HKEY_USERS\S-1-5-21-3467059179-3465910588-4126901205-1007\Software\Microsoft\SystemCertificates\AddressBook*]
    @Allowed: (Read) (RestrictedCode)
    [HKEY_USERS\S-1-5-21-3467059179-3465910588-4126901205-1007\Software\SecuRom\!CAUTION! NEVER A OR CHANGE ANY KEY*]
    "???????????????????????? "=hex:ac,69,36,31,c5,6b,88,7a,77,f5,4c,42,1e,3e,f2,0e,
    06,94,30,e9,e9,c3,ab,94,94,ab,06,06,f4,70,94,60,00,00,00,00,00,00,00,00,00,\
    [HKEY_LOCAL_MACHINE\System\ControlSet001\Enum\HID\Vid_046d&Pid_c018\6&3b2e9ec3&0&0000\LogConf]
    @DACL=(02 0000)
    - - - - - - - > 'explorer.exe'(2660)
    c:\windows\system32\WININET.dll
    c:\windows\system32\ieframe.dll
    c:\program files\Portrait Displays\Pivot Software\winphook.dll
    c:\windows\system32\webcheck.dll
    c:\windows\system32\WPDShServiceObj.dll
    c:\windows\system32\PortableDeviceTypes.dll
    c:\windows\system32\PortableDeviceApi.dll
    Completion time: 2011-07-02 11:51:05
    ComboFix-quarantined-files.txt 2011-07-02 18:51
    ComboFix2.txt 2011-07-02 02:32
    Pre-Run: 127,853,703,168 bytes free
    Post-Run: 127,952,986,112 bytes free
    - - End Of File - - 33963702DBF4D161C5832E5230D558C4
  17. 2011/07/02
    Thanks for Attach.txt :)
    I can see that you re-run Combofix instead of posting the original log.
    I still need to see it.
    Navigate to C:\Qoobox folder and post a content of ComboFix2.txt log.
    BTW, how is computer doing?
  18. 2011/07/02
    Milkman23
    Comp is running great!! not a problem since i ran the TDSSKiller and Combofix
    c:\temp\fse
    c:\windows\ppatch~1
    c:\windows\pppatc~1
    c:\windows\sks~1
    c:\windows\sks~2
    c:\windows\wnsxs~1
    -------\Legacy_FOPN
    2011-07-02 02:18 . 2011-07-02 02:18 28752 ----a-w- c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{EB78CEF2-AD35-4266-8DF5-3D6B97B60C9B}\MpKsl7cfc6d52.sys
    2011-06-29 20:23 . 2011-06-07 15:55 7074640 ----a-w- c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{EB78CEF2-AD35-4266-8DF5-3D6B97B60C9B}\mpengine.dll
    @= "Service "
    HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\24380071
    R1 MpKsl7cfc6d52;MpKsl7cfc6d52;c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{EB78CEF2-AD35-4266-8DF5-3D6B97B60C9B}\MpKsl7cfc6d52.sys [7/1/2011 7:18 PM 28752]
    R2 CSHelper;CopySafe Helper Service;c:\windows\SYSTEM32\CSHelper.exe [1/16/2010 3:59 PM 266240]
    *NewlyCreated* - MPKSL7CFC6D52
    *NewlyCreated* - WUAUSERV
    2011-06-01 c:\windows\Tasks\GoogleUpdateTaskMachineCore1cc202b92d88e10.job
    BHO-{2A32EFE1-1ACD-4CF7-9F72-3C2CC28880A1} - (no file)
    BHO-{3CEFE32A-6805-4F77-BBEE-DC3C32C0F9A6} - (no file)
    BHO-{41833C93-EE9E-472F-9DB9-8CB402659890} - (no file)
    BHO-{4664BAA6-DB16-4836-B878-EBA3338F3734} - (no file)
    BHO-{542adc8c-4f73-4c17-9394-c0fd51d0398e} - (no file)
    BHO-{5C9E9E35-9524-4DCF-94F0-3F03AB5F88F8} - (no file)
    BHO-{6FED410D-73D1-4FB7-A466-B22FA391FA5D} - (no file)
    BHO-{73BDEA63-5750-4ABB-A7E8-F079B2E370A4} - (no file)
    BHO-{74BCF4CF-EB01-463A-8F3B-065286F9C275} - (no file)
    BHO-{75AEE836-9155-44E0-96E7-7BA042ED6E74} - (no file)
    BHO-{87a930ec-bc4b-4388-a3e5-2e574308fd84} - (no file)
    BHO-{8963fe7a-d87a-4ff6-822a-0f5b437cd5f9} - (no file)
    BHO-{AFB67358-50B6-46A8-8BBE-0B42980B91D3} - (no file)
    BHO-{B2814E74-88CB-4A28-949E-1A4F99F6BDF9} - (no file)
    BHO-{C28132D3-A042-D2B2-159B-AA8F032629EC} - (no file)
    BHO-{C74F5288-9E3A-40B3-9423-6D9019A2CCF0} - (no file)
    BHO-{D3F2AFFE-FCA4-4334-800C-5608ABF05B02} - (no file)
    BHO-{FB55771D-45B3-44A4-BDBF-5E27D7D4DDCF} - (no file)
    Toolbar-SITEguard - (no file)
    WebBrowser-{604BC32A-9680-40D1-9AC6-E06B23A1BA4C} - (no file)
    HKCU-Run-Yahoo! Pager - c:\program files\Yahoo!\Messenger\YahooMessenger.exe
    HKCU-Run-AntiVirus_AntiSpyware_2011 - c:\documents and settings\James\Application Data\AntiVirus_AntiSpyware_2011\AntiVirus AntiSpyware.exe
    MSConfigStartUp-SunJavaUpdateSched - c:\program files\Java\jre6\bin\jusched.exe
    MSConfigStartUp-Yahoo! Pager - c:\progra~1\Yahoo!\MESSEN~1\YAHOOM~1.EXE
    Rootkit scan 2011-07-01 19:19
    hidden files: 0
    @DACL=(02 0000)
    - - - - - - - > 'explorer.exe'(1572)
    c:\program files\ArcSoft\PhotoImpression 5\share\pihook.dll
    ------------------------ Other Running Processes ------------------------
    c:\program files\Microsoft Security Client\Antimalware\MsMpEng.exe
    c:\windows\system32\LEXBCES.EXE
    c:\windows\system32\LEXPPS.EXE
    c:\program files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
    c:\program files\Bonjour\mDNSResponder.exe
    c:\program files\Common Files\Portrait Displays\Shared\DTSRVC.exe
    c:\program files\Canon\IJPLM\IJPLMSVC.EXE
    c:\program files\Java\jre6\bin\jqs.exe
    c:\windows\system32\UAService7.exe
    c:\program files\Canon\CAL\CALMAIN.exe
    c:\program files\Portrait Displays\Pivot Software\floater.exe
    c:\program files\Acer Display\eDisplay Management\DTHtml.exe
    c:\program files\iPod\bin\iPodService.exe
    c:\program files\Common Files\Portrait Displays\Shared\HookManager.exe
    c:\program files\Common Files\Portrait Displays\Drivers\pdiSdkHelper.exe
    Completion time: 2011-07-01 19:32:12 - machine was rebooted
    ComboFix-quarantined-files.txt 2011-07-02 02:32
    Pre-Run: 126,205,915,136 bytes free
    Post-Run: 127,978,274,816 bytes free
    WindowsXP-KB310994-SP2-Home-BootDisk-ENU.exe
    [boot loader]
    timeout=2
    default=multi(0)disk(0)rdisk(0)partition(2)\WINDOWS
    [operating systems]
    c:\cmdcons\BOOTSECT.DAT= "Microsoft Windows Recovery Console" /cmdcons
    UnsupportedDebug= "do not select this" /debug
    multi(0)disk(0)rdisk(0)partition(2)\WINDOWS= "Microsoft Windows XP Home Edition" /fastdetect /NoExecute=OptIn
    - - End Of File - - BF096263CED5F6BD079D9912D29ED418
  19. 2011/07/02
    Milkman23
    i won't be letting my step son be using this computer any time soon as every time he does I get some kind of malicious program or virus stuck in here.
  20. 2011/07/02
    Hahaha...I'm glad to hear good news though :)
    Combofix log looks good now..
    We'll run couple more scans to make sure nothing else is hiding.
    Download OTL to your Desktop.
    • Double click on the icon to run it. Make sure all other windows are closed and to let it run uninterrupted.
    • Click the Scan All Users checkbox.
    • Under the Custom Scan box paste this in:
    netsvcs
    drivers32
    %SYSTEMDRIVE%\*.*
    %systemroot%\Fonts\*.com
    %systemroot%\Fonts\*.dll
    %systemroot%\Fonts\*.ini
    %systemroot%\Fonts\*.ini2
    %systemroot%\Fonts\*.exe
    %systemroot%\system32\spool\prtprocs\w32x86\*.*
    %systemroot%\REPAIR\*.bak1
    %systemroot%\REPAIR\*.ini
    %systemroot%\*.scr
    %systemroot%\*._sy
    %APPDATA%\Adobe\Update\*.*
    %ALLUSERSPROFILE%\Favorites\*.*
    %APPDATA%\Microsoft\*.*
    %PROGRAMFILES%\*.*
    %APPDATA%\Update\*.*
    %systemroot%\*. /mp /s
    CREATERESTOREPOINT
    %systemroot%\System32\config\*.sav
    %PROGRAMFILES%\bak. /s
    %systemroot%\system32\bak. /s
    %ALLUSERSPROFILE%\Start Menu\*.lnk /x
    %systemroot%\system32\config\systemprofile\*.dat /x
    %systemroot%\*.config
    %systemroot%\system32\*.db
    %APPDATA%\Microsoft\Internet Explorer\Quick Launch\*.lnk /x
    %USERPROFILE%\Desktop\*.exe
    %PROGRAMFILES%\Common Files\*.*
    %systemroot%\*.src
    %systemroot%\install\*.*
    %systemroot%\system32\DLL\*.*
    %systemroot%\system32\HelpFiles\*.*
    %systemroot%\system32\rundll\*.*
    %systemroot%\winn32\*.*
    %systemroot%\Java\*.*
    %systemroot%\system32\test\*.*
    %systemroot%\system32\Rundll32\*.*
    %systemroot%\AppPatch\Custom\*.*
    %APPDATA%\Roaming\Microsoft\Windows\Recent\*.lnk /x
    %PROGRAMFILES%\PC-Doctor\Downloads\*.*
    %PROGRAMFILES%\Internet Explorer\*.tmp
    %PROGRAMFILES%\Internet Explorer\*.dat
    %USERPROFILE%\My Documents\*.exe
    %USERPROFILE%\*.exe
    %systemroot%\ADDINS\*.*
    %systemroot%\assembly\*.bak2
    %systemroot%\Config\*.*
    %systemroot%\REPAIR\*.bak2
    %systemroot%\SECURITY\Database\*.sdb /x
    %systemroot%\SYSTEM\*.bak2
    %systemroot%\Web\*.bak2
    %systemroot%\Driver Cache\*.*
    %PROGRAMFILES%\Mozilla Firefox\0*.exe
    %ProgramFiles%\Microsoft Common\*.*
    %ProgramFiles%\TinyProxy.
    %USERPROFILE%\Favorites\*.url /x
    %systemroot%\system32\*.bk
    %systemroot%\*.te
    %systemroot%\system32\system32\*.*
    %ALLUSERSPROFILE%\*.dat /x
    %systemroot%\system32\drivers\*.rmv
    dir /b "%systemroot%\system32\*.exe" | find /i " " /c
    dir /b "%systemroot%\*.exe" | find /i " " /c
    %PROGRAMFILES%\Microsoft\*.*
    %systemroot%\System32\Wbem\proquota.exe
    %PROGRAMFILES%\Mozilla Firefox\*.dat
    %USERPROFILE%\Cookies\*.txt /x
    %SystemRoot%\system32\fonts\*.*
    %systemroot%\system32\winlog\*.*
    %systemroot%\system32\Language\*.*
    %systemroot%\system32\Settings\*.*
    %systemroot%\system32\*.quo
    %SYSTEMROOT%\AppPatch\*.exe
    %SYSTEMROOT%\inf\*.exe
    %SYSTEMROOT%\Installer\*.exe
    %systemroot%\system32\config\*.bak2
    %systemroot%\system32\Computers\*.*
    %SystemRoot%\system32\Sound\*.*
    %SystemRoot%\system32\SpecialImg\*.*
    %SystemRoot%\system32\code\*.*
    %SystemRoot%\system32\draft\*.*
    %SystemRoot%\system32\MSSSys\*.*
    %ProgramFiles%\Javascript\*.*
    %systemroot%\pchealth\helpctr\System\*.exe /s
    %systemroot%\Web\*.exe
    %systemroot%\system32\msn\*.*
    %systemroot%\system32\*.tro
    %AppData%\Microsoft\Installer\msupdates\*.*
    %ProgramFiles%\Messenger\*.*
    %systemroot%\system32\systhem32\*.*
    %systemroot%\system\*.exe
    HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\Results\Install|LastSuccessTime /rs
    /md5start
    /md5stop
    • Click the Quick Scan button. Do not change any settings unless otherwise told to do so. The scan wont take long.
    • When the scan completes, it will open two notepad windows: OTL.txt and Extras.txt. These are saved in the same location as OTL.
    • Please copy (Edit->Select All, Edit->Copy) the contents of these files, one at a time, and post them back here.
  21. 2011/07/03
    Milkman23
    OTL logfile created on: 7/3/2011 10:15:12 AM - Run 1
    OTL by OldTimer - Version 3.2.25.0 Folder = C:\Documents and Settings\James\Desktop
    Windows XP Home Edition Service Pack 2 (Version = 5.1.2600) - Type = NTWorkstation
    Internet Explorer (Version = 8.0.6001.18702)
    Locale: 00000409 | Country: United States | Language: ENU | Date Format: M/d/yyyy
    2.00 Gb Total Physical Memory | 1.51 Gb Available Physical Memory | 75.73% Memory free
    4.83 Gb Paging File | 4.48 Gb Available in Paging File | 92.82% Paging File free
    Paging file location(s): C:\pagefile.sys 3048 3048 [binary data]
    %SystemDrive% = C: | %SystemRoot% = C:\WINDOWS | %ProgramFiles% = C:\Program Files
    Drive C: | 149.02 Gb Total Space | 119.17 Gb Free Space | 79.97% Space Free | Partition Type: NTFS
    Computer Name: LIVINGROOM | User Name: James | Logged in as Administrator.
    Boot Mode: Normal | Scan Mode: All users
    Company Name Whitelist: Off | Skip Microsoft Files: Off | No Company Name Whitelist: On | File Age = 30 Days
    PRC - [2011/07/03 10:12:53 | 000,580,096 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\James\Desktop\OTL.exe
    PRC - [2010/11/30 14:20:36 | 000,997,408 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Microsoft Security Client\msseces.exe
    PRC - [2010/11/11 13:26:42 | 000,226,984 | ---- | M] (Microsoft Corporation) -- c:\Program Files\Microsoft Security Client\Antimalware\MpCmdRun.exe
    PRC - [2010/11/11 13:26:40 | 000,011,736 | ---- | M] (Microsoft Corporation) -- c:\Program Files\Microsoft Security Client\Antimalware\MsMpEng.exe
    PRC - [2010/01/16 15:59:17 | 000,266,240 | ---- | M] () -- C:\WINDOWS\SYSTEM32\CSHelper.exe
    PRC - [2009/09/08 18:25:52 | 000,096,334 | ---- | M] (Canon Inc.) -- C:\Program Files\Canon\CAL\CALMAIN.exe
    PRC - [2009/08/24 17:17:12 | 000,327,168 | ---- | M] (Portrait Displays, Inc) -- C:\Program Files\Acer Display\eDisplay Management\dthtml.exe
    PRC - [2009/08/24 17:14:58 | 000,069,632 | ---- | M] () -- C:\Program Files\Common Files\Portrait Displays\Shared\DTSRVC.exe
    PRC - [2009/08/24 17:14:48 | 000,114,688 | ---- | M] (Portrait Displays Inc.) -- C:\Program Files\Common Files\Portrait Displays\Shared\HookManager.exe
    PRC - [2009/07/15 14:43:48 | 000,203,376 | ---- | M] (Portrait Displays, Inc.) -- C:\Program Files\Common Files\Portrait Displays\Drivers\pdiSDKHelper.exe
    PRC - [2009/07/15 14:43:46 | 000,109,168 | ---- | M] (Portrait Displays, Inc.) -- C:\Program Files\Common Files\Portrait Displays\Drivers\pdisrvc.exe
    PRC - [2007/06/13 03:23:07 | 001,033,216 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\explorer.exe
    PRC - [2007/04/13 08:49:00 | 000,101,528 | ---- | M] () -- C:\Program Files\Canon\IJPLM\ijplmsvc.exe
    PRC - [2007/02/09 13:17:30 | 000,694,008 | ---- | M] () -- C:\Program Files\Portrait Displays\Pivot Software\Floater.exe
    PRC - [2007/02/09 13:17:26 | 000,694,008 | ---- | M] () -- C:\Program Files\Portrait Displays\Pivot Software\wpCtrl.exe
    PRC - [2005/07/22 16:27:50 | 000,122,880 | ---- | M] (Sony DADC Austria AG.) -- C:\WINDOWS\SYSTEM32\UAService7.exe
    MOD - [2011/07/03 10:12:53 | 000,580,096 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\James\Desktop\OTL.exe
    MOD - [2007/02/09 13:16:08 | 000,245,760 | ---- | M] () -- C:\Program Files\Portrait Displays\Pivot Software\Winphook.dll
    MOD - [2006/08/25 08:45:55 | 001,054,208 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.2982_x-ww_ac3f9c03\comctl32.dll
    SRV - File not found [Auto | Stopped] -- -- (HitmanPro35CrusaderBoot) Hitman Pro 3.5 Crusader (Boot)
    SRV - File not found [Disabled | Stopped] -- -- (HidServ)
    SRV - File not found [On_Demand | Stopped] -- -- (gusvc)
    SRV - File not found [Disabled | Stopped] -- -- (AppMgmt)
    SRV - File not found [On_Demand | Stopped] -- -- (ACDaemon)
    SRV - [2010/11/11 13:26:40 | 000,011,736 | ---- | M] (Microsoft Corporation) [Auto | Running] -- c:\Program Files\Microsoft Security Client\Antimalware\MsMpEng.exe -- (MsMpSvc)
    SRV - [2010/01/16 15:59:17 | 000,266,240 | ---- | M] () [Auto | Running] -- C:\WINDOWS\SYSTEM32\CSHelper.exe -- (CSHelper)
    SRV - [2009/09/08 18:25:52 | 000,096,334 | ---- | M] (Canon Inc.) [Auto | Running] -- C:\Program Files\Canon\CAL\CALMAIN.exe -- (CCALib8)
    SRV - [2009/08/24 17:14:58 | 000,069,632 | ---- | M] () [Auto | Running] -- C:\Program Files\Common Files\Portrait Displays\Shared\DTSRVC.exe -- (DTSRVC)
    SRV - [2009/07/15 14:43:46 | 000,109,168 | ---- | M] (Portrait Displays, Inc.) [Auto | Running] -- C:\Program Files\Common Files\Portrait Displays\Drivers\pdisrvc.exe -- (PdiService)
    SRV - [2007/04/13 08:49:00 | 000,101,528 | ---- | M] () [Auto | Running] -- C:\Program Files\Canon\IJPLM\ijplmsvc.exe -- (IJPLMSVC)
    SRV - [2005/07/22 16:27:50 | 000,122,880 | ---- | M] (Sony DADC Austria AG.) [Auto | Running] -- C:\WINDOWS\SYSTEM32\UAService7.exe -- (UserAccess7) SecuROM User Access Service (V7)
    SRV - [2003/03/03 12:33:40 | 000,143,360 | ---- | M] (Intel(R) Corporation) [On_Demand | Stopped] -- C:\Program Files\Intel\NCS\Sync\NetSvc.exe -- (NetSvc)
    DRV - [2011/07/03 10:08:59 | 000,028,752 | ---- | M] (Microsoft Corporation) [Kernel | System | Running] -- c:\Documents and Settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{53767C80-62B8-4BC4-BD5D-80C1E93CC904}\MpKslf404085d.sys -- (MpKslf404085d)
    DRV - [2009/07/15 14:43:32 | 000,017,136 | ---- | M] (Portrait Displays, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\SYSTEM32\DRIVERS\PdiPorts.sys -- (PdiPorts)
    DRV - [2007/04/11 10:23:32 | 000,035,328 | ---- | M] (Service & Quality Technology.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\SYSTEM32\DRIVERS\Capt905c.sys -- (SQTECH905C)
    DRV - [2007/02/09 13:17:18 | 000,017,465 | ---- | M] (Portrait Displays, Inc.) [Kernel | System | Running] -- C:\WINDOWS\SYSTEM32\DRIVERS\pivot.sys -- (Pivot)
    DRV - [2007/02/09 13:17:16 | 000,011,323 | ---- | M] (Portrait Displays, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\SYSTEM32\DRIVERS\pivotmou.sys -- (pivotmou)
    DRV - [2006/11/10 15:05:00 | 000,018,688 | ---- | M] (Arcsoft, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\SYSTEM32\DRIVERS\afc.sys -- (Afc)
    DRV - [2004/12/09 08:25:49 | 000,047,104 | ---- | M] (Protection Technology) [Kernel | Boot | Running] -- C:\WINDOWS\System32\drivers\sfdrv01.sys -- (sfdrv01) StarForce Protection Environment Driver (version 1.x)
    DRV - [2004/10/28 03:47:59 | 000,006,656 | ---- | M] (Protection Technology) [Kernel | Boot | Running] -- C:\WINDOWS\System32\drivers\sfhlp02.sys -- (sfhlp02) StarForce Protection Helper Driver (version 2.x)
    DRV - [2004/08/03 22:29:49 | 000,019,455 | ---- | M] (Intel(R) Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\SYSTEM32\DRIVERS\wvchntxx.sys -- (iAimFP4)
    DRV - [2004/08/03 22:29:47 | 000,012,063 | ---- | M] (Intel(R) Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\SYSTEM32\DRIVERS\wsiintxx.sys -- (iAimFP3)
    DRV - [2004/08/03 22:29:45 | 000,023,615 | ---- | M] (Intel(R) Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\SYSTEM32\DRIVERS\wch7xxnt.sys -- (iAimTV4)
    DRV - [2004/08/03 22:29:43 | 000,033,599 | ---- | M] (Intel(R) Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\SYSTEM32\DRIVERS\watv04nt.sys -- (iAimTV3)
    DRV - [2004/08/03 22:29:42 | 000,019,551 | ---- | M] (Intel(R) Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\SYSTEM32\DRIVERS\watv02nt.sys -- (iAimTV1)
    DRV - [2004/08/03 22:29:41 | 000,029,311 | ---- | M] (Intel(R) Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\SYSTEM32\DRIVERS\watv01nt.sys -- (iAimTV0)
    DRV - [2004/08/03 22:29:37 | 000,012,415 | ---- | M] (Intel(R) Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\SYSTEM32\DRIVERS\wadv01nt.sys -- (iAimFP0)
    DRV - [2004/08/03 22:29:37 | 000,012,127 | ---- | M] (Intel(R) Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\SYSTEM32\DRIVERS\wadv02nt.sys -- (iAimFP1)
    DRV - [2004/08/03 22:29:37 | 000,011,775 | ---- | M] (Intel(R) Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\SYSTEM32\DRIVERS\wadv05nt.sys -- (iAimFP2)
    DRV - [2004/08/03 22:29:36 | 000,161,020 | ---- | M] (Intel(R) Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\SYSTEM32\DRIVERS\i81xnt5.sys -- (i81x)
    DRV - [2004/05/13 06:00:04 | 000,111,808 | ---- | M] (Protection Technology) [Kernel | Boot | Running] -- C:\WINDOWS\System32\drivers\prohlp02.sys -- (prohlp02)
    DRV - [2004/05/13 04:19:36 | 000,079,488 | ---- | M] (Protection Technology) [Kernel | System | Running] -- C:\WINDOWS\System32\drivers\prodrv06.sys -- (prodrv06)
    DRV - [2004/03/08 12:55:50 | 000,013,567 | ---- | M] (B.H.A Corporation) [Kernel | System | Running] -- C:\WINDOWS\System32\drivers\CDRBSDRV.SYS -- (cdrbsdrv)
    DRV - [2003/12/01 08:20:52 | 000,004,832 | ---- | M] (Protection Technology) [Kernel | Boot | Running] -- C:\WINDOWS\System32\drivers\sfhlp01.sys -- (sfhlp01)
    DRV - [2003/08/29 04:59:24 | 001,101,696 | ---- | M] (Broadcom Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\SYSTEM32\DRIVERS\BCMSM.sys -- (BCMModem)
    DRV - [2003/04/19 01:32:04 | 000,004,736 | ---- | M] () [Kernel | Auto | Running] -- C:\WINDOWS\SYSTEM32\DRIVERS\tandpl.sys -- (tandpl)
    DRV - [2003/03/02 18:44:26 | 000,007,552 | ---- | M] () [Kernel | Auto | Running] -- C:\WINDOWS\SYSTEM32\DRIVERS\enodpl.sys -- (enodpl)
    DRV - [2002/11/08 12:45:06 | 000,017,217 | ---- | M] (Dell Computer Corporation) [Kernel | System | Running] -- C:\WINDOWS\SYSTEM32\DRIVERS\omci.sys -- (omci)
    DRV - [2001/08/17 11:11:06 | 000,066,591 | ---- | M] (3Com Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\SYSTEM32\DRIVERS\EL90XBC5.SYS -- (EL90XBC)
    IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,SearchMigratedDefaultName = Search
    IE - HKLM\Software\Microsoft\Internet Explorer\SearchURL\w, = http://www.Google.com/
    IE - HKU\.DEFAULT\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Page_URL = http://www.dell4me.com/myway
    IE - HKU\.DEFAULT\SOFTWARE\Microsoft\Internet Explorer\Main,First Home Page = http://www.dell4me.com/myway
    IE - HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
    IE - HKU\S-1-5-18\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Page_URL = http://www.dell4me.com/myway
    IE - HKU\S-1-5-18\SOFTWARE\Microsoft\Internet Explorer\Main,First Home Page = http://www.dell4me.com/myway
    IE - HKU\S-1-5-18\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
    IE - HKU\S-1-5-19\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
    IE - HKU\S-1-5-20\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
    IE - HKU\S-1-5-21-3467059179-3465910588-4126901205-1007\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Secondary_Page_URL = www.bing.com [binary data]
    IE - HKU\S-1-5-21-3467059179-3465910588-4126901205-1007\SOFTWARE\Microsoft\Internet Explorer\Main,SearchDefaultBranded = 1
    IE - HKU\S-1-5-21-3467059179-3465910588-4126901205-1007\SOFTWARE\Microsoft\Internet Explorer\Main,SearchMigratedDefaultName = Search
    IE - HKU\S-1-5-21-3467059179-3465910588-4126901205-1007\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = http://www.msn.com/
    IE - HKU\S-1-5-21-3467059179-3465910588-4126901205-1007\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
    IE - HKU\S-1-5-21-3467059179-3465910588-4126901205-1007\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyOverride" = <local>;*.local
    FF - HKLM\software\mozilla\Firefox\extensions\\{EEC1131E-06BE-4D9A-9C4E-797C18825414}: C:\Documents and Settings\D'Anne\Local Settings\Application Data\{EEC1131E-06BE-4D9A-9C4E-797C18825414} [2011/04/19 08:10:09 | 000,000,000 | ---D | M]
    [2011/03/03 16:49:42 | 000,000,000 | ---D | M] (No name found) -- C:\Documents and Settings\James\Application Data\Mozilla\Extensions
    O1 HOSTS File: ([2011/07/01 19:18:51 | 000,000,027 | ---- | M]) - C:\WINDOWS\SYSTEM32\DRIVERS\ETC\hosts
    O2 - BHO: (no name) - {02478D38-C3F9-4efb-9B51-7695ECA05670} - No CLSID value found.
    O2 - BHO: (Adobe PDF Reader Link Helper) - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll (Adobe Systems Incorporated)
    O2 - BHO: (no name) - {5C255C8A-E604-49b4-9D64-90988571CECB} - No CLSID value found.
    O2 - BHO: (DriveLetterAccess) - {5CA3D70E-1895-11CF-8E15-001234567890} - C:\WINDOWS\SYSTEM32\dla\tfswshx.dll (Sonic Solutions)
    O2 - BHO: (no name) - {65D886A2-7CA7-479B-BB95-14D1EFB7946A} - No CLSID value found.
    O2 - BHO: (Google Toolbar Notifier BHO) - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.6.6209.1142\swg.dll (Google Inc.)
    O2 - BHO: (MSN Toolbar Helper) - {d2ce3e00-f94a-4740-988e-03dc2f38c34f} - C:\Program Files\MSN\Toolbar\3.0.1203.0\msneshellx.dll (Microsoft Corp.)
    O2 - BHO: (no name) - {FDD3B846-8D59-4ffb-8758-209B6AD74ACC} - No CLSID value found.
    O3 - HKLM\..\Toolbar: (MSN Toolbar) - {1E61ED7C-7CB8-49d6-B9E9-AB4C880C8414} - C:\Program Files\MSN\Toolbar\3.0.1203.0\msneshellx.dll (Microsoft Corp.)
    O3 - HKLM\..\Toolbar: (no name) - {BA52B914-B692-46c4-B683-905236F6F655} - No CLSID value found.
    O3 - HKU\.DEFAULT\..\Toolbar\WebBrowser: (no name) - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - No CLSID value found.
    O3 - HKU\S-1-5-18\..\Toolbar\WebBrowser: (no name) - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - No CLSID value found.
    O3 - HKU\S-1-5-21-3467059179-3465910588-4126901205-1007\..\Toolbar\WebBrowser: (no name) - {4E7BD74F-2B8D-469E-9EB4-FE6FA694B13E} - No CLSID value found.
    O3 - HKU\S-1-5-21-3467059179-3465910588-4126901205-1007\..\Toolbar\WebBrowser: (no name) - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - No CLSID value found.
    O4 - HKLM..\Run: [DT ACR] C:\Program Files\Common Files\Portrait Displays\Shared\DT_startup.exe ()
    O4 - HKLM..\Run: [MSC] c:\Program Files\Microsoft Security Client\msseces.exe (Microsoft Corporation)
    O4 - HKLM..\Run: [PivotSoftware] C:\Program Files\Portrait Displays\Pivot Software\wpctrl.exe ()
    O6 - HKLM\Software\Policies\Microsoft\Internet Explorer\control panel present
    O6 - HKLM\Software\Policies\Microsoft\Internet Explorer\Low Rights present
    O6 - HKLM\Software\Policies\Microsoft\Internet Explorer\Restrictions present
    O7 - HKU\.DEFAULT\Software\Policies\Microsoft\Internet Explorer\Control Panel present
    O7 - HKU\.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveAutoRun = 67108863
    O7 - HKU\.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 323
    O7 - HKU\S-1-5-18\Software\Policies\Microsoft\Internet Explorer\Control Panel present
    O7 - HKU\S-1-5-18\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveAutoRun = 67108863
    O7 - HKU\S-1-5-18\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 323
    O7 - HKU\S-1-5-19\Software\Policies\Microsoft\Internet Explorer\Control Panel present
    O7 - HKU\S-1-5-20\Software\Policies\Microsoft\Internet Explorer\Control Panel present
    O7 - HKU\S-1-5-21-3467059179-3465910588-4126901205-1007\Software\Policies\Microsoft\Internet Explorer\Control Panel present
    O7 - HKU\S-1-5-21-3467059179-3465910588-4126901205-1007\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveAutoRun = 67108863
    O7 - HKU\S-1-5-21-3467059179-3465910588-4126901205-1007\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 323
    O7 - HKU\S-1-5-21-3467059179-3465910588-4126901205-1007\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDrives = 0
    O10 - NameSpace_Catalog5\Catalog_Entries\000000000004 [] - C:\Program Files\Bonjour\mdnsNSP.dll (Apple Inc.)
    O15 - HKU\S-1-5-21-3467059179-3465910588-4126901205-1007\..Trusted Domains: ([]msn in My Computer)
    O15 - HKU\S-1-5-21-3467059179-3465910588-4126901205-1007\..Trusted Domains: //@install.mar@ ([]msni in My Computer)
    O15 - HKU\S-1-5-21-3467059179-3465910588-4126901205-1007\..Trusted Domains: //@mail.mar@ ([]msni in Local intranet)
    O16 - DPF: {15B782AF-55D8-11D1-B477-006097098764} http://media.keytrain.com/player/IE/awswaxd.cab (Macromedia Authorware Web Player Control)
    O16 - DPF: {166B1BCA-3F9C-11CF-8075-444553540000} http://fpdownload.macromedia.com/pub/shockwave/cabs/director/sw.cab (Shockwave ActiveX Control)
    O16 - DPF: {1A1F56AA-3401-46F9-B277-D57F3421F821} http://www.worldwinner.com/games/v47/shared/FunGamesLoader.cab (FunGamesLoader Object)
    O16 - DPF: {233C1507-6A77-46A4-9443-F871F945D258} http://fpdownload.macromedia.com/get/shockwave/cabs/director/sw.cab (Shockwave ActiveX Control)
    O16 - DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} C:\Program Files\Yahoo!\Common\Yinsthelper.dll (Installation Support)
    O16 - DPF: {4ED9DDF0-7479-4BBE-9335-5A1EDB1D8A21} http://download.mcafee.com/molbin/shared/mcinsctl/en-us/4,0,0,76/mcinsctl.cab (Reg Error: Key error.)
    O16 - DPF: {4F1E5B1A-2A80-42CA-8532-2D05CB959537} http://by23fd.bay23.hotmail.msn.com/resources/MsnPUpld.cab (MSN Photo Upload Tool)
    O16 - DPF: {5ED80217-570B-4DA9-BF44-BE107C0EC166} http://cdn.scan.onecare.live.com/resource/download/scanner/wlscbase6087.cab (Windows Live Safety Center Base Module)
    O16 - DPF: {6C6FE41A-0DA6-42A1-9AD8-792026B2B2A7} http://www.worldwinner.com/games/v41/freecell/freecell.cab (FreeCell Control)
    O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} http://update.microsoft.com/microsoftupdate/v6/V5Controls/en/x86/client/muweb_site.cab?1165536969073 (MUWebControl Class)
    O16 - DPF: {8A0019EB-51FA-4AE5-A40B-C0496BBFC739} http://picture.vzw.com/activex/VerizonWirelessUploadControl.cab (Verizon Wireless Media Upload)
    O16 - DPF: {8A94C905-FF9D-43B6-8708-F0F22D22B1CB} http://www.worldwinner.com/games/shared/wwlaunch.cab (Wwlaunch Control)
    O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} http://java.sun.com/update/1.6.0/jinstall-1_6_0_26-windows-i586.cab (Java Plug-in 1.6.0_26)
    O16 - DPF: {8F6E7FB2-E56B-4F66-A4E1-9765D2565280} http://www.worldwinner.com/games/launcher/ie/v2.22.01.0/iewwload.cab (WorldWinner ActiveX Launcher Control)
    O16 - DPF: {8FFBE65D-2C9C-4669-84BD-5829DC0B603C} http://fpdownload.macromedia.com/get/flashplayer/current/polarbear/ultrashim.cab (Reg Error: Key error.)
    O16 - DPF: {A17E30C4-A9BA-11D4-8673-60DB54C10000} http://us.dl1.yimg.com/download.yahoo.com/dl/installs/yse/ymmapi_416.dll (Yahoo! MailTo)
    O16 - DPF: {B06CE1BC-5D9D-4676-BD28-1752DBF394E0} http://www.worldwinner.com/games/v41/hangman/hangman.cab (Hangman Control)
    O16 - DPF: {BCC0FF27-31D9-4614-A68E-C18E1ADA4389} http://download.mcafee.com/molbin/shared/mcgdmgr/en-us/1,0,0,16/mcgdmgr.cab (Reg Error: Key error.)
    O16 - DPF: {C3F79A2B-B9B4-4A66-B012-3EE46475B072} http://messenger.zone.msn.com/binary/MessengerStatsPAClient.cab56907.cab (MessengerStatsClient Class)
    O16 - DPF: {CAFEEFAC-0016-0000-0026-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_26-windows-i586.cab (Java Plug-in 1.6.0_26)
    O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_26-windows-i586.cab (Java Plug-in 1.6.0_26)
    O16 - DPF: {D0C0F75C-683A-4390-A791-1ACFD5599AB8} http://games.myspace.com/Gameshell/GameHost/1.0/OberonGameHost.cab (Oberon Flash Game Host)
    O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} http://fpdownload2.macromedia.com/get/shockwave/cabs/flash/swflash.cab (Shockwave Flash Object)
    O16 - DPF: {DF780F87-FF2B-4DF8-92D0-73DB16A1543A} http://games.pogo.com/online2/pogo/bejeweled2/popcaploader_v6.cab (PopCapLoader Object)
    O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} http://platformdl.adobe.com/NOS/getPlusPlus/1.6/gp.cab (Reg Error: Key error.)
    O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 192.168.0.1 205.171.3.25
    O20 - HKLM Winlogon: Shell - (Explorer.exe) - C:\WINDOWS\explorer.exe (Microsoft Corporation)
    O24 - Desktop Components:0 () - http://www.runescape.com/lang/en/aff/runescape/img/bg2.jpg
    O24 - Desktop Components:1 (My Current Home Page) - About:Home
    O24 - Desktop WallPaper: C:\Documents and Settings\James\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
    O24 - Desktop BackupWallPaper: C:\Documents and Settings\James\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
    O32 - HKLM CDRom: AutoRun - 1
    O32 - AutoRun File - [2002/09/03 07:59:58 | 000,000,000 | ---- | M] () - C:\AUTOEXEC.BAT -- [ NTFS ]
    O37 - HKLM\...com [@ = ComFile] -- "%1" %*
    NetSvcs: 6to4 - File not found
    NetSvcs: AppMgmt - File not found
    NetSvcs: HidServ - File not found
    NetSvcs: Ias - File not found
    NetSvcs: Iprip - File not found
    NetSvcs: Irmon - File not found
    NetSvcs: NWCWorkstation - File not found
    NetSvcs: Nwsapagent - File not found
    NetSvcs: WmdmPmSp - File not found
    Drivers32: msacm.iac2 - C:\WINDOWS\System32\iac25_32.ax (Intel Corporation)
    Drivers32: msacm.l3acm - C:\WINDOWS\SYSTEM32\l3codeca.acm (Fraunhofer Institut Integrierte Schaltungen IIS)
    Drivers32: msacm.sl_anet - C:\WINDOWS\System32\sl_anet.acm (Sipro Lab Telecom Inc.)
    Drivers32: msacm.trspch - C:\WINDOWS\System32\TSSOFT32.ACM (DSP GROUP, INC.)
    Drivers32: MSVideo8 - C:\WINDOWS\System32\vfwwdm32.dll (Microsoft Corporation)
    Drivers32: vidc.cvid - C:\WINDOWS\System32\iccvid.dll (Radius Inc.)
    Drivers32: vidc.iv31 - C:\WINDOWS\System32\IR32_32.DLL ()
    Drivers32: vidc.iv32 - C:\WINDOWS\System32\IR32_32.DLL ()
    Drivers32: vidc.iv41 - C:\WINDOWS\System32\ir41_32.ax (Intel Corporation)
    Drivers32: vidc.iv50 - C:\WINDOWS\System32\ir50_32.dll (Intel Corporation)
    Drivers32: VIDC.MJPG - C:\WINDOWS\System32\Pvmjpg21.dll (Pegasus Imaging Corporation)
    Drivers32: VIDC.VP31 - vp31vfw.dll File not found
    CREATERESTOREPOINT
    Restore point Set: OTL Restore Point
    ========== Files/Folders - Created Within 30 Days ==========
    [2011/07/03 10:12:46 | 000,580,096 | ---- | C] (OldTimer Tools) -- C:\Documents and Settings\James\Desktop\OTL.exe
    [2011/07/01 19:02:04 | 000,000,000 | RHSD | C] -- C:\cmdcons
    [2011/07/01 18:57:39 | 000,518,144 | ---- | C] (SteelWerX) -- C:\WINDOWS\SWREG.exe
    [2011/07/01 18:57:39 | 000,406,528 | ---- | C] (SteelWerX) -- C:\WINDOWS\SWSC.exe
    [2011/07/01 18:57:39 | 000,212,480 | ---- | C] (SteelWerX) -- C:\WINDOWS\SWXCACLS.exe
    [2011/07/01 18:57:39 | 000,060,416 | ---- | C] (NirSoft) -- C:\WINDOWS\NIRCMD.exe
    [2011/07/01 18:57:30 | 000,000,000 | ---D | C] -- C:\WINDOWS\ERDNT
    [2011/07/01 18:56:51 | 000,000,000 | ---D | C] -- C:\Qoobox
    [2011/07/01 18:50:39 | 004,130,437 | R--- | C] (Swearware) -- C:\Documents and Settings\James\Desktop\ComboFix.exe
    [2011/07/01 13:38:54 | 001,448,752 | ---- | C] (Kaspersky Lab ZAO) -- C:\Documents and Settings\James\Desktop\tdsskiller.exe
    [2011/06/27 12:02:03 | 000,607,017 | R--- | C] (Swearware) -- C:\Documents and Settings\James\Desktop\dds.scr
    [2011/06/27 12:01:33 | 001,904,128 | ---- | C] (AVAST Software) -- C:\Documents and Settings\James\Desktop\aswMBR.exe
    [2011/06/25 19:14:00 | 000,039,984 | ---- | C] (Malwarebytes Corporation) -- C:\WINDOWS\System32\drivers\mbamswissarmy.sys
    [2011/06/25 19:14:00 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Start Menu\Programs\Malwarebytes' Anti-Malware
    [2011/06/25 19:13:53 | 000,022,712 | ---- | C] (Malwarebytes Corporation) -- C:\WINDOWS\System32\drivers\mbam.sys
    [2011/06/25 17:17:50 | 000,157,472 | ---- | C] (Sun Microsystems, Inc.) -- C:\WINDOWS\System32\javaws.exe
    [2011/06/25 17:17:50 | 000,145,184 | ---- | C] (Sun Microsystems, Inc.) -- C:\WINDOWS\System32\javaw.exe
    [2011/06/25 17:17:50 | 000,145,184 | ---- | C] (Sun Microsystems, Inc.) -- C:\WINDOWS\System32\java.exe
    [2011/06/25 17:17:50 | 000,073,728 | ---- | C] (Sun Microsystems, Inc.) -- C:\WINDOWS\System32\javacpl.cpl
    [2011/06/17 19:29:38 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Start Menu\Programs\Google Earth
    [2003/12/09 13:16:52 | 000,442,368 | ---- | C] ( ) -- C:\WINDOWS\System32\comintfs.dll
    [7 C:\WINDOWS\System32\*.tmp files -> C:\WINDOWS\System32\*.tmp -> ]
    [2 C:\WINDOWS\*.tmp files -> C:\WINDOWS\*.tmp -> ]
    ========== Files - Modified Within 30 Days ==========
    [2011/07/03 10:15:00 | 000,000,422 | -H-- | M] () -- C:\WINDOWS\tasks\User_Feed_Synchronization-{99C7E015-A9F4-4734-9BD9-487DD37545E8}.job
    [2011/07/03 10:14:00 | 000,000,886 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineUA.job
    [2011/07/03 10:14:00 | 000,000,424 | -H-- | M] () -- C:\WINDOWS\tasks\MP Scheduled Scan.job
    [2011/07/03 10:08:47 | 000,002,048 | --S- | M] () -- C:\WINDOWS\BOOTSTAT.DAT
    [2011/07/03 10:08:46 | 2145,439,744 | -HS- | M] () -- C:\hiberfil.sys
    [2011/07/03 00:19:00 | 000,000,882 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineCore1cc202b92d88e10.job
    [2011/07/02 18:47:25 | 000,000,129 | ---- | M] () -- C:\Documents and Settings\James\jagex_runescape_preferences2.dat
    [2011/07/02 18:47:25 | 000,000,046 | ---- | M] () -- C:\Documents and Settings\James\jagex_runescape_preferences.dat
    [2011/07/02 15:59:48 | 000,001,286 | ---- | M] () -- C:\Documents and Settings\James\Desktop\Runescape.url
    [2011/07/02 11:38:45 | 004,130,437 | R--- | M] (Swearware) -- C:\Documents and Settings\James\Desktop\ComboFix.exe
    [2011/07/01 19:18:51 | 000,000,027 | ---- | M] () -- C:\WINDOWS\System32\drivers\ETC\hosts
    [2011/07/01 19:02:08 | 000,000,327 | RHS- | M] () -- C:\BOOT.INI
    [2011/07/01 13:38:54 | 001,448,752 | ---- | M] (Kaspersky Lab ZAO) -- C:\Documents and Settings\James\Desktop\tdsskiller.exe
    [2011/06/27 12:02:05 | 000,607,017 | R--- | M] (Swearware) -- C:\Documents and Settings\James\Desktop\dds.scr
    [2011/06/27 12:01:33 | 001,904,128 | ---- | M] (AVAST Software) -- C:\Documents and Settings\James\Desktop\aswMBR.exe
    [2011/06/25 23:45:56 | 000,256,000 | ---- | M] () -- C:\WINDOWS\PEV.exe
    [2011/06/25 20:27:11 | 000,302,592 | ---- | M] () -- C:\Documents and Settings\James\Desktop\rxuy0xvn.exe
    [2011/06/25 19:14:00 | 000,000,784 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\Malwarebytes' Anti-Malware.lnk
    [2011/06/25 17:17:33 | 000,157,472 | ---- | M] (Sun Microsystems, Inc.) -- C:\WINDOWS\System32\javaws.exe
    [2011/06/25 17:17:33 | 000,145,184 | ---- | M] (Sun Microsystems, Inc.) -- C:\WINDOWS\System32\javaw.exe
    [2011/06/25 17:17:33 | 000,073,728 | ---- | M] (Sun Microsystems, Inc.) -- C:\WINDOWS\System32\javacpl.cpl
    [2011/06/25 17:17:32 | 000,472,808 | ---- | M] (Sun Microsystems, Inc.) -- C:\WINDOWS\System32\deployJava1.dll
    [2011/06/25 17:17:32 | 000,145,184 | ---- | M] (Sun Microsystems, Inc.) -- C:\WINDOWS\System32\java.exe
    [2011/06/19 21:30:10 | 000,001,170 | ---- | M] () -- C:\WINDOWS\System32\WPA.DBL
    [2011/06/18 00:31:39 | 000,001,729 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\Adobe Reader 8.lnk
    [2011/07/01 19:02:08 | 000,000,211 | ---- | C] () -- C:\Boot.bak
    [2011/07/01 19:02:05 | 000,260,272 | RHS- | C] () -- C:\cmldr
    [2011/07/01 18:57:39 | 000,256,000 | ---- | C] () -- C:\WINDOWS\PEV.exe
    [2011/07/01 18:57:39 | 000,208,896 | ---- | C] () -- C:\WINDOWS\MBR.exe
    [2011/07/01 18:57:39 | 000,098,816 | ---- | C] () -- C:\WINDOWS\sed.exe
    [2011/07/01 18:57:39 | 000,080,412 | ---- | C] () -- C:\WINDOWS\grep.exe
    [2011/07/01 18:57:39 | 000,068,096 | ---- | C] () -- C:\WINDOWS\zip.exe
    [2011/06/25 20:27:00 | 000,302,592 | ---- | C] () -- C:\Documents and Settings\James\Desktop\rxuy0xvn.exe
    [2011/06/25 19:14:00 | 000,000,784 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\Malwarebytes' Anti-Malware.lnk
    [2011/06/18 00:31:39 | 000,001,804 | ---- | C] () -- C:\Documents and Settings\All Users\Start Menu\Programs\Adobe Reader 8.lnk
    [2011/06/18 00:31:39 | 000,001,729 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\Adobe Reader 8.lnk
    [2011/04/19 11:38:51 | 000,011,916 | -HS- | C] () -- C:\Documents and Settings\James\Local Settings\Application Data\k8g76qfqbt723d00fnb0dy5g4u67
    [2011/04/19 11:38:51 | 000,011,916 | -HS- | C] () -- C:\Documents and Settings\All Users\Application Data\k8g76qfqbt723d00fnb0dy5g4u67
    [2011/04/18 19:20:36 | 000,000,664 | ---- | C] () -- C:\WINDOWS\System32\d3d9caps.dat
    [2011/04/18 14:49:33 | 000,000,128 | ---- | C] () -- C:\Documents and Settings\All Users\Application Data\~20897588r
    [2011/04/18 14:49:32 | 000,000,160 | ---- | C] () -- C:\Documents and Settings\All Users\Application Data\~20897588
    [2011/04/18 14:49:23 | 000,000,400 | ---- | C] () -- C:\Documents and Settings\All Users\Application Data\20897588
    [2011/04/18 14:42:55 | 000,000,120 | ---- | C] () -- C:\WINDOWS\Ckuwokelodasode.dat
    [2011/04/18 14:42:55 | 000,000,000 | ---- | C] () -- C:\WINDOWS\Xpoxohewazuco.bin
    [2011/04/11 20:47:02 | 000,000,177 | ---- | C] () -- C:\WINDOWS\AWSHKWV.INI
    [2011/02/28 13:53:33 | 000,493,184 | ---- | C] () -- C:\Documents and Settings\LocalService\Local Settings\Application Data\FontCache3.0.0.0.dat
    [2011/02/16 02:23:47 | 000,002,304 | ---- | C] () -- C:\WINDOWS\System32\Machnm32.sys
    [2010/04/27 07:19:32 | 000,016,968 | ---- | C] () -- C:\WINDOWS\System32\drivers\hitmanpro35.sys
    [2010/03/15 20:22:43 | 000,047,740 | ---- | C] () -- C:\WINDOWS\System32\mlfcache.dat
    [2010/01/16 15:59:17 | 000,266,240 | ---- | C] () -- C:\WINDOWS\System32\CSHelper.exe
    [2009/12/03 18:29:26 | 000,000,020 | ---- | C] () -- C:\WINDOWS\popcinfot.dat
    [2009/12/03 18:29:26 | 000,000,000 | ---- | C] () -- C:\WINDOWS\popcreg.dat
    [2008/06/23 22:40:33 | 000,000,000 | ---- | C] () -- C:\Program Files\uninstall.dat
    [2008/03/13 17:46:43 | 000,691,545 | ---- | C] () -- C:\WINDOWS\unins000.exe
    [2008/03/13 17:46:43 | 000,002,545 | ---- | C] () -- C:\WINDOWS\unins000.dat
    [2008/03/12 01:34:02 | 000,000,118 | ---- | C] () -- C:\WINDOWS\System32\MRT.INI
    [2008/03/06 15:44:41 | 000,000,773 | ---- | C] () -- C:\WINDOWS\WININIT.INI
    [2008/03/06 13:49:46 | 000,000,073 | ---- | C] () -- C:\WINDOWS\PUZZLES.INI
    [2007/04/12 17:07:49 | 000,000,036 | ---- | C] () -- C:\WINDOWS\Tiny_Run.ini
    [2006/09/16 13:51:11 | 000,000,256 | ---- | C] () -- C:\WINDOWS\PROVW.INI
    [2006/09/16 13:51:10 | 000,000,687 | ---- | C] () -- C:\WINDOWS\KPSTUDIO.INI
    [2006/07/24 15:40:53 | 000,000,162 | ---- | C] () -- C:\WINDOWS\mrpotato.ini
    [2006/05/02 13:39:26 | 000,000,000 | ---- | C] () -- C:\WINDOWS\Textart.INI
    [2006/02/18 15:52:58 | 000,000,000 | ---- | C] () -- C:\WINDOWS\SETUP32.INI
    [2005/11/25 18:17:22 | 000,000,043 | ---- | C] () -- C:\WINDOWS\popcinfo.dat
    [2005/10/30 02:16:07 | 000,053,760 | ---- | C] () -- C:\WINDOWS\System32\ZLIB.DLL
    [2005/05/08 11:27:41 | 000,000,023 | ---- | C] () -- C:\WINDOWS\SpaceTaxi.INI
    [2005/01/15 11:15:07 | 000,000,498 | ---- | C] () -- C:\WINDOWS\EReg077.dat
    [2005/01/09 20:23:41 | 000,025,600 | ---- | C] () -- C:\Documents and Settings\James\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
    [2004/12/13 20:37:18 | 000,004,096 | ---- | C] () -- C:\WINDOWS\d3dx.dat
    [2004/12/04 23:43:35 | 000,000,128 | ---- | C] () -- C:\Documents and Settings\James\Local Settings\Application Data\fusioncache.dat
    [2004/11/26 10:22:40 | 000,000,383 | ---- | C] () -- C:\WINDOWS\QTW.INI
    [2004/11/21 01:23:22 | 000,000,754 | ---- | C] () -- C:\WINDOWS\WORDPAD.INI
    [2004/11/04 17:00:03 | 000,001,273 | ---- | C] () -- C:\WINDOWS\hegames.ini
    [2004/10/27 20:07:45 | 000,000,810 | ---- | C] () -- C:\WINDOWS\cdPlayer.ini
    [2004/10/24 16:12:30 | 000,004,569 | ---- | C] () -- C:\WINDOWS\System32\secupd.dat
    [2004/02/04 13:19:23 | 000,061,678 | ---- | C] () -- C:\Documents and Settings\James\Application Data\PFP110JPR.{PB
    [2004/02/04 13:19:23 | 000,012,358 | ---- | C] () -- C:\Documents and Settings\James\Application Data\PFP110JCM.{PB
    [2004/01/28 18:23:52 | 000,032,768 | ---- | C] () -- C:\WINDOWS\System32\instlsp.exe
    [2004/01/24 02:30:25 | 000,000,002 | ---- | C] () -- C:\WINDOWS\msoffice.ini
    [2004/01/24 01:23:02 | 000,000,174 | ---- | C] () -- C:\WINDOWS\System32\mcini.ini
    [2004/01/23 18:51:48 | 000,007,552 | ---- | C] () -- C:\WINDOWS\System32\drivers\enodpl.sys
    [2004/01/23 18:51:48 | 000,004,736 | ---- | C] () -- C:\WINDOWS\System32\drivers\tandpl.sys
    [2004/01/21 18:59:10 | 000,000,599 | ---- | C] () -- C:\WINDOWS\DELLSTAT.INI
    [2004/01/14 17:50:27 | 000,000,061 | ---- | C] () -- C:\WINDOWS\smscfg.ini
    [2004/01/14 17:46:39 | 000,149,504 | ---- | C] () -- C:\WINDOWS\UNWISE.EXE
    [2004/01/14 17:41:37 | 000,000,258 | ---- | C] () -- C:\WINDOWS\System32\BDEMERGE.INI
    [2004/01/14 17:38:12 | 000,000,335 | ---- | C] () -- C:\WINDOWS\nsreg.dat
    [2004/01/14 17:33:17 | 000,000,780 | ---- | C] () -- C:\WINDOWS\orun32.ini
    [2004/01/14 17:17:52 | 000,002,048 | --S- | C] () -- C:\WINDOWS\BOOTSTAT.DAT
    [2004/01/14 17:16:03 | 000,363,520 | ---- | C] () -- C:\WINDOWS\System32\psisdecd.dll
    [2004/01/14 17:16:00 | 000,442,466 | ---- | C] () -- C:\WINDOWS\System32\PERFH009.DAT
    [2004/01/14 17:16:00 | 000,071,732 | ---- | C] () -- C:\WINDOWS\System32\PERFC009.DAT
    [2004/01/14 17:15:45 | 000,001,793 | ---- | C] () -- C:\WINDOWS\System32\fxsperf.ini
    [2004/01/14 17:00:38 | 000,000,550 | ---- | C] () -- C:\WINDOWS\System32\OEMINFO.INI
    [2003/08/13 21:54:00 | 000,000,000 | ---- | C] () -- C:\WINDOWS\System32\px.ini
    [2003/02/05 10:11:12 | 000,000,126 | ---- | C] () -- C:\WINDOWS\System32\DLBAPLC.INI
    [2002/09/03 08:05:08 | 000,200,144 | ---- | C] () -- C:\WINDOWS\System32\FNTCACHE.DAT
    [2002/09/03 07:59:14 | 000,004,161 | ---- | C] () -- C:\WINDOWS\ODBCINST.INI
    [2002/09/03 07:56:30 | 000,021,640 | ---- | C] () -- C:\WINDOWS\System32\emptyregdb.dat
    [2002/09/03 07:31:46 | 013,107,200 | ---- | C] () -- C:\WINDOWS\System32\OEMBIOS.BIN
    [2002/09/03 07:31:44 | 000,004,594 | ---- | C] () -- C:\WINDOWS\System32\OEMBIOS.DAT
    [2002/08/29 04:00:00 | 000,673,088 | ---- | C] () -- C:\WINDOWS\System32\MLANG.DAT
    [2002/08/29 04:00:00 | 000,272,128 | ---- | C] () -- C:\WINDOWS\System32\PERFI009.DAT
    [2002/08/29 04:00:00 | 000,218,003 | ---- | C] () -- C:\WINDOWS\System32\DSSEC.DAT
    [2002/08/29 04:00:00 | 000,046,258 | ---- | C] () -- C:\WINDOWS\System32\MIB.BIN
    [2002/08/29 04:00:00 | 000,028,626 | ---- | C] () -- C:\WINDOWS\System32\PERFD009.DAT
    [2002/08/29 04:00:00 | 000,001,788 | ---- | C] () -- C:\WINDOWS\System32\dcache.bin
    [2002/08/29 04:00:00 | 000,000,741 | ---- | C] () -- C:\WINDOWS\System32\NOISE.DAT
    [1979/12/31 23:00:00 | 000,012,288 | ---- | C] () -- C:\WINDOWS\System32\e100bmsg.dll
    ========== Custom Scans ==========
    < %SYSTEMDRIVE%\*.* >
    [2002/09/03 07:59:58 | 000,000,000 | ---- | M] () -- C:\AUTOEXEC.BAT
    [2010/04/27 07:09:23 | 000,000,211 | ---- | M] () -- C:\Boot.bak
    [2002/09/03 07:38:46 | 000,000,512 | -HS- | M] () -- C:\BOOTSECT.DOS
    [2008/06/19 23:41:19 | 000,035,809 | ---- | M] () -- C:\caavsetupLog.txt
    [2008/12/22 17:28:05 | 000,190,718 | ---- | M] () -- C:\caisslog.txt
    [2004/08/03 23:00:00 | 000,260,272 | RHS- | M] () -- C:\cmldr
    [2011/07/02 11:51:06 | 000,012,873 | ---- | M] () -- C:\ComboFix.txt
    [2002/09/03 07:59:58 | 000,000,000 | ---- | M] () -- C:\CONFIG.SYS
    [2004/01/14 17:06:32 | 000,005,508 | R--- | M] () -- C:\DELL.SDR
    [2009/11/29 11:02:28 | 000,000,045 | ---- | M] () -- C:\error.log
    [2002/09/03 07:59:58 | 000,000,000 | ---- | M] () -- C:\IO.SYS
    [2004/01/14 17:39:49 | 000,000,855 | ---- | M] () -- C:\IPH.PH
    [2002/09/03 07:59:58 | 000,000,000 | ---- | M] () -- C:\MSDOS.SYS
    [2004/10/24 16:33:26 | 000,047,564 | RHS- | M] () -- C:\NTDETECT.COM
    [2004/10/24 16:33:26 | 000,250,032 | RHS- | M] () -- C:\NTLDR
    [2011/07/03 10:08:45 | 3196,059,648 | -HS- | M] () -- C:\pagefile.sys
    [2011/02/16 02:23:05 | 000,000,173 | ---- | M] () -- C:\pdisdk.log
    [2011/02/16 02:23:49 | 000,000,184 | ---- | M] () -- C:\pivot.log
    [2007/07/08 01:42:51 | 000,000,268 | ---- | M] () -- C:\sqmdata00.sqm
    [2007/07/08 01:42:51 | 000,000,244 | ---- | M] () -- C:\sqmnoopt00.sqm
    [2004/01/14 17:41:59 | 000,000,087 | ---- | M] () -- C:\SystemInfo.ini
    [2010/08/03 20:35:18 | 000,000,146 | ---- | M] () -- C:\systemscandata.txt
    [2011/07/01 13:41:09 | 000,058,634 | ---- | M] () -- C:\TDSSKiller.2.5.8.0_01.07.2011_13.40.29_log.txt
    [2011/07/01 13:51:01 | 000,057,906 | ---- | M] () -- C:\TDSSKiller.2.5.8.0_01.07.2011_13.45.06_log.txt
    [2011/01/27 16:08:32 | 000,000,150 | ---- | M] () -- C:\YServer.txt
    < %systemroot%\Fonts\*.com >
    [2006/04/18 16:39:28 | 000,026,040 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalMonospace.CompositeFont
    [2006/06/29 15:53:56 | 000,026,489 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalSansSerif.CompositeFont
    [2006/04/18 16:39:28 | 000,029,779 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalSerif.CompositeFont
    [2006/06/29 15:58:52 | 000,030,808 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalUserInterface.CompositeFont
    < %systemroot%\Fonts\*.dll >
    < %systemroot%\Fonts\*.ini >
    [2002/09/03 07:59:02 | 000,000,067 | -HS- | M] () -- C:\WINDOWS\Fonts\DESKTOP.INI
    < %systemroot%\Fonts\*.ini2 >
    < %systemroot%\Fonts\*.exe >
    < %systemroot%\system32\spool\prtprocs\w32x86\*.* >
    [2007/10/21 22:00:00 | 000,027,136 | ---- | M] (CANON INC.) -- C:\WINDOWS\system32\spool\prtprocs\w32x86\CNMPD97.DLL
    [2007/10/21 22:00:00 | 000,069,632 | ---- | M] (CANON INC.) -- C:\WINDOWS\system32\spool\prtprocs\w32x86\CNMPP97.DLL
    [2008/07/06 05:06:10 | 000,089,088 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\spool\prtprocs\w32x86\filterpipelineprintproc.dll
    [2008/07/06 03:50:03 | 000,597,504 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\spool\prtprocs\w32x86\printfilterpipelinesvc.exe
    < %systemroot%\REPAIR\*.bak1 >
    < %systemroot%\REPAIR\*.ini >
    < %systemroot%\system32\*.jpg >
    < %systemroot%\*.jpg >
    < %systemroot%\*.png >
    < %systemroot%\*.scr >
    < %systemroot%\*._sy >
    < %APPDATA%\Adobe\Update\*.* >
    < %ALLUSERSPROFILE%\Favorites\*.* >
    < %APPDATA%\Microsoft\*.* >
    < %PROGRAMFILES%\*.* >
    [2008/06/23 22:40:33 | 000,000,000 | ---- | M] () -- C:\Program Files\uninstall.dat
    < %APPDATA%\Update\*.* >
    < %systemroot%\*. /mp /s >
    < %systemroot%\System32\config\*.sav >
    [2002/09/03 07:47:18 | 000,094,208 | ---- | M] () -- C:\WINDOWS\System32\config\DEFAULT.SAV
    [2002/09/03 07:47:18 | 000,602,112 | ---- | M] () -- C:\WINDOWS\System32\config\SOFTWARE.SAV
    [2002/09/03 07:47:18 | 000,380,928 | ---- | M] () -- C:\WINDOWS\System32\config\SYSTEM.SAV
    < %PROGRAMFILES%\bak. /s >
    < %systemroot%\system32\bak. /s >
    < %ALLUSERSPROFILE%\Start Menu\*.lnk /x >
    [2004/10/24 16:41:11 | 000,000,272 | -HS- | M] () -- C:\Documents and Settings\All Users\Start Menu\DESKTOP.INI
    < %systemroot%\system32\config\systemprofile\*.dat /x >
    < %systemroot%\*.config >
    < %systemroot%\system32\*.db >
    < %APPDATA%\Microsoft\Internet Explorer\Quick Launch\*.lnk /x >
    [2004/10/24 17:04:00 | 000,000,177 | -HS- | M] () -- C:\Documents and Settings\James\Application Data\Microsoft\Internet Explorer\Quick Launch\DESKTOP.INI
    [2004/01/21 18:58:54 | 000,000,079 | ---- | M] () -- C:\Documents and Settings\James\Application Data\Microsoft\Internet Explorer\Quick Launch\Show Desktop.scf
    < %USERPROFILE%\Desktop\*.exe >
    < %PROGRAMFILES%\Common Files\*.* >
    < %systemroot%\*.src >
    < %systemroot%\install\*.* >
    < %systemroot%\system32\DLL\*.* >
    < %systemroot%\system32\HelpFiles\*.* >
    < %systemroot%\system32\rundll\*.* >
    < %systemroot%\winn32\*.* >
    < %systemroot%\Java\*.* >
    < %systemroot%\system32\test\*.* >
    < %systemroot%\system32\Rundll32\*.* >
    < %systemroot%\AppPatch\Custom\*.* >
    < %APPDATA%\Roaming\Microsoft\Windows\Recent\*.lnk /x >
    < %PROGRAMFILES%\PC-Doctor\Downloads\*.* >
    < %PROGRAMFILES%\Internet Explorer\*.tmp >
    < %PROGRAMFILES%\Internet Explorer\*.dat >
    < %USERPROFILE%\My Documents\*.exe >
    < %USERPROFILE%\*.exe >
    < %systemroot%\ADDINS\*.* >
    [2002/08/29 04:00:00 | 000,000,791 | ---- | M] () -- C:\WINDOWS\ADDINS\fxsext.ecf
    < %systemroot%\assembly\*.bak2 >
    < %systemroot%\Config\*.* >
    < %systemroot%\REPAIR\*.bak2 >
    < %systemroot%\SECURITY\Database\*.sdb /x >
    < %systemroot%\SYSTEM\*.bak2 >
    < %systemroot%\Web\*.bak2 >
    < %systemroot%\Driver Cache\*.* >
    < %PROGRAMFILES%\Mozilla Firefox\0*.exe >
    < %ProgramFiles%\Microsoft Common\*.* >
    < %ProgramFiles%\TinyProxy. >
    < %USERPROFILE%\Favorites\*.url /x >
    [2004/10/24 17:04:00 | 000,000,122 | -HS- | M] () -- C:\Documents and Settings\James\Favorites\Desktop.ini
    < %systemroot%\system32\*.bk >
    < %systemroot%\*.te >
    < %systemroot%\system32\system32\*.* >
    < %ALLUSERSPROFILE%\*.dat /x >
    < %systemroot%\system32\drivers\*.rmv >
    < dir /b "%systemroot%\system32\*.exe" | find /i " " /c >
    < dir /b "%systemroot%\*.exe" | find /i " " /c >
    < %PROGRAMFILES%\Microsoft\*.* >
    < %systemroot%\System32\Wbem\proquota.exe >
    < %PROGRAMFILES%\Mozilla Firefox\*.dat >
    < %USERPROFILE%\Cookies\*.txt /x >
    [2009/06/25 21:47:37 | 000,000,067 | -HS- | M] () -- C:\Documents and Settings\James\Cookies\desktop.ini
    [2011/07/03 10:15:03 | 000,262,144 | ---- | M] () -- C:\Documents and Settings\James\Cookies\INDEX.DAT
    < %SystemRoot%\system32\fonts\*.* >
    < %systemroot%\system32\winlog\*.* >
    < %systemroot%\system32\Language\*.* >
    < %systemroot%\system32\Settings\*.* >
    < %systemroot%\system32\*.quo >
    < %SYSTEMROOT%\AppPatch\*.exe >
    < %SYSTEMROOT%\inf\*.exe >
    [2007/06/26 23:10:26 | 000,317,440 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\inf\unregmp2.exe
    < %SYSTEMROOT%\Installer\*.exe >
    < %systemroot%\system32\config\*.bak2 >
    < %systemroot%\system32\Computers\*.* >
    < %SystemRoot%\system32\Sound\*.* >
    < %SystemRoot%\system32\SpecialImg\*.* >
    < %SystemRoot%\system32\code\*.* >
    < %SystemRoot%\system32\draft\*.* >
    < %SystemRoot%\system32\MSSSys\*.* >
    < %ProgramFiles%\Javascript\*.* >
    < %systemroot%\pchealth\helpctr\System\*.exe /s >
    < %systemroot%\Web\*.exe >
    < %systemroot%\system32\msn\*.* >
    < %systemroot%\system32\*.tro >
    < %AppData%\Microsoft\Installer\msupdates\*.* >
    < %ProgramFiles%\Messenger\*.* >
    [2004/08/04 00:56:41 | 000,028,672 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\custsat.dll
    [2002/08/20 11:32:18 | 000,004,821 | ---- | M] () -- C:\Program Files\Messenger\LOGOWIN.GIF
    [2002/08/20 11:32:18 | 000,007,047 | ---- | M] () -- C:\Program Files\Messenger\LVBACK.GIF
    [2002/08/20 11:32:22 | 000,000,807 | ---- | M] () -- C:\Program Files\Messenger\MAILTMPL.TXT
    [2008/05/02 07:22:02 | 000,083,968 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\msgsc.dll
    [2004/08/04 00:56:13 | 000,180,224 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\msgslang.dll
    [2004/10/13 09:24:37 | 001,694,208 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\msmsgs.exe
    [2002/08/20 14:08:38 | 000,069,663 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\MSMSGSIN.EXE
    [2002/08/29 04:00:00 | 000,002,882 | ---- | M] () -- C:\Program Files\Messenger\NEWALERT.WAV
    [2002/08/29 04:00:00 | 000,006,156 | ---- | M] () -- C:\Program Files\Messenger\NEWEMAIL.WAV
    [2002/08/29 04:00:00 | 000,006,160 | ---- | M] () -- C:\Program Files\Messenger\ONLINE.WAV
    [2002/08/20 11:32:20 | 000,004,454 | ---- | M] () -- C:\Program Files\Messenger\TYPE.WAV
    [2004/07/17 11:41:04 | 000,115,981 | ---- | M] () -- C:\Program Files\Messenger\xpmsgr.chm
    < %systemroot%\system32\systhem32\*.* >
    < %systemroot%\system\*.exe >
    [1996/08/27 02:12:00 | 000,004,176 | R--- | M] (Apple Computer, Inc.) -- C:\WINDOWS\system\QTNOTIFY.EXE
    < HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU >
    < HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\ Auto Update\Results\Install|LastSuccessTime /rs >
    ========== Files - Unicode (All) ==========
    [2008/06/10 23:07:22 | 000,000,000 | ---D | M](C:\Documents and Settings\James\Application Data\??sembly) -- C:\Documents and Settings\James\Application Data\аѕsembly
    [2008/05/02 12:38:15 | 000,000,000 | ---D | M](C:\Documents and Settings\James\Application Data\?racle) -- C:\Documents and Settings\James\Application Data\Οracle
    ========== Alternate Data Streams ==========
    @Alternate Data Stream - 88 bytes -> C:\Documents and Settings\James\My Documents\Install_Facebook_Plug-In_1.0.3[1]:SummaryInformation
    @Alternate Data Stream - 100 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:F085C8A1
    < End of report >
