Active All system tray icons gone!
Discussion in 'Malware and Virus Removal Archive' started by poetink, 2009/02/12.
  1. 2009/02/12
    poetink
    poetink Inactive Thread Starter
    [Active] All system tray icons gone!
    Hi,
    Last night I downloaded a program called (or at least I thought it was) "style XP" from the "emule" file sharing program. (yes I know, I probably should've been more careful).
    But after it downloaded, I did scan it with my AV program before opening it and it didn't detect anything wrong, so I tried installing it.
    I clicked on what was an icon that resembled a key, and a prompt came up that said something (to my best recollection since I closed the prompt fast) about it being called "black box" and mentioned something about it being used for aircraft. (obviously meaning something about the black boxes planes use to record flights in case of crashes and the like). :confused:
    After this came up, I rebooted right away. and when windows came back up, the first thing that happened was that my AV program (Avast) tried coming on, but something came up near the system tray icon saying that "something" was preventing Avast from starting, loading, or activating (it came up pretty fast so I don't remember everything it said before the avast icon disappeared).
    Not only did my AV program fail to boot up, but everything else that booted in the system tray before was no longer there. One of which is the sound icon. And now without that, my computer's sound is not working and according to the sound and audio properties, it's saying I have no audio device. But the sound does come on briefly at the log on screen, but when it gets to the desktop, the sound stops functioning.
    IE7 is also having problems now where I can't go to any sites. When I try going somewhere using my favorites folder, another browser window comes up and just goes to my default start page "google ". (I'm currently using firefox since it seems to be working normally).
    When I tried to start up Avast, a prompt comes up saying that "Avast is not a valid win32 application ". The same is said when I try to start superantispyware. Other prgrams seem to be running normally though.
    I also tried using system restore, but it couldn't restore the computer.
    Any idea if this could be a virus or spyware/malware that avast just didn't detect and if so, what can I do, if anything?
    I'm running windows XP with SP3 installed.
    Any help would be appreciated as I'm at my wits end and very angry with myself for downloading this program from emule especially if it indeed is a virus of somekind and caused this problem. A definite lesson to be learned.
  2. 2009/02/12
    poetink
    I was just able to start up my security center by restarting it in services. Then I turned on my filewall, and to my dismay, it asked me if I wanted to allow a file called flec006 to be allowed by the firewall. I of course said no. And quickly did a search on google for flec006 and found out is is a virus/spyware. I'm currently searching high and low for a way to get rid of this. While I am doing this, if anyone here knows of a solution please let me know! Thanks.
    Hi,
    Read this post as indicated at the top of this forum & follow the instructions.
  5. 2009/02/12
    poetink
    Ok Arie. Here is the first log file from DDS.txt:
    DDS (Ver_09-02-01.01) - NTFSx86
    Run by Compaq_Owner at 21:15:42.89 on Thu 02/12/2009
    Internet Explorer: 7.0.5730.13 BrowserJavaVersion: 1.6.0_12
    Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.503.126 [GMT -5:00]
    C:\WINDOWS\system32\svchost -k DcomLaunch
    svchost.exe
    C:\WINDOWS\System32\svchost.exe -k netsvcs
    C:\WINDOWS\system32\svchost.exe -k WudfServiceGroup
    svchost.exe
    svchost.exe
    C:\WINDOWS\system32\LEXBCES.EXE
    C:\WINDOWS\system32\LEXPPS.EXE
    C:\WINDOWS\system32\svchost.exe -k imgsvc
    C:\windows\system\hpsysdrv.exe
    C:\Program Files\Mozilla Firefox\firefox.exe
    C:\WINDOWS\explorer.exe
    C:\Documents and Settings\Compaq_Owner\Desktop\dds.scr
    uStart Page = hxxp://www.google.com/
    uDefault_Page_URL = hxxp://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iehome&locale=EN_US&c=Q105&bd=presario&pf=desktop
    uDefault_Search_URL = hxxp://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iesearch&locale=EN_US&c=Q105&bd=presario&pf=desktop
    uSearch Bar = hxxp://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iesearch&locale=EN_US&c=Q105&bd=presario&pf=desktop
    mSearch Bar = hxxp://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iesearch&locale=EN_US&c=Q105&bd=presario&pf=desktop
    uInternet Connection Wizard,ShellNext = hxxp://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iehome&locale=EN_US&c=Q105&bd=presario&pf=desktop
    mWinlogon: UIHost=c:\windows\system32\logonui.exe
    BHO: {02478D38-C3F9-4efb-9B51-7695ECA05670} - No File
    BHO: NoExplorer - No File
    BHO: Adobe PDF Link Helper: {18df081c-e8ad-4283-a596-fa578c2ebdc3} - c:\program files\common files\adobe\acrobat\activex\AcroIEHelperShim.dll
    BHO: AVG Safe Search: {3ca2f312-6f6e-4b53-a66e-4e65e497c8c0} - c:\program files\avg\avg8\avgssie.dll
    BHO: SSVHelper Class: {761497bb-d6f0-462c-b6eb-d4daf1d92d43} - c:\program files\java\jre6\bin\ssv.dll
    BHO: Google Toolbar Notifier BHO: {af69de43-7d58-4638-b6fa-ce66b5ad205d} - c:\program files\google\googletoolbarnotifier\5.0.926.3450\swg.dll
    BHO: Java(tm) Plug-In 2 SSV Helper: {dbc80044-a445-435b-bc74-9c25c1c588a9} - c:\program files\java\jre6\bin\jp2ssv.dll
    BHO: JQSIEStartDetectorImpl Class: {e7e6f031-17ce-4c07-bc86-eabfe594f69c} - c:\program files\java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
    BHO: Cooliris Plug-In for Internet Explorer: {eaee5c74-6d0d-4aca-9232-0da4a7b866ba} - c:\program files\piclensie\cooliris.dll
    TB: {9516EB1C-AC77-492D-8FD6-A05AFAC9EA6E} - No File
    EB: {32683183-48a0-441b-a342-7c2a440a9478} - No File
    uRun: [Desktop Architect] "c:\program files\desktop architect\datray.exe" -S
    uRun: [ctfmon.exe] c:\windows\system32\ctfmon.exe
    mRun: [hpsysdrv] c:\windows\system\hpsysdrv.exe
    mRun: [SiSPower] Rundll32.exe SiSPower.dll,ModeAgent
    mRun: [ISUSPM Startup] c:\progra~1\common~1\instal~1\update~1\ISUSPM.exe -startup
    mRun: [SunJavaUpdateSched] "c:\program files\java\jre6\bin\jusched.exe "
    mPolicies-system: EnableLUA = 0 (0x0)
    IE: &ieSpell Options - c:\program files\iespell\iespell.dll/SPELLOPTION.HTM
    IE: &Search - http://edits.mywebsearch.com/toolbaredits/menusearch.jhtml?p=ZU
    IE: Check &Spelling - c:\program files\iespell\iespell.dll/SPELLCHECK.HTM
    IE: E&xport to Microsoft Excel - c:\progra~1\mi1933~1\office11\EXCEL.EXE/3000
    IE: Lookup on Merriam Webster - file://c:\program files\iespell\Merriam Webster.HTM
    IE: Lookup on Wikipedia - file://c:\program files\iespell\wikipedia.HTM
    IE: {0E17D5B7-9F5D-4fee-9DF6-CA6EE38B68A8} - res://c:\program files\iespell\iespell.dll/SPELLCHECK.HTM
    IE: {1606D6F9-9D3B-4aea-A025-ED5B2FD488E7} - res://c:\program files\iespell\iespell.dll/SPELLOPTION.HTM
    IE: {e2e2dd38-d088-4134-82b7-f2ba38496583} - %windir%\Network Diagnostic\xpnetdiag.exe
    IE: {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - {CAFEEFAC-0016-0000-0012-ABCDEFFEDCBC} - c:\program files\java\jre6\bin\npjpi160_12.dll
    IE: {3437D640-C91A-458f-89F5-B9095EA4C28B} - {04F93351-81D2-4484-9982-0D55DEFFFAE6} - c:\program files\piclensie\cooliris.dll
    Trusted Zone: drivecleaner.com
    Trusted Zone: errorprotector.com
    Trusted Zone: imageservr.com
    Trusted Zone: systemdoctor.com
    DPF: {05CA9FB0-3E3E-4B36-BF41-0E3A5CAA8CD8} - hxxp://download.microsoft.com/download/e/4/9/e494c802-dd90-4c6b-a074-469358f075a6/OGAControl.cab
    DPF: {0742B9EF-8C83-41CA-BFBA-830A59E23533} - hxxps://support.microsoft.com/OAS/ActiveX/MSDcode.cab
    DPF: {17492023-C23A-453E-A040-C7C580BBF700} - hxxp://download.microsoft.com/download/F/D/9/FD9E437D-5BC8-4264-A093-DFA2C39D197E/LegitCheckControl.cab
    DPF: {1D4DB7D2-6EC9-47A3-BD87-1E41684E07BB} - hxxp://ak.exe.imgfarm.com/images/nocache/funwebproducts/ei/MyFunCardsFWBInitialSetup1.0.0.15-3.cab
    DPF: {233C1507-6A77-46A4-9443-F871F945D258} - hxxp://download.macromedia.com/pub/shockwave/cabs/director/sw.cab
    DPF: {5AE58FCF-6F6A-49B2-B064-02492C66E3F4} - hxxp://catalog.update.microsoft.com/v7/site/ClientControl/en/x86/MuCatalogWebControl.cab?1233963438359
    DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} - hxxp://update.microsoft.com/microsoftupdate/v6/V5Controls/en/x86/client/muweb_site.cab?1233081266718
    DPF: {6F15128C-E66A-490C-B848-5000B5ABEEAC} - hxxps://h20436.www2.hp.com/ediags/dex/secure/HPDEXAXO.cab
    DPF: {73ECB3AA-4717-450C-A2AB-D00DAD9EE203} - hxxp://h20270.www2.hp.com/ediags/gmn2/install/HPProductDetection.cab
    DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_12-windows-i586.cab
    DPF: {8FFBE65D-2C9C-4669-84BD-5829DC0B603C} - hxxp://fpdownload.macromedia.com/get/flashplayer/current/polarbear/ultrashim.cab
    DPF: {C52439A0-2693-4E40-B141-9F9AD5257241} - hxxps://ediagnostics.lexmark.com/serval.cab
    DPF: {C7DB51B4-BCF7-4923-8874-7F1A0DC92277} - hxxp://office.microsoft.com/officeupdate/content/opuc4.cab
    DPF: {CAFEEFAC-0014-0002-0003-ABCDEFFEDCBA} - hxxp://java.sun.com/products/plugin/autodl/jinstall-142-windows-i586.cab
    DPF: {CAFEEFAC-0016-0000-0001-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_01-windows-i586.cab
    DPF: {CAFEEFAC-0016-0000-0012-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_12-windows-i586.cab
    DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_12-windows-i586.cab
    DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} - hxxp://fpdownload2.macromedia.com/get/shockwave/cabs/flash/swflash.cab
    DPF: {D71F9A27-723E-4B8B-B428-B725E47CBA3E} - hxxp://imikimi.com/download/imikimi_plugin.cab
    Handler: linkscanner - {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} -
    Notify: !SASWinLogon - c:\program files\superantispyware\SASWINLO.dll
    Notify: igfxcui - igfxsrvc.dll
    SSODL: 0aMCPClient - {F5DF91F9-15E9-416B-A7C3-7519B11ECBFC} - No File
    SSODL: WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - c:\windows\system32\WPDShServiceObj.dll
    SEH: SABShellExecuteHook Class: {5ae067d3-9afb-48e0-853a-ebb7f4a000da} - c:\program files\superantispyware\SASSEH.DLL
    SEH: {F552DDE6-2090-4bf4-B924-6141E87789A5} - No File
    LSA: Notification Packages =
    ================= FIREFOX ===================
    FF - ProfilePath - c:\docume~1\compaq~1\applic~1\mozilla\firefox\profiles\2ov2z8v2.default\
    FF - prefs.js: browser.search.selectedEngine - qtl
    FF - prefs.js: browser.startup.homepage - hxxp://www.google.com/
    FF - component: c:\documents and settings\compaq_owner\application data\mozilla\firefox\profiles\2ov2z8v2.default\extensions\piclens@cooliris.com\components\coolirisstub.dll
    FF - plugin: c:\program files\google\google updater\2.4.1487.6512\npCIDetect13.dll
    FF - plugin: c:\program files\google\update\1.2.141.5\npGoogleOneClick7.dll
    FF - plugin: c:\program files\ksolo\npAVX.dll
    FF - plugin: c:\program files\mozilla firefox\plugins\npGoogleGadgetPluginFirefoxWin.dll
    FF - plugin: c:\program files\mozilla firefox\plugins\npyaxmpb.dll
    FF - plugin: c:\program files\unity\webplayer\loader\npUnity3D32.dll
    FF - plugin: c:\program files\viewpoint\viewpoint experience technology\npViewpoint.dll
    R1 SASDIFSV;SASDIFSV;c:\program files\superantispyware\sasdifsv.sys [2009-1-15 8944]
    R1 SASKUTIL;SASKUTIL;c:\program files\superantispyware\SASKUTIL.SYS [2009-1-15 55024]
    R1 sK9Ou0s;sK9Ou0s;c:\documents and settings\compaq_owner\application data\drivers\srosa2.sys [2009-2-12 7168]
    S0 Partizan;Partizan;c:\windows\system32\drivers\partizan.sys --> c:\windows\system32\drivers\Partizan.sys [?]
    S2 gupdate1c9862c67c9220c;Google Update Service (gupdate1c9862c67c9220c);c:\program files\google\update\GoogleUpdate.exe [2009-2-3 133104]
    S3 RegGuard;RegGuard;c:\windows\system32\drivers\regguard.sys [2009-2-12 29584]
    S3 SASENUM;SASENUM;c:\program files\superantispyware\SASENUM.SYS [2009-1-15 7408]
    2009-02-12 19:52 29,584 a------- c:\windows\system32\drivers\regguard.sys
    2009-02-12 19:49 <DIR> --d----- c:\program files\Greatis
    2009-02-12 19:13 <DIR> --d----- C:\VundoFix Backups
    2009-02-12 12:57 <DIR> --d----- c:\program files\Panda Security
    2009-02-12 06:07 <DIR> --d----- c:\documents and settings\compaq_owner\.housecall6.6
    2009-02-12 05:38 <DIR> --d----- c:\docume~1\alluse~1\applic~1\avg8
    2009-02-12 04:41 17,857 a------- c:\windows\system32\drivers\SGuard.sys
    2009-02-12 04:17 <DIR> --d----- c:\docume~1\compaq~1\applic~1\iolo
    2009-02-12 04:17 <DIR> --d----- c:\docume~1\alluse~1\applic~1\iolo
    2009-02-12 04:16 <DIR> --d----- c:\program files\CCleaner
    2009-02-12 03:54 406 a------- c:\windows\system32\ioloBootDefrag.cfg
    2009-02-12 03:34 <DIR> --d----- c:\program files\Yahoo!
    2009-02-12 02:14 <DIR> --d-h--- c:\docume~1\compaq~1\applic~1\m
    2009-02-12 02:10 <DIR> --d----- c:\windows\system32\drivers\down
    2009-02-12 02:04 <DIR> --d-h--- c:\docume~1\compaq~1\applic~1\drivers
    2009-02-12 01:29 0 a------- c:\windows\windowfx3.ini
    2009-02-12 01:28 0 a------- c:\windows\windowfx2.ini
    2009-02-12 01:27 10 a------- c:\windows\system32\wfxhelp22.dll
    2009-02-11 23:39 0 -------- c:\windows\WB.ini
    2009-02-11 23:37 42,672 -------- c:\windows\system32\wbsys.dll
    2009-02-11 23:17 24 a------- c:\windows\LogonStudio.ini
    2009-02-11 23:16 187,392 a------- c:\windows\system32\JPGUtils.dll
    2009-02-11 23:16 <DIR> --d----- c:\program files\WinCustomize
    2009-02-11 20:46 266,360 a------- c:\windows\system32\TweakUI.exe
    2009-02-11 20:46 160,217 a------- c:\windows\system32\PowerToysLicense.rtf
    2009-02-11 19:52 <DIR> --d----- c:\windows\Icons
    2009-02-11 19:52 <DIR> --d----- c:\program files\FileSubmit
    2009-02-11 19:37 <DIR> --d----- c:\program files\OneRiot
    2009-02-11 19:11 <DIR> --d----- c:\docume~1\compaq~1\applic~1\Stardock
    2009-02-11 19:10 <DIR> --d-h--- c:\docume~1\alluse~1\applic~1\{4D84A86B-BFC2-4B9B-B3C4-207F5860E952}
    2009-02-11 19:10 <DIR> --d----- c:\program files\Stardock
    2009-02-11 17:12 <DIR> --d----- c:\program files\PicLensIE
    2009-02-10 13:49 2,560 a------- c:\windows\_MSRSTRT.EXE
    2009-02-10 13:49 <DIR> --dsh--- C:\INCINERATE
    2009-02-09 16:46 <DIR> --d----- c:\windows\system32\CatRoot2
    2009-02-08 21:07 <DIR> --d----- c:\docume~1\compaq~1\applic~1\WinBatch
    2009-02-08 20:45 <DIR> --d----- c:\program files\VIA
    2009-02-08 20:45 <DIR> --d----- C:\softpaq
    2009-02-08 20:30 156,672 -------- c:\windows\system32\RtlCPAPI.dll
    2009-02-08 20:30 69,632 -------- c:\windows\soundman.exe
    2009-02-08 20:30 40,448 -------- c:\windows\system32\ChCfg.exe
    2009-02-08 20:30 9,196,032 -------- c:\windows\system32\RTLCPL.exe
    2009-02-08 20:30 141,016 -------- c:\windows\system32\alsndmgr.wav
    2009-02-08 20:30 208,896 -------- c:\windows\alcupd.exe
    2009-02-08 20:30 139,264 -------- c:\windows\alcrmv.exe
    2009-02-08 16:24 <DIR> --d----- c:\program files\Ares
    2009-02-07 23:10 <DIR> --d----- c:\docume~1\compaq~1\applic~1\ieSpell
    2009-02-07 23:09 <DIR> --d----- c:\program files\ieSpell
    2009-02-06 21:27 <DIR> --d----- c:\documents and settings\compaq_owner\Tracing
    2009-02-06 21:20 <DIR> --d----- c:\program files\common files\Windows Live
    2009-02-05 16:53 <DIR> --d----- c:\program files\common files\xing shared
    2009-02-05 12:14 <DIR> --d----- c:\program files\filehippo.com
    2009-02-03 12:23 126,656 a------- c:\windows\system\CardView.dll
    2009-02-01 22:07 <DIR> --d----- c:\program files\Eusing Free Registry Cleaner
    2009-02-01 13:38 <DIR> --d----- c:\program files\common files\Stardock
    2009-01-30 19:44 <DIR> --d----- c:\program files\Unity
    2009-01-29 14:50 <DIR> --d----- c:\program files\eMule
    2009-01-28 16:08 <DIR> --d----- c:\program files\WS_FTP
    2009-01-28 13:38 12 a------- c:\windows\dirsaver.ini
    2009-01-28 13:38 569,588 a------- c:\windows\DateTime.scr
    2009-01-28 13:38 0 a------- c:\windows\FlashForge.ini
    2009-01-28 13:35 <DIR> --d----- c:\program files\Goldshell
    2009-01-28 12:40 146,321 a------- c:\windows\system32\plus!.hlp
    2009-01-28 12:40 1,300 a------- c:\windows\system32\cool.dll
    2009-01-28 12:40 32,768 a------- c:\windows\system32\dapanel.cpl
    2009-01-28 12:40 <DIR> --d----- c:\program files\Desktop Architect
    2009-01-27 21:46 <DIR> --d----- c:\program files\HP
    2009-01-27 21:27 <DIR> --d----- c:\program files\kSolo
    2009-01-27 17:56 <DIR> --d----- c:\program files\Flash MX
    2009-01-27 15:44 <DIR> --d----- c:\windows\ShellNew
    2009-01-27 14:54 <DIR> --d----- c:\docume~1\compaq~1\applic~1\XnView
    2009-01-27 14:37 <DIR> --d----- c:\program files\XnView
    2009-01-27 14:24 25,608 a------- c:\windows\system32\X3DAudio1_4.dll
    2009-01-27 14:22 <DIR> --d----- c:\windows\Logs
    2009-01-27 13:44 <DIR> --d----- c:\program files\Atomic Clock
    2009-01-27 13:38 410,984 a------- c:\windows\system32\deploytk.dll
    2009-01-27 11:55 <DIR> --d----- c:\docume~1\alluse~1\applic~1\SUPERAntiSpyware.com
    2009-01-27 11:55 <DIR> --d----- c:\program files\SUPERAntiSpyware
    2009-01-27 11:55 <DIR> --d----- c:\docume~1\compaq~1\applic~1\SUPERAntiSpyware.com
    2009-01-27 11:54 <DIR> --d----- c:\program files\common files\Wise Installation Wizard
    2009-01-27 11:46 <DIR> --d----- c:\program files\Windows Media Connect 2
    2009-01-27 10:35 <DIR> --d-h--- c:\program files\WindowsUpdate
    2009-01-27 03:25 <DIR> --d----- c:\windows\system32\Adobe
    2009-01-27 02:54 459,264 -c------ c:\windows\system32\dllcache\msfeeds.dll
    2009-01-27 02:54 267,776 -c------ c:\windows\system32\dllcache\iertutil.dll
    2009-01-27 02:54 52,224 -c------ c:\windows\system32\dllcache\msfeedsbs.dll
    2009-01-27 02:54 383,488 -c------ c:\windows\system32\dllcache\ieapfltr.dll
    2009-01-27 02:54 63,488 -c------ c:\windows\system32\dllcache\icardie.dll
    2009-01-27 02:54 13,824 -c------ c:\windows\system32\dllcache\ieudinit.exe
    2009-01-27 02:54 2,455,488 -c------ c:\windows\system32\dllcache\ieapfltr.dat
    2009-01-27 02:54 991,232 -c------ c:\windows\system32\dllcache\ieframe.dll.mui
    2009-01-27 02:54 6,066,176 -c------ c:\windows\system32\dllcache\ieframe.dll
    2009-01-27 02:20 <DIR> --d----- c:\windows\ServicePackFiles
    2009-01-27 02:08 616,960 a------- c:\windows\system32\advapi32.dll
    2009-01-27 02:07 <DIR> --d----- c:\windows\EHome
    2009-01-27 00:04 705,536 a------- c:\windows\system32\Incinerator.dll
    2009-01-27 00:04 30,942 a------- c:\windows\system32\iolobtdfg.exe
    2009-01-27 00:04 25,264 a------- c:\windows\system32\smrgdf.exe
    2009-01-27 00:04 <DIR> --d----- c:\program files\iolo
    2009-01-26 23:39 87,040 ac------ c:\windows\system32\dllcache\wiafbdrv.dll
    2009-01-26 23:39 87,040 a------- c:\windows\system32\wiafbdrv.dll
    2009-01-26 23:39 352,256 a------- c:\windows\system32\LXBKUTIL.DLL
    2009-01-26 23:39 69,632 a------- c:\windows\system32\lxbkscin.dll
    2009-01-26 23:39 983,101 a------- c:\windows\system32\LXBKGF.DLL
    2009-01-26 23:39 57,344 a------- c:\windows\system32\lxbkcinf.dll
    2009-01-26 23:39 49,152 a------- c:\windows\system32\lxbkcoin.dll
    2009-01-26 23:39 266 a------- c:\windows\system32\lxbkcoin.ini
    2009-01-26 23:39 454,656 a------- c:\windows\system32\LXBKJSWR.DLL
    2009-01-26 23:39 <DIR> --d----- c:\program files\Lexmark X1100 Series
    2009-01-26 23:39 <DIR> --d----- c:\documents and settings\compaq_owner\WINDOWS
    2009-01-19 14:08 524,288 a------- c:\windows\opuc.dll
    2009-02-12 05:53 76,487 a------- c:\windows\pchealth\helpctr\offlinecache\index.dat
    2009-02-12 00:43 2,830,848 a------- c:\windows\system32\logonuiX.exe
    2009-02-03 10:36 5,058 a------- c:\windows\help\hhcolreg.dat
    2006-08-30 13:43 774,144 ac------ c:\program files\RngInterstitial.dll
    ============= FINISH: 21:16:48.67 ===============
  6. 2009/02/12
    poetink
    And here's the log listing from attach.txt:
    UNLESS SPECIFICALLY INSTRUCTED, DO NOT POST THIS LOG.
    IF REQUESTED, ZIP IT UP & ATTACH IT
    Boot Device: \Device\HarddiskVolume2
    Install Date: 6/13/2007 12:18:10 PM
    System Uptime: 2/12/2009 8:35:02 PM (1 hours ago)
    Motherboard: ASUSTek Computer INC. | | Kelut
    Processor: AMD Sempron(tm) 3000+ | Socket A | 1999/166mhz
    ==== Disk Partitions =========================
    C: is FIXED (NTFS) - 32 GiB total, 17.839 GiB free.
    D: is FIXED (FAT32) - 5 GiB total, 0.908 GiB free.
    E: is CDROM ()
    ==== Disabled Device Manager Items =============
    Class GUID: {36FC9E60-C465-11CF-8056-444553540000}
    Description: USB Mass Storage Device
    Device ID: USB\VID_058F&PID_9360\9205291
    Manufacturer: Compatible USB storage device
    Name: USB Mass Storage Device
    PNP Device ID: USB\VID_058F&PID_9360\9205291
    Service: USBSTOR
    ==== System Restore Points ===================
    No restore point in system.
    ==== Installed Programs ======================
    Adobe AIR
    Adobe Flash Player 10 ActiveX
    Adobe Flash Player 10 Plugin
    Adobe Reader 9
    Adobe Shockwave Player 11
    Agere Systems PCI Soft Modem
    Apple Software Update
    Ares 2.1.1
    CCleaner (remove only)
    Cooliris for Internet Explorer
    DateTime ScreenSaver
    Desktop Architect
    eMule
    filehippo.com Update Checker
    FlashForge
    Google Earth
    Google Update Helper
    Google Updater
    High Definition Audio Driver Package - KB835221
    Hotfix for Windows Media Format 11 SDK (KB929399)
    HP Product Detection
    HpSdpAppCoreApp
    ieSpell
    InterVideo WinDVD Player
    iolo technologies' System Mechanic 5
    Ipswitch WS_FTP LE
    IrfanView (remove only)
    Java 2 Runtime Environment, SE v1.4.2_03
    Java(TM) 6 Update 12
    Java(TM) SE Runtime Environment 6 Update 1
    kSolo Recorder
    LimeWire 4.18.8
    LogonStudio
    Microsoft .NET Framework 2.0 Service Pack 1
    Microsoft Application Error Reporting
    Microsoft Compression Client Pack 1.0 for Windows XP
    Microsoft Internationalized Domain Names Mitigation APIs
    Microsoft National Language Support Downlevel APIs
    Microsoft Office 2000 SR-1 Premium
    Microsoft Silverlight
    Microsoft User-Mode Driver Framework Feature Pack 1.0
    Microsoft Visual C++ 2005 Redistributable
    Microsoft Visual J# .NET Redistributable Package 1.1
    Mozilla Firefox (3.0.6)
    MSXML 4.0
    MSXML 4.0 SP2 (KB936181)
    MSXML 6.0 Parser (KB927977)
    Nero
    QuickTime
    RealPlayer
    Realtek AC'97 Audio
    S3 S3Display
    S3 S3Gamma2
    S3 S3Info2
    S3 S3Overlay
    S3GSetup
    Security Update for Windows Internet Explorer 7 (KB956390)
    Security Update for Windows Internet Explorer 7 (KB958215)
    Security Update for Windows Media Player (KB911564)
    Security Update for Windows Media Player 10 (KB936782)
    Security Update for Windows Media Player 6.4 (KB925398)
    Security Update for Windows XP (KB923689)
    Sonic Update Manager
    SoundPackager
    SUPERAntiSpyware Free Edition
    Tweak UI
    Unity Web Player
    VIA Rhine-Family Fast Ethernet Adapter
    VIA/S3G Display Driver
    Viewpoint Media Player
    Visual C++ 8.0 CRT (x86) WinSXS MSM
    WebFldrs XP
    Windows Genuine Advantage Validation Tool (KB892130)
    Windows Media Format 11 runtime
    Windows Media Player 11
    Windows XP Service Pack 3
    WinRAR archiver
    XnView 1.95.4
    ==== Event Viewer Messages From Past Week ========
    2/12/2009 8:14:26 PM, error: Rasman [20132] - Remote Access Connection Manager failed to start because the RAS RPC module failed to initialize. The specified procedure could not be found.
    2/12/2009 8:14:26 PM, error: Service Control Manager [7023] - The Remote Access Connection Manager service terminated with the following error: The specified procedure could not be found.
    2/12/2009 8:12:58 PM, error: Service Control Manager [7006] - The ScRegSetValueExW call failed for Type with the following error: Access is denied.
    2/12/2009 8:12:58 PM, error: Service Control Manager [7026] - The following boot-start or system-start driver(s) failed to load: Partizan
    2/12/2009 8:12:58 PM, error: Service Control Manager [7000] - The ASCTRM service failed to start due to the following error: The system cannot find the file specified.
    2/12/2009 8:12:58 PM, error: Service Control Manager [7001] - The Wireless Zero Configuration service depends on the NDIS Usermode I/O Protocol service which failed to start because of the following error: The service cannot be started, either because it is disabled or because it has no enabled devices associated with it.
    2/12/2009 8:12:34 PM, error: PlugPlayManager [12] - The device 'Microsoft System Management BIOS Driver' (Root\SYSTEM\0002) disappeared from the system without first being prepared for removal.
    2/12/2009 8:12:34 PM, error: PlugPlayManager [12] - The device 'Microcode Update Device' (Root\SYSTEM\0001) disappeared from the system without first being prepared for removal.
    2/12/2009 8:12:34 PM, error: PlugPlayManager [12] - The device 'Plug and Play Software Device Enumerator' (Root\SYSTEM\0000) disappeared from the system without first being prepared for removal.
    2/12/2009 8:11:40 PM, error: BITS [16391] - The BITS job list is not in a recognized format. It may have been created by a different version of BITS. The job list has been cleared.
    2/12/2009 8:08:52 PM, error: DCOM [10005] - DCOM got error "%1058" attempting to start the service wuauserv with arguments " " in order to run the server: {E60687F7-01A1-40AA-86AC-DB1CBF673334}
    2/12/2009 6:52:01 PM, error: Service Control Manager [7000] - The Distributed Transaction Coordinator service failed to start due to the following error: The service did not respond to the start or control request in a timely fashion.
    2/12/2009 6:52:01 PM, error: Service Control Manager [7009] - Timeout (30000 milliseconds) waiting for the Distributed Transaction Coordinator service to connect.
    2/12/2009 6:50:52 PM, error: Service Control Manager [7023] - The Windows Firewall/Internet Connection Sharing (ICS) service terminated with the following error: The class is configured to run as a security id different from the caller
    2/12/2009 6:50:52 PM, error: Service Control Manager [7034] - The Google Update Service (gupdate1c9862c67c9220c) service terminated unexpectedly. It has done this 1 time(s).
    2/12/2009 8:33:44 PM, error: Service Control Manager [7034] - The TCP/IP NetBIOS Helper service terminated unexpectedly. It has done this 1 time(s).
    2/12/2009 8:33:44 PM, error: Service Control Manager [7034] - The SSDP Discovery Service service terminated unexpectedly. It has done this 1 time(s).
    2/12/2009 8:33:44 PM, error: Service Control Manager [7034] - The WebClient service terminated unexpectedly. It has done this 1 time(s).
    2/12/2009 8:33:47 PM, error: Service Control Manager [7034] - The DNS Client service terminated unexpectedly. It has done this 1 time(s).
    2/12/2009 8:33:50 PM, error: Service Control Manager [7031] - The Windows Driver Foundation - User-mode Driver Framework service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 120000 milliseconds: Restart the service.
    2/12/2009 8:49:52 PM, error: Service Control Manager [7023] - The Application Management service terminated with the following error: The specified module could not be found.
    ==== End Of File ===========================
  7. 2009/02/13
    noahdfear
    noahdfear Inactive
    Hi poetink,
    Please visit the following webpage for instructions for downloading and running ComboFix
    How to use ComboFix
    Download ComboFix by sUBs from here, saving the file to your desktop.
    Disable realtime protection applications as they sometimes interfere with the tool. Check this link for your applicable programs.
    • Close all open programs and windows
    • Double click ComboFix.exe and follow the prompts.
    • It may reboot your computer and resume running when you logon. Wait for it to complete. When finished, it will open a log for you. Post that log in your next reply.
    Note: Do not mouseclick combofix's window while its running. That may cause it to stall
    **NOTE - I recommend you allow the Recovery Console to be downloaded and installed if or when prompted.
  8. 2009/02/13
    poetink
    Thanks noahdfear, but unfortunately I already tried combofix. It wouldn't even run. All I got was that "combofix is not a valid win32 application" error prompt, which I understand is part of this virus' function.
    What I need (if possible and if one exists) is somekind of manual removal of this thing. I've read from searching around about it that they say you have to try removing it in safe mode and deleting registry entries. I haven't tried this myself yet, but people who have tried, some say that the virus won't even allow them to go into safe mode.
    This is a major problem for me, because if I can't get rid of this thing, I'm stuck. Because I have no operating system disc to even reformat the drive for a reinstall if all else fails.
  9. 2009/02/13
    poetink
    Problem solved!
    After an extensive search, I finally found an old thread from another forum where a person was experiencing this virus and several others. The person resolved the problem himself by downloading and running a program called prevxcsi there is a free version of it, but it only uninstalls 2 found problems for free, you have to pay for a license to remove the rest. I scanned the computer with it, and it indeed found the flec006.exe virus (along with 19 other viruses I didn't know where on the computer!)
    I went to the program's site http://www.prevx.com And paid for a month license for $15.95 and rescanned, removed everything, and now it's as if there was no virus! At first my sound didn't come back up, but I checked the services area of windows, and saw that the "windows audio" service was turned off and set on manual, I started it, put on automatic, and my sound returned on my next reboot. So all I can say is whew! I thought I was dead in the water there for a while. So thanks to everyone that posted replies here to try and help me. I really appreciate it. And I strongly suggest anyone to try the prevx program, it was well worth the money, believe me! :)
  10. 2009/02/14
    noahdfear
    noahdfear Inactive
    Happy to hear of your success. Suggest you run an online scan to be sure there's nothing else remaining. Do an online scan with Kaspersky Online Scanner
    Click Accept, when prompted to download and install the program files and database of malware definitions.
    • Click Run at the Security prompt.
    • The program will then begin downloading and installing and will also update the database.
    • Please be patient as this can take several minutes.
    • Once the update is complete, click on My Computer under the green Scan bar to the left to start the scan.
    • Once the scan is complete, it will display if your system has been infected. It does not provide an option to clean/disinfect. We only require a report from it.
    • Click View scan report at the bottom.
    • Click the Save Report As... button.
    • Click the Save as Text button to save the file to your desktop so that you may post it in your next reply.
    **Note**
    To optimize scanning time and produce a more sensible report for review:
    • Close any open programs.
    • Turn off the real-time scanner of all antivirus or antispyware programs while performing the online scan.
    Post the Kaspersky log here.
