Resolved AddressBook Plus--Beloved 32 bit Legacy App
Discussion in 'Other PC Software' started by flamingo, 2011/07/09.
  1. 2011/08/07
    The backup disks are tied to your specific hardware & would not install,as you have already found out, on any other computer.
    If you could lay your hands on retail disks, it would work like charm.
  2. 2012/05/27
    flamingo
    flamingo Well-Known Member Thread Starter
    Success!! Address Book Plus under XP under VirtualBox
    At long, long last I have succeeded in getting new life from my beloved Address Book Plus (also called Instant Address Book) last released for Win 98 and probably a 16 bit application. At rsinfo's suggestion, I installed VirtualBox and its extension pak on my 64 bit Win 7 Home Premium laptop. I got a no-longer-in-use retail full version of XP Pro and installed it under VirtualBox. I updated XP to SP2 and then to most current updates. I then installed the Address Book Plus application. This all went extremely smoothly and the application executed fine. However, I couldn't write a file nor could I read an old file. I got a file incompatibility error. Researching the error didn't lead anywhere so I gave up. That was about three months ago. Last week I decided to try again. I'm not sure what I did differently, but it worked like a charm. I could read and write files shareable the Win 7 desktop and also to USB flashdrive. The application response time is instantaneous, just like it was under native 32 bit Vista, XP, Me, and 98. A complete success!!
    I am really impressed with VirtualBox. It installed flawlessly as did the extension pac. It didn't ask questions I couldn't answer. In the three months between my two attempts, there was one update to the VirtualBox and extension pac and that update was flawless. I didn't have to learn much about VirtualBox. It just worked. I am very impressed with that. Switching between the application under XP and the native Win 7 is trivially easy -- just move the cursor.
    I am a happy camper. Thanks everyone. Maybe over the next year or two I'll find a new application that has the functionality and ease of use of my legacy application.
    Now I'll see if I can use my legacy Canon Multipass printer which has no Win 7 drivers. Ink cartridges are only $1.20 each and that is less than 1/10 the price of current printer cartridges. No wonder Canon wanted to make it obsolete.
    ..Paul..
    Good to know you succeeded.
    Regarding your printer, try Xerox Mobile Express Driver. I haven't personally tested it, but its worth a try.
  5. 2012/06/01
    flamingo
    I looked at Xerox Mobile Express Driver per rsinfo's suggestion. It looked promising but I didn't find any descriptions of user experiences for non-Xerox printers. I'll come back to it later and do some more searching.
    Given my success with VirtualBox, I figured I would try installing the Canon drivers for XP (the most recent drivers available) on my XP running under VirtualBox on my Win 7 64 bit laptop. Much to my surprise and delight, it installed easily and seems to work fine for normal B&W and color printing. I haven't tried scanning. I've got some questions about VirtualBox but I guess I should go to the VirtualBox support site for those.
    ..Paul..
