Activate Admin Acct without logging in?
Discussion in 'Windows 7' started by Alex Ethridge, 2012/12/05.
  1. 2012/12/05
    Alex Ethridge
    Is there a way to activate the Administrator account in Windows 7 without logging in?
  2. 2012/12/06
    Hi Alex. There are ways you can enable the hidden Administrator account but to activate it, you do have to log into it.
    I assume you already enabled the account correct?
    Alex Ethridge
    No, the primary account is corrupt and I cannot log in. I was hoping for a way to activate the Admin account so I could then get in and create a new account, delete the corrupt one.
    I have an image from a couple of months back; I guess I'll use that.
  5. 2012/12/06
    See if the administrator account is enabled when you boot into Windows 7 using Safe Mode.
    The administrator account should be enabled there.
    If the administrator account still is not enabled in Safe Mode then follow the instructions here, Windows 7 - Built-in Administrator - Enable from WinRE.
  6. 2012/12/06
    The admin account is disabled by default in Win 7.
    You have to go to a CMD prompt via run as admin and then type:
    net user administrator /active:yes
    Course, you have to be insides Windows to do this.
  7. 2012/12/06
    That command can also be run from the Safe Mode with Command Prompt (press F8 while restarting the PC to get to the Advanced Boot Options).
