Solved A ton of viruses!
Discussion in 'Malware and Virus Removal Archive' started by KingZK, 2013/09/26.
  1. 2013/09/30
    KingZK
    KingZK Inactive Thread Starter
    Farbar Service Scanner Version: 13-09-2013
    Ran by Heidi (administrator) on 30-09-2013 at 20:43:31
    Running from "C:\Users\Heidi\Downloads "
    Windows 7 Professional Service Pack 1 (X64)
    Boot Mode: Normal
    Internet Services:
    Connection Status:
    Localhost is accessible.
    LAN connected.
    Google IP is accessible.
    Google.com is accessible.
    Yahoo.com is accessible.
    Windows Firewall:
    Firewall Disabled Policy:
    System Restore:
    System Restore Disabled Policy:
    Action Center:
    Windows Update:
    Windows Autoupdate Disabled Policy:
    Windows Defender:
    Other Services:
    File Check:
    C:\Windows\System32\nsisvc.dll => MD5 is legit
    C:\Windows\System32\drivers\nsiproxy.sys => MD5 is legit
    C:\Windows\System32\dhcpcore.dll => MD5 is legit
    C:\Windows\System32\drivers\afd.sys => MD5 is legit
    C:\Windows\System32\drivers\tdx.sys => MD5 is legit
    C:\Windows\System32\Drivers\tcpip.sys => MD5 is legit
    C:\Windows\System32\dnsrslvr.dll => MD5 is legit
    C:\Windows\System32\mpssvc.dll => MD5 is legit
    C:\Windows\System32\bfe.dll => MD5 is legit
    C:\Windows\System32\drivers\mpsdrv.sys => MD5 is legit
    C:\Windows\System32\SDRSVC.dll => MD5 is legit
    C:\Windows\System32\vssvc.exe => MD5 is legit
    C:\Windows\System32\wscsvc.dll => MD5 is legit
    C:\Windows\System32\wbem\WMIsvc.dll => MD5 is legit
    C:\Windows\System32\wuaueng.dll => MD5 is legit
    C:\Windows\System32\qmgr.dll => MD5 is legit
    C:\Windows\System32\es.dll => MD5 is legit
    C:\Windows\System32\cryptsvc.dll => MD5 is legit
    C:\Program Files\Windows Defender\MpSvc.dll => MD5 is legit
    C:\Windows\System32\ipnathlp.dll => MD5 is legit
    C:\Windows\System32\iphlpsvc.dll => MD5 is legit
    C:\Windows\System32\svchost.exe => MD5 is legit
    C:\Windows\System32\rpcss.dll => MD5 is legit
    **** End of log ****
  2. 2013/09/30
    OTL fix log?
    KingZK
    File\Folder C:\Users\Heidi\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\Intel(R) Turbo Boost Technology Monitor 2.0.lnk not found!
    PendingFileRenameOperations files...
    this is the only file working from the OTL scan I have tried in Safe mode and it never comes back from never responding mode.
  5. 2013/10/02
    [​IMG] Update Adobe Flash Player: http://get.adobe.com/flashplayer/
    Make sure you UN-check Yes, install McAfee Security Scan Plus
    NOTE 1: Beginning with Adobe Flash Version 11.3, the universal installer includes the 32-bit and 64-bit versions of the Flash Player.
    NOTE 2: While installing make sure you UN-check any extra garbage which wants to install alongside.
    [​IMG] Update Adobe Reader
    You can download it from http://www.adobe.com/products/acrobat/readstep2.html
    After installing the latest Adobe Reader, uninstall all previous versions (if present).
    Note. If you already have Adobe Photoshop® Album Starter Edition installed or do not wish to have it installed UNcheck the box which says Also Download Adobe Photoshop® Album Starter Edition.
    Alternatively, you can uninstall Adobe Reader and install one of two free alternatives:
    - Foxit PDF Reader from HERE.
    It's a much smaller file to download and uses a lot less resources than Adobe Reader.
    Note: When installing FoxitReader, make sure to UN-check any pre-checked toolbar, or any other garbage.
    - PDF-XChange Viewer: http://www.tracker-software.com/product/pdf-xchange-viewer
    [​IMG] 1. Update your Java version here: http://www.java.com/en/download/installed.jsp
    Note 2: If you're running 64-bit system make sure you install BOTH, 32-bit and 64-bit Java.
    Note 3: The Java Quick Starter (JQS.exe) adds a service to improve the initial startup time of Java applets and applications. If you don't want to run another extra service, go to Start > Control Panel > Java > Advanced > Miscellaneous and uncheck the box for Java Quick Starter. Click OK and restart your computer.
    2. Now, we need to remove old Java version and its remnants...
    Download JavaRa to your desktop and unzip it.
    • Run JavaRa.exe (Vista and 7 users! Right click on JavaRa.exe, click Run As Administrator), pick the language of your choice and click Select. Then click Remove Older Versions.
    • Accept any prompts.
    • Do NOT post JavaRa log.
    Your computer is clean [​IMG]
    1. We need to reset system restore to prevent your computer from being accidentally reinfected by using some old restore point(s). We'll create fresh, clean restore point, using following OTL script:
    Run OTL
    • Under the Custom Scans/Fixes box at the bottom, paste in the following:
    :OTL
    :Commands
    [purity]
    [emptytemp]
    [EMPTYFLASH]
    [emptyjava]
    [CLEARALLRESTOREPOINTS]
    [Reboot]
    • Post resulting log.
    2. Now, we'll remove all tools, we used during our cleaning process
    Clean up with OTL:
    • Double-click OTL.exe to start the program.
    • Close all other programs apart from OTL as this step will require a reboot
    • On the OTL main screen, press the CLEANUP button
    • Say Yes to the prompt and then allow the program to reboot your computer.
    3. Make sure Windows Updates are current.
    4. If any trojans, rootkits or bootkits were listed among your infection(s), make sure, you change all of your on-line important passwords (bank account(s), secured web sites, etc.) immediately!
    5. Check if your browser plugins are up to date.
    Firefox - https://www.mozilla.org/en-US/plugincheck/
    other browsers: https://browsercheck.qualys.com/ (click on "Launch a quick scan now" link)
    7. Run Malwarebytes "Quick scan" once in a while to assure safety of your computer.
    8. Run Temporary File Cleaner (TFC), AdwCleaner and Junkware Removal Tool (JRT) weekly.
    9. Download and install Secunia Personal Software Inspector (PSI): http://secunia.com/vulnerability_scanning/personal/. The Secunia PSI is a FREE security tool designed to detect vulnerable and out-dated programs and plug-ins which expose your PC to attacks. Run it weekly.
    10. (optional) If you want to keep all your programs up to date, download and install FileHippo Update Checker.
    11. (Windows XP only) Run defrag at your convenience.
    12. When installing\updating ANY program, make sure you always select "Custom " installation, so you can UN-check any possible "drive-by-install" (foistware), like toolbars etc., which may try to install along with the legitimate program. Do NOT click "Next" button without looking at any given page.
    13. Read:
    How did I get infected?, With steps so it does not happen again!: http://www.bleepingcomputer.com/forums/topic2520.html
    Simple and easy ways to keep your computer safe and secure on the Internet: http://www.bleepingcomputer.com/tutorials/keep-your-computer-safe-online/
    14. Please, let me know, how your computer is doing.
  6. 2013/10/06
    The issue seems to be resolved.
