A suggestion, not a problem
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by JGB, 2016/08/12.
  1. 2016/08/12
    JGB
    JGB Well-Known Member Thread Starter
    I continually switch between Firefox and Thunderbird, and it is becoming a bit tedious to pull up the Windows taskbar to make the switch every time. I keep the Windows taskbar hidden, and most times in Firefox I can't access it directly by dropping the cursor down to the screen bottom.
    So, how's about a Firefox menubar icon to go directly to Thunderbird, and likewise in Thunderbird, to go to Firefox. I suppose it could be done as an add-on.
    JGB,
  2. 2016/08/12
    Why not use a keyboard with buttons to enable the web or mail? My Genius keyboard has www/mail/explorer as 3 buttons on top right panel. It has a Media control set in the top middle and 11 further buttons to the left which I rarely use including a page scroll wheel. Neil.
    If you unhide the taskbar does the problem go away?
  5. 2016/08/13
    There are already Firefox add-ons/extensions that can launch Thunderbird.
  6. 2016/08/14
    JGB
    Retiredlearner.
    In actual fact my Logitech KB does have 2 buttons I had programmed to flip between FF and TB. I just forgot about them!!!
    However I noticed that the button to go to Tbird will flip, but the FF button opens a new window, defeating the purpose. I'll have to check that out....
    Steve
    Yes, once the taskbar is visible, I can switch easily.
    I looked for them, found nothing. Maybe you could tell me what their names are.
    JGB,
    #5
  7. 2016/08/14
    Yes, those buttons work well for me. I can open both FF and TB at the touch of a button - as the saying goes. :D
  8. 2016/08/16
