A More Virtuous Setting for Virtual Memory?
Discussion in 'Windows XP' started by dkline, 2006/10/07.
  1. 2006/11/04
    charlesvar
    charlesvar Inactive Alumni
    Hi Dave,
    About need, if you have one on C and running only one OS, no you don't need it.
    The OS would re create it if needed. Lots of cleaning/privacy tools delete pagefile.sys - the OS just re creates it.
    Regards - Charles
  2. 2006/11/04
    Christer
    Christer Geek Member Staff
    I anticipated that Windows would moan about it, even if it has abandoned the pagefile on that partition. If you try to delete a pagefile that is actually in use, you wouldn't be able to.
    Christer
    dkline
    dkline Inactive Thread Starter
    Yeah, Windows can get kinda surly at times, can't it.
  5. 2006/11/11
    MerleOne
    MerleOne Inactive
    Yes you can. If it is still used by the system, windows will not let you delete it.
    .merle1.
  6. 2006/11/11
    Bill Castner
    Bill Castner Inactive
    It can be deleted.
    Set the pagefile minimum and maximum to zero.
    Start, Run, cmd
    attrib -s -h drive_letter:\pagefile.sys
    del drive_letter:\pagefile.sys
    Reset your Virtual memory settings.
  7. 2006/11/11
    Mr. Fix It
    Mr. Fix It Inactive
    It's not a box of candy!
    [SIZE= "2"]... why all the partitions? It's not a box of candy. My vote is for no paging file and a system managed virtual memory. But really, why all the partitions? Buy some additional hard drives; they are dirt cheap - and you will better accomplish what, I think, you are trying to accomplish. Are you with me?[/SIZE] :D
  8. 2006/11/12
    The Paging File and Virtual Memory are one and the same - no pagefile equates to no virtual memory.
  9. 2006/11/13
    dkline
    Thanks everyone.
    I've got a paging file of 1536-3072 on the C partition, with no paging files on the D, E and F partitions. Seems to be working fine.
