4 gbyte limit
Discussion in 'Windows XP' started by screamer, 2004/04/23.
  1. 2004/04/28
    JSS3rd Lifetime Subscription
    JSS3rd Geek Member
    Hi Christer ...
    Like you, I used to be an avid Norton SystemWorks fan, but became disenchanted with the way the programs insinuated themselves into my computer's "fabric ". It turned out the only one I really was using was SpeedDisk, anyway, so I went from SystemWorks to Utilities. Because of the problems SpeedDisk caused with PartitionMagic I quit using it, too.
    I'm interested in your comments about SpeedDisk vs the XP defrag utility, as I was given to understand that the XP defragger was just a simplified version of SpeedDisk. In any event, I've had no further problems with PM since dumping SpeedDisk and using the XP defragger.
  2. 2004/04/28
    Christer
    Christer Geek Member Staff
    Not Speed Disk, it´s Diskeeper.
    According to The Windows XP defragger â€" is it good enough for the enterprise? Diskeeper is the first (only even today?) third party defragger to be approved of by MS.
    The article is a bit outdated but interesting anyway.
    Christer
    bluzkat
    bluzkat Inactive
    diskeeper vs. speed disk
    I also used to use Speed Disk (as well as SystemWorks). I started using Diskeeper about a year ago (ver 7). I've quit using all the Norton stuff except I still use Norton A/V. I have used Norton programs for as long as I've had a PC. Diskeeper seems to do a very good job, but I still prefer to run it manually. The current version is 8, I compared it to the WinXp version and it seems to run a little faster, it also offers many more options like running at boot and 'Set it and Forget it'. I guess if I run Win98 again I'll reinstall the Norton stuff, but it just doesn't seem to do much for WinXP.
    B :cool:
  5. 2004/05/20
    screamer
    screamer Well-Known Member Thread Starter
    Thought I would use this thread for my next question as it seems relevant.
    Since converting my slave drive to NTFS after your recommendations and being happy with it, can I now do the same on my main drive, and after doing so run my Ghost image to restore it, as that was of course created on FAT 32.
  6. 2004/05/20
    reboot
    reboot Inactive
    Interesting read this is :cool:
    If you're happy with your boot partition being FAT32, leave it.
    If you convert it to NTFS, and then decide to use your ghost image, it will be back to FAT32. Ghost doesn't care, it simply writes the stuff back, byte by byte, in the format it was created.
  7. 2004/05/20
    JSS3rd Geek Member
    Screamer ...
    Of course you can convert your main drive to NTFS, but what's the point of going back to FAT32, via your Ghost backup, after doing so? You could, instead, make a new backup of the drive after converting to NTFS.
  8. 2004/05/22
    screamer
    Thank you reboot & JSS3rd for your input, and you have convinced me to leave as is.
    It was just that comparing the NTFS with the FAT 32, the former seems much more efficient in keeping the files from framenting.
    I certainly do not want to reinstall the OS & all the apps, and as Ghost would just keep FAT 32, I will just have to live with all those horrid red lines on the defragmenter that show up every time I look at my C drive. :(
  9. 2004/05/22
    Screamer ....
    Why would you need to reinstall the OS and all the apps?
    All you need to do once you have converted your main drive to NTFS is to make another Ghost image - you then have two images to fall back on, one Fat 32, the other NTFS.
    In fact if you use Ghost you should make images regularly as your HD is changing all the time with Windows Updates, new apps, etc and hold onto a few for security.
  10. 2004/05/22
    JSS3rd Geek Member
    Screamer ...
    I don't understand why you're so hesitant to convert your main drive, with the OS and your installed programs, to NTFS. It sounds almost as though you think you'll have to format the drive as part of the process. That isn't so, and you won't have to reinstall a thing. Converting to NTFS doesn't do anything to the info on your drive except change the manner in which all those bits and bytes are handled by XP. In the unlikely event that you should run into a problem during the conversion, you always have your current Ghost image to fall back on.
    I should have been more emphatic in my last post ... you SHOULD make a new Ghost backup after converting to NTFS and, as Pete says, you should make backups frequently.
  11. 2004/05/22
    Rockster2U
    Rockster2U Geek Member
    OK, I'm convinced - going to give Diskeeper a test drive. (this from a big time Norton Fan) ;)
  12. 2004/05/22
    bluzkat
    bluzkat Inactive
    Rockster,
    Like I said before I've used Norton programs for years but since I've started using XP they are becoming an endangered species. I still use Norton AV, but its days are numbered. I've been using Diskeeper for about 18 months and really like it alot. I did go back and try Norton Speedisk again but returned to Diskeeper, this time without any doubts. The main difference you will notice is Diskeeper does not group all your programs together like Speedisk does, this is not a problem. Diskeeper arranges programs for optimum performance, not so they look nice and neat in the 'defrag window'. Give it a try... 30 day trial version available HERE
    B :cool:
  13. 2004/05/22
    Rockster2U
    Go Man Go :D :D you won't regret it.
    From an ex-Norton fan - many moons ago!
  14. 2004/05/22
    Rockster2U
    Done deal - Initial reaction very positive. Have spent the last couple of nights just doing some housekeeping/maintenance after changing sound cards and video cards in my main box. Have been trying to get my boot sequence finely tuned after some issues with leftovers from a Winfast PCI TV card - got all that squared away and logs were looking flawless, but wasn't happy with boot times. Got into it big time this morning and am very happy, now this Diskeeeper is like icing on the cake. Quite impressed - will put it through its paces as I learn more about it and how to optimize it. Thanks ......
  15. 2004/05/22
    screamer
    Sorry JSS3rd, am definitely in Super Numpty mode here as I presumed that a drive needed to be empty to convert it from FAT32 to NTFS :eek: This probably explains your confusion in me wanting to use my Ghost image after I had converted the drive.
  16. 2004/05/22
    screamer
    Hi PeteC, my last post probably answers your question. :) It's a pity you do not live closer BTW, because as you will gather, I could use a guru on my doorstep. :)
