Resolved SmadAv 2015 v10
Discussion in 'Security and Privacy' started by FuzMic, 2015/02/11.
  1. 2015/02/11
    FuzMic
    FuzMic Well-Known Member Thread Starter
    Hi guys
    Appreciate views on SmadAv.
    SmadAv seems to pick up quite a bit of registry problems and virus that escape Avast. Once detected and removal, it will not show up again.
    The exe file is small unlike Avast or AVG. Installation is fast as it is tiny 1.2M. Can this be a true virus protection program; it seems too small & fast to be true.
    The free version can be downloaded at download.com.
  2. 2015/03/05
    Malnutrition
    Malnutrition Active Member
    Never heard of it.
    Here are some, you may be interested in, if you are looking for something very light on your system, with very good detection.
    http://www.mysecuritywin.com/xvirus-personal-guard.html
    http://www.crystalsecurity.eu/
    https://secureaplus.secureage.com/Main/index.php
    http://www.360totalsecurity.com/en/
    http://www.pcmgr-global.com/
    The first two can be ran alongside of your current antivirus for an added layer of protection, just note that those are in beta stages now so if you scan with them make sure and check their findings at Virus Total before removing anything. :)
    https://www.virustotal.com/
    lj50 Lifetime Subscription
    If you are going to use any application that has the potential of changing the registry BACKUP YOU REGISTRY FIRST.
    lj50,
    Malnutrition
    Indeed this is true, but for your security applications? I suppose that is good practice but perhaps a little stringent for an antivirus, since most people run scans often with their antivirus, that is a lot of backing up the registry. :D
  6. 2015/03/06
    I'm only suggesting backups for apps that clean the reg. Another good practice before installing apps is to create a restore point.
    lj50,
    #5
  7. 2015/03/06
    Malnutrition
    Indeed. :)
  8. 2015/03/07
    FuzMic
    Thanks guys, will check out the light AV
  9. 2015/03/07
    Never heard of any of these "light AV" !
    Malnutrition, are you using anything from this list ?
  10. 2015/03/07
    Malnutrition
    I certainly am, I am using SecurAplus, and it works great, only 1% Cpu and pretty good detection rate. I am happy with it. :)
  11. 2015/03/07
    FuzMic
    Noted your kind sharing from your malnrition vault
    Malnutrition likes this.
  12. 2015/03/07
    Malnutrition
    Here also are two programs that can remove Gigs of junk from your computer. :)
    System Ninja
    Wipe by Privacy Root
    Also a nice AV companion that I use on my other machine, can be used mainly as an on demand scanner, it picks up junk that other software can miss. :)
    VirIt eXplorer Lite.
  13. 2015/03/07
    I would be vary of all these av, as they are not very well known and in the security world if its unknown, stay clear of it.
  14. 2015/03/07
    Malnutrition
    I would not post anything harmful. :) They are 100% safe.
  15. 2015/03/10
    FuzMic
    Peace with you guys.
