roaming profiles
Discussion in 'Legacy Windows' started by MOROZCO, 2004/01/11.
  1. 2004/01/11
    MOROZCO
    MOROZCO Inactive Thread Starter
    Does anyone know if you can move outlook profiles into the roaming profile so it will follow the user to each pc they log into
  2. 2004/01/11
    Logik007
    Logik007 Inactive
    It should be in the roaming profile already.
    MOROZCO
    Thanks all
    Greetings,
    The roaming profile is not set up by default, what can do though is download a tool from www.slipstick.com that creates imports your profile to you my documents where apon opening outlook when looged in even the first run it imports the filej, this will save time for us at setup and over time when we reformat pcs.
