Problem with window firewall.
Discussion in 'Windows XP' started by Mandingos, 2006/11/23.
  1. 2006/11/23
    Mandingos
    Mandingos Inactive Thread Starter
    Alright, the other day I was going to connect my computer to my xbox 360 and I had to open up some ports on windows firewall to allow it. When I tried to open the firewall settings I first got the message, "Due to an unidentified error, Firewall settings cannot be changed" or something similar. So I did a search on google and found a few methods to fix this. I tried everyone I found and none worked. Now I get the message "Windows Firewall settings cannot be displayed because the associated service is not running ". When I click yes to start the service I get the message "Windows cannot start the Windows Firewall/Internet Connection Sharing (ICS) service." I looked on the internet once again and still nothing worked. I even tried removing and installing SP2 again, but that didn't work either.
    I recently had the trojan.small.fb, and I think I removed it successfully, but it must have done some damage to a few files. I also had the agent.uj spyware right before that, again I think I removed it successfully. I should also note that my network connections folder shows no connections as well. Also, when I try to run fixwareout, I get a log saying that I am missing Windows/system32/autoexec.nt. When I run hijackthis, I get a message near the end of the scan saying "An unexpected error has occurred at procedure: modMain_CheckOther14Item() Error #62 Input past end of file ". However, the scan still completes and outputs a log file.
    Whew, I think that's all the details on the problem. Sorry, I know its a doozy, but I've tried everything and I'm getting quite frustrated. Help would be absolutely appreciated.
  2. 2006/11/23
    I'd wager that your system is still infected. The HjT error message is an error as a result of installing or starting an msdos or 16bit windows based program. There are viruses that specificallt target hijackThis, other antispyware apps and antivirus apps in an effort to render them unusable.
    Bill Castner
    Bill Castner Inactive
    Firewall issues:
    Download the SharedAccess.reg file and double click to merge it with your registgry: http://windowsxp.mvps.org/sharedaccess.htm
    Then Start, Run, and Enter each of these lines. (You can copy/paste them from here:
    regsvr32 %windir%\system32\atl.dll
    regsvr32 %windir%\system32\hnetcfg.dll
    regsvr32 %windir%\system32\netshell.dll
    regsvr32 %windir%\system32\netcfgx.dll
    regsvr32 %windir%\system32\netman.dll
    Reboot.
    Restore Autoexec.nt:
    Browse to "%windir%/repair/" (usually "C:\WINDOWS\repair ")
    Right-Click and Copy the AUTOEXEC.NT file
    Browse to "%windir%/system32/" (usually "C:\WINDOWS\System32 ")
    Right-Click inside the window and Paste the file
    Question: What made you think you had Wareout?
    HijackThis error
    The message occurs when it is issues reading the older *.ini files. It is harmless, but should not occur with the current version of HJT: http://www.spywareinfo.com/~merijn/downloads.html
    Make sure HJT this is run from its own folder, and not from the desktop or the user My Documents folder.
  5. 2006/11/24
    Mandingos
    Ok, I followed the steps you gave Bill. I still have no luck opening the firewall settings, and my network connections still aren't showing up. Replacing the autoexec.nt worked fine though. I had fixwareout from a previous infection, and I figured I should just note that my autoexec.nt was missing.
    Here is my HJT log:
    Logfile of HijackThis v1.99.1
    Scan saved at 2:32:22 PM, on 11/24/2006
    MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
    C:\WINDOWS\system32\csrss.exe
    C:\Program Files\Grisoft\AVG Anti-Spyware 7.5\guard.exe
    C:\Program Files\Ahead\InCD\InCD.exe
    C:\Program Files\D-Tools\daemon.exe
    C:\Program Files\Creative\SBAudigy2\Surround Mixer\CTSysVol.exe
    C:\Program Files\Creative\SBAudigy2\DVDAudio\CTDVDDet.EXE
    C:\WINDOWS\System32\CTsvcCDA.exe
    C:\Program Files\AlienAutopsy\Test_BS.exe
    C:\Program Files\Ahead\InCD\InCDsrv.exe
    C:\Program Files\ICQLite\ICQLite.exe
    C:\Program Files\Microsoft AntiSpyware\gcasDtServ.exe
    C:\WINDOWS\CTHELPER.EXE
    C:\Program Files\Creative\MediaSource\RemoteControl\RcMan.exe
    C:\Program Files\Mozilla Firefox\firefox.exe
    C:\hijackthis\HijackThis.exe
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://www.alienware.com
    O1 - Hosts: localhost 127.0.0.1
    O3 - Toolbar: (no name) - {12EE7A5E-0674-42f9-A76B-000000004D00} - (no file)
    O4 - HKLM\..\Run: [SBDrvDet] C:\Program Files\Creative\SB Drive Det\SBDrvDet.exe /r
    O4 - HKLM\..\Run: [nwiz] nwiz.exe /install
    O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
    O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
    O4 - HKLM\..\Run: [NeroCheck] C:\WINDOWS\system32\NeroCheck.exe
    O4 - HKLM\..\Run: [InCD] C:\Program Files\Ahead\InCD\InCD.exe
    O4 - HKLM\..\Run: [gcasServ] "C:\Program Files\Microsoft AntiSpyware\gcasServ.exe "
    O4 - HKLM\..\Run: [DAEMON Tools-1033] "C:\Program Files\D-Tools\daemon.exe" -lang 1033
    O4 - HKLM\..\Run: [CTSysVol] C:\Program Files\Creative\SBAudigy2\Surround Mixer\CTSysVol.exe
    O4 - HKLM\..\Run: [CTDVDDet] C:\Program Files\Creative\SBAudigy2\DVDAudio\CTDVDDet.EXE
    O4 - HKLM\..\Run: [AlienAutopsy] "C:\Program Files\AlienAutopsy\Test_BS.exe" -h
    O4 - HKLM\..\Run: [ICQ Lite] "C:\Program Files\ICQLite\ICQLite.exe" -minimize
    O4 - HKLM\..\Run: [CTHelper] CTHELPER.EXE
    O4 - HKLM\..\Run: [Zune Launcher] "C:\Program Files\Zune\ZuneLauncher.exe "
    O4 - HKLM\..\Run: [dmkts.exe] C:\WINDOWS\system32\dmkts.exe
    O4 - HKCU\..\Run: [RemoteCenter] C:\Program Files\Creative\MediaSource\RemoteControl\RcMan.exe
    O4 - HKCU\..\Run: [Weather] C:\Program Files\AWS\WeatherBug\Weather.exe 1
    O4 - HKCU\..\Run: [RealPlayer] "C:\Program Files\Real\RealPlayer\realplay.exe" /RunUPGToolCommandReBoot
    O4 - Global Startup: Adobe Gamma Loader.lnk = C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe
    O9 - Extra button: ICQ Pro - {6224f700-cba3-4071-b251-47cb894244cd} - C:\Program Files\ICQ\ICQ.exe (file missing)
    O9 - Extra 'Tools' menuitem: ICQ - {6224f700-cba3-4071-b251-47cb894244cd} - C:\Program Files\ICQ\ICQ.exe (file missing)
    O9 - Extra button: WeatherBug - {AF6CABAB-61F9-4f12-A198-B7D41EF1CB52} - C:\Program Files\AWS\WeatherBug\Weather.exe (file missing) (HKCU)
    O16 - DPF: {CAFEEFAC-0014-0000-0000-ABCDEFFEDCBA} (Java Plug-in 1.4.0) -
    O18 - Protocol: ms-help - {314111C7-A502-11D2-BBCA-00C04F8EC294} - C:\Program Files\Common Files\Microsoft Shared\Help\hxds.dll
    O21 - SSODL: WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - C:\WINDOWS\system32\WPDShServiceObj.dll
    O23 - Service: AVG Anti-Spyware Guard - Anti-Malware Development a.s. - C:\Program Files\Grisoft\AVG Anti-Spyware 7.5\guard.exe
    O23 - Service: Creative Service for CDROM Access - Creative Technology Ltd - C:\WINDOWS\System32\CTsvcCDA.exe
    O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
    O23 - Service: InCD File System Service (InCDsrv) - Unknown owner - C:\Program Files\Ahead\InCD\InCDsrv.exe
    O23 - Service: iPodService - Apple Computer, Inc. - C:\Program Files\iPod\bin\iPodService.exe
    O23 - Service: ISSvc (ISSVC) - Unknown owner - C:\Program Files\Norton Internet Security\ISSVC.exe (file missing)
  6. 2006/11/24
    Use HjT to Fix:
    leftover spyware toolbar
    this is Trojan.Pakes:
    optional:
    some versions of WeatherBug have spyware.
    First, download, install & update Adaware:
    http://www.download.com/3000-2144-10045910.html
    Adaware should clean up the trojan, but before scanning or using HjT, boot the comp in Safe Mode (press F8 key at restart). Once booted, delete all file and folders in:
    c:/documents & settings/user_name/local settings/temp
    c:/documents & settings/user_name/local settings/temporary internet files
    c:/windows/temp
    Turn off System Restore:
    http://support.microsoft.com/kb/310405
    Run HjT and remove the above items.
    Scan w/ Adaware.
    Scan w/ av pgm.
    Reboot & rescan with HjT. Post new log here.
    If all OK for a day or two, turn System Restore back on.
  7. 2006/12/06
    Mandingos
    Ok, I followed all the steps and AVG detected trojan.small and trojan.small.fb, and successfully quarantined them. After doing all this, I retried the steps given in the 2nd reply for fixing my firewall problem. I still have no luck in opening my firewall settings. My HJT log looked alright, here it is:
    Scan saved at 2:07:00 AM, on 12/6/2006
    O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~4\OFFICE11\REFIEBAR.DLL
    I realize I waited awhile to do all this, but I went out of town for a week and a half and then forgot all about it. Do you have any other suggestions on what I should try?
  8. 2006/12/06
    Which firewall are you trying to configure? You have 2 firewalls, one that comes w/ windows and one from Norton. Be sure to enable one or the other, never both at same time. To use Nortons you have to completely disable windows firewall in Control Panel/Windows Firewall as well as Admin Tools/ Services/Windows Firewall.
  9. 2006/12/06
    Rockster2U
    Rockster2U Geek Member
    I pose this as a question - shouldn't the 09 entries for ICQ and Weatherbug also be removed along with their respective folders. And, I believe you are going to need to run a registry search using something like RegSeeker or JV16 PowerTools to find and remove the leftover Symantec and Norton entries which can be quite problematic.
    Mandingos - wait for confirmation from Tony or Bill.
  10. 2006/12/06
    Mandingos
    I am trying to configure the windows firewall, just so I can open up some ports or perhaps turn it off completely. However, I cannot even open up the settings of the firewall, my first post details what is says when I try. I no longer use the norton firewall, because it was corrupted awhile back. As you noticed rockster, there are still leftover files from norton because I wasn't able to uninstall it normally because of the corruption. I should also point out that my network connections folder is showing up as empty, and I know there should be at least 2 connections displayed in there. Do you think this could be a trojan causing this, or maybe the leftover Norton files?
  11. 2006/12/06
    Unlikely that Norton caused missing network items.
    However, I would reinstall Norton newly, configure the Norton firewall to allow everything or remove any existing items in it, and then uninstall it. When Norton got installed. it "took over" for windows firewall. Because it was not cleanly uninstalled, it actually may be still running or in effect, and is preventing windows firewall from functioning.
  12. 2006/12/06
    Mandingos
    Is there any other possible way to get rid of the files? I used a friend's disc to install norton, and I don't think I would be able to get a hold of it.
  13. 2006/12/07
  14. 2006/12/07
    Rockster2U
    Hehehe .......... and you said you already borked the removal? Me thinks its going to take a bit of manual work but I'll await your comments and absent a CD (oh, to "borrow " software) to install and then uninstall as Tony suggested, he's given you the next best thing with that tool.
  15. 2006/12/07
    Mandingos
    I think that got rid of all the files successfully. I don't see any leftovers. However, I'm still not able to access the windows firewall settings. Also, now when I try to open my network connections, I get a message telling me to start the Networking service. Sorry, I know this is a hassle for you guys, I just have no idea on what to do about it anymore. Oh yea, heres my HJT log just in case:
    Scan saved at 11:26:36 PM, on 12/7/2006
  16. 2006/12/08
    Control Panel > Administrative Tools > Services
    DHCP
    Network Location Awareness service
    Probably some Norton + Symantec stuff there too, disable them.
  17. 2006/12/08
    Rockster2U
    First, create a new restore point
    Then look for the following:
    C:\Program Files\Symantec
    C:\Program Files\Common\Symantec
    C:\Documents and Settings\UserName\Application Data\Symantec
    C:\Documents and Settings\EachOtherUserName\Application Data\Symantec
    C:\Documents and Settings\AllUsers\Application Data\Symantec
    Delete them all
    Download, Install and Run the newest version of RegSeeker
    Clean the registry using this tool (make sure backup before deletion is checked)
    Using RegSeeker, do a search for Symantec - delete them all
    Using RegSeeker, do a search for Norton - delete them all
    Reboot
    Now, you have most of Norton cleaned up and perhaps Tony or Bill can help you from here.
