Resolved msfeedssync.exe application error
Discussion in 'Internet Explorer & Microsoft Edge' started by Spanner, 2009/09/26.
  1. 2009/09/26
    Spanner
    Spanner Inactive Thread Starter
    I keep getting a window with 'msfeedssync.exe application error' followed by "the instruction at ox77d4bbcd" referenced memmory at "0x00000048" the memory could not be read, click ok to terminate or cancel to debug. then a window to send or not to send a report,
    What is happening please.Spanner.
  2. 2009/09/26
    Spanner
    Contents tab reveals Contents Adviser with 'Enable' highlighted, Settings is not highlighted and does not respond, therefore Iam unable to get to'Feeds' to uncheck automaticaly update.
    Spanner
  5. 2009/09/26
    You are in the wrong place in the window - see attached image ....
      File size:
      84.2 KB
      133
  6. 2009/09/26
    Spanner
    The 'Internet Options' Icon on the PC that has the fault is a Globe with a single tick, it does not have the Globe with 3 Ticks.This PC that I am using to communicate with you does not have the msfeedssync.exe problem and has an Icon for Internet Options with 3 ticks on a pad and does open a window as per the image. Spanner
  7. 2009/09/26
    That screenshot was from IE 8 on Windows 7 - I shall have to fire up my netbook -- the only computer remaining with XP loaded to see what you refer to.
    In the meantime which version of IE on the recalcitrant computer? I only have IE 8.
  8. 2009/09/26
    Spanner
    The 'recalcitrant' ( I have other words ) computer has IE5 I believe, 'system information' will not show on screen.( The computer was a young man's first S/H Pc and had some strange hardware, and a lot of lights, part home made. Not sure how far I will go with this, may decide to convert it into a light show with music.
    Spanner
  9. 2009/09/26
    :cool:
    If it's in fact running IE 5 then RSS feeds were not around then - to check Help > About in IE.
    I would suspect a later version given that you see the message re. msfeedssynch.exe.
    Another approch wouls be to go into Scheduled Tasks, show hidden Tasks and delete the schedule, if it exists.
    BTW - which OS is it running?
