Windows Vista Event Viewer Problems
Discussion in 'Legacy Windows' started by Evan Omo, 2007/04/15.
  1. 2007/04/15
    Evan Omo Computer Support Technician Staff Thread Starter
    Hi everyone,
    I am running Windows Vista Ultimate 32-bit edition. My problem that I have been having is with event viewer. When I open it I get the familiar prompt from UAC telling me whether to continue or cancel. I hit continue and event viewer opens fine but it doesn't display any events or logs. I then get an error message that says MMC (Microsoft Management Console) has detected an error in a snap-in and will unload it. Then my options are to report this error to microsoft and shutdown MMC or to unload the snap-in and continue running event viewer. :mad: If I report the error to microsoft it just closes event viewer. If I choose to unload the snap-in then the error message window closes and I get another error message that says:
    Snap-in unavailable. This snap-in has performed a non-valid operation and has been unloaded. To continue worknig with this snap-in restart MMC or try loading this snap-in again.
    FX:{b05566ad-fe9c-4363-be05-7a4cbb7cb510}
    Exception message: Item has already been added. Key in dictionary: '' Key being added: ''
    Exception type: System.ArgumentException
    Exception stack trace: at System.Collections.Hashtable.Insert(Object key, Object nvalue, Boolean add)
    at System.Collections.Hashtable.Add(Object key, Object value)
    at Microsoft.Windows.ManagementUI.CombinedControls.EventPublishers.GetPublishers()
    at Microsoft.Windows.ManagementUI.CombinedControls.EventPublishers.GetPublisher(String publisherIdentifier)
    at Microsoft.Windows.ManagementUI.CombinedControls.ViewerContext.GetPublisher(String publisherId)
    at Microsoft.Windows.ManagementUI.CombinedControls.ChannelConfig.GetLocalizedNameFromChannel()
    at Microsoft.Windows.ManagementUI.CombinedControls.ConfigFolder.Initialize()
    at Microsoft.Windows.ManagementUI.CombinedControls.EventsNode.CreateChildNodes()
    at Microsoft.Windows.ManagementUI.CombinedControls.EventsNode.InsertChildren()
    at Microsoft.EventViewer.SnapIn.MMCEventsNode.ExpandNode()
    at Microsoft.EventViewer.SnapIn.MMCRootNode.ExpandNode()
    at Microsoft.EventViewer.SnapIn.MMCRootNode.OnExpand(AsyncStatus status)
    at Microsoft.ManagementConsole.NodeSyncManager.ProcessRequest(NodeRequestInfo info, IRequestStatus requestStatus)
    at Microsoft.ManagementConsole.NamespaceSnapInBase.ProcessRequest(Request request)
    at Microsoft.ManagementConsole.SnapIn.ProcessRequest(Request request)
    at Microsoft.ManagementConsole.Internal.SnapInClient.Microsoft.ManagementConsole.Internal.IMessageClient.ProcessRequest(Request request)
    at Microsoft.ManagementConsole.Internal.IMessageClient.ProcessRequest(Request request)
    at Microsoft.ManagementConsole.Executive.RequestStatus.BeginRequest(IMessageClient messageClient, RequestInfo requestInfo)
    at Microsoft.ManagementConsole.Executive.SnapInRequestOperation.ProcessRequest()
    at Microsoft.ManagementConsole.Executive.Operation.OnThreadTransfer(SimpleOperationCallback callback)
    I have already ran sfc /scannow and I ran chkdsk which didn't make any difference. I booted from the windows CD and went to command prompt to see if I could run chkdsk /r but I got an error message that said windows can't check the disk because the drive is write protected. :( I am trying to avoid doing a repair install to fix this issue so is there anyway I can fix problem without doing a repair install? :confused: Any help would be appreciated. :)
  2. 2007/04/15
    As an update I tried Last Known Good Configuration and Safe Mode. I still got the same error message with event viewer while in safe mode. I am all out of ideas. Please help. :(
    I googled my problem that I have been having and I got alot of hits. A lot of people are having this same problem but there are no solutions. :mad: On my computer I have opened all of the other administrative tools without any problems and they work fine. :) It seems that I am getting this error only in event viewer. So can somone please tell me how I can get event viewer to run again. :confused: :(
  5. 2007/04/18
    Anyone?
  6. 2007/04/23
    usasma
    usasma Inactive
    Just a shot in the dark, but since the other tools work fine, I'd suggest trying to find a copy of eventvwr.msc and replace your current one with it.
  7. 2007/04/23
    Thanks for you reply usasma. I just wanted to let you know that I got my issue resolved by doing a repair install with the Windows Vista DVD. I made another thread where this topic was continued because no one replied to this thread. http://windowsbbs.com/showthread.php?t=64013 That link is where this topic continued. :)
