Cursor Problems
Discussion in 'Windows XP' started by tr2k7, 2007/01/02.
  1. 2007/01/02
    tr2k7
    tr2k7 Inactive Thread Starter
    i got a new computer and when i am moving the mouse, it jumps to the bottom left of the screen or the top right of the screen. what could be causing this? thanks
  2. 2007/01/02
    Bill Castner
    Bill Castner Inactive
    One odd suggestion:
    Turn off the language bar and the built-in microphone.
    I recently went to a local school to resolve this exact issue for 2,000+ brand new laptops from Dell.
    Second suggestion:
    If a laptop with a touch pad, reduce its sensitivity, including for acting as a double-click if pressed. If you are not used to typing on the things your palms could be resting on the touch pad.
    You did have an active firewall and actively scanning antivirus program installed before you ever connected to the internet, right?
    tr2k7
    it is a destop with a plain corded laser mouse. i already turned off the language bar and it doesnt have a built in mic
    and yes i have a firewall and an antivirus program
  5. 2007/01/02
    Bill Castner
    You have an intermittent contact at the mouse connection; and/or, you have a bad cord for the mouse.
    If you are stretching the cord on the the mouse, and this is particularly true for PS/2 mice, you have created or exposed an intermittent PS/2 connector. Only two, small, solder points hold that PS/2 connector on the motherboard.
    Any tension from the cord of the mouse can break or make intermittent the soldered connections.
    Fourth possibility.
    You are using a PS/2 adapter to USB for the mouse.
    Do not do this. It will never reliably work.
    Connect the USB mouse to a USB port.
    Throw the unreliable adapter away.
    Then Start, Run, devmgmt.msc
    Expand the Mouse and other Pointing devices subsection.
    Right click on the mouse, and choose Uninstall.
    Reboot.
    Let the New Hardware Wizard at boot figure out your changes.
  6. 2007/01/02
    Bill Castner
    I should add a fifth possibility:
    Since it is a laser mouse, be sure you use a laser mouse designed mouse pad. The worst case is running it on the plain desktop. There are simply too many reflections from varnished wood, veneer, or even worse, no reflections at all from glass.
    Use a laser designed mousepad.
  7. 2007/01/02
    bluzkat
    bluzkat Inactive
    tr2k7,
    Also check to make sure there is nothing interfering with the laser. The smallest piece of lint or hair can cause erratic behavior such as this.
    B :cool:
  8. 2007/01/03
    tr2k7
    maybe its the desk then. i havent had a chance to pick up a mouse pad for it yet. i will try that and see. thanks
