Resolved command line to delete folder contents
Discussion in 'Windows 7' started by Sebastian42, 2012/08/05.
  1. 2012/08/05
    Sebastian42
    Sebastian42 Well-Known Member Thread Starter
    What line in a batch file would delete the contents of
    C:\Users\MyName\AppData\Local\Microsoft\Windows\Temporary Internet Files\ ?
    del /F /S /Q /A "C:\Users\MyName\AppData\Local\Microsoft\Windows\Temporary Internet Files\*.*" fails
    so does
    del "C:\Users\MyName\AppData\Local\Microsoft\Windows\Temporary Internet Files\*.*" /q
  2. 2012/08/05
    Instead use rd /S "%LOCALAPPDATA%\Microsoft\Windows\Temporary Internet Files "
    You can add the /Q switch for quiet mode.
    Sebastian42
    NO improvement
  5. 2012/08/05
    SpywareDr
  6. 2012/08/15
    Sebastian42
    To solve a problem in Window Live Mail, I was advised to empty the Temporary Internet Files folder. I found that it is an easy matter to select all its contents and dispose of them by pressing the delete key. It seems sensible maintenance, so I tried to automate the process by writing a batch file. However the code I used will not work for THAT folder (TIF)- it will empty other folders. I would like code for a batch file (command line) that automates what I CAN do manually. I have established that the 'delete Temporary Internet Files' setting of CCleaner ALSO fails to do what I can achieve manually; and the 'delete' button of Internet Options likewise fails.
  7. 2012/08/15
    Sebastian42
    SpywareDR - your suggestion looked like it had possibilities, so even though I understand very little of it, I ran the following code :
    @echo off
    SET SRC1=C:\Documents and Settings
    SET SRC2=Local Settings\Temporary Internet Files\Content.IE5
    SET SRC3=Local Settings\History
    SET SRC4=Local Settings\Temp
    SET SRC5=Cookies
    echo cleaning temporary internet files
    FOR /D %%X IN ( "%SRC1%\* ") DO FOR /D %%Y IN ( "%%X\%SRC2%\*.* ") DO RMDIR /S /Q "%%Y "
    echo cleaning history
    FOR /D %%X IN ( "%SRC1%\* ") DO FOR /D %%Y IN ( "%%X\%SRC3%\*.* ") DO RMDIR /S /Q "%%Y "
    echo cleaning windows temp files
    FOR /D %%X IN ( "%SRC1%\* ") DO FOR /D %%Y IN ( "%%X\%SRC4%\*.* ") DO RMDIR /S /Q "%%Y "
    FOR /D %%X IN ( "%SRC1%\* ") DO FOR %%Y IN ( "%%X\%SRC3%\*.* ") DO DEL /F /S /Q "%%Y "
    FOR /D %%X IN ( "%SRC1%\* ") DO FOR %%Y IN ( "%%X\%SRC4%\*.* ") DO DEL /F /S /Q "%%Y "
    echo cleaning Cookies
    FOR /D %%X IN ( "%SRC1%\* ") DO FOR %%Y IN ( "%%X\%SRC5%\*.* ") DO DEL /F /S /Q "%%Y "
    del /f /s /q "%windir%\temp "
    FOR /D %%X IN ( "%windir%\temp\* ") DO RMDIR /S /Q "%%X "
    It made NO difference to the contents of TIF while I watched them but I know that code is meant to operate 'on logoff'.
    "Document and Settings" suggests to me that it is for WinXP, since I have not been able to find a 'documents and settings' in Win7.
  8. 2012/08/15
    DEL C:\Folder1\Folder2\*.*
    will delete anything and everything underneath Folder2.
  9. 2012/08/15
    You cannot remove the temporary internet files dir (RD) while explorer is running. Same with cookies, history and any other dir that has an index.dat file in it. You'll need to use taskkill explorer.exe prior to removing those dirs.
    This should work:
    @echo off
    taskkill /f /im explorer.exe
    rd /S/q  "%LOCALAPPDATA%\Microsoft\Windows\Temporary Internet Files "
    start explorer.exe
    Also, if have Google Chrome installed, and it's updating itself, then deleting the temp internet files will fail.
  10. 2012/08/15
    Sebastian42
    As I stated, my code works for other folders, but NOT for Temporary Internet Files folder.
  11. 2012/08/15
    Sebastian42
    I have Chrome installed, but rarely use it. Presumably it wont update unless it is launched.
    I have not tried to remove the TIF folder, but to empty it of contents - I CAN do that 'manually', actually USING Windows Explorer.
    Because that TIF folder is needed, I added the line :
    "md "%LOCALAPPDATA%\Microsoft\Windows\Temporary Internet Files "
    and then watched the contents of TIF as I double-clicked that bat file on the desktop. NO improvement.
    More to the point, the bat file hangs WITHOUT CONTENT in a 'DOS' Window.
    I noticed the term '%LOCALAPPDATA%' and do not really understand it, but the path to the TIF folder contains '\AppData\Local\'. Is THAT discrepancy like to cause the problem ?
  12. 2012/08/16
    The command posted by Tony works fine. When you run it from within Windows, you'll have to run it with Admin. privileges.
    Copy the .bat file to C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup and it will be run when Windows starts.
    The Temporary Internet Files folder gets re-created once you start IE.
  13. 2012/08/16
    No need to use MD because the TIF dir will get recreated automatically next time IE is run.
    %ABCDEFG% = environment variables:
    http://technet.microsoft.com/en-us/library/dd560744(v=ws.10).aspx
    Try using:
    rd /S/q "%CSIDL_INTERNET_CACHE% "
    or the full path:
    rd /S/q " C:\Users\username\AppData\Local\Microsoft\Windows\Temporary Internet Files "
    oops, thanks Arie, I forgot that.
  14. 2012/08/16
    Sebastian42
    "No need to use MD because the TIF dir will get recreated automatically next time IE is run. "
    Since I rarely use I.E. but TIF is obviously replenished at each booting (?) [and therefore, I infer, NEEDED], I want re-assurance that it comes right without having to launch I.E.
  15. 2012/08/16
    Sebastian42
    "you'll have to run it with Admin. privileges "
    How would I do that for a batch file ?
  16. 2012/08/16
    Sebastian42
    Sebastian42
    "Copy the .bat file to C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup and it will be run when Windows starts. "
    I KNOW here to put a batch file so that it will run at Windows Launch.
    I did not necessarily want my batch to run at Windows launch. I simply wanted a batch that would work when I run it.
  18. 2012/08/16
    Right-click run as administrator
  19. 2012/08/16
    Sebastian42
    rd /S/q "C:\Users\username\AppData\Local\Microsoft\Windows\Temporary Internet Files "
    Running that code in a batchfile did NOT affect the content of the TIF folder. So I ran it again. Only once did a 'DOS' window show with lots of 'file can't be found' - but not long enough for me to see which files failed. Subsequent runnings simply show a 'DOS' window for an instant. Most importantly - NO improvement for emptying TIF (or deleting it).
  20. 2012/08/16
    Sebastian42
    Clicking 'run as administrator' in the content menu of the batch file, left TIF and its contents as I found them.
  21. 2012/08/16
    Well, it does work perfectly fine for me.
    So.... what folder (full path) are you looking at?
