Resolved CD/DVD label maker software
Discussion in 'Other PC Software' started by John32073, 2015/03/03.
  1. 2015/03/03
    John32073
    John32073 Well-Known Member Thread Starter
    Does anyone know of some CD/DVD label making software the I can use the CD stomper Labels with ? I have quite a bit of these label left over from some time ago. I tried the Acoustcia software but can't change the paper format
    John
  2. 2015/03/03
    John32073
    I tryed that one already can't change paper format
  5. 2015/03/03
    John32073
    anyone using a program with a cd stomper paper let me know what program you useplease.
    stomper paper i use has 2 cd printable layouts kinda like upper is 11 o'clock bottom is like 5 oclock (not stright up 12 and 6 alined on top of each other
  6. 2015/03/03
    Hi John32073, I have a Stomper Pro Pack v3.x. This kit I used extensively after I purchased it in 2004. It has a CD with all the software/drivers/Templates/Clip Art on it.
    My problem is that it worked OK using XP OS and was designed to operate on Windows 95/98/NT4.0 and MAC so it's a little out of date for W8.1.
    Here's a link to the support at Stomper:http://www.surething.com/support
    They're up to version 6 now but you may get some help if you ask. Neil.
  7. 2015/03/07
    John32073
    I found Sure Thing CD Labeling software it works very well and has a free trail offer It takes my labels sheets. I also found Audiolabel software and I downloaded it anone with the template for Pro CD Label2-up( that's the template for my labels sheets) It also came with a trial period
    I up and printing now, Thanks for the input folks
    John
  8. 2015/03/08
    Nice to see you're all sorted.;) Neil.
