Can I continue using WinZip after 45 days
Discussion in 'Other PC Software' started by dwdw, 2009/01/08.
  1. 2009/01/08
    dwdw
    dwdw Inactive Thread Starter
    I installed the trial version of WinZip 12 on Windows XP. After 45 days, it prompted me to buy. As a student, I didn't have that budget. Is there any way for me to continue using WinZip without purchasing?
    Thanks for your advice!
    dwdw,
  2. 2009/01/08
    wildfire
    wildfire Getting Old
    Short answer yes, Buy it.
    If you wish to consider other options have a look at 7-zip
    XP has the "send to compressed folder" function that is free and works like a charm;)
  5. 2009/01/09
    jsaia
    jsaia Inactive
    or an older version of winrar
  6. 2009/01/09
    goddez1
    goddez1 Inactive
    Speaking of an older version, although Winrar is very good, an older version of winzip will also continue to run. I use both Winrar and winzip version 8. Anything older than version 9 should continue to run with a nag.
  7. 2009/01/09
    Hi dwdw, I'm probably late with my suggestion but I use :www.camunzip.com which is free and no reminders about purchase. Neil.:D
  8. 2009/01/09
    Pssst... it's still against the EULA to keep using the program for free after 30 days!
  9. 2009/01/09
    dwdw
    Thanks for the suggestions. Appreciate that. Now the problem is: Winzip goes further than nagging, it does not even allow you to use it after 45 days, which is annoying. :(
    dwdw,
    #8
  10. 2009/01/09
    It's quite right! You want to use it? Pay for it. If you can't afford it, there are enough free alternatives.
  11. 2009/01/10
    goddez1
    goddez1 Inactive
    Sorry Arie,
    Apologies....:eek: I wasn't aware of the Eula on the older versions. Mine is paid for and has been for a long time. That's why I still use version 8. It's been a long time since I've even seen or read such. I thought winzip released certain older versions as freeware now.
    As you suggested and I agree, there are plenty of good free ones.
  12. 2009/01/13
    dwdw
    I guess I did not make it clear on the question at the first place. Because one can use previous versions of Winzip after the trial period with some naggings, I thought that was the case for WinZip v12, so I was surprised to find out that it prevented me from using it.
    Now I am clear that WinZip stops working after the 45-day free trial period, according to http://www.winzip.com/clhm.htm. I decide to use 7-zip instead.
    Thanks for all the feedback. Appreciate that.
