Yahoo messenger encountered problem
Discussion in 'General Internet' started by panchal, 2002/08/21.
  1. 2002/08/21
    panchal
    panchal Inactive Thread Starter
    I downloaded latest version of Yahoo messenger 5.5 but on logging I get error it had encountered problem pl inform Microsoft , can view error report but on closing this message YM also closes but if I donot close this error message I can continue to use Yahoo mssngr.
    Any one help please
    panchal
    panchal@omantel.net.om
  2. 2002/08/21
    Abraxas
    Abraxas Inactive
    You could try reinstalling the messenger.
    In the meantime, disable error reporting:
    Right-click My Computer, Properties, Advanced tab. Click Error Reporting button and disable it.
    panchal
    tried reinstalling but no able to resolve
    Thanks abarax, I tried to reinstall after removing entire old program but problem persist do u know whom to contact in yahoo or is it Microsoft I.E compatability problem
  5. 2002/08/21
    panchal
    Disabling error reporting doesnot help
    As per your advice Abarax I tried to disable error reporting but still it reports ,,,if I totally diable then not able to open Ymssngr,
    message still appearing it is ridiculous issue
  6. 2002/08/21
    markp62
    markp62 Geek Member Alumni
    Did you install Yahoo Companion?
  7. 2002/08/22
    Doodad
    Doodad Guest
  8. 2002/08/23
    Talon
    Talon Inactive
    Yahoo Messenger Problems
    You might wish to do a search for either of the following two
    pieces of software: MIRANDA or TRILLIAN.
    Either program allows you to connect to AIM, ICQ, and
    Yahoo Messenger without having to install the bulky
    and ofttimes buggy software associated with either.
    Just a thought...
    Regards,
    Jim Talon
  9. 2002/08/29
    panchal
    workaround but
    I used this option to run program compatiblity click Ypager.exe properties and choose run program win98 or 2000 then YM started working however webcam doesnot start.
    Another problem if revert backs to ver. 5 is if the other end friend has ver 5.5 then webcam will not work. back to square one
