XP work around for HP 5200 scanjet
Discussion in 'PC Hardware' started by Goaglen, 2011/01/02.
  1. 2011/01/02
    Goaglen Contributing Member
    Goaglen Well-Known Member Thread Starter
    Does anyone know of a work around in XP Pro for an HP 5200 scanjet?
    Hardware installed; hardware recognized; precision scan loads; scanjet makes noises as if it will scan; does not complete scan or load an image.
    Scanjet is > six years old, worked fine under W2000 OS.
    Searched drivers for it and found none for XP system.
    Is there a driver set or registry setting which will free it to work?
    Is there a software file which can be changed to allow it to work?
  2. 2011/01/02
    hawk22
    hawk22 Geek Member
  5. 2011/01/02
    Zander
    Zander Geek Member Alumni
    If nothing else, try using Win 2K or Windows NT drivers. I used to have an old Visioneer Scanner that didn't have any XP drivers available for it. I used the Win NT drivers and it worked great. If all else fails, you've got nothing to lose. ;)
  6. 2011/01/03
    JohnB Lifetime Subscription
    JohnB Well-Known Member
    Hi Zander, I have a Visioneer scanner but don't have the NT drivers. Can you tell where to get them. My scanner is a OneTouch 5820 USB.
    Thanks.
  7. 2011/01/03
    Zander
  8. 2011/01/03
  9. 2011/04/27
    From a PM .....
