XP Pro won't recognize 2nd HD
Discussion in 'Windows XP' started by mbcannon2, 2004/12/05.
  1. 2004/12/05
    mbcannon2
    mbcannon2 Inactive Thread Starter
    Attempting to install 2nd Seagate HDD. Followed instructions and removed jumper to set up HDD as slave.
    Instruction booklet tells me to go to CMOS setup and perform some actions but I can't get to CMOS during startup sequence. Have tried F1, F8, Shift, Delete and Escape and am stymied.
    Any hlep?
    Thanks in advance!
  2. 2004/12/05
    picard
    picard Inactive
    Hi mbcannon2
    If it happends to be a Compaq try F10.
    Bmoore1129
    Bmoore1129 Geek Member
    mbcannon2
    If that doesn't work, watch your screen as it boots. In the lower left corner there will be a line of text that will tell you how to get into the setup. It may help to have your finger over the pause button so you can stop it in place while you read. To continue, hit the space bar or the key it has told you to use for entering setup.
  5. 2004/12/05
    surferdude2
    surferdude2 Inactive
    Method : System
    del during boot AMI, Award
    Esc during boot Toshiba
    F1 during boot Toshiba; Phoenix; Late model PS/1 Value Point and 330s
    F2 during boot NEC
    F10 when square in top RH corner of screen Compaq
    Ins during boot IBM PS/2s w/ Reference Partition
    Reset twice Some Dells
    Alt Enter Dell
    Alt ? some PS/2s
    Ctrl-Esc General
    Ctrl Ins some PS/2s when pointer at top right of screen
    Ctrl Alt Esc AST Advantage, Award, Tandon
    Ctrl Alt + General
    Ctrl Alt S Phoenix
    Ctrl Alt Ins Zenith, Phoenix
    Ctrl S Phoenix
    Ctrl Shift Esc Tandon 386
    Shift Ctrl Alt + Num Pad del Olivetti PC Pro
    Setup disk Old Compaqs, Epson (Gemini), IBM, IBM PS/2, Toshiba, old 286s
