XP Pro - Vanishing Admin Tools
Discussion in 'Windows XP' started by MCoatney, 2004/09/16.
  1. 2004/09/16
    MCoatney
    MCoatney Inactive Thread Starter
    The computer Im developing on at work is running an upgraded XP Home,
    to the XP Pro. I have installed (with some difficulty) IIS (whole package)
    Now I want to set up a Virtual Directory for my ASP.NET files, but I have no
    Internet Service Manager. Administration Tools are not there :eek: Help!
  2. 2004/09/16
    MCoatney - Welcome to the Board :)
    Does this link help - compatible with XP ....
    http://www.microsoft.com/downloads/...15-c8f4-47ef-a1e4-a8dcbacff8e3&displaylang=en
    and a quote from Help & Support ....
    " Administration Tools
    From a computer running Windows XP Professional, you can manage any server running Windows 2000 Professional by using Remote Desktop.
    Do not use Windows 2000 Administration Tools (which is included on the Windows 2000 Server CD-ROM as a single MMC console) on computers running Windows XP Professional. Windows 2000 Administration Tools should be removed from computers running Windows 2000 Professional before upgrading to Windows XP Professional. If Windows 2000 Administration Tools is detected during the upgrade from Windows 2000 Professional to Windows XP Professional, you will be advised to remove it before upgrading. "
    MCoatney
    First, I want to thank you for responding. You directed me right to what I said I needed.
    However, Internet Services Manager is not there! Everything I have read says it should be right there in the Administrative Tools. Hmmm... The plot thickens
  5. 2004/09/16
    Johanna
    Johanna Inactive Alumni
    In the Control Panel >Taskbar & Start Menu> Start Menu > Advanced click "customize" and verify that "do not display Admin Tools" is not ticked.
    Johanna
  7. 2004/09/22
    MCoatney
    Thanks to everyone responding, I have not yet found a solution. I think the package is just not installed. I don't know why this would be, when I go to the "Install optional Windows components" the only box not checked under IIS is FTP.
    I get a huge list of Administration Tools now (thanks to you all) right where it should be, but none of them is what I need.
