XP Pro SP2 / XP Pro x64 HDD FS
Discussion in 'Windows XP' started by silver, 2005/08/26.
  1. 2005/08/26
    silver
    silver Inactive Thread Starter
    Just wondering if XP Pro SP2 and XP Pro x64 use exactly the same file system or if there are significant differences. I always use a seconday partition at the beginning of my HDD for my swap file. Can they share the same swap partition ?
  2. 2005/08/26
    Depends if 64bit uses the same file name. If it does - no can do.
    silver
    That's what I thought of immediately after the post. I've created a 4GB partition in the root of the HDD and will have Windows use different swapfiles insode that partition.
  5. 2005/08/27
