XP made hard drive "read only"
Discussion in 'Windows XP' started by Argent, 2006/04/07.
  1. 2006/04/07
    Argent
    Argent Inactive Thread Starter
    My friend was playing around and repartitioned a drive thru the Manage. He ******* up the size of the partition and fixed it, but now the drive is "read only" !!!
    Took the drive out to a Linix box, repartitioned and formated and the drive is STILL "read only "! How can this be fixed???
    TIA!!!
  2. 2006/04/07
    Since you have used Linux, I presume you have formatted it with FAT/FAT32 file system. Try to run chkdsk /f on the drive.
    Argent
    Drive was in XP and listed as unknown in the Manager. He partitioned there in NTSF/gave it a drive letter and the the disk became "read only ". He moved the drive to the Linix box and deleted/repartitioned and formatted (in the Linix box) and the drive was still "read only ".
    That is the steps taken...
  5. 2006/04/07
    Go to the drive manufacturer's website and download their disk utilities to check it out and, if possible, perform a low level format.
