XP Install Problems, BSOD'S, chkdsk hangs,files not copied, etc
Discussion in 'PC Hardware' started by bluepeter75, 2006/07/04.
  1. 2006/07/04
    bluepeter75
    bluepeter75 Inactive Thread Starter
    Hi,
    I have a problem which is driving me nuts. I get random BSOD, sometimes 20 a day before I get fed up restarting. I have put new memory in, new power supply, formatted and reinstalled windows (XP PRO) several times. I'm tearing my hair out. Dumplog follows, hope you can help. Many thanks in anticipation.
    Opened log file 'c:\debuglog.txt'
    Microsoft (R) Windows Debugger Version 6.6.0003.5
    Loading Dump File [C:\WINDOWS\Minidump\Mini070406-08.dmp]
    Executable search path is: C:\WINDOWS;C:\WINDOWS\system32;C:\WINDOWS\system32\drivers
    Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible
    Product: WinNt, suite: TerminalServer SingleUserTS
    Built by: 2600.xpsp_sp2_gdr.050301-1519
    Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055a420
    Debug session time: Tue Jul 4 20:13:30.125 2006 (GMT+1)
    System Uptime: 0 days 1:06:30.662
    Loading Kernel Symbols
    Loading User Symbols
    Loading unloaded module list
    * Bugcheck Analysis *
    BugCheck 1000000A, {fffe8080, 2, 1, 806ee2dc}
    Probably caused by : ntoskrnl.exe ( nt!KeReleaseMutant+bb )
    Followup: MachineOwner
    kd> !analyze -v;r;kv;lmtn;.logclose;q
    IRQL_NOT_LESS_OR_EQUAL (a)
    interrupt request level (IRQL) that is too high. This is usually
    caused by drivers using improper addresses.
    If a kernel debugger is available get the stack backtrace.
    Arguments:
    Arg1: fffe8080, memory referenced
    Arg2: 00000002, IRQL
    Arg3: 00000001, value 0 = read operation, 1 = write operation
    Arg4: 806ee2dc, address which referenced memory
    Debugging Details:
    WRITE_ADDRESS: fffe8080
    CURRENT_IRQL: 2
    FAULTING_IP:
    hal!KfLowerIrql+c
    806ee2dc 890d8000feff mov [fffe0080],ecx
    CUSTOMER_CRASH_COUNT: 8
    DEFAULT_BUCKET_ID: COMMON_SYSTEM_FAULT
    BUGCHECK_STR: 0xA
    LAST_CONTROL_TRANSFER: from 804e4939 to 806ee2dc
    STACK_TEXT:
    b6128cdc 804e4939 00000000 83c796b0 00000000 hal!KfLowerIrql+0xc
    b6128cf0 80565674 00000000 00000001 00000000 nt!KeReleaseMutant+0xbb
    b6128d54 804de7ec 00000188 00000000 0203750c nt!NtReleaseMutant+0x76
    b6128d54 7c90eb94 00000188 00000000 0203750c nt!KiFastCallEntry+0xf8
    WARNING: Frame IP not in any known module. Following frames may be wrong.
    0203750c 00000000 00000000 00000000 00000000 0x7c90eb94
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    804e4939 8b4508 mov eax,[ebp+0x8]
    SYMBOL_STACK_INDEX: 1
    FOLLOWUP_NAME: MachineOwner
    SYMBOL_NAME: nt!KeReleaseMutant+bb
    MODULE_NAME: nt
    IMAGE_NAME: ntoskrnl.exe
    DEBUG_FLR_IMAGE_TIMESTAMP: 42250ff9
    FAILURE_BUCKET_ID: 0xA_W_nt!KeReleaseMutant+bb
    eax=00000000 ebx=00000000 ecx=00000000 edx=00000000 esi=83c796b0 edi=83c8f408
    eip=806ee2dc esp=b6128ce0 ebp=b6128cf0 iopl=0 nv up ei pl zr na po nc
    cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010246
    hal!KfLowerIrql+0xc:
    806ee2dc 890d8000feff mov [fffe0080],ecx ds:0023:fffe0080=????????
    b6128cdc 804e4939 00000000 83c796b0 00000000 hal!KfLowerIrql+0xc (FPO: [0,0,0])
    b6128cf0 80565674 00000000 00000001 00000000 nt!KeReleaseMutant+0xbb (FPO: [Non-Fpo])
    b6128d54 804de7ec 00000188 00000000 0203750c nt!NtReleaseMutant+0x76 (FPO: [Non-Fpo])
    b6128d54 7c90eb94 00000188 00000000 0203750c nt!KiFastCallEntry+0xf8 (FPO: [0,0] TrapFrame @ b6128d64)
    start end module name
    804d7000 806eb100 nt ntoskrnl.exe Wed Mar 02 00:59:37 2005 (42250FF9)
    806ec000 8070c380 hal halaacpi.dll Wed Aug 04 06:59:05 2004 (41107B29)
    b5a8c000 b5acc100 HTTP HTTP.sys Sat Oct 09 00:48:20 2004 (41672744)
    b5eb5000 b5ecaf80 av5flt av5flt.sys Mon Oct 17 11:28:05 2005 (43537CB5)
    b60d8000 b60ec400 wdmaud wdmaud.sys Wed Aug 04 07:15:03 2004 (41107EE7)
    b6321000 b6323700 WNMFLT WNMFLT.SYS Wed Sep 21 17:08:43 2005 (4331858B)
    b6345000 b6396300 srv srv.sys Tue May 10 01:17:49 2005 (427FFDAD)
    b63bf000 b63e6f00 PavProc PavProc.sys Thu Jan 08 07:54:16 2004 (3FFD0CA8)
    b63e7000 b640f280 IDSFLT IDSFLT.SYS Wed Sep 21 17:08:05 2005 (43318565)
    b6460000 b648c400 mrxdav mrxdav.sys Wed Aug 04 07:00:49 2004 (41107B91)
    b64b5000 b64c3d80 sysaudio sysaudio.sys Wed Aug 04 07:15:54 2004 (41107F1A)
    b6585000 b6588b80 ASPI32 ASPI32.SYS Tue Dec 23 02:02:44 1997 (349F1BC4)
    b66c1000 b66c4280 ndisuio ndisuio.sys Wed Aug 04 07:03:10 2004 (41107C1E)
    b67ad000 b67be700 pavdrv51 pavdrv51.sys Mon Jun 13 15:51:39 2005 (42AD9D7B)
    b691f000 b6936480 dump_atapi dump_atapi.sys Wed Aug 04 06:59:41 2004 (41107B4D)
    b6937000 b69571a0 glausb glausb.sys Fri Aug 15 17:56:49 2003 (3F3D10D1)
    b6980000 b69a0f00 ipnat ipnat.sys Wed Sep 29 23:28:36 2004 (415B3714)
    b69a1000 b6a0fa00 mrxsmb mrxsmb.sys Fri May 05 10:41:42 2006 (445B1DD6)
    b6a10000 b6a3aa00 rdbss rdbss.sys Fri May 05 10:47:55 2006 (445B1F4B)
    b6a63000 b6a84d00 afd afd.sys Wed Aug 04 07:14:13 2004 (41107EB5)
    b6a85000 b6aacc00 netbt netbt.sys Wed Aug 04 07:14:36 2004 (41107ECC)
    b6aad000 b6b04d80 tcpip tcpip.sys Thu Apr 20 12:51:47 2006 (444775D3)
    b6b05000 b6b17400 ipsec ipsec.sys Wed Aug 04 07:14:27 2004 (41107EC3)
    b6b54000 b6b56900 Dxapi Dxapi.sys Fri Aug 17 21:53:19 2001 (3B7D843F)
    b6b5c000 b6b5ef80 mouhid mouhid.sys Fri Aug 17 21:47:57 2001 (3B7D82FD)
    bf800000 bf9c1180 win32k win32k.sys Thu Oct 06 01:05:44 2005 (43446A58)
    bf9c2000 bf9d3580 dxg dxg.sys Wed Aug 04 07:00:51 2004 (41107B93)
    bf9d4000 bfae5200 SiSGRV SiSGRV.dll Wed Oct 29 19:01:55 2003 (3FA00EA3)
    f6f05000 f6f38200 update update.sys Wed Aug 04 06:58:32 2004 (41107B08)
    f6f39000 f6f69100 rdpdr rdpdr.sys Wed Aug 04 07:01:10 2004 (41107BA6)
    f6f6a000 f6f82bc0 PPPoEWin PPPoEWin.SYS Thu Sep 25 14:52:45 2003 (3F72F32D)
    f6f83000 f6f93e00 psched psched.sys Wed Aug 04 07:04:16 2004 (41107C60)
    f6f94000 f6faa680 ndiswan ndiswan.sys Wed Aug 04 07:14:30 2004 (41107EC6)
    f6fab000 f6fbe900 parport parport.sys Wed Aug 04 06:59:04 2004 (41107B28)
    f6fbf000 f7185960 IntelS51 IntelS51.sys Fri Dec 10 19:30:38 2004 (41B9F95E)
    f7186000 f71a8e80 USBPORT USBPORT.SYS Wed Aug 04 07:08:34 2004 (41107D62)
    f71a9000 f71cc980 portcls portcls.sys Wed Aug 04 07:15:47 2004 (41107F13)
    f71cd000 f7285380 cmuda cmuda.sys Fri Oct 17 04:52:00 2003 (3F8F6760)
    f7286000 f72a8680 ks ks.sys Wed Aug 04 07:15:20 2004 (41107EF8)
    f72a9000 f72bc780 VIDEOPRT VIDEOPRT.SYS Wed Aug 04 07:07:04 2004 (41107D08)
    f72bd000 f7325700 sisgrp sisgrp.sys Wed Oct 29 18:54:56 2003 (3FA00D00)
    f7326000 f7328280 fnetmon fnetmon.SYS Thu Jul 14 13:22:04 2005 (42D658EC)
    f733a000 f733cc00 srvkp srvkp.sys Wed Oct 29 19:36:35 2003 (3FA016C3)
    f736e000 f7388580 Mup Mup.sys Wed Aug 04 07:15:20 2004 (41107EF8)
    f7389000 f73a4300 netflt netflt.sys Fri Oct 14 16:13:08 2005 (434FCB04)
    f73a5000 f73d1a80 NDIS NDIS.sys Wed Aug 04 07:14:27 2004 (41107EC3)
    f73d2000 f73e8780 KSecDD KSecDD.sys Wed Aug 04 06:59:45 2004 (41107B51)
    f73e9000 f740c000 Fastfat Fastfat.sys Wed Aug 04 07:14:15 2004 (41107EB7)
    f740c000 f741df00 sr sr.sys Wed Aug 04 07:06:22 2004 (41107CDE)
    f741e000 f741f000 fltmgr fltmgr.sys unavailable (00000000)
    f743d000 f7454480 atapi atapi.sys Wed Aug 04 06:59:41 2004 (41107B4D)
    f7455000 f747a700 dmio dmio.sys Wed Aug 04 07:07:13 2004 (41107D11)
    f747b000 f7499880 ftdisk ftdisk.sys Fri Aug 17 21:52:41 2001 (3B7D8419)
    f749a000 f74aaa80 pci pci.sys Wed Aug 04 07:07:45 2004 (41107D31)
    f74ab000 f74d8d80 ACPI ACPI.sys Wed Aug 04 07:07:35 2004 (41107D27)
    f74fa000 f7502c00 isapnp isapnp.sys Fri Aug 17 21:58:01 2001 (3B7D8559)
    f750a000 f7514500 MountMgr MountMgr.sys Wed Aug 04 06:58:29 2004 (41107B05)
    f751a000 f7526c80 VolSnap VolSnap.sys Wed Aug 04 07:00:14 2004 (41107B6E)
    f752a000 f7532e00 disk disk.sys Wed Aug 04 06:59:53 2004 (41107B59)
    f753a000 f7546200 CLASSPNP CLASSPNP.SYS Wed Aug 04 07:14:26 2004 (41107EC2)
    f756a000 f7572a00 processr processr.sys Wed Aug 04 06:59:14 2004 (41107B32)
    f757a000 f7586e00 i8042prt i8042prt.sys Wed Aug 04 07:14:36 2004 (41107ECC)
    f758a000 f7594380 Imapi Imapi.SYS Wed Aug 04 07:00:12 2004 (41107B6C)
    f759a000 f75a6180 cdrom cdrom.sys Wed Aug 04 06:59:52 2004 (41107B58)
    f75aa000 f75b8080 redbook redbook.sys Wed Aug 04 06:59:34 2004 (41107B46)
    f75ba000 f75c8b80 drmk drmk.sys Wed Aug 04 07:07:54 2004 (41107D3A)
    f75ca000 f75d9d80 serial serial.sys Wed Aug 04 07:15:51 2004 (41107F17)
    f75da000 f75e6880 rasl2tp rasl2tp.sys Wed Aug 04 07:14:21 2004 (41107EBD)
    f75ea000 f75f4200 raspppoe raspppoe.sys Wed Aug 04 07:05:06 2004 (41107C92)
    f75fa000 f7605d00 raspptp raspptp.sys Wed Aug 04 07:14:26 2004 (41107EC2)
    f760a000 f7612900 msgpc msgpc.sys Wed Aug 04 07:04:11 2004 (41107C5B)
    f761a000 f7623f00 termdd termdd.sys Wed Aug 04 06:58:52 2004 (41107B1C)
    f763a000 f7643480 NDProxy NDProxy.SYS Fri Aug 17 21:55:30 2001 (3B7D84C2)
    f764a000 f7658100 usbhub usbhub.sys Wed Aug 04 07:08:40 2004 (41107D68)
    f766a000 f7672700 netbios netbios.sys Wed Aug 04 07:03:19 2004 (41107C27)
    f767a000 f7682880 Fips Fips.SYS Sat Aug 18 02:31:49 2001 (3B7DC585)
    f768a000 f7692700 wanarp wanarp.sys Wed Aug 04 07:04:57 2004 (41107C89)
    f769a000 f76a3c80 APPFLT APPFLT.SYS Wed Oct 06 11:02:17 2004 (4163C2A9)
    f76ba000 f76c2d80 HIDCLASS HIDCLASS.SYS Wed Aug 04 07:08:18 2004 (41107D52)
    f76ca000 f76d9900 Cdfs Cdfs.SYS Wed Aug 04 07:14:09 2004 (41107EB1)
    f777a000 f7780200 PCIIDEX PCIIDEX.SYS Wed Aug 04 06:59:40 2004 (41107B4C)
    f7782000 f7786900 PartMgr PartMgr.sys Sat Aug 18 02:32:23 2001 (3B7DC5A7)
    f779a000 f77a0000 kbdclass kbdclass.sys Wed Aug 04 06:58:32 2004 (41107B08)
    f77a2000 f77a6280 usbohci usbohci.sys Wed Aug 04 07:08:34 2004 (41107D62)
    f77aa000 f77b0800 usbehci usbehci.sys Wed Aug 04 07:08:34 2004 (41107D62)
    f77b2000 f77b9580 Modem Modem.SYS Wed Aug 04 07:08:04 2004 (41107D44)
    f77ba000 f77bb000 fdc fdc.sys unavailable (00000000)
    f77c2000 f77c6880 TDI TDI.SYS Wed Aug 04 07:07:47 2004 (41107D33)
    f77ca000 f77ce580 ptilink ptilink.sys Fri Aug 17 21:49:53 2001 (3B7D8371)
    f77d2000 f77d6080 raspti raspti.sys Fri Aug 17 21:55:32 2001 (3B7D84C4)
    f77da000 f77df020 wanatw4 wanatw4.sys Tue Jul 16 16:23:14 2002 (3D343A62)
    f77e2000 f77e7a00 mouclass mouclass.sys Wed Aug 04 06:58:32 2004 (41107B08)
    f77ea000 f77ef000 flpydisk flpydisk.sys Wed Aug 04 06:59:24 2004 (41107B3C)
    f77fa000 f77ff200 vga vga.sys Wed Aug 04 07:07:06 2004 (41107D0A)
    f7802000 f7806a80 Msfs Msfs.SYS Wed Aug 04 07:00:37 2004 (41107B85)
    f780a000 f7811880 Npfs Npfs.SYS Wed Aug 04 07:00:38 2004 (41107B86)
    f7812000 f7818a80 NETFLTDI NETFLTDI.SYS Wed Oct 06 11:02:45 2004 (4163C2C5)
    f781a000 f7820880 ShldDrv ShldDrv.SYS Mon Aug 29 13:20:06 2005 (4312FD76)
    f7822000 f7828180 HIDPARSE HIDPARSE.SYS Wed Aug 04 07:08:15 2004 (41107D4F)
    f782a000 f782e500 watchdog watchdog.sys Wed Aug 04 07:07:32 2004 (41107D24)
    f784a000 f784e100 cpoint cpoint.sys Fri Aug 12 13:36:57 2005 (42FC97E9)
    f788a000 f7891480 DSAFLT DSAFLT.SYS Wed Sep 21 17:07:48 2005 (43318554)
    f78e2000 f78e6500 SMSFLT SMSFLT.SYS Fri Sep 30 08:29:18 2005 (433CE94E)
    f790a000 f790d000 BOOTVID BOOTVID.dll Fri Aug 17 21:49:09 2001 (3B7D8345)
    f798e000 f7991c80 serenum serenum.sys Wed Aug 04 06:59:06 2004 (41107B2A)
    f7992000 f7994980 gameenum gameenum.sys Wed Aug 04 07:08:20 2004 (41107D54)
    f7996000 f7998580 ndistapi ndistapi.sys Fri Aug 17 21:55:29 2001 (3B7D84C1)
    f79aa000 f79adc80 mssmbios mssmbios.sys Wed Aug 04 07:07:47 2004 (41107D33)
    f79ba000 f79bc580 hidusb hidusb.sys Fri Aug 17 22:02:16 2001 (3B7D8658)
    f79de000 f79e1f00 MODEMCSA MODEMCSA.sys Fri Aug 17 21:57:37 2001 (3B7D8541)
    f79ee000 f79f0280 rasacd rasacd.sys Fri Aug 17 21:55:39 2001 (3B7D84CB)
    f79f6000 f79f8f00 ws2ifsl ws2ifsl.sys Fri Aug 17 21:55:58 2001 (3B7D84DE)
    f79fa000 f79fbb80 kdcom kdcom.dll Fri Aug 17 21:49:10 2001 (3B7D8346)
    f79fc000 f79fd100 WMILIB WMILIB.SYS Fri Aug 17 22:07:23 2001 (3B7D878B)
    f79fe000 f79ff000 dmload dmload.sys unavailable (00000000)
    f7a00000 f7a01100 swenum swenum.sys Wed Aug 04 06:58:41 2004 (41107B11)
    f7a02000 f7a03280 USBD USBD.SYS Fri Aug 17 22:02:58 2001 (3B7D8682)
    f7a04000 f7a05000 Fs_Rec Fs_Rec.SYS unavailable (00000000)
    f7a06000 f7a07080 Beep Beep.SYS Fri Aug 17 21:47:33 2001 (3B7D82E5)
    f7a08000 f7a09080 mnmdd mnmdd.SYS Fri Aug 17 21:57:28 2001 (3B7D8538)
    f7a0a000 f7a0b080 RDPCDD RDPCDD.sys Fri Aug 17 21:46:56 2001 (3B7D82C0)
    f7a0c000 f7a0d100 dump_WMILIB dump_WMILIB.SYS Fri Aug 17 22:07:23 2001 (3B7D878B)
    f7a18000 f7a19000 ParVdm ParVdm.SYS unavailable (00000000)
    f7a5e000 f7a5f360 COMFiltr COMFiltr.sys Wed Sep 25 09:34:57 2002 (3D917531)
    f7ac2000 f7ac2d00 pciide pciide.sys Fri Aug 17 21:51:49 2001 (3B7D83E5)
    f7ad0000 f7ad0d00 dxgthk dxgthk.sys Fri Aug 17 21:53:12 2001 (3B7D8438)
    f7b94000 f7b94c00 audstub audstub.sys Fri Aug 17 21:59:40 2001 (3B7D85BC)
    f7bc0000 f7bc1000 Null Null.SYS unavailable (00000000)
    f7bcc000 f7bccb80 mbmiodrvr mbmiodrvr.sys Sat Apr 10 15:42:35 2004 (407807DB)
    Unloaded modules:
    b58d2000 b58fc000 kmixer.sys
    Checksum: 00000000
    b608b000 b60b5000 kmixer.sys
    Checksum: 00000000
    f7c51000 f7c52000 drmkaud.sys
    Checksum: 00000000
    b61bd000 b61ca000 DMusic.sys
    Checksum: 00000000
    b60b5000 b60d8000 aec.sys
    Checksum: 00000000
    b61cd000 b61db000 swmidi.sys
    Checksum: 00000000
    f7a44000 f7a46000 splitter.sys
    Checksum: 00000000
    f77f2000 f77f7000 Cdaudio.SYS
    Checksum: 00000000
    f79ea000 f79ed000 Sfloppy.SYS
    Checksum: 00000000
    Closing open log file c:\debuglog.txt
  2. 2006/07/04
    bluepeter75 - Welcome to the Board :)
    Have patience until the one member of the BBS who can read these dump files chances by.
    In the meantime I suggest you download the diagnostics software from the manufacturer of your hard drive and check out the drive - you seem to have done most other things.
    In the mean time try making sure that all your drivers are up to date.
    BUGCHECK_STR: 0xA is commonly caused by a faulty driver.
    bluepeter75
    Thanks for the welcome, when I restart and send error report to Microsoft, their response varies from it being caused by unknown hardware (last night was the latest time) to 'unknown driver' to a specific driver (only a few times but a different driver each time, I've updated all the ones it mentioned and think I've checked the rest).
    The error signature is
    BCCode : 1000000a BCP1 : FFFE8080 BCP2 : 00000002 BCP3 : 00000001
    BCP4 : 806EE2DC OSVer : 5_1_2600 SP : 2_0 Product : 256_1
    if that helps.
  6. 2006/07/05
    Not really, but if you have 1 or 2 more dumps, please post them too.
  7. 2006/07/05
    bluepeter75
    I have about 30 - 40 since I last cleared them out, I'll post the most recent two when I get home, I'm at work just now. Thanks.
  8. 2006/07/05
    bluepeter75
    I actually have about 700 minidumps. Here's one from this morning:
    Loading Dump File [C:\WINDOWS\Minidump\Mini070506-01.dmp]
    Debug session time: Tue Jul 4 22:35:42.953 2006 (GMT+1)
    System Uptime: 0 days 0:02:11.486
    Arguments:
    Debugging Details:
    CURRENT_IRQL: 2
    FAULTING_IP:
    hal!KfLowerIrql+c
    CUSTOMER_CRASH_COUNT: 1
    BUGCHECK_STR: 0xA
    STACK_TEXT:
    b61d9cdc 804e4939 00000000 83c12420 00000000 hal!KfLowerIrql+0xc
    b61d9cf0 80565674 00000000 00000001 00000000 nt!KeReleaseMutant+0xbb
    b61d9d54 804de7ec 00000188 00000000 02337508 nt!NtReleaseMutant+0x76
    b61d9d54 7c90eb94 00000188 00000000 02337508 nt!KiFastCallEntry+0xf8
    02337508 00000000 00000000 00000000 00000000 0x7c90eb94
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    MODULE_NAME: nt
    eax=00000000 ebx=00000000 ecx=00000000 edx=00000000 esi=83c12420 edi=83b568b8
    eip=806ee2dc esp=b61d9ce0 ebp=b61d9cf0 iopl=0 nv up ei pl zr na po nc
    b61d9cdc 804e4939 00000000 83c12420 00000000 hal!KfLowerIrql+0xc (FPO: [0,0,0])
    b61d9cf0 80565674 00000000 00000001 00000000 nt!KeReleaseMutant+0xbb (FPO: [Non-Fpo])
    b61d9d54 804de7ec 00000188 00000000 02337508 nt!NtReleaseMutant+0x76 (FPO: [Non-Fpo])
    b61d9d54 7c90eb94 00000188 00000000 02337508 nt!KiFastCallEntry+0xf8 (FPO: [0,0] TrapFrame @ b61d9d64)
    b5eae000 b5ec3f80 av5flt av5flt.sys Mon Oct 17 11:28:05 2005 (43537CB5)
    b60ac000 b60d5f00 kmixer kmixer.sys Wed Aug 04 07:07:46 2004 (41107D32)
    b60fe000 b6120c80 aec aec.sys Fri Oct 01 18:00:21 2004 (415D8D25)
    b6121000 b6135400 wdmaud wdmaud.sys Wed Aug 04 07:15:03 2004 (41107EE7)
    b6352000 b6354700 WNMFLT WNMFLT.SYS Wed Sep 21 17:08:43 2005 (4331858B)
    b638e000 b63df300 srv srv.sys Tue May 10 01:17:49 2005 (427FFDAD)
    b63e0000 b6407f00 PavProc PavProc.sys Thu Jan 08 07:54:16 2004 (3FFD0CA8)
    b6430000 b6458280 IDSFLT IDSFLT.SYS Wed Sep 21 17:08:05 2005 (43318565)
    b6481000 b64ad400 mrxdav mrxdav.sys Wed Aug 04 07:00:49 2004 (41107B91)
    b65be000 b65c1b80 ASPI32 ASPI32.SYS Tue Dec 23 02:02:44 1997 (349F1BC4)
    b665e000 b666cd80 sysaudio sysaudio.sys Wed Aug 04 07:15:54 2004 (41107F1A)
    b66ea000 b66ed280 ndisuio ndisuio.sys Wed Aug 04 07:03:10 2004 (41107C1E)
    b67ce000 b67df700 pavdrv51 pavdrv51.sys Mon Jun 13 15:51:39 2005 (42AD9D7B)
    b68c0000 b68cd400 swmidi swmidi.sys Fri Aug 17 22:00:42 2001 (3B7D85FA)
    b6940000 b6957480 dump_atapi dump_atapi.sys Wed Aug 04 06:59:41 2004 (41107B4D)
    b6b58000 b6b5a900 Dxapi Dxapi.sys Fri Aug 17 21:53:19 2001 (3B7D843F)
    b6fb0000 b6fbce80 DMusic DMusic.sys Wed Aug 04 07:07:37 2004 (41107D29)
    f6edd000 f6edff80 mouhid mouhid.sys Fri Aug 17 21:47:57 2001 (3B7D82FD)
    f6ee1000 f6ee3580 hidusb hidusb.sys Fri Aug 17 22:02:16 2001 (3B7D8658)
    f741e000 f743c780 fltmgr fltmgr.sys Wed Aug 04 07:01:17 2004 (41107BAD)
    f77f2000 f77f6500 SMSFLT SMSFLT.SYS Fri Sep 30 08:29:18 2005 (433CE94E)
    f7882000 f7889480 DSAFLT DSAFLT.SYS Wed Sep 21 17:07:48 2005 (43318554)
    f79fe000 f79ff700 dmload dmload.sys Fri Aug 17 21:58:15 2001 (3B7D8567)
    f7a04000 f7a05f00 Fs_Rec Fs_Rec.SYS Fri Aug 17 21:49:37 2001 (3B7D8361)
    f7a18000 f7a19a80 ParVdm ParVdm.SYS Fri Aug 17 21:49:49 2001 (3B7D836D)
    f7a38000 f7a39900 splitter splitter.sys Wed Aug 04 07:07:46 2004 (41107D32)
    f7b96000 f7b96c00 audstub audstub.sys Fri Aug 17 21:59:40 2001 (3B7D85BC)
    f7bc2000 f7bc2b80 Null Null.SYS Fri Aug 17 21:47:39 2001 (3B7D82EB)
    f7bce000 f7bceb80 mbmiodrvr mbmiodrvr.sys Sat Apr 10 15:42:35 2004 (407807DB)
    f7bf0000 f7bf0b80 drmkaud drmkaud.sys Wed Aug 04 07:07:56 2004 (41107D3C)
    f7c4c000 f7c4cd00 dxgthk dxgthk.sys Fri Aug 17 21:53:12 2001 (3B7D8438)
    Unloaded modules:
    Checksum: 00000000
    Checksum: 00000000
  9. 2006/07/05
    bluepeter75
    And here's another from yesterday. Hope this is all helping!
    Loading Dump File [C:\WINDOWS\Minidump\Mini070306-04.dmp]
    Debug session time: Mon Jul 3 22:16:55.500 2006 (GMT+1)
    System Uptime: 0 days 0:02:18.031
    Arguments:
    Debugging Details:
    CURRENT_IRQL: 2
    FAULTING_IP:
    hal!KfLowerIrql+c
    CUSTOMER_CRASH_COUNT: 4
    BUGCHECK_STR: 0xA
    STACK_TEXT:
    b6734cdc 804e4939 00000000 83f3a450 00000000 hal!KfLowerIrql+0xc
    b6734cf0 80565674 00000000 00000001 00000000 nt!KeReleaseMutant+0xbb
    b6734d54 804de7ec 00000420 00000000 0083f8e8 nt!NtReleaseMutant+0x76
    b6734d54 7c90eb94 00000420 00000000 0083f8e8 nt!KiFastCallEntry+0xf8
    0083f8e8 00000000 00000000 00000000 00000000 0x7c90eb94
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    MODULE_NAME: nt
    eax=00000000 ebx=00000000 ecx=00000000 edx=00000000 esi=83f3a450 edi=83cd3568
    eip=806ee2dc esp=b6734ce0 ebp=b6734cf0 iopl=0 nv up ei pl zr na po nc
    b6734cdc 804e4939 00000000 83f3a450 00000000 hal!KfLowerIrql+0xc (FPO: [0,0,0])
    b6734cf0 80565674 00000000 00000001 00000000 nt!KeReleaseMutant+0xbb (FPO: [Non-Fpo])
    b6734d54 804de7ec 00000420 00000000 0083f8e8 nt!NtReleaseMutant+0x76 (FPO: [Non-Fpo])
    b6734d54 7c90eb94 00000420 00000000 0083f8e8 nt!KiFastCallEntry+0xf8 (FPO: [0,0] TrapFrame @ b6734d64)
    b6397000 b63bef00 PavProc PavProc.sys Thu Jan 08 07:54:16 2004 (3FFD0CA8)
    b6589000 b658cb80 ASPI32 ASPI32.SYS Tue Dec 23 02:02:44 1997 (349F1BC4)
    b66bd000 b66c0280 ndisuio ndisuio.sys Wed Aug 04 07:03:10 2004 (41107C1E)
    f6e83000 f6eb6200 update update.sys Wed Aug 04 06:58:32 2004 (41107B08)
    f6eb7000 f6ee7100 rdpdr rdpdr.sys Wed Aug 04 07:01:10 2004 (41107BA6)
    f6ee8000 f6f00bc0 PPPoEWin PPPoEWin.SYS Thu Sep 25 14:52:45 2003 (3F72F32D)
    f6f01000 f6f11e00 psched psched.sys Wed Aug 04 07:04:16 2004 (41107C60)
    f6f12000 f6f28680 ndiswan ndiswan.sys Wed Aug 04 07:14:30 2004 (41107EC6)
    f6f29000 f6f3c900 parport parport.sys Wed Aug 04 06:59:04 2004 (41107B28)
    f6f3d000 f7103960 IntelS51 IntelS51.sys Fri Dec 10 19:30:38 2004 (41B9F95E)
    f7104000 f7126e80 USBPORT USBPORT.SYS Wed Aug 04 07:08:34 2004 (41107D62)
    f7127000 f714a980 portcls portcls.sys Wed Aug 04 07:15:47 2004 (41107F13)
    f714b000 f7203380 cmuda cmuda.sys Fri Oct 17 04:52:00 2003 (3F8F6760)
    f7204000 f7226680 ks ks.sys Wed Aug 04 07:15:20 2004 (41107EF8)
    f7227000 f723a780 VIDEOPRT VIDEOPRT.SYS Wed Aug 04 07:07:04 2004 (41107D08)
    f723b000 f72a3700 sisgrp sisgrp.sys Wed Oct 29 18:54:56 2003 (3FA00D00)
    f72d6000 f72d6b80 Null Null.SYS Fri Aug 17 21:47:39 2001 (3B7D82EB)
    f72fe000 f72fec00 audstub audstub.sys Fri Aug 17 21:59:40 2001 (3B7D85BC)
    f7892000 f7899480 DSAFLT DSAFLT.SYS Wed Sep 21 17:07:48 2005 (43318554)
    f78ea000 f78ee500 SMSFLT SMSFLT.SYS Fri Sep 30 08:29:18 2005 (433CE94E)
    f7a12000 f7a13a80 ParVdm ParVdm.SYS Fri Aug 17 21:49:49 2001 (3B7D836D)
    f7b55000 f7b55b80 mbmiodrvr mbmiodrvr.sys Sat Apr 10 15:42:35 2004 (407807DB)
    f7b98000 f7b98d00 dxgthk dxgthk.sys Fri Aug 17 21:53:12 2001 (3B7D8438)
    Unloaded modules:
    Checksum: 00000000
    Checksum: 00000000
  10. 2006/07/05
    bluepeter75
    And one more from a month ago. To my untrained eye they all look very similar (probably caused by: ntoskrnl.exe; Bugcheck: 0xA) but if I could read them I wouldn't be posting!
    Many thanks to anyone who takes the time to read these and tries to help.
    Loading Dump File [C:\WINDOWS\Minidump\Mini060506-01.dmp]
    Debug session time: Mon Jun 5 08:11:10.109 2006 (GMT+1)
    System Uptime: 0 days 0:51:34.653
    Arguments:
    Debugging Details:
    CURRENT_IRQL: 2
    FAULTING_IP:
    hal!KfLowerIrql+c
    BUGCHECK_STR: 0xA
    STACK_TEXT:
    b6218cdc 804e4939 00000000 83e604a8 00000000 hal!KfLowerIrql+0xc
    b6218cf0 80565674 00000000 00000001 00000000 nt!KeReleaseMutant+0xbb
    b6218d54 804de7ec 00000060 00000000 0744fa50 nt!NtReleaseMutant+0x76
    b6218d54 7c90eb94 00000060 00000000 0744fa50 nt!KiFastCallEntry+0xf8
    0744fa50 00000000 00000000 00000000 00000000 0x7c90eb94
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    MODULE_NAME: nt
    eax=00000000 ebx=00000000 ecx=00000000 edx=00000000 esi=83e604a8 edi=83b18020
    eip=806ee2dc esp=b6218ce0 ebp=b6218cf0 iopl=0 nv up ei pl zr na po nc
    b6218cdc 804e4939 00000000 83e604a8 00000000 hal!KfLowerIrql+0xc (FPO: [0,0,0])
    b6218cf0 80565674 00000000 00000001 00000000 nt!KeReleaseMutant+0xbb (FPO: [Non-Fpo])
    b6218d54 804de7ec 00000060 00000000 0744fa50 nt!NtReleaseMutant+0x76 (FPO: [Non-Fpo])
    b6218d54 7c90eb94 00000060 00000000 0744fa50 nt!KiFastCallEntry+0xf8 (FPO: [0,0] TrapFrame @ b6218d64)
    b58fa000 b5923f00 kmixer kmixer.sys Wed Aug 04 07:07:46 2004 (41107D32)
    b5b2c000 b5b6c100 HTTP HTTP.sys Sat Oct 09 00:48:20 2004 (41672744)
    b5e42000 b5e56400 wdmaud wdmaud.sys Wed Aug 04 07:15:03 2004 (41107EE7)
    b5f2f000 b5f3dd80 sysaudio sysaudio.sys Wed Aug 04 07:15:54 2004 (41107F1A)
    b6087000 b609cf80 av5flt av5flt.sys Mon Oct 17 11:28:05 2005 (43537CB5)
    b6251000 b6253700 WNMFLT WNMFLT.SYS Wed Sep 21 17:08:43 2005 (4331858B)
    b6345000 b636cf00 PavProc PavProc.sys Thu Jan 08 07:54:16 2004 (3FFD0CA8)
    b636d000 b63be300 srv srv.sys Tue May 10 01:17:49 2005 (427FFDAD)
    b658d000 b6590b80 ASPI32 ASPI32.SYS Tue Dec 23 02:02:44 1997 (349F1BC4)
    b66d1000 b66d4280 ndisuio ndisuio.sys Wed Aug 04 07:03:10 2004 (41107C1E)
    b69a1000 b6a0f400 mrxsmb mrxsmb.sys Wed Jan 19 04:26:50 2005 (41EDE18A)
    b6a10000 b6a3aa00 rdbss rdbss.sys Thu Oct 28 02:13:57 2004 (418047D5)
    b6aad000 b6b04d80 tcpip tcpip.sys Fri Jan 13 02:28:12 2006 (43C7103C)
    b6b50000 b6b52900 Dxapi Dxapi.sys Fri Aug 17 21:53:19 2001 (3B7D843F)
    f6edd000 f6f10200 update update.sys Wed Aug 04 06:58:32 2004 (41107B08)
    f6f35000 f6f37280 fnetmon fnetmon.SYS Thu Jul 14 13:22:04 2005 (42D658EC)
    f7336000 f7338c00 srvkp srvkp.sys Wed Oct 29 19:36:35 2003 (3FA016C3)
    f734a000 f734cf00 ws2ifsl ws2ifsl.sys Fri Aug 17 21:55:58 2001 (3B7D84DE)
    f76ba000 f76c9900 Cdfs Cdfs.SYS Wed Aug 04 07:14:09 2004 (41107EB1)
    f76ca000 f76d2d80 HIDCLASS HIDCLASS.SYS Wed Aug 04 07:08:18 2004 (41107D52)
    f783a000 f783e100 cpoint cpoint.sys Fri Aug 12 13:36:57 2005 (42FC97E9)
    f78d2000 f78d6200 ATWPKT2 ATWPKT2.SYS Wed Apr 07 16:40:01 2004 (407420D1)
    f78fa000 f78fe500 SMSFLT SMSFLT.SYS Fri Sep 30 08:29:18 2005 (433CE94E)
    f79ae000 f79b1c80 mssmbios mssmbios.sys Wed Aug 04 07:07:47 2004 (41107D33)
    f79be000 f79c0580 hidusb hidusb.sys Fri Aug 17 22:02:16 2001 (3B7D8658)
    f79e2000 f79e5f00 MODEMCSA MODEMCSA.sys Fri Aug 17 21:57:37 2001 (3B7D8541)
    f79f2000 f79f4280 rasacd rasacd.sys Fri Aug 17 21:55:39 2001 (3B7D84CB)
    f7a14000 f7a15a80 ParVdm ParVdm.SYS Fri Aug 17 21:49:49 2001 (3B7D836D)
    f7a3c000 f7a3d360 COMFiltr COMFiltr.sys Wed Sep 25 09:34:57 2002 (3D917531)
    f7b9f000 f7b9fc00 audstub audstub.sys Fri Aug 17 21:59:40 2001 (3B7D85BC)
    f7bc7000 f7bc7b80 Null Null.SYS Fri Aug 17 21:47:39 2001 (3B7D82EB)
    f7bd3000 f7bd3b80 mbmiodrvr mbmiodrvr.sys Sat Apr 10 15:42:35 2004 (407807DB)
    f7c0a000 f7c0ad00 dxgthk dxgthk.sys Fri Aug 17 21:53:12 2001 (3B7D8438)
    Unloaded modules:
    b5dcd000 b5df7000 kmixer.sys
    Checksum: 00000000
    f7b42000 f7b43000 drmkaud.sys
    Checksum: 00000000
    b668d000 b669a000 DMusic.sys
    Checksum: 00000000
    b64cd000 b64db000 swmidi.sys
    Checksum: 00000000
    b5e1f000 b5e42000 aec.sys
    Checksum: 00000000
    f7a5a000 f7a5c000 splitter.sys
    Checksum: 00000000
    Checksum: 00000000
    f79ee000 f79f1000 Sfloppy.SYS
    Checksum: 00000000
  11. 2006/07/05
    You are right about the cause - ntoskrnl.exe - no doubt others will give their interpretation, but I would encourage you to run chkdsk, specifically chkdsk /r and the disk diagnostic software from the hard drive manufacturer.
  12. 2006/07/05
    bluepeter75
    I'm off to try that now - I'll get back to you and let you know how I get on.
  13. 2006/07/05
    bluepeter75
    Ok here goes. I tried to run chkdsk /r but
    "The type of the file system is FAT32.
    Cannot lock current drive.
    Chkdsk cannot run because the volume is in use by another process. Would you like this volume to be checked the next time the system restarts? (Y/N) "
    Chkdsk without the /r runs ok.
    After that, I downloaded the diagnostic software from maxtor, and when I ran the quick check it said 'The drive is failing - back up all your files and exchange with us if your drive is still in warranty' or words to that effect. On subsequent runs it passed the diagnostic tests but I'm sure that's the problem now, it's just intermittent.
    Oh well, Hi Ho, Hi Ho, it's hard drive shopping I go!
    Thanks for your help Arie and PeteC, and compliments on the site, it has taught me a lot from this and the many other threads I have read in the couple of days I have been visiting the site. I'll be checking in in future with any other problems I have!!
  14. 2006/07/05
    You should have answered Y :) chkdsk would then have run at the next boot.
    You had covered most of the points noted on various hits on Google and the only real question mark pointed at the hard drive. Seems like the disk diagnostics agreed in part at least.
    Good luck - let us know how it goes.
  15. 2006/07/06
    bluepeter75
    The nightmare continues!!!
    I took out my current hard drive (maxtor 120Gb) and got a 4Gb Seagate from my dad's old system. I formatted that disk and tried to install XP. While doing the DOS part of the install, several files could not be copied (cyclad-z.inf, another cycl???.???, headsp~1.wmv, minipl~1.wmv, 4 x utopia~?.wav and 3 x sv-262e1.png). I assume the wmv are windows media video, I know the wav files are sounds, and a quick google search suggests .png are image files. Could the lack of .inf files be causing all these problems? If so do I have a defective XP disk?
    Anyway, the next stage of the install got so far, then bsod again, this time PAGE FAULT IN NON_PAGED AREA. So I now conclude that my hard drive was not at fault, as this other hd blue screens also.
    My next step and the stage I am at now is to remove everything from the motherboard excluding the (original) hard drive, memory and processor (with fan), to see if that makes any difference. I also have my USB broadband modem plugged in, and my keyboard and mouse (USB) and monitor. I tried running chkdsk /r on reboot, it got as far as 5% then froze.
    Incidentally, the processor is not overheating (55 C can handle 80 C).
    If anybody can help me with this I owe them LOTS of cyber pints!!
    Thanks for listening to my tales of woe.
    However, if this works I should be able to pinpoint the cause but I won't hold my breath.
  16. 2006/07/06
    Your problems could be down to any number of things, including a faulty motherboard, CPU, video card, etc. You say you replaced the memory so given that it is compatible with your board that should be OK.
    Your idea of a minimum build is a good one, but you will need the video card too.
    Your XP installation problem could be a damaged or dirty CD or a faulty CD drive, coupled with any of the above items.
    I wish you luck - I suspect you are going to need it :)
    I have moved your thread to the Hardware forum with title edit.
  17. 2006/07/06
    bluepeter75
    Thanks PeteC, I have no video card in my system at the moment, I took it out a while ago when I was blaming it for my problems, I'm just using on-board video. I have just run chkdsk /r, which stalled several times but eventually ran, and found no problems. I'm going to try some things which are usually guaranteed to crash the system now, to see if it is more robust with most hardware removed.
    Thanks for your patience, I'll let you know if I ever find the cause!
  18. 2006/07/07
    Rockster2U
    Rockster2U Geek Member
    From the characteristic behavior and problem description you have given, it would be adviseable to check your memory.
    more: You don't say much about your system or identify anything other than HDD's you tried but bad memory or incorrect memory timings wll cause everything you have described, including the difficulty in copying files during an attempted installation.
  19. 2006/07/07
    bluepeter75
    Thanks Rockster, I'm afraid I am on my 2nd lot of memory, I started with 1 stick 512Mb DDR333. I checked this with Memtest and it checked fine. Even so, I swapped it for 2 sticks total 512 Mb DDR266 and the problems are the same.
    If you want more details I have an ASRock K7S41GX Motherboard, an Athlon XP 3000+ processor and a Maxtor 120Gb Hard drive. I am still on a 'bare bones' system, with only these and my keyboard, mouse and monitor plugged in. and my AOL broadband modem.
    The PC had 2 bsod today, my wife was streaming radio and when the kids went on games websites and bebo, it went bsod after about 15 mins. (Oh yeah, the wife persuaded me to plug the speakers back in). I have since removed the speakers again in case they are the cause.
    I am starting to believe it may be the modem/AOL software, I think I might try plugging my dial up modem back in and removing broadband, see if that helps.
    Any suggestions?
  20. 2006/07/07
    Rockster2U
    I can't in good conscience advise you to go out and buy some decent memory because there is no way to diagnose this strictly as a memory related problem. Having said that, it should be noted that not all memory is created equal. Just because its PC 2700 or PC 2100 (DDR 333 or DDR 266) doesn't mean much - it could be good memory or it could be garbage. I've seen some very good memory that tests out fine yet is worthless re: stability on certain motherboards. Most memory available at retail is average at best. The other consideration here is that with a SIS chipset you will be better off matching your memory to your CPU and running in an auto configuration setting, so the question is - do you have a 266 Athlon or a 333? Some of the more generic CAS3 modules also run better at 2.5 on K7's.
    Again, I can not say with certainty that this is a memory related set of problems you are encountering - it just has all of the characteristics based upon your earlier posts and its an area worth taking a closer look at.
  21. 2006/07/07
    bluepeter75
    Thanks again, your knowledge goes way beyond mine. As a follow up, I have been running the PC for hours now with the 'bare bones' system, the only difference from when it bsod'd twice this afternoon is I have the speakers unplugged. I hate to tempt fate but I have tried the usual "guaranteed" ways to get it to bsod but it won't do it (YET!).
    How do I do the above? I have looked in device manager and cannot see where it will tell me if it is a 266 or 333 Athlon. I can use either set of memory so this sounds like a good idea if you think it'll help.
    Also "generic CAS3 modules?" :confused: "run better at 2.5?" :confused: 2.5 whats? Sorry for my ignorance, the rest made sense to me!
    I am grateful for your advice.
