xp home - start button->settings ?
Discussion in 'Windows XP' started by captjlddavis, 2005/02/13.
  1. 2005/02/13
    captjlddavis
    captjlddavis Well-Known Member Thread Starter
    Getting old, can't remember...
    Start button ->Settings:
    I show:
    Control panel->
    Printers and Fax->
    Taskbar and Start menu
    I don't recall how I edited these entries ( if I in fact did ?)
    Is it possible to get "Folder Options" in this menu ?
    ie
    Control Panel
    Folder Options ?
    Printer and Fax
    I have "Control Panel" set to expand and can get to folder options thru there.
    Thanks for any assistance.
    regards:captjlddavis
  2. 2005/02/13
    surferdude2
    surferdude2 Inactive
    Right click the Start button > Properties > Start Menu > Customize button > Advanced tab, and you'll find all the available setting that XP offers. Anything else will require 3rd party help. No "Folder Options" there.
    I understand how you feel, I often forget where this stuff is located.
    captjlddavis
    surferdude2,
    Thanks very much.
    Maybe I was thinking of 98SE or maybe I am just losing it.
    It hell getting old.
  5. 2005/02/13
    surferdude2
    Yes sir, I know a little about that subject too. I'm 68 and the yrs. are flying! Must be all the fun I'm having. ;)
    All the best.
  6. 2005/02/14
    JSS3rd Lifetime Subscription
    JSS3rd Geek Member
    Sure beats the alternative, though! :D
    As I've told people for years (adjusting annually, of course), I'm a 29 year old man, with a 49 year old body (I wish!), and a 69 year old birth certificate.
    I'm just about ready for Halloween, 2004, and somehow or other it's already Valentine's Day, 2005!
    I found this "Create Shortcut to Folder Options Window" page on The Elder Geek's site, but it doesn't work for me ... maybe because I use Classic mode? Perhaps you'll have better luck.
  7. 2005/02/14
    captjlddavis
    JSS3rd,
    No problem creating "ShortCut" to folder options on Desktop or Start Button
    I was trying to get "Folder Options" to display in Start->Settings as it does in Win98se...
  8. 2005/02/14
    You can add Folder Options to the Windows Explorer icon bar by View > Toolbars > Customize - in Classic view at least, if that is of any help to you.
