XP Home Hijacking/Virus - Major Problem
Discussion in 'Security and Privacy' started by jirobert, 2005/02/21.
  1. 2005/02/21
    jirobert
    jirobert Inactive Thread Starter
    I believe I have a virus/hijack that becomes a system service, during the installation of XP, with admin privileges. I disabled server service. It is now running and the service no longer shows in MMC or Admin Tools. I am also missing Workstation Service. When I use C:\net config server /hidden:no it returns "The service name is invalid ". The same returns for workstation service.
    I have the XP firewall running with all ports closed, no exceptions. Remote desktop service, smb over tcp service, netbios service and remote assistance service are all disabled. When I start the computer these services start and ports 137, 138, 139, 445 and 3389 are opened as exceptions to the firewall settings. All of this is done before the cable is connected to the internet.
    I have tried lowlevel formatting the drive before installation and the problem returns each time. I have the problem on two computers using different original XP CD's for installation. Help
  2. 2005/02/21
    Pro or home? I think Home from your title but want to make sure.
    What SP?
    Does this mean before you hook a cable to the network card (for a local network) or simply before you connect to the internet?
    lachelp
    lachelp Inactive
    You have to a bit more work to do...
    Uninstall Microsoft Networking, Windows File and Printer Sharing, disable NetBIOS and uncheck import LMHOST in the advanced settings of TPC/IP and also kill off TCP NetBIOS helper service.
    Cheers!
  5. 2005/02/22
    If you meant 'client for microsoft networks' then OK. But with XP, you cannot remove networking as you could with previous OS versions. All you can do is use a netsh string to reset it to the default values.
