XP Defrag error "the connection to the defragmenter engine has been lost"
Discussion in 'Windows XP' started by raingirlIT, 2006/07/23.
  1. 2006/07/23
    raingirlIT
    raingirlIT Inactive Thread Starter
    So...it had been more than a month or so since I did some computer clean up. I ran disk cleanup, and set my checkdisk to run at the next startup. It did that (took almost 2 hours because it found some bad sectors I think) and start up was fine.
    The next thing on my list was disk defrag. I am using the built in XP defrag program, but I get the error "the connection to the defragmenter engine has been lost. Restart degragmentation ". I get the same error whether I choose analyse or defrag. Restarting the program/computer didn't help.
    Since the last defrag I installed AVG free version and Zone Alarm free version. Could either of those caused this?
    I did some googling, but I there were a lot of sites that really had no fixes, just suggestions, but I wasn't sure what to try first. A few sites mentioned possible malaware causing it.
    I haven't tried running it in safemode, so I don't know if that would help.
  2. 2006/07/23
    raingirlIT
    system file checker seems to have fixed it. The first one said I didn't have that worm (thank goodness!).
    I've never used system file checker before. Thanks for the tip and the help!
