XP and Bluray stuff
Discussion in 'Windows XP' started by cold iron, 2012/05/09.
  1. 2012/05/09
    cold iron
    cold iron Well-Known Member Thread Starter
    Hi..I have a i7 machine with a partition that has win7 and xp pro. I have a Bluray burner that will burn bluray disks on the win7 side, but on the the XP side I can play a bluray disk using a bluray program, but using XP explorer it will not look in a bluray disk. Is there any patch that will help XP work with the big bluray disk?
  2. 2012/05/09
    cold iron
    Thanks Arie for your help.
  5. 2012/05/12
    cold iron
    Hi Arie, I down loaded the file and ran it, buy I got a message that the file could not run on my putter. So, still working on the issue.
  6. 2012/05/12
    There's a work-around for that:
    • Start Toshiba UDF 2.5 XP Driver setup
    • When the error message displays, DO NOT close the message box
    • In Windows Explorer, navigate to C:\Documents and Settings\{user name}\Local Settings\Temp\{1347D5A6-4FE0-476A-B85F-D0FC91F55EB0}
    • Right click thdudf.inf, select Install
    • Reboot your PC
  7. 2012/05/16
    cold iron
    Thanks I'll give it a try.
