XCOPY and User Problem.
Discussion in 'Windows XP' started by visee, 2007/08/17.
  1. 2007/08/17
    visee
    visee Inactive Thread Starter
    XCOPY problem.
    If in Windows->CMD
    type
    XCOPY /E /C /I /F /G /H /K /Y
    is (all empty-folder) (0 bytes file), (A/S/H/R )
    if as same as file name. no tell me to doit.
    Correct ?
    Yes, I was read XCOPY /? that document, but
    And in Safe-Mode (Windows xp sp1) that (USB Memory Stick (support-USB2.0) Drive)
    if my computer is support USB 2.0 , in safe mode = USB2.0 or down to USB1.1 to run ?
    Last, can you tell me.
    Login user = Administrator
    do this xcopy C:\Document and Setting\Administrator\My Desktop\MYLOVEPIC\*.*
    to C:\Document and Serring\GUEST\MYLOVEPIC\*.*
    if completed, and logout; login in "GUEST (limit user) "
    can access that "\GUEST\MYLOVEPIC\*.* files ?
    or need changed file setting to GUEST ?
    I do not understand ?
    And next question is "
    Please!
  2. 2007/08/17
    surferdude2
    surferdude2 Inactive
    I'm having a problem understanding you but perhaps I can help by giving you the path to the Windows Command Line Help.
    For specific information on the XCOPY command type or copy/paste the following line in your Start > Run window and press Enter:
    %windir%\hh.exe ms-its:ntcmds.chm::/xcopy.htm
    For help with ALL XP command line commands, type or copy/paste the following line in your Start > Run window and press Enter:
    %windir%\hh.exe ms-its:C:\WINDOWS\Help\ntcmds.chm::/ntcmds.htm
    visee
    which copy() is faster ?
    Thanks, but
    Folder1 = total 150,000 files and 4000 folder(s) and 1.5GB used
    I check some file is 0 byes and some folder is no file(s). and some file is hidden.
    but I need that 0 byes and no file(s) folder .
    In windows "MyComputer/Path1" mouse right click "copy" and
    "MyComputer/Path2" mouse right clicl "parse"
    that status bar/Est time() is need use some "GDI" , so maybe slow?
    and need enable that show all hidden file first?
    AND/OR
    If use CMD /Xcopy() to copy, becuase only CMD mode, will fast?
    Correct? Please suggest! thanks.
